Volvo Wheel Loader BM L180 Service Repair Manual
Brand: Volvo
Type of Machine: Wheel Loader
Model: Volvo BM L180 Wheel Loader
Number of Pages: 4275 Pages
1 Volvo BM L180
Description
AC safety L150 up to and incl. ser. no. 1328
Adjusting axial clearance, rear axle mounting
Air conditioning, performance test (R12 and R134a)
APS (Automatic Power Shift)
Attachment unlocking locking with Separate attachment locking
Bleeding fuel system
Boom kick-out and bucket positioner, adjusting
Boom kick-out, bucket positioner and floating position
Changing bushing in axle mounting L150 w.e.fr. se. no. 1234 and L180
Charging batteries
Charging of batteries
Checking and adjusting shock valve, lifting cylinder piston end
Checking and adjusting shock valve, tilting function
Checking function, engine
Checking opening pressure, back-up valve
Cleanliness when working on brake and hydraulic systems
Control valve functions
Contronic Display Unit
Contronic System
Description
Description1
Description2
Description3
Description4
Description5
Description6
Description7
Description8
Description9
Detent function floating position and floating position
Detent function lifting boom kick-out (SW18)
Differential carrier assembly EV85, L150 up to and incl. se. no. 1233 Figure 1
Differential carrier assembly, AWB40, (L150 w.e.fr. se. no. 1234 and L180) Figure 1
Differential carrier assembly, Changing L150 w.e.fr. se. no. 1234 and L180 (AWB40)
Downshifting switch, engine braking
Dual control, gear shifting forward – reverse
Electric welding
Electrical distribution box in cab
Electrical system
Electrical system1
Emergency operation, electrical
Engine power reduction when changing travelling direction
Engine, L150
Engine, L180
Fitting rear axle
Front rear axle bridge, L150 up to and incl. se. no. 1233
Front rear axle bridge, L150 w.e.fr. se. no. 1234 and L180
Function
Functions not included in the central warning
Gear selector valve Transmission
Gear selector valve
Gear shifting, signal to the ECU from the selector control
Hub reduction, Changing seal, One side L150 up to and incl. se. no. 1233 (with drive axles AH65 and 70)
Hydraulic diagram, L150 basic machine
Hydraulic diagram, L150-1
Hydraulic diagram, L180 basic machine
Hydraulic diagram, L180-1
Hydraulic diagram, steering system, lever steering Figure 1
Hydraulic diagram, steering system, secondary steering Figure 1
Hydraulic pump
Injection system, low-emission engine
Instruments and controls Figure 1
Intercooler
Lever steering, adjusting steering speed
Lifting arm, changing bearings at lower bucket or attachment bracket pivoting points
Lifting cylinder (removed), changing bushings
Lifting cylinder, changing seals in machine
Lifting cylinder
Lifting frame
Loader l150
Manual release of parking brake
Measuring axial and radial clearance, rear axle mounting
Monitored functions
Monitoring transmission filter
Operating with ECU disconnected
Other electrical functions
Parking brake Wiring diagram
Parking brake
Planetary gear, AH70N, (L150 up to and incl. se. no. 1233) Figure 1
Planetary gear, AWB40, (L150 w.e.fr. se. no. 1234 up to and incl. 1595 and L180 up to and incl. se. no. 1327) Figure 1
Planetary gear, AWB40, Figure 1
Product Identification Plates L150
Product Identification Plates L180
Reconditioning variable piston pump L180
Reconditioning variable piston pump, L150
Refrigerants, R134a
Removing rear axle
Repairing hydraulic system
Safety valve on receiver drier
Service brakes
Servo system
Shift valve
Shock and anti-cavitation functions
Shock valves in valve block, checking
Special instructions when working on the electrical system
Starting engine Figure 1
Starting engine
Starting low-emission engine
Steering lever, checking output voltage
