Martin Welker
104
230,310
Volvo Wheel Loader BM 4500 Parts Manual
Brand: Volvo
Type of Machine: Wheel Loader
Model: Volvo BM 4500 Wheel Loader
Number of Pages: 4547 Pages
1 Volvo BM4400
2 Volvo BM4400
3 Volvo BM4400
4 Volvo BM4400
AC compressor, fill with oil
Action for reducing risk of fire
Action to be taken in case of abnormal lubricating oil consumption
Air cleaner 99297, 99299, 99817
Air compressor 1
Air compressor with fitting parts Tillv No -4525
Air compressor with fitting parts Tillv No 4526-
Air compressor
Air condition 90065 tillv nr 5119-
Air cooler with fitting parts 99297, 99299
Air ducts prod nr 33205,33210
Air filter 99297, 99299, 99817
Air filter
Air-condition 98621,99198,99237,99238 99638 Tillv Nr -5118
Air-condition evaporator 90065
Alternative lubricants for axles with wet brakes
Alternator tillv nr 4526 - 6914
Alternator tillv nr 6915-
Alternator with assembling details
Amendments in Service Manual Engine, D10B; Drive Axle, AWB 40B and Drive Axle, AWB 41 AWB 50
Anti-freeze reservoir
Attachment bracket
Attachment locking
Automatic gear shifter
Automatic greasing systems of foreign manufacture
Automatic transmission lubricants
Battery and alternator test procedure
Battery with assembling details
Belt transmission
Biodegradable hydraulic fluids
Brake cylinder
Brake system
Brake unit tillv nr -4525
Brake unit tillv nr 4526 -
Brake valve
Brake
Cab body Prod Nr 33201, 33202
Cab body prod nr 33205,33210
Camshaft
Care Track
Centrifugal governor 99297, 99299
Charging oil-pump drive ht -4525
Charging oil-pump drive ht 4526-5320
Charging oil-pump drive ht 5321-
Checking and adjusting end float, HT 130
Classification of oils
Cleaning of the machine
Clutch reconditioning of 3rd - 4th Gear 1
Clutches 1st and 2nd speeds
Clutches 3rd and 4th speeds
Clutches forward and reverse
Clutches, gears and shafts
Cold-starting device
Compactor 98599 protector plates and Bottom G Plates
Compactor 98599 driver's cab and Engine Plates
Compaktor wheels 98440, 99283
Compressed air horn 99734
Control valve tillv nr-5595,5696-5730
Control valve
Controls prod nr 33205,33210
Controls
Cooling system tillv nr -3728
Cooling system tillv nr 3729-
Cooling system, oil-cooler
Cooling system
Correction
Crankshaft and related parts
Cylinder block
Cylinder head
Damping valve, reconditioning, HT 130
DEF AdBlue AUS32 sampling, method
Description transmission
Detecting leaks with inspection lamp
Diesel fuels - quality and function
Differential housing
Differential lock pneumatic system Tillv Nr -4525
Differential lock pneumatic system Tillv Nr 4526-
Differential lock
Disc brake
Discontinued recommendation for usage of anti-corrosion agent in cooling system
Distribution box Prod Nr 33201, 33202
Distribution box prod nr 33205,33210
Door Prod Nr 33201, 33202
Door prod nr 33205,33210
Double brake pedals 99219
Double brake pedals
Drive axle, front prod no 23515 23515
Drive axle, rear prod nr 23509 23509
Drive axle, rear prod nr 23522 23522
Drive axle,front prod nr 23541
Driver's cab Prod Nr 33201, 33202
Driver's cab prod nr 33205,33210
Driveshafts with assembly parts
Dropbox gears and shafts
Dropbox housing and cover
Dropbox HT 131
E tools, HT 130
ECU, functional check
Elect. system, aut. powershift. 99371, 99382, 99541, 99728 - 99730
Electric system, front
Electric system, rear
Electronic control unit
Emergency steering equipment 99757, 90062 Tillv Nr 4526-
Emergency steering equipment, 98642, 98562 Tillv Nr -4525
Engine heater 9 8346
Engine mounting
Engine plates tillv. nr -2897
Engine plates tillv.nr 2898-
