Volvo Wheel Loader L40B Service and Repair Manual
Brand: Volvo
Type of Machine: Wheel Loader
Type of Manual: Service and Repair Manual, Hydraulic Diagram, Electrical Diagram
Model: Volvo L40B Wheel Loader
Number of Pages: 4394 Pages
1 Volvo L40B
Description
Accumulators, checking in machine
Air cleaner, description
Axles, changing oil
Battery, charging
Battery, description
Boom Suspension System, general description
Brake system, component
Brake, description
Cab description
Cab mounts, tightening torques
Cab mounts, tightening torques1
Cab mounts, tightening torques2
Cable markings Figure 1
Cable markings Figure 2
Cable markings
Camshaft, description
Central ground connections1
Central ground connections2
Cleanliness when working on hydraulic components
Cleanliness, braking and hydraulic system
Combination control (by steering wheel), changing
Component list, Relays
Connecting rod, description
Connectors, overview1
Connectors, overview2
Control valve
Conversion tables
Coolant, changing
Cooling system, description
Crankshaft, description
Cylinder head, description
Description
Display of bar graph
Display unit and keyboard
ECU 2, error codes and diagnostic functions
ECU 2, functions
Electric welding
Electric welding1
Electrical components, engine side
Electrical system, description
Electrical system, instructions
Electronic unit (ECU), fuse position1
Electronic unit (ECU), fuse position2
Electronic unit (ECU)1
Electronic unit (ECU)2
Engine timing gear, description
Engine, changing oil and filter
Engine, description
Environmental concern
Frame and steering joint, general
Frame and track unit, description
Fuel feed pump, description
Fuel filters, replacing
Fuel system, description
General information to note when working on the hydraulic system
Hydraulic attachment bracket (quickfit), description
Hydraulic components, storage and transport
Hydraulic diagram, brake system, dry brakes
Hydraulic diagram, brake system, wet brakes
Hydraulic oil tank, changing oil and filter
Hydraulic oil tank, description
Hydraulic oil, storage and handling
Hydraulic pump, description Figure 1
Hydraulic pump, description Figure 2
Hydraulic pump, description Figure 3
Hydraulic system, description
Hydraulic system, position of main components
Hydraulic system, repair of hydraulic components in workshop
Hydraulic system, volume
IB - fuse F02
Instrument panel (display unit), replacing
Instrument panel, description1
Instrument panel, description2
Key pad, replacing
Keypad, description
Lifting frame, description
Lighting, specifications
Lock cylinder
Lock cylinder1
Lubricant recommendation
Lubrication system, description
Machine, transporting
Marking connector pin description
Maximum fan speed, checking
Oil pump, description
Power transmission, description
Pro FET-components in electronic unit (ECU)
Relays and fuses in engine compartment
Repairs of minor damage on internal and external plastic parts (scratches, dents, breaks)
Service intervals
Service Programme
Servo valve, description
Starter lock, replacing
Steering system, description
Steering system, troubleshooting and elimination
Tightening torques wheel nuts
Tilting and lifting cylinders
Towing
Transmission, component position
Troubleshooting chart
Turbocharger, description
Valves, adjusting1
Valves, adjusting2
Valves, description
Windows, general
Wiring diagram, figure text
Work on the machine's electrical system
Diagrams
Electric cables with component marking
Hydraulic diagram transmission Figure 1
Hydraulic diagram transmission Figure 2
Hydraulic diagram, Boom Suspension System Figure 1
Hydraulic diagram, Boom Suspension System Figure 2
Hydraulic diagram, control valve
Hydraulic diagram, steering system Figure 1
Hydraulic diagram, working hydraulic system
Wiring diagram 1
Wiring diagram 2
Wiring diagram 3
Wiring diagram 4
Wiring diagram 5
Wiring diagram 6
Wiring diagram 7
Wiring diagram 8
Wiring diagram 9
Wiring diagram 10
Wiring diagram 11
Wiring diagram 12
Wiring diagram 13
Wiring diagram 14
Wiring diagram 15
Wiring diagram 16
Wiring diagram 17
Wiring diagram 18
Wiring diagram 19
Installation Instruction
Air-conditioning system
BSS
CareTrack1
CareTrack2
Oil bath air filter
Precleaner Turbo 2
Repair
Accumulator, checking (removed) Figure 1
Assembling the hydraulic motor Figure 1
Brake calliper removed, reconditioning
Brake calliper removed, reconditioning1
Brake disc, replacing one
Brake disc, replacing one1
Brake linings, checking wear
Brake system, checking function, hydraulic
Check and adjust hydrostatic drive
Compression test
Coolant pump, replacing
Discarded accumulators Figure 1
Door window, replacing
E-tool Cab support
Feed pump, replacing
Frame joint, changing bearings
Hydrostatic motor, installation1
Hydrostatic motor, installation2
Hydrostatic motor, removal1
Hydrostatic motor, removal2
Hydrostatic pump, removing and installing
Implement attachment, repacking removed hydraulic cylinder
Injectors all, testing and adjusting incl removing and fitting
Oil cooler, replacing
Rear window, replacing
Secondary limiting valve, test and adjust
Service positions Figure 1
Service positions
Stand-by pressure and working pressure, checking and adjusting
Steering system, checking and adjusting working pressure
Steering valve, reconditioning (removed)
Thermostat, replacing
Windscreen, replacing
Safety
CE-marking, EMC-directive
Decontamination
Environmentally hazardous fluids
Environmentally safe handling
Fire prevention measures
Loader boom, safety strut
Safety concerns everybody!
