Martin Welker
104
230,310
Volvo Wheel Loader L220H Service and Repair Manual
Brand: Volvo
Type of Machine: Wheel Loader
Type of Manual: Hydraulic and Electrical Diagram, Service and Repair Manual
Model: Volvo L220H Wheel Loader
Number of Pages: 7215 Pages
Volvo L220H
Description
3rd, or 3rd 4th hydraulic function, description1
3rd, or 3rd 4th hydraulic function, description2
ACM, I O list
AdBlue® DEF pump unit diagnostics, description
Air conditioning, component location
Air conditioning, function description
Air conditioning, tightening torques
Air conditioning, tightening torques1
Alternator 80 A, description
Alternator, description
Automatic brake valve, description
Automatic differential brake, Limited Slip, description
Auxiliary brake (engine braking), description
Axle oil cooler, component location
Axle oil cooler, description
Battery disconnector switch, description
Battery, charging
Battery, description
Boom Suspension System, component description
Boom suspension system, component location
Boom Suspension System, description
Booting sequence
Brake accumulator, description
Brake system, component location
Braking system, description
Cab and air conditioning
Cab, description
Cable and component designations
Cable and component marking explanations
Calibration of 3rd 4th hydraulic function, description
Calibration of Comfort Drive Control (CDC), function description
Calibration of lift lower function, description
Calibration of tilt in out function, description
CareTrack W-ECU, description
CCM, I O list
CDC valve, lever steering, description
Central lubrication system, description
Central valve, description
Change of lubrication interval
Chassis connection
Climate control system, description
Comfort Drive Control (CDC), component location
Comfort Drive Control (CDC), description
Components list1
Components list2
Components list3
Connectors, overview
Connectors, position
Control valve, description
Coolant with anti-freeze and corrosion protection, recommendation
Cooling fan motor, description
Cooling fan, component location
Cooling fan, description
Cooling system, description1
Cooling system, description2
Crankcase ventilation, description1
Crankcase ventilation, description2
Diagnostic tools, description
Differential lock, description
Dosage valves, description
Drive axles, description
Driver seat, component description1
Driver seat, component description2
Driver seat, component description3
Drivetrain, component location
E-2016
ECM (Engine Control Module), I O list1
ECM (Engine Control Module), I O list2
ECM (Engine Control Module), I O list3
ECO - accelerator pedal
Electric door opener, description
Electrical system, description
Electrical system, work instructions
Electronic control system, description1
Electronic control system, description2
Engine, description1
Engine, description2
Engine, description3
Engine, reference values
Exhaust aftertreatment fuel system diagnostics, description
Exhaust Aftertreatment System, description
Exhaust Gas Recirculation (EGR), description
Faulttracing
Filling lubricant
Fire suppression system, component description
Fire suppression system, functional description
Foot brake valve, description
Frame joint, description
Frame, description
Front axle, component description
Fuel system, description1
Fuel system, description2
GPMECU1, I O list
GPMECU2, I O list
GPMECU3, I O list
HMICU, I O list1
HMICU, I O list2
Hood opening
Hydraulic attachment locking, description
Hydraulic components, cleanliness when handling
Hydraulic oil tank, description
Hydraulic pump flow regulation, description
Hydraulic pumps, description
Hydraulic transmission calibration, description
Hydraulic transmission, description1
Hydraulic transmission, description2
Information display, general
Information display, service mode
Infrared Thermometer
Inlet and exhaust system, description1
Inlet and exhaust system, description2
Inlet and exhaust system, description3
Intermittent wiper and washer
Internal Exhaust Gas Recirculation (IEGR), description
Key feed
Leak detector 951 1207, description
Lever control, electric servo, description
Lifting cylinder, description
Load Assist, description
Lubrication points, central lubrication
Lubrication system, component locations1
Lubrication system, component locations2
Lubrication system, description1
Lubrication system, description2
Lubrication system, description3
Oil cooler, component location
Parameter settings
Parking brake, component description
Parking brake, component location
Parking brake, function description1
Parking brake, function description2
Pause heater, description
Preheating, description
Pressure monitor, description
Pressure monitor, description1
Propeller shaft, component description
Pump unit, description
Rear axle mounting, component description
Rear axle, component description
Rear vision system
Regeneration process, description
Reverse warning system, description
Reversible cooling fan, description1
Reversible cooling fan, description2
Secondary steering, component location
Secondary steering, description
Service
Servo system, description
Shift valve, description
Shift valve, description1
Software parameters, description
Software, parameter settings and read-outs
Starter motor, description
Steering cylinder, description
Steering system, component location
Steering system, description
Steering valve, description
System voltage