Engine turbo protection when transporting wheel loaders
Engine with fitting parts
Exhaust cooling 97297, 99299
Exhaust system
Fan 1
Fan 2
Fan 90317
Fan
Feed lines
Feed pump
Filter
Final gear, front
Final gear, rear prod nr 23509
Final gear, rear prod nr 23522
Fluid levels
Footbrake valve with mountings
Fork arms, information warranty matters, altered procedures
Frame
Front and rear mudguards 98562, 99332
Fuel filter 98607
Fuel filter
Fuel injection pump with fitting parts
Fuel level sender
Fuel lines, injectors
Fuel sampling, method
Fuel system
Fuel tank
Gear selector valve, reconditioning, HT 130
General, HT 130
Glass panes and interior components Prod Nr 33205,33210
GRD G700B LabourTimeGuide Old version
G700B Labour Time Guide Foreword.pdf
Greasing of hydraulic pump drive shaft
Handbrake Tillv Nr -5118
Handbrake Tillv Nr 5119-
Headlamp 1
Headlamp 2
Headlamp 3
Heating system 33201 hytt nr - 2705 33202 Hytt Nr - 2684
Heating system 33201 hytt nr 2706-4517 33202 Hytt Nr 2685-10928
Hydraulic pump 98642
Hydraulic attachment bracket 98053
Hydraulic cylinder lifting Tillv Nr - 5228
Hydraulic cylinder lifting Tillv Nr 5229 -
Hydraulic cylinder tillv nr -4525
Hydraulic cylinder tillv nr 4526-
Hydraulic cylinder
Hydraulic lines, valves and filter
Hydraulic pump 1
Hydraulic pump 2
Hydraulic pump tillv nr 4526-
Hydraulic system front Tillv No -4525
Hydraulic system front Tillv No 4526-
Hydraulic system rear Tillv No 4526-
Hydraulic system rear Tillv Nr -3743
Hydraulic system rear Tillv Nr 3744 - 4525
Hydraulic system
Hydraulic transmission with fitting parts
Hydraulic-oil tank tillv nr -4525
Hydraulic-oil tank tillv nr 4526 -
Inductive sensors
Information about new publications
Information on Bio-diesel fuel (RME-fuel)
Injection pump
Injector
Inlet system
Instructions for crack in lifting frame
Instructions for shielded metal arc welding
Instrument panel and instruments Prod Nr 33205,33210
Instruments and instrument panel Prod Nr 33201, 33202
Instruments and instrument panel Prod Nr 33201, 33202-1
Insulating matting Prod Nr 33201, 33202
Insulating matting prod nr 33205,33210
Interior components and rear-view mirror Prod Nr 33201, 33202
Intermediate shaft, changing bearings and gears, HT 130
Level lock 99218
Lift automatic and bucket automatic
Lifting unit
Lighting 98599,98274,98275,98276
Lighting
Lubricating oil system
Machine data
Magnet valve
Mechanical attachment bracket 98052
New linkage in operator seat
New tool for programming the automatic greasing system TWIN
New warranty routines for Bosch diesel equipment
Oil analyses
Oil cooler 99856
Oil cooler
Oil pump, reconditioning, HT 130
Oil pump
Oil sampling, method
Oil tank tillv nr -4525
Oil tank tillv nr 4526-
Oils for Volvo wheel loaders equipped with AWB axles (Axle Wet Brakes)
Oils for Volvos wheel loaders equipped with AWB axles (Axle Wet Brakes)
Operator seat with fitting parts
Operator's seat 1
Operator's seat
Parking brake pneumatic system 90203
Parking brake valve
Pipe connection to smoke eliminator 99297, 99299
Pneumatic cylinder
Pneumatic system components Tillv No -4525
Pneumatic system components Tillv No 4526-
Pneumatic system pipes Tillv No -4525
Pneumatic system pipes Tillv No 4526-
Power shaft tillv nr -3707
Power shaft tillv nr 3708-
Power shafts
Power take off, reconditioning, HT 130
Pre-heater
Pressure gauge brake system
Priority valve 99757
Production development list for Volvo BM transmissions
Programming instructions for electronic control unit (ECU)
Propeller shafts with fitting parts
Protection equipment for coarse dust
