Martin Welker
104
230,310
Volvo Truck FM12 Repair and Service Manual
Brand: Volvo
Type of Manual: Repair and Service Manual
Model: Volvo FM12 Truck
Number of Pages: 5665 Pages
21002-2 2103-06-02-01 Cylinder compression test 1
21035-4 2109-12-04-01 Engine parts, transferring 1
21035-4 2109-12-04-01 Engine parts, transferring 2
21035-4 2109-12-04-01 Engine parts, transferring 3
21035-4 2109-12-04-01 Engine parts, transferring 4
21035-4 2109-12-04-01 Engine parts, transferring 5
21035-4 2109-12-04-01 Engine parts, transferring 6
21038-5 2102-19-05-01 Engine, install and remove from overhaul stand 1
21038-5 2102-19-05-01 Engine, install and remove from overhaul stand 2
21038-5 2102-19-05-01 Engine, install and remove from overhaul stand 3
21038-5 2102-19-05-01 Engine, install and remove from overhaul stand 4
21070-1 2102-01-01-01 Engine, remove 1
21070-1 2102-01-01-01 Engine, remove 2
21070-1 2102-01-01-01 Engine, remove 3
21070-1 2102-01-01-01 Engine, remove 4
21070-1 2102-01-01-01 Engine, remove 5
21070-1 2102-01-01-01 Engine, remove 6
21070-1 2102-01-01-01 Engine, remove 7
21070-1 2102-01-01-01 Engine, remove 8
21072-1 2102-02-01-01 Engine, install 1
21072-1 2102-02-01-01 Engine, install 2
21072-1 2102-02-01-01 Engine, install 3
21072-1 2102-02-01-01 Engine, install 4
21072-1 2102-02-01-01 Engine, install 5
21072-1 2102-02-01-01 Engine, install 6
21072-1 2102-02-01-01 Engine, install 7
21072-1 2102-02-01-01 Engine, install 8
21104-2 2112-03-02-01 Coolant seal cylinder head, replace
21105-5 2119-03-05-03 Valve seat, replace (one)
21110-3 2115-03-03-02 Sealing strip, valve cover, replace 1
21110-3 2115-03-03-02 Sealing strip, valve cover, replace 2
21110-3 2115-03-03-02 Sealing strip, valve cover, replace 3
21112-3 2119-03-03-04 Camshaft bearing brackets, replace
21122-1 2111-01-02-01 Cylinder head, remove 1
21122-1 2111-01-02-01 Cylinder head, remove 2
21122-1 2111-01-02-01 Cylinder head, remove 3
21122-1 2111-01-02-01 Cylinder head, remove 4
21122-1 2111-01-02-01 Cylinder head, remove 5
21124-1 2111-02-01-01 Cylinder head, install 1
21124-1 2111-02-01-01 Cylinder head, install 2
21124-1 2111-02-01-01 Cylinder head, install 3
21124-1 2111-02-01-01 Cylinder head, install 4
21124-1 2111-02-01-01 Cylinder head, install 5
21124-1 2111-02-01-01 Cylinder head, install 6
21124-1 2111-02-01-01 Cylinder head, install 7
21131-5 2119-03-05-05 Coolant plug, cylinder head, replace (side or rear)
21132-3 2111-03-03-03 Cylinder head, replace 1
21132-3 2111-03-03-03 Cylinder head, replace 2
21165-3 2116-03-03-02 Valve cover gasket, replace (first)
21171-4 2111-06-04-01 Cylinder head, pressure test (first) 1
21171-4 2111-06-04-01 Cylinder head, pressure test (first) 2
21171-4 2111-06-04-01 Cylinder head, pressure test (first) 3
21171-4 2111-06-04-01 Cylinder head, pressure test (first) 4
21177-4 2119-12-04-01 Cylinder head, transfer parts 1
21177-4 2119-12-04-01 Cylinder head, transfer parts 2
21177-4 2119-12-04-01 Cylinder head, transfer parts 3
21177-4 2119-12-04-01 Cylinder head, transfer parts 4
21177-4 2119-12-04-01 Cylinder head, transfer parts 5
21177-4 2119-12-04-01 Cylinder head, transfer parts 6