Tech Tool, operations
Tech Tool, operations1
Tech Tool, operations2
Tech Tool, operations3
Tech Tool, operations4
Tech Tool, operations5
Tech Tool, operations6
Tilt cylinder, description
TP-Linkage's bearing points
Transmission, component location
Unit injectors, checking
Viscous cab suspension, description
Volvo Co-Pilot, description
W-ECU, I O list
Windows, general, gluing
Windows, general
Working hydraulic system, component location
Working hydraulic system, description
Diagrams
Explanations to hydraulic diagram
Hydraulic diagram transmission
Hydraulic diagram, basic machine Figure 1
Hydraulic diagram, complete1 Figure 1
Hydraulic diagram, complete1 Figure 2
Hydraulic diagram, complete2 Figure 1
Hydraulic diagram, complete2 Figure 2
Table of contents, wiring diagrams1
Table of contents, wiring diagrams2
Wiring diagram - Aftertreatment1
Wiring diagram - Aftertreatment2
Wiring diagram - Brake
Wiring diagram - BSS
Wiring diagram - CDC
Wiring diagram - Electrically controlled battery disconnector - Key operated, with emergency stop
Wiring diagram - Electrically controlled battery disconnector - Manual, with emergency stop
Wiring diagram - Electrically controlled battery disconnector - Manual, without emergency stop
Wiring diagram - Gear
Wiring diagram - Start
Wiring diagram WD201
Wiring diagram WD202
Wiring diagram WD208
Wiring diagram WD210
Wiring diagram WD211
Wiring diagram WD212
Wiring diagram WD214-1
Wiring diagram WD214-2
Wiring diagram WD220
Wiring diagram WD221-1
Wiring diagram WD221-2
Wiring diagram WD223
Wiring diagram WD224
Wiring diagram WD275
Wiring diagram WD301-1
Wiring diagram WD301-2
Wiring diagram WD301-3
Wiring diagram WD302
Wiring diagram WD303
Wiring diagram WD304
Wiring diagram WD305
Wiring diagram WD306-1
Wiring diagram WD306-2
Wiring diagram WD320-1
Wiring diagram WD320-2
Wiring diagram WD321-1
Wiring diagram WD321-2
Wiring diagram WD322-1
Wiring diagram WD322-2
Wiring diagram WD322-3
Wiring diagram WD324-1
Wiring diagram WD324-2
Wiring diagram WD325
Wiring diagram WD326
Wiring diagram WD330
Wiring diagram WD331
Wiring diagram WD333
Wiring diagram WD334
Wiring diagram WD335
Wiring diagram WD337
Wiring diagram WD350
Wiring diagram WD351
Wiring diagram WD352
Wiring diagram WD360-1
Wiring diagram WD360-2
Wiring diagram WD361
Wiring diagram WD362
Wiring diagram WD363
Wiring diagram WD371-1
Wiring diagram WD371-2
Wiring diagram WD372
Wiring diagram WD373
Wiring diagram WD374
Wiring diagram WD375
Wiring diagram WD376
Wiring diagram WD401
Wiring diagram WD402
Wiring diagram WD403
Wiring diagram WD404
Wiring diagram WD405
Wiring diagram WD406
Wiring diagram WD501
Wiring diagram WD601
Wiring diagram WD602
Wiring diagram WD604
Wiring diagram WD801
Wiring diagram WD802-1
Wiring diagram WD802-2
Wiring diagram WD804
Wiring diagram WD805
Wiring diagram WD806
Wiring diagram WD807-1
Wiring diagram WD807-2
Wiring diagram WD808
Wiring diagram WD831
Wiring diagram WD903
Wiring diagram WD904
Wiring diagram WD909
Wiring diagram WD910
Wiring diagram WD911
Wiring diagram WD912
Wiring diagram WD913-1
Wiring diagram WD913-2
Wiring diagram WD915
Installation Instruction
3rd 4th hydraulic function, installing new
3rd hydraulic function, installing new
After market engine, transfer of components
Alternator 120 Amp, installing new
Attachment locking, installing new
Attachment worklight, installing new
Axle oil cooler, installing new
Back up alarm, installing new
Boom suspension system, installing new
Cab front work light LED, installing new
Cab illuminated entrance LED, installing new
Cab rear work light LED, installing new
Cab side work light LED, installing new
Cab, air pre cleaner, installing new
CareTrack, installing new
CareTrack
Decal set, installing new
Emergency stop, installing new
Engine heater, installing new1
Engine heater, installing new2
Forward view camera, installing new
Front work light LED, installing new
Fuel filter extra, installing new
Grill work light LED, installing new
Hand throttle, installing new
High Sulphur Fuel Conversion kit, installing new
Lever steering (CDC), electric, installing new
Pre-cleaner cyclone type, installing new
Pre-cleaner cyclone type, installing new1
Pre-cleaner oil bath type, installing new
Pre-cleaner oil bath type, installing new1
Pre-cleaner turbo type, installing new
Pre-cleaner turbo type, installing new1
Radiator grille guard, installing new
Radio, installing new
Rapid oil exchange (ROX), installing new
Rear view camera, installing new
Rear view mirror, installing new
Reflecting stickers, installing new
Reverse warning system, installing new
Reversible fan, installing new
Rotating beacon, installing new
Single lever control, 2nd hydraulic function, installing new
Single lever control, 3rd hydraulic function, installing new
Single lever control, 4th hydraulic function, installing new
Warning beacon flashing strobe light, installing new
Wind shield guard, installing new
Repair
0 General
1 Standard Parts, Service
2 Engine with Mounting & Equipment
3 Elect. Warning, Information, Instruments
4 Power Transmission
5 Brake
6 Steering
7 Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit
8 Machinery House, Cab, Exterior Trim Parts
9 Hydraulic, Digging, Handling, Grading Equipment, Misc
Safety
CE-marking, EMC-directive
Checking function
Decontamination
Environmentally hazardous fluids
Environmentally safe handling
Fire prevention measures
Safety concerns everybody!