Steering valve
Stop solenoid, fitting
Stop solenoid
Tightening torques
Tilting cylinder (removed), changing bearings
Tilting cylinder, changing seals in machine
Tilting cylinder
Towing
Transmission HT210, HT220 Figure 1
Transmission, Checking oil pressure
Transmission, Fault tracing
Transmission, Removing and fitting
Units (functions) connected to the control unit
Working pressure and stand-by pressure, checking and adjusting
Diagrams
Code key for connectors (connected to the circuit board)
Code key for connectors (others)
Code key for diodes
Codes using in wiring diagrams
Explanations to wiring diagrams (Lead- and component marking) Figure 1
List of Cicuits
Wiring diagram, circuit 1-1 — 1-10
Wiring diagram, circuit 2-1 — 2-10
Wiring diagram, circuit 3-1 — 3-10
Wiring diagram, circuit 4-1 — 4-10
Wiring diagram, circuit 5-1 — 5-10
Wiring diagram, circuit 6-1 — 6-10
Wiring diagram, circuit 7-1 — 7-9
Wiring diagram, circuit 8-1 — 8-10
Wiring diagram, circuit 9-1 — 9-7
Wiring diagram, circuit 10-1 — 10-8
Wiring diagram, circuit 11-1 — 11-7
Wiring diagram, circuit 12-1 — 12-9
Wiring diagram, circuit 13-1 — 13-10
Wiring diagram, circuit 13-1 — 13-10-1
Wiring diagram, circuit 14-1 — 14-7
Wiring diagram, circuit 15-1 — 15-5
Wiring diagram, circuit 16-1 — 16-8
Wiring diagram, circuit 17-1 — 17-7
Wiring diagram, circuit 18-1 — 18-7
Wiring diagram, circuit 19-1 — 19-7
Wiring diagram, circuit 20-1 — 20-7
Wiring diagram, circuit 20-1 — 20-10
Wiring diagram, circuit 21-1 — 21-10
Wiring diagram, circuit 22-1 — 22-9
Installation Instruction
Air Conditioning
Care Track
CDC
Cleaner
Cleaner1
Engine Heater
Hip Belt
Installation Kit for Operators Seat
Installation Kit for Operators Seat1
Kit for fitting the radio
Protecting Grating
Rotating Beacon
Sun Blind
Windshiled Washer
Work Light
Work Light1
Repair
Accumulator, boom suspension system
Accumulator, changing seals
Accumulator, Checking (Removed)
Accumulator, checking and adjusting
Adjusting differential lock
Bake discs, Checking wear L150 w.e.fr. ser. no. 1234 (with drive axles AWB40) and L180
Bleeding brake system
Brake discs, Changing L150 up to and incl. ser. no. 1233 (with drive axles AH65 and 70)
Brake discs, Changing L150 w.e.fr. ser. no. 1234 (with drive axles AWB40) and L180
Brake pedal, Adjusting pedal angle
Brake piston, Changing seals L150 w.e.fr. ser. no. 1234 (with drive axles AWB40) and L180
Brake system, Checking and adjusting pressure in circuit
Brake system, Checking and adjusting, Unloading pressure
Changing crankshaft front oil seal
Changing fuel tank
Changing or repairing hydraulic pumps
Checking and adjusting idling speed
Checking and adjusting injection timing
Checking closing pressure, pressure-reducing valves R1 and R2
Checking function, Brake system
Checking stalling speed
E-tools
Fitting engine
Frame joint, changing bearings and pins
Headlamps, adjusting
Hydraulic diagram, brake system,
Hydraulic diagram, brake system,1
Hydraulic diagram, brake system,2
Oil pump, (pump 2) checking and adjusting working pressure
Oil pump, checking and adjusting working pressure
Oil sump gasket, changing including cleaning oil strainer
Reconditioning hydraulic oil pump
Removing engine
Safety valve tb, checking opening pressure
Servo pressure, checking and adjusting
Servo pressure, checking at spool in control valve
Servo valve, adjusting controls
Speed, checking with frequency meter
Time Guide
Safety
A few simple rules for batteries
A few simple rules of safety
A few simple rules when inflating tyres
A few simple rules when servicing
Charging batteries
Danger in connection with polymer materials
Measures to preveent fire
Refrigerant in air-conditioning units
Safety concerns everybody!