21201-2 2129-03-02-02 Gasket, coolant cover oil cooler, replace 1
21201-2 2129-03-02-02 Gasket, coolant cover oil cooler, replace 2
21201-2 2129-03-02-02 Gasket, coolant cover oil cooler, replace 3
21201-2 2129-03-02-02 Gasket, coolant cover oil cooler, replace 4
21201-2 2129-03-02-02 Gasket, coolant cover oil cooler, replace 5
21201-2 2129-03-02-02 Gasket, coolant cover oil cooler, replace 6
21208-3 2129-03-03-03 Oil plug, replace (upper side engine block)
21231-3 2129-03-03-02 Core plug, replace 1
21231-3 2129-03-03-02 Core plug, replace 2
21233-3 2125-03-03-01 Flywheel housing, replace 1
21233-3 2125-03-03-01 Flywheel housing, replace 2
21233-3 2125-03-03-01 Flywheel housing, replace 3
21233-3 2125-03-03-01 Flywheel housing, replace 4
21233-3 2125-03-03-01 Flywheel housing, replace 5
21233-3 2125-03-03-01 Flywheel housing, replace 6
21235-3 2125-06-03-02 Flywheel housing run-out, check 1
21235-3 2125-06-03-02 Flywheel housing run-out, check 2
21311-3 2131-03-03-01 Cylinder liners and pistons, replace (All) 1
21311-3 2131-03-03-01 Cylinder liners and pistons, replace (All) 2
21311-3 2131-03-03-01 Cylinder liners and pistons, replace (All) 3
21311-3 2131-03-03-01 Cylinder liners and pistons, replace (All) 4
21377-3 2139-05-03-03 Cylinder liner seat, milling
21405-5 2140-19-05-01 Valves, remove and install (one cylinder) 1
21414-3 2140-05-03-01 Valves and engine injectors, adjust 1
21414-3 2140-05-03-01 Valves and engine injectors, adjust 2
21414-3 2140-05-03-01 Valves and engine injectors, adjust 3
21414-3 2140-05-03-01 Valves and engine injectors, adjust 4
21414-3 2140-05-03-01 Valves and engine injectors, adjust 5
21414-3 2140-05-03-01 Valves and engine injectors, adjust 6
21415-5 2143-03-05-03 Valve guides, replace (one cylinder head) 1
21415-5 2143-03-05-03 Valve guides, replace (one cylinder head) 2
21416-2 2149-03-02-01 Valve stem seals, replace
21417-5 2143-06-05-01 Valve guide wear, check
21418-3 2149-03-03-01 Valve stem seals, replace 1
21418-3 2149-03-03-01 Valve stem seals, replace 2
21440-1 2146-01-01-01 Rocker arm shaft, remove 1
21440-1 2146-01-01-01 Rocker arm shaft, remove 2
21440-1 2146-01-01-01 Rocker arm shaft, remove 3
21442-1 2146-02-01-01 Rocker arm shaft, install 1
21442-1 2146-02-01-01 Rocker arm shaft, install 2
21442-1 2146-02-01-01 Rocker arm shaft, install 3
21444-4 2145-03-04-01 Rocker arms, replace (all) 1
21444-4 2145-03-04-01 Rocker arms, replace (all) 2
21448-4 2145-04-04-02 Rocker arm, overhaul
21451-4 2145-06-04-01 Rocker arm bushings, check
21503-3 2154-06-03-01 Camshaft timing, check 1
21503-3 2154-06-03-01 Camshaft timing, check 2
21507-3 2152-03-03-04 Sealant, timing gear plate, replace 1
21507-3 2152-03-03-04 Sealant, timing gear plate, replace 2
21511-3 2151-05-03-01 Timing gear plate, adjust 1
21511-3 2151-05-03-01 Timing gear plate, adjust 2
21513-3 2154-06-03-04 Camshaft wear, check 1
21513-3 2154-06-03-04 Camshaft wear, check 2
21513-3 2154-06-03-04 Camshaft wear, check 3
21513-3 2154-06-03-04 Camshaft wear, check 4
21515-2 2151-03-02-01 Timing gear cover (upper), replace 1
21515-2 2151-03-02-01 Timing gear cover (upper), replace 2
21520-2 2152-03-02-02 Sealing ring timing cover, replace 1
