Martin Welker
104
230,310
Volvo Wheel Loader L25B Parts Catalog
Brand: Volvo
Type of Machine: Wheel Loader
Model: Volvo L25B Wheel Loader
Number of Pages: 227 Pages
0 General
2 Engine with Mounting and Equipment
Camshaft
Cylinder head
Engine assy
Engine housing
Engine oil preheating
Engine stop device
Exhaust system
Fan, Blower casing
Filter - Water separator
Fuel filter - Feed pump
Fuel pipes
Fuel tank
Hand throttle
Injection pipes, Injection valve
Oil cooler
Oil filter
Oil pump
Oil sump
Piston
Prefilter - Oil bath air filter
Pre-filter - Turbo II
Speed adjustment - Fuel injection pump
Speed control
Suction system, filter
Timing gear housing (front cover)
Valve mechanism
3 Elec, Warning, Information, Instruments
Additional lighting - Swiss
All-round side lamp
Antitheft system
Battery
Central computer
Electric installation
Electrical system for control pressure valve 11390713
Instruments panel
Lighting, front
Lighting, rear
Number plate illumination
Radio
Signal horn
Starter
Travel alarm, acoustic
Windscreen washer system
Wiper installation
4 Power Transmission
Assembly - front axle
Assembly - rear axle
Cardan shaft
Differential - front axle
Differential carrier - assy rear axle
Differential lock
Final drive-front axle
Final drivel-rear axle
Gearbox assy
Hand inching control
Housing - front axle
Housing - rear axle
Inch control
Lines - hydrostatic drive
Temperature-regulator
Valves - Variable displacement pump
Variable displacement motor
5 Brakes
Brake cylinder
Brake lines
Central brake
Hand brake
6 Steering
Steering assembly
Steering cylinder
Steering pump
Steering valve
Steering-hydraulic equipment - front vehicle
Steering-hydraulic equipment - rear vehicle
7 Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit
Articulation point
Frame
8 Machinery House, Cab, Exterior Trim Parts
Cab frame
Door
Driver's seat1
Driver's seat2
Engine hood
Front mudguard
Handrail
Heater
Interior equipment - Canopy
Interior equipment
Isolation - Cabine
Mudflap rear
Noise screening
Operator's seat, air suspensioned with fitting parts
Plates
Rear view mirror
Steps and ladder
Stop block for wheel
Tools
Window pane
9 Hydraulic, Digging, Handling, Grading and Misc Equip
Attachment mounting plate - Quick change, hydraulic
Auxil. pomp with lines (Skid Steer attachment)
Auxil. pump with lines
Blocking valve 11390713
Bolt-on cutting edge
Bucket with teeth
Bucket without teeth
Control valve1
Control valve2
Fork lift attachment support
Fork lift with grab
Fork tines
Hay fork - Dirty fork
Hydraulic function - Nr. 3
Hydraulic function - Nr. 4
Hydraulic lines - lift hydraulic
Hydraulic lines - tilt hydraulic
Hydraulic oil tank
Leakage line - Option
Lift cylinder
Lift frame
Line fracture safety - Lift
Line fracture safety - Tilt
Lines - rear vehicle
Lines to attachment mounting plate
Load hook, telescopically
Pump - working hydraulic
Radiateur - Installation
Servo control valve
Shutter bucket with teeth
Shutter bucket without teeth
Side tip bucket
Suction recoil filter
Tilt cylinder
Tipping bucket
