Martin Welker
104
230,310
Volvo Wheel Loader BM L160 Parts and Service Manual
Brand: Volvo
Type of Machine: Wheel Loader
Type of Manual: Parts Catalog, Service Bulletins
Model: Volvo BM L160 Wheel Loader
Number of Pages: 5567 Pages
1 Volvo BM L160
Air Conditioning
4-5 HYD Function
AC
Air conditioning AC, basic principles
Air conditioning unit, components
Air conditioning unit, general
Air conditioning unit, operation
Attachment bracket
BSS
Checking pressure, general
Compressor, changing (special instructions)
Compressor, changing magnetic clutch
Compressor, changing pulley bearing (removed)
Compressor, changing shaft seal
Compressor, changing valve plate
Converting R12 to R134a
Equipment maintenance, changing oil in station
E-tools
Fan
General
Handling of non-condensable gases
Heating unit, operation
Hoses and connections
Leak detector 951 1207, new model
Receiver drier, changing
Recycling refrigerant R134a with station 981 2443
Refrigerant, charging
Refrigerant, discharging
Repair instructions
Scale 981 2444
Scales 9812513
Special tools and other equipment
Specifications
Technical data, leak detector 951 1207, new model
Technical data, scale 981 2444
Technical data, station 981 2443
Technical data, station 981 2512
Technical data, vacuum pump 981 2445
Vacuum pump 981 2445
Big-end bearing shells, changing
Biodegradable hydraulic fluids
Camshaft bearings, changing
Camshaft, changing
Classification of oils
Compression test
Coolant pump, reconditioning
Copper sleeve for injector, changing
Cranckshaft Specs
Crank motion
Crankshaft seal, front, changing
Crankshaft seal, rear, changing
Crankshaft, changing
Crankshaft, checking
Crankshaft, reconditioning
Cylinder bore, measuring
Cylinder head, face grinding
Cylinder head, pressure testing
Cylinder heads and valve mechanism
Cylinder liner seat, milling
Cylinder liners and pistons, changing
Description TD102
Diesel fuels - quality and function
Engine transmission camshaft specs
E-tools, TD102
Flywheel ring gear (for starter motor), changing.
Foreword
Fuel feed pressure, checking
Fuel system descr
Fuel system, bleeding of air
General instructions, TD 102
Information on Bio-diesel fuel (RME-fuel)
Injection advance angle, checking and adjusting
Injection pump, fitting
Injection pump, removing
Injection Specifications, TD102
Intercooler - induction manifold, tightened in two
Intercooler
Lubrication general
Main bearing shells, changing
Oil pump desc
Oil pump line Specifications, TD102
Oil pump, changing
Oil pump, reconditioning
Oils for Volvos wheel loaders equipped with AWB axles (Axle Wet Brakes)
Piston rings, changing
Pistons and piston rings
Raising and supporting machines (up to and including the E models)
Relief valve, changing
Rocker mechanism, reconditioning
Specifications TD102
Specifications, TD102 1
Specifications, TD102 2
Thermostat, changing
Thermostat
Timing gears, changing
Timing gears
Turbo specs
Turbocharger, changing
Turbocharger, checking end float
Turbocharger, checking running clearance
Turbocharger, reconditioning
Valve grinding and decarbonizing
Valve guides, changing
Valve mechanism Specifications, TD102
Valve seat inserts, changing
Volvo standard tightening torques
Parts BM L160
Brake
Electrical, Warning, Information, Instrument
Engine with mounting and equipment
Frame, springs, damping
Hydraulic, digging, handling, grading equipment
Machinery house, cab, exterior trim parts
Power transmission
Steering
Service Bulletins 1
AC compressor, fill with oil
Action to be taken in case of abnormal lubricating oil consumption
Alternative lubricants for axles with wet brakes
Amendments in Service Manual Engine
Automatic greasing systems of foreign manufacture
Automatic transmission lubricants
Battery and alternator test procedure
Cleaning of the machine
DEF AdBlue AUS32 sampling, method
Detecting leaks with inspection lamp
Discontinued recommendation for usage of anti-corrosion agent in cooling system
ECU, functional check
Fork arms, information warranty matters, altered procedures
Fuel sampling, method
Greasing of hydraulic pump drive shaft
Instructions for crack in lifting frame
Instructions for shielded metal arc welding
Oil sampling, method
Quality of illustrations in technical reports
Recommendations for Oil Sampling Intervals
Repair instructions for attachments
Reports
Seals
Tyres, various types
Water separator improvement
Service Bulletins 2
Attachment lights
Automatic gear shifter
CDC
Conversion kits for air-conditioning installations
Correction
Double control barke
E-2017
Engine injection system malfunction
Fitting of edge saver on buckets
Inductive sensors
Modified way of attaching radio CR-502
New linkage in operator seat
New stop shaft on Bosch injection pump with RQV - governor
Product plates on HT Transmissions
Production development list for Volvo BM transmissions
PTO- shafts for HT200- and HT300- series
Rear axle suspension
REAR CRANKSHAFT SEAL
Recovering reclaiming refrigerant R134a using recovery unit FRS-10 GS
Replacing operator seat shock absorber
Shift valve, checking
Software in E-ECU for engines supplied as spare part
Ventilation servo casing
Wear sleeves for front and rear crankshaft seals
Special tools and misc
41 RM Compaction ABG Time Guide
GRD G700B LabourTimeGuide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
Special Recommendation Tools Wheel Loaders
Special tool catalog
Time Guide Current generation
Time Guide Old generation
Transmission HT200 HT201
Clutch shaft reverse - second HT201
Clutch shaft third - fourth HT201
Clutch shaft, forward - first HT201
Clutch shaft, forward - first, HT200
Clutch shaft, reverse - second, HT200
Clutch shaft, third - fourth, HT200 1
Clutch shaft, third - fourth, HT200, HT 200
Damping valve, reconditioning
Description
E-tools
Forward and first clutches,
Gear selector valve, reconditioning
General
Lubricating oil valve, reconditioning
Oil pump and turbine shaft bearing, reconditioning
Power take-off, reconditioning
Reverse and second clutches,
Specifications 1
Specifications
Third and fourth clutches,
Tightening torques
Torque converter, rebuilding
Torque converter, reconditioning
Torque converter
Transmission HT 200
Transmission, assembling
Transmission, dismantling
VOLVO BM standard tightening torques
Weights
