Wacker Neuson Dumper 1001 Service Manual and Diagram 1000144662
Brand: Wacker Neuson
Type of Machine: Dumper
Type of Manual: Service Manual, Electrical and Hydraulic Diagram
Model: Wacker Neuson 1001 Dumper
Part Number: 1000144662
Publication Date: 2007
Number of Pages: 162 Pages
1 Operation
1.1 Important information on this service manual
1.2 Identification of warnings and dangers
1.3 Designated use and exemption from liability
1.4 Type labels and component numbers
1.5 Machine: overview
1.6 Operating equipment: overview
1.7 Operating equipment: legend
1.8 Maintenance prop
1.9 Centre pivot prop
2 Specifications
2.1 Chassis
2.2 Engine
2.3 Travelling drive
2.4 Brakes
2.5 Steering system
2.6 Work hydraulics
2.7 Loader unit
2.8 Drive specifications
2.9 Vibration
2.10 Electric system (up to BB001360)
2.11 Electric system (from AB100001H)
2.12 Tyres
2.13 Noise levels
2.14 Coolant compound table
2.15 General tightening torques
2.16 Dimensions model 1001
3 Maintenance
3.1 Fluids and lubricants
3.2 Maintenance plan (overview)
3.3 Service package
3.4 Introduction
3.5 Fuel system
3.6 Engine lubrication system
3.7 Cooling system
3.8 Air filter
3.9 V-belt
3.10 Hydraulic system
3.11 Lubrication points
3.12 Tyre maintenance
3.13 Changing wheels
3.14 Electric system
3.15 Battery master switch
3.16 General maintenance work
4 Engine
4.1 Engine overview 3TNE74 (up to BB001360)
4.2 Fuel system (up to BB001360)
4.3 Engine overview 3TNV76-XNSV (from AB100001H)
4.4 Fuel system (from AB100001H)
4.5 Checking and adjusting valve tip clearance
4.6 Tightening order for cylinder head bolts
4.7 Checking the injection nozzles
4.8 Checking the nozzle jet
4.9 Fuel injection time (up to BB001360)
4.10 Fuel injection time (from AB100001H)
4.11 Adjusting engine revs
4.12 Compression
4.13 Checking the coolant thermostat
4.14 Checking the thermal switch
4.15 Oil pressure switch
4.16 Checking the coolant circuit
4.17 Engine trouble
5 Travelling drive
5.1 Variable displacement pump A10VG45DA (up to BB001360)
5.2 Variable displacement pump A10VG28DA (from AB100001H)
5.3 Rear hydraulic motor
5.4 Front hydraulic motor
5.5 Travelling drive: overview
5.6 Towing and transporting the machine
5.7 Test instruction
6 Brakes
6.1 Brake circuit up to serial no. BB001360
6.2 Brake circuit from serial no. BB001361
7 Steering system
7.1 Steering circuit
7.2 Steering unit: diagram
7.3 Steering unit connections
7.4 Steering unit: overview
8 Hydraulic system
8.1 Control valve connections: overview
8.2 Test instructions
8.3 Diagram up to serial no. BB001360
8.4 Diagram up to serial no. BB001360: legend
8.5 Diagram from serial no. AB100001H
8.6 Diagram from serial no. AB100001H: legend
8.7 Hydraulics diagram A3 up to serial no. BB001360
8.8 Hydraulics diagram A3 from serial no. AB10001H
9 Electric system
9.1 Ohm's Law (current, voltage, resistance); power
9.2 Measuring equipment, measuring methods
9.3 Relays
9.4 Electric components
9.5 Fuse box in instrument panel (up to BB001360)
9.6 Instrument panel up to BB001360: overview
9.7 Fuse box in instrument panel (from AB100001H)
9.8 Instrument panel (from AB100001H): overview
9.9 Wiring diagram up to serial no. BB001360: legend
9.10 Wiring diagram version 1 A4 up to serial no. BB001360
9.11 Wiring diagram from serial no. AB100001H: legend
9.12 Wiring diagram version 1 A4 from serial no. AB100001H
9.13 Main wiring harness from AB100001H: legend
9.14 Main wiring harness from AB100001H
9.15 Engine wiring harness from AB100001H: legend
9.16 Engine wiring harness from AB100001H
9.17 Wiring diagram A3 up to serial no. BB001360: legend
9.18 Wiring diagram A3 up to serial no. BB001360
9.19 Wiring diagram A3 from serial no. AB100001H: legend
9.20 Wiring diagram A3 from serial no. AB100001H
9.21 Main wiring harness from AB100001H: legend
9.22 Main wiring harness from AB100001H
9.23 Engine wiring harness from AB100001H: legend
9.24 Engine wiring harness from AB100001H
1 Operation
2 Specifications
2.1 Chassis
2.2 Engine
2.4 Brakes
2.5 Steering system
2.6 Work hydraulics
2.7 Loader unit
2.9 Vibration
2.12 Tyres
2.13 Noise levels
3 Maintenance
3.3 Service package
3.4 Introduction
3.5 Fuel system
3.7 Cooling system
3.8 Air filter
3.9 V-belt
4 Engine
4.12 Compression
4.17 Engine trouble
5 Travelling drive
6 Brakes
7 Steering system
8 Hydraulic system
9 Electric system
9.3 Relays
- Wacker Neuson 803 Spare Parts List
- Wacker Neuson Skid Steer Loader Track ST31 Error Codes, Service, Operator's & Parts Manual EN ES FR
- Wacker Neuson Crawler Excavator 3503 Spare Parts List_1000189534
- Wacker Neuson Compact Excavator 2503 3503 3003 3703 Service Manual_1000081433
- Wacker Neuson Reversible Vibratory Plates DPU 6555 H Operator, Repair Manual & Spare Parts Catalog
- Wacker Neuson Crawler Excavator EZ17 Spare Parts List_1000298089
- Wacker Neuson Skid Steer Loader Track ST35 Error Codes, Service, Operator's & Parts Manual EN DE FR
- Wacker Neuson Wheel Loaders 550 5055 5055L Spare Parts List_1000274206
- Wacker Neuson Track Excavator 6003 Service Manual_1000129840
- Wacker Neuson Track Excavators 75Z3, 8003 Operators Manual_1000132136
- Wacker Neuson Track Excavators 50Z3 Service Manual 1000129833
- Wacker Neuson Wheel Loaders 750, 850 Service Manual_1000183988
- Wacker Neuson Track Excavators 1404 Service Manual_1000166693
- Wacker Neuson Walk-Behind Trowels CT 36-5A Parts Manual_0009438
- Wacker Neuson Kramer Wheel Loader 1150 Spare Parts Manual_100018445