21522-2 2154-03-02-01 Camshaft, replace 1
21522-2 2154-03-02-01 Camshaft, replace 2
21522-2 2154-03-02-01 Camshaft, replace 3
21522-2 2154-03-02-01 Camshaft, replace 4
21522-2 2154-03-02-01 Camshaft, replace 5
21524-3 2119-03-03-02 Camshaft bearing brackets, replace
21531-3 2153-03-03-01 Timing gears, replace (all) 1
21531-3 2153-03-03-01 Timing gears, replace (all) 2
21571-3 2151-03-03-02 Sealant, timing gear casing upper, replace 1
21571-3 2151-03-03-02 Sealant, timing gear casing upper, replace 2
21573-3 2151-03-03-03 Sealant, timing gear casing and flywheel casing, replace
21603-3 2162-03-03-01 Main bearings, replace (all) 1
21603-3 2162-03-03-01 Main bearings, replace (all) 2
21603-3 2162-03-03-01 Main bearings, replace (all) 3
21607-3 2169-03-03-01 Flywheel bearing, replace
21611-3 2165-03-03-01 Connecting rod bearings, replace (all) 1
21611-3 2165-03-03-01 Connecting rod bearings, replace (all) 2
21621-3 2166-03-03-01 Flywheel, replace 1
21621-3 2166-03-03-01 Flywheel, replace 2
21621-3 2166-03-03-01 Flywheel, replace 3
21631-3 2166-06-03-01 Flywheel, check 1
21631-3 2166-06-03-01 Flywheel, check 2
21632-2 2169-06-02-01 Flywheel sensor distance, check 1
21632-2 2169-06-02-01 Flywheel sensor distance, check 2
21650-4 2161-03-04-01 Crankshaft, replace 1
21650-4 2161-03-04-01 Crankshaft, replace 2
21652-2 2167-03-02-03 Sealant crankshaft cover assembly, replace (front) 1
21652-2 2167-03-02-03 Sealant crankshaft cover assembly, replace (front) 2
21652-2 2167-03-02-03 Sealant crankshaft cover assembly, replace (front) 3
21652-2 2167-03-02-03 Sealant crankshaft cover assembly, replace (front) 4
21652-2 2167-03-02-03 Sealant crankshaft cover assembly, replace (front) 5
21667-3 2167-03-03-01 Crankshaft seal, replace (rear) 1
21667-3 2167-03-03-01 Crankshaft seal, replace (rear) 2
21667-3 2167-03-03-01 Crankshaft seal, replace (rear) 3
21668-3 2167-03-03-02 Crankshaft seal, replace (front) 1
21668-3 2167-03-03-02 Crankshaft seal, replace (front) 2
21668-3 2167-03-03-02 Crankshaft seal, replace (front) 3
21668-3 2167-03-03-02 Crankshaft seal, replace (front) 4
21687-5 2166-03-05-01 Flywheel ring gear, replace
21705-3 2172-03-03-02 Sump gasket, replace
21706-1 2171-01-01-01 Oil sump, remove 1
21706-1 2171-01-01-01 Oil sump, remove 2
21708-1 2171-02-01-01 Oil sump, install 1
21708-1 2171-02-01-01 Oil sump, install 2
21818-2 2182-03-02-02 Engine mounting pad rear, replace (one)
22111-3 2211-19-03-01 Oil pump, remove-install 1
22111-3 2211-19-03-01 Oil pump, remove-install 2
22111-3 2211-19-03-01 Oil pump, remove-install 3
22121-2 2219-06-02-01 Oil pressure, check
22150-3 2213-03-03-01 Pressure oil pipe, replace 1
22150-3 2213-03-03-01 Pressure oil pipe, replace 2
22201-3 2229-03-03-06 Oil filter nipple, replace 1
22201-3 2229-03-03-06 Oil filter nipple, replace 2
22202-2 2229-03-02-04 Piston cooling solenoid, replace
22207-3 2223-03-03-01 Oil filter, engine, replace 1
22207-3 2223-03-03-01 Oil filter, engine, replace 2
22212-2 2229-03-02-01 Gasket oil filter housing, replace 1
22212-2 2229-03-02-01 Gasket oil filter housing, replace 2
22212-2 2229-03-02-01 Gasket oil filter housing, replace 3
22212-2 2229-03-02-01 Gasket oil filter housing, replace 4