Safety during work on machines
Safety rules when servicing
Safety when handling oils and fuel
Safety when raising and jacking up the machine
Safety when working with air conditioning refrigerant
Some simple rules regarding tyre handling
Waste handling
Working in environmentally contaminated areas
Service Bulletins
Action to be taken in case of abnormal lubricating oil consumption
Adapter Cable for ECU 2
Additional fuel tank support bracket
CareTrack Telematics system
Check of coolant level sensor assembly
Drive pump solenoids with sealed connectors
ECU 2, functions
ECU 2, introduction and installation instruction
ECU 2, programming instructions
ECU retainer, additional support plate
ECU, functional check
Engine oil in the cooling system or coolant in the oil system and external oil or radiator leakage
External leakage at quick attachment bracket
Fuel sampling, method
Gap between attachment and attachment bracket causing leakages
Hydraulic oil tank
Improvement of inner seals at fuel level sensor
Introduction of new engines with Tier 3 exhaust emission level
Leakage by the cover of the hydraulic suction filter
Method for mounting the screw on the pin for bucket positioner rod
New assembly method for quick coupler pins
New cab heater blower fan switch
New coolant
New electrical AC thermostat
New fuel level sensor
New retainer, salt fertilizer box (Option)
Programming instructions for electronic control unit (ECU)
Reports
Servicing the PTO drive for the second hydraulic drive motor
Solenoid valve
Special Tools, Misc
GRD G700B LabourTimeGuide
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
Special tool catalog
Special Tools Recommendations
Time Guide Currrent generation
Time Guide Old generation
Specifications
Air conditioning (option), capacity
Axles, tightening torques
Battery, specifications
Brakes, specifications
Cooling system, capacity
Cooling system, capacity1
Counterweight, tightening torques
Counterweight, tightening torques1
Damper weight, weight
Engine, capacity
Engine, specifications
Engine, tightening torque
Engine, weights
Frame, weight
Front axle, capacity
Front axle, specification
Front axle, specification1
Front axle, weight
Hydraulic system, specification
Power transmission, specifications
Rear axle, capacity
Rear axle, specification
Rear axle, weight
Service brake, specifications
Steering joint, tightening torques
Steering system, specifications
Steering system, specifications1
Steering, hydraulic equipment, tightening torques
Tire size
VOLVO standard tightening torques
Wheel, tightening torque
Working hydraulics, tightening torques
Brand: Volvo
1 Volvo L40B
Description
Axles, changing oil
Battery, charging
Brake, description
Cab description
Cable markings
Control valve
Conversion tables
Coolant, changing
Description
ECU 2, functions
Electric welding
Electric welding1
Engine, description
IB - fuse F02
Key pad, replacing
Keypad, description
Lock cylinder
Lock cylinder1
Service intervals
Service Programme
Towing
Valves, adjusting1
Valves, adjusting2
Valves, description
Windows, general
Diagrams
Wiring diagram 1
Wiring diagram 2
Wiring diagram 3
Wiring diagram 4
Wiring diagram 5
Wiring diagram 6
Wiring diagram 7
Wiring diagram 8
Wiring diagram 9
Wiring diagram 10
Wiring diagram 11
Wiring diagram 12
Wiring diagram 13
Wiring diagram 14
Wiring diagram 15
Wiring diagram 16
Wiring diagram 17
Wiring diagram 18
Wiring diagram 19
BSS
CareTrack1
CareTrack2
Oil bath air filter
Precleaner Turbo 2
Repair
Compression test
E-tool Cab support
Service positions
Safety
Decontamination
Waste handling
Service Bulletins
ECU 2, functions
Hydraulic oil tank
New coolant
Reports
Solenoid valve
Special Tools, Misc
Specifications
Engine, capacity
Engine, weights
Frame, weight
Front axle, weight
Rear axle, capacity
Rear axle, weight
Tire size
- Volvo Construction Equipment All Training Set (8.5Gb)
- Volvo Wheel Loader L60F L70F L90F Service Manual
- Volvo PTT 2.01 KG
- Volvo FM10 D10B-360 Engine-MID-128
- Volvo Wheel Loader L110E/L120E shop manual
- VOLVO EXCAVATOR EC210B Training
- Volvo Excavator EC340D,EC380D,EC480D Service Training
- Volvo EW160B Error
- Volvo FM D13A 480 Engine parts, transferring
- Volvo Training EC55B-08 Hydraulic Circuit
- VOLVO Premium Tech Tool 2.03.40 (MEGA LINK)
- VOLVO L120F Service manual Persian
- Volvo Impact 2016 - Torrent
- Volvo EC210 LC Diagram
- Volvo PROSIS manuals
