Martin Welker
104
230,792
Volvo Wheel Loader L220H Parts Catalog
Brand: Volvo
Type of Machine: Wheel Loader
Model: Volvo L220H Wheel Loader
Number of Pages: 913 Pages
Brakes
Accumulators 85495
Accumulators 85742
Accumulators SN 2048-
Brake line, front and rear axle, arctic 86128
Brake line, others 86127
Brake line, others 86128
Brake lines, front axle and rear axle 86127
Brake pipes, front axle and rear axle
Disc brake, front. 56001
Dual brake pedals
Hose protection
Multi-disc brake, rear 23967
Multi-disc brake, rear 23968
Oil cooler, forword, motor circuit. 85949
Oil cooler, forword, motor circuit. 85969
Oil cooler, forword, pump circuit. 85949
Oil cooler, forword, pump circuit. 85969
Oil cooler, rear, motor circuit. 85949
Oil cooler, rear, motor circuit. 85969
Oil cooler, rear, pump circuit. 85949
Oil cooler, rear, pump circuit. 85969
Parking brake 22597
Valve SN -2047
Valve SN -2047-1
Valve SN 2048-
Valve SN 2048-1
Valve
Elec, Warning, Information, Instruments
Alternator, Charge Regulator
Battery box with fitting parts
Cable, Fuse, Relay
Instrument, Sensor, Warning and Information
Lighting
Miscellaneous
Other Electrical Equipment
Starting System
Engine with Mounting and Equipment
Cooling Systen
Fuel System
Hand throttle control 86000
Ignition and Control System
Inlet, Exhaust System
Lubricating System
Miscellaneous
Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit
Belly guard, front. 85331
Belly guard, rear. 85329
Belly guard, rear. 85903
Counterweight 84883
Counterweight 85512
Counterweight. 85328
Frame 85733
Frame joint, vertical bearing
Frame
Protecting plates 85342
Protecting plates 85353
Protecting plates 85497
Protecting plates 85709
Protecting plates 85727
Protecting plates 85767
Protecting plates 85776
Protecting plates 85788
Protecting plates
Protection, brake pipes 85801
Radiator, kylare. 85037
Rear hitch and counterweight
Wheel 85506
Wheel 86266, 86270, 85504
Hydraulic, Digging, Handling, Grading and Misc Equip
Angle sensor, tilt 86113, 86118
Angle sensor, tilt
Angle sensor
Attachment bracket 85348
Automatic lubrication 86188
Boom suspension system 85963
Central lubrication for tool bar. 94804
Central lubrication with fitting parts. B1 86090, 86095
Central lubrication with fitting parts. B1 86188
Central lubrication with fitting parts. B2 86090
Central lubrication with fitting parts. B2 86095
Central lubrication with fitting parts. B2 86188
Central lubrication with fitting parts. B3 86090
Central lubrication with fitting parts. B3 86095
Central lubrication with fitting parts. B3 86188
Central lubrication, B1 86090
Central lubrication, B1 86095
Central lubrication, B1 86188
Central lubrication, tool bar 86153
Cleaner kit, Pneumatic gun 86198
Control valve 85954
Control valve 85961, 86113
Control valve 86116, 86118
Control valve with fitting parts.
Control valve
Distribution block, B1. 86090, 86095
Distribution block, B1. 86188
Distribution block, B2. 86090
Distribution block, B2. 86095
Distribution block, B2. 86188
Distribution block, B3. 86090, 86095
Distribution block, B3. 86188
Extended lube points for lift arm system 85735
Feed- and return lines - control valve
Feed line and return line 86131, 86134
Fire extinguisher 85766
Fire suppression system 85904
Fire suppression system 859041
Fire suppression system 859043
Hydraulic Control 3rd-4th 84795
Hydraulic Control 3rd-4th 85961
Hydraulic Control 3rd-4th 86113
Hydraulic Control 3rd-4th 86116
Hydraulic Control 3rd-4th 86118
Hydraulic cylinder 85185
Hydraulic cylinder, lifting
Hydraulic cylinder, tilting 84894
Hydraulic cylinder, tilting 85647
Hydraulic oil cooler 85989, 86574
Hydraulic oil cooler 85990, 86575
Hydraulic oil tank, with fitting parts
Hydraulic oil tank
Hydraulic pump with fitting parts
Hydraulic system, attachment bracket. 85772
Hydraulic system, attachment bracket. 85966
Hydraulic system, attachment bracket. 86120
Hydraulic system, attachment bracket. 86134
Hydraulic system, leakage lines
Hydraulic system, lift function 85694
Hydraulic system, lift function 85771
Hydraulic system, tilt function 85771
Lifting- and tilt cylinder with assembly parts.
Lifting frame work with assembly parts 33863
Lifting frame work with assembly parts 33864
Lifting frame work with assembly parts 85740
Load sensing line
Log pusher 85185
Pump 86090, 86095, 86188
Pump with fitting parts 86090, 86095
Pump with fitting parts 86188
Relief valve. 85963
Return line, control valve 85959, 85973
Servo hydraulic Feed line and return line 85966, 85757, 86120
Suction line, tank - pump
Towing hitch 85784
Towing hitch 85785
Towing hitch 86490
Towing hitch. 86539
Valve 85772, 86120, 86134, 85966
Valve 85963
Valve body with assembly parts
Valve body, central block
Machinery House, Cab, Exterior Trim Parts
Air Conditioning Unit
Cab Interior-Upholstery
Cab, Naked, Canopy
Doors, Hatch, Cover Plate
Engine Hood, Mudguard, Foot Step
Interior Equipment
Miscellaneous
Protective Equipment
Trim Part, Outside, Glass, Sealing Moulding
Power Transmission
Front Axle, Rear Axle
Gearbox
Propeller Shaft
Torque converter 22597
Transmission, Hydraulic Control
Product identification plate
Steering
Angle sensor, steering 85954
CDC - steering 85954
Secondary steering system. 85957
Shift valve
Steering column with fitting parts 11294122
Steering column with fitting parts 11294122-1
Steering cylinder with fitting parts
Steering cylinder
Steering Knob Installation 80309
Steering system, pressure and return lines
Steering system
Steering wheel