22212-2 2229-03-02-01 Gasket oil filter housing, replace 5
22212-2 2229-03-02-01 Gasket oil filter housing, replace 6
22213-2 2222-03-02-01 Oil filter housing, replace 1
22213-2 2222-03-02-01 Oil filter housing, replace 2
22325-5 2231-06-05-01 Oil cooler, pressure test 1
22325-5 2231-06-05-01 Oil cooler, pressure test 2
22327-3 2232-03-03-02 Oil cooler insert, replace 1
22327-3 2232-03-03-02 Oil cooler insert, replace 2
22327-3 2232-03-03-02 Oil cooler insert, replace 3
22327-3 2232-03-03-02 Oil cooler insert, replace 4
22327-3 2232-03-03-02 Oil cooler insert, replace 5
22327-3 2232-03-03-02 Oil cooler insert, replace 6
22327-3 2232-03-03-02 Oil cooler insert, replace 7
22331-3 2219-03-03-01 Piston cooling nozzle, replace 1
22331-3 2219-03-03-01 Piston cooling nozzle, replace 2
22331-3 2219-03-03-01 Piston cooling nozzle, replace 3
22335-2 2229-03-02-03 Overflow valve, oil cooler, replace 1
22335-2 2229-03-02-03 Overflow valve, oil cooler, replace 2
22336-2 2229-03-02-07 Thermostat valve or pressure valve oil cooler, replace 1
22336-2 2229-03-02-07 Thermostat valve or pressure valve oil cooler, replace 2
22336-2 2229-03-02-07 Thermostat valve or pressure valve oil cooler, replace 3
22336-2 2229-03-02-07 Thermostat valve or pressure valve oil cooler, replace 4
22337-2 2229-03-02-05 Piston cooling valve, replace
22338-2 2229-03-02-10 Opening valve, piston cooling, replace
22340-2 2229-03-02-11 Control valve, piston cooling, replace 1
22340-2 2229-03-02-11 Control valve, piston cooling, replace 2
22341-2 2219-03-02-01 Reduction valve, replace 1
22341-2 2219-03-02-01 Reduction valve, replace 2
22341-2 2219-03-02-01 Reduction valve, replace 3
22342-2 2239-03-02-01 Safety valve oil pressure, replace 1
22342-2 2239-03-02-01 Safety valve oil pressure, replace 2
22342-2 2239-03-02-01 Safety valve oil pressure, replace 3
22342-2 2239-03-02-01 Safety valve oil pressure, replace 4
22343-2 2239-03-02-03 Overflow valve oil filter, full flow, replace 1
22343-2 2239-03-02-03 Overflow valve oil filter, full flow, replace 2
22343-2 2239-03-02-03 Overflow valve oil filter, full flow, replace 3
22343-2 2239-03-02-03 Overflow valve oil filter, full flow, replace 4
22343-2 2239-03-02-03 Overflow valve oil filter, full flow, replace 5
22343-2 2239-03-02-03 Overflow valve oil filter, full flow, replace 6
22344-2 2239-03-02-02 Overflow valve oil filter, by-pass, replace 1
22344-2 2239-03-02-02 Overflow valve oil filter, by-pass, replace 2
22344-2 2239-03-02-02 Overflow valve oil filter, by-pass, replace 3
23001-3 2300-16-03-01 Fuel consumption parameter, adjust
23003-3 2309-05-03-01 Fuel system, bleeding 1
23003-3 2309-05-03-01 Fuel system, bleeding 2
23302-2 2331-03-02-01 Feed pump, replace
23306-3 2335-03-03-02 Fuel filter, replace (one) 1
23306-3 2335-03-03-02 Fuel filter, replace (one) 2
23306-3 2335-03-03-02 Fuel filter, replace (one) 3
23306-3 2335-03-03-02 Fuel filter, replace (one) 4
23311-3 2339-03-03-01 Filter, water separator, replace 1
23311-3 2339-03-03-01 Filter, water separator, replace 2
23311-3 2339-03-03-01 Filter, water separator, replace 3
23311-3 2339-03-03-01 Filter, water separator, replace 4