Safety rules when servicing
Safety when handling oils and fuel
Safety when lifting and supporting complete machine
Safety when working on hydraulic systems
Safety when working with air conditioning refrigerant
Service position 1
Service position 2
Some simple rules regarding tyre handling
Starting with booster batteries
Towing
Waste handling
Working in environmentally contaminated areas
Working under raised boom
Service Bulletins
0 General
5 Brake
6 Steering
Special Tools, Misc
Special tool Manual
Special Tools Recommendations
Time Guide Currrent generation
Time Guide Old generation
Specifications
3rd 4th hydraulic function, specifications
3rd 4th hydraulic function, tightening torques
AdBlue® DEF information
AdBlue® DEF
Air conditioning, refrigerant, weight
Air conditioning, specifications
Alternative fuels
Alternator 80 A, specification
Automatic lubrication system, specifications
Axle suspension, tightening torque
Battery, specifications
Battery, weight
Boom Suspension System, specifications
Boom Suspension System, tightening torques
Brake accumulator, specifications
Brake system, specifications
Cabin, tightening torques
Calibration of Comfort Drive Control (CDC), specification
Calibration of working hydraulics, specifications
Control valve, lever steering (CDC), specifications
Control valve, specifications
Control valve, tightening torques
Conversion tables
Coolant
Cooling fan rpm, specifications
Cooling fan, tightening torques
Cooling system, specifications
Cooling system, tightening torques
Counterweight, tightening torques
Counterweight, weight
EGR system, tightening torques
Engine, capacities1
Engine, capacities2
Engine, specifications
Engine, tightening torques
Fire suppression system, specification
Frame joint, tightening torques
Front and rear axles, specifications
Front and rear axles, tightening torque
Front and rear axles, volume
Front and rear axles, volume1
Front wheel brake, tightening torque
Fuel system, specifications
Fuel system, tightening torques
Function times, specifications
Hydraulic connections, tightening torques
Hydraulic pump (P1), specifications
Hydraulic pump (P2), specifications
Hydraulic pump (P3), specifications
Hydraulic pumps, tightening torques
Hydraulic system, volume
Hydraulic transmission, capacity
Inlet and exhaust system, specification1
Inlet and exhaust system, specification2
Inlet and exhaust system, tightening torques1
Inlet and exhaust system, tightening torques2
Lever steering (CDC), specifications
Lever steering CDC, tightening torques
Lift cylinder, tightening torques
Lighting, specifications
Lubrication system, specifications
Lubrication system, tightening torques
Parking brake, specifications1
Parking brake, specifications2
Preheating, specifications
Propeller shaft, tightening torque
Rear axle mounting, volume
Recommended lubricants1
Recommended lubricants2
Recommended lubricants3
Reversible cooling fan, tightening torques
Secondary steering pump, specifications
Servo system, specifications
Starter motor, specifications
Starter motor, tightening torques
Steering cylinder, tightening torque
Steering, specifications
Temperature limits for cooling fan speed, specifications1
Temperature limits for cooling fan speed, specifications2
Tilt cylinder, tightening torques
Transmission, specifications
Transmission, specifications1
Transmission, tightening torques
Volvo Co-Pilot, specifications
Volvo Co-Pilot, tightening torques
Volvo standard tightening torques
Wheel brake, specification
Wheels, tightening torques