Service position
Starting with booster batteries
Service Bulletins
AC compressor, fill with oil
Action for reducing risk of fire
Action to be taken in case of abnormal lubricating oil consumption
Alternative lubricants for axles with wet brakes
Amendments in Service Manual Engine, D10B; Drive Axle, AWB 40B and Drive Axle, AWB 41 AWB 50
Automatic greasing systems of foreign manufacture
Automatic transmission lubricants
Battery and alternator test procedure
Biodegradable hydraulic fluids
Brake return spring moved
Change of tightening torque for engine lubricating oil filters
Cleaning of the machine
Coding ECU (Electronic Control Unit)
DEF AdBlue AUS32 sampling, method
Detecting leaks with inspection lamp
Diesel test standards
Diesel test standards1
Discontinued recommendation for usage of anti-corrosion agent in cooling system
ECU, functional check
Fluid levels
Fork arms, information warranty matters, altered procedures
Fuel sampling, method
Greasing of hydraulic pump drive shaft
Instructions for crack in lifting frame
Instructions for shielded metal arc welding
New alternator
New propeller shafts
New warranty routines for Bosch diesel equipment
Non - VCE buckets and attachments
Oil analyses
Oil sampling, method
Oils for Volvos wheel loaders equipped with AWB axles (Axle Wet Brakes)
Production development list for Volvo BM transmissions
PTO- shafts for HT200- and HT300- series
Quality of illustrations in technical reports
Raising and supporting machines (up to and including the E models)
Rear axle mounting
Recommendations for Oil Sampling Intervals
Recovering reclaiming refrigerant R134a using recovery unit FRS-10 GS
Repair instructions for attachments
Replacement of rubber collar on expansion tank
Replacing operator seat shock absorber
Reports
Seals
Software in E-ECU for engines supplied as spare part
Transporting a wheel loader on another vehicle
Tyres, various types
Ventilation servo casing
Water separator improvement
Special Tools, Misc
Special tool catalog
Time Guide Current generation
Time Guide Old generation
Specifications
Air cleaner
Air conditioning (AC)
Alternator with governor
Axles (L150 up to and incl. ser.no. 1233)
Battery
Boom suspension system, boom suspension system for wheel loaders
Boom suspension system, checking function
Bulbs
Capacities
Cold-starting device (optional equipment)
Cooling system Specifications L150
Cooling system Specifications L180
Drive axles Specifications L180
Drive axles, up to and incl. ser. no. 1233
Feed pump Specifications L150
Feed pump Specifications L180
Fuse
Hydraulic diagram, complete Figure 1
Hydraulic diagram, Specifications L150
Hydraulic diagram, Specifications L180
Hydraulic diagram, steering system, basic machine Figure 1
Hydraulic diagram, Tightening torques
Hydraulic oil pump (in common with servo system) Specifications L150
Hydraulic oil pump (in common with servo system) Specifications L180
Hydraulic system Specifications L150
Hydraulic system Specifications L180
Injection pump Specifications L150
Injection pump Specifications L180
Injectors Specifications L150
Injectors Specifications L180
Intercooler
Parking brake Specifications L150
Parking brake, w.e.fr. ser. no. 1262 electrically operated Specifications L180
Releasing the hydraulic oil pressure in the accumulators
Servo pump Specifications L150
Servo pump Specifications L180
Specifications L150
Specifications L180
Specifications, boom suspension system
Starter motor L150
System voltage
Tightening torques Cab
Tightening torques Trasmission
Transmission Specifications L150
Transmission Specifications L180
Turbocharger Specifications L150
Turbocharger Specifications L180
Valve block, boom suspension system
Volvo BM standard tightening torques
Weights (approx.)
Brand: Volvo
1 Volvo BM L180
Description
Charging batteries
Contronic System
Description
Description1
Description2
Description3
Description4
Description5
Description6
Description7
Description8
Description9
Electric welding
Electrical system
Electrical system1
Engine, L150
Engine, L180
Fitting rear axle
Function
Gear selector valve
Hydraulic pump
Intercooler
Lifting cylinder
Lifting frame
Loader l150
Monitored functions
Parking brake
Refrigerants, R134a
Removing rear axle
Service brakes
Servo system
Shift valve
Starting engine
Steering valve
Stop solenoid
Tightening torques
Tilting cylinder
Towing
Diagrams
Code key for diodes
List of Cicuits
Air Conditioning
Care Track
CDC
Cleaner
Cleaner1
Engine Heater
Hip Belt
Protecting Grating
Rotating Beacon
Sun Blind
Windshiled Washer
Work Light
Work Light1
Repair
Changing fuel tank
E-tools
Fitting engine
Removing engine
Time Guide
Safety
Charging batteries
Service position
Service Bulletins
Fluid levels
New alternator
Oil analyses
Rear axle mounting
Reports
Seals
Special Tools, Misc
Specifications
Air cleaner
Battery
Bulbs
Capacities
Fuse
Intercooler
Specifications L150
Specifications L180
Starter motor L150
System voltage
Weights (approx.)
- Volvo Construction Equipment All Training Set (8.5Gb)
- Volvo Wheel Loader L60F L70F L90F Service Manual
- Volvo PTT 2.01 KG
- Volvo FM10 D10B-360 Engine-MID-128
- Volvo Wheel Loader L110E/L120E shop manual
- VOLVO EXCAVATOR EC210B Training
- Volvo Excavator EC340D,EC380D,EC480D Service Training
- Volvo EW160B Error
- Volvo FM D13A 480 Engine parts, transferring
- Volvo Training EC55B-08 Hydraulic Circuit
- VOLVO Premium Tech Tool 2.03.40 (MEGA LINK)
- VOLVO L120F Service manual Persian
- Volvo Impact 2016 - Torrent
- Volvo EC210 LC Diagram
- Volvo PROSIS manuals