Protector plates and loaded weights
Quality of illustrations in technical reports
Radiator casing
Radiator with exhaust pipe 99297, 99299
Radiator with fitting parts Prod Nr 33205,33210
Radiator with fitting parts Tillv Nr -3743
Radiator with fitting parts Tillv Nr 3744-
Raising and supporting machines (up to and including the E models)
Range selector controls tillv nr -5118
Range selector valve
Rebuilding hot water valve 1
Recommendations for Oil Sampling Intervals
Reconditioning of coolant pump
Reconditioning transmission
Reconditioning, HT 130
Recovering reclaiming refrigerant R134a using recovery unit FRS-10 GS
Regulator control
Regulator
Repair instructions for attachments
Repair kit, part no
Replacing operator seat shock absorber
Reporting of accidents and incidents
Reports
Reverse-motion alarm 99888
Revolving warning light 98194,99660
Revolving warning light 99886
RM Compaction ABG Time Guide Old 2009-01-26
Foreword
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Compaction Time guide old version 2008-10-27
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Paving Systems ABG Time Guide Old 2009-01-26
Foreword
Screeds
Hydraulics
Structural
Drive system
Electrical
Roof door 99121
Safety parts details signal for parking brake 98632 Tillv. Nr -3473
Safety parts details signal for parking brake 98632 Tillv.nr 3474-
Safety parts detals signal for parking brake 99715,90059
Safety roof 98547
Seals
Seat suspension
Securing pipe in transmission housing, HT 130
Sign plates and decals 1
Sign plates and decals 2
Sign plates and decals 3
Signal horn, reflex and windshield wipers, rear
Single-acting lifting function 99161
Smoke eliminator 99297, 99299
Software in E-ECU for engines supplied as spare part
Special tool catalog 2014-11-17
General
Index
Hooks
1. Enviroment and Safety equipment
2. Measuring equipment
3. Tightening and Loosening tools
4. Lifting equipment
5. Pullers and Pressing equipment
6. Drifts
7. Guide pins and Guide sleeves
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Specifications, HT 130
Spot lights 99297, 99299
Starter motor mo 28596-
Starter motor mo-28595
Starter motor
Starting heater
Steering column with fitting parts Prod Nr 33205, 33210
Steering system tillv nr -4525
Steering system tillv nr 4526-
Steering unit
Sugar cane handlers
Tightening torques, HT 130
Tilting system
Time Guide Current generation 2014-12_12
Time Guide Old generation 2014-12-12
Time Guide Previous generation 2014-12_12
Timing gear casing,timinggears and engine-speed Indicator
Tool information Adapters for measuring hydraulic pressure
Tool information
Tools 98192
Tools for removing cable terminals
Torque converter 98599
Torque converter, reconditioning (Fichtel & Sachs)
Torque converter, reconditioning (Twin Disc)
Torque converter
Transmission pump
Transmission, assembling
Transmissions 130
Transmissions 131–132
Transporting a wheel loader on another vehicle
Troque converter and lubricating oil valve, reconditioning
Turbo charger
Turbocharger with fitting parts
Tyre-inflating equipment 96041,99407
Tyres, various types
Valve 98642
Valve body
Valve section 1
Valve section 2
Valve section
Ventilation servo casing
Ventilaton pane 98942
Volvo standard tightening torques
Warning light
Water pump with fitting parts
Water pump
Water separator improvement
Wear sleeves for front and rear crankshaft seals
Weight (without oil), approx, HT 130
Wheel 1
Wheel 2
Wheel cleaner for 98440. 99445
Windscreen washer 90106
Windscreen washer 98632, 98633, 99715
Windshield wipers front 1
Windshield wipers front 2
Worklight