23314-2 2339-11-02-01 Water separator, water draining
23325-2 2331-03-02-03 Fuel primer pump, electrical, replace
23326-2 2331-03-02-04 Feed pump valves, replace
23331-3 2334-03-03-02 Fuel filter housing, replace 1
23331-3 2334-03-03-02 Fuel filter housing, replace 2
23331-3 2334-03-03-02 Fuel filter housing, replace 3
23333-2 2335-06-02-02 Drainage valve, water separator, check
23352-2 2339-03-02-05 Fuel pressure sensor, replace
23378-2 2339-06-02-01 Fuel feed pressure, check
23414-3 2340-03-03-01 Filter for fuel tank ventilation, replace
23415-3 2349-11-03-01 Fuel tank strainer, clean and drain condensation water
23416-2 2346-03-02-01 Fuel line, replace (one)
23419-3 2346-03-03-02 Fuel line, electrical heated, replace
23607-3 2362-03-03-01 Overflow valve, replace 1
23607-3 2362-03-03-01 Overflow valve, replace 2
23607-3 2362-03-03-01 Overflow valve, replace 3
23710-3 2374-06-03-01 Preload unit injector, check 1
23710-3 2374-06-03-01 Preload unit injector, check 2
23732-3 2372-06-03-01 Yoke, injector, check 1
23732-3 2372-06-03-01 Yoke, injector, check 2
23732-3 2372-06-03-01 Yoke, injector, check 3
23733-3 2379-03-03-04 Sleeve, unit injector, replace 1
23733-3 2379-03-03-04 Sleeve, unit injector, replace 2
23733-3 2379-03-03-04 Sleeve, unit injector, replace 3
23734-2 2374-03-02-01 Unit injector, replace (one) 1
23734-2 2374-03-02-01 Unit injector, replace (one) 2
23737-3 2374-03-03-01 Unit injector, replace (one)
23814-3 2841-22-03-01 Control unit, updating with PC electronic fuel control
24117-3 2419-03-03-02 Filter, gas, replace 1
24117-3 2419-03-03-02 Filter, gas, replace 2
24128-3 2419-03-03-08 Pressure sensor, replace 1
24128-3 2419-03-03-08 Pressure sensor, replace 2
24130-3 2419-03-03-09 Temperature sensor, replace 1
24130-3 2419-03-03-09 Temperature sensor, replace 2
24131-2 2419-03-02-02 Control unit, replace
24132-3 2419-03-03-10 Injector valve, replace
24133-3 2419-03-03-11 Injector valve, replace 1
24133-3 2419-03-03-11 Injector valve, replace 2
24134-2 2419-03-02-03 Knock sensor, replace
24136-3 2419-03-03-12 Shut-off valve, replace 1
24136-3 2419-03-03-12 Shut-off valve, replace 2
24137-3 2419-03-03-13 Vent pipe, drain
24138-3 2419-03-03-14 Filter, gas, replace 1
24138-3 2419-03-03-14 Filter, gas, replace 2
24142-3 2419-03-03-16 Heat exchanger, replace
24144-3 2419-11-03-02 Filter, gas, clean 1
24144-3 2419-11-03-02 Filter, gas, clean 2
24145-3 2419-11-03-03 Shut-off valve, clean 1
24145-3 2419-11-03-03 Shut-off valve, clean 2
24146-3 2419-03-03-17 Pressure regulator, replace 1
24146-3 2419-03-03-17 Pressure regulator, replace 2
24147-3 2419-03-03-18 Relief valve, replace
24405-2 2441-03-02-01 Gas tanks, draining 1
24405-2 2441-03-02-01 Gas tanks, draining 2
24407-1 2441-01-01-01 Gas tank, remove 1
24407-1 2441-01-01-01 Gas tank, remove 2
24410-2 2444-03-02-01 Solenoid valve, tank valve, replace
24411-1 2441-02-01-01 Gas tank, install 1
24411-1 2441-02-01-01 Gas tank, install 2
24412-2 2441-03-02-03 Tensioning band, gas tank, replace
24413-3 2441-03-03-02 Bracket, gas tank, replace
24414-3 2441-03-03-03 Pressure regulator, gas tank, replace
24416-3 2449-03-03-02 Non-return valve, replace 1
24416-3 2449-03-03-02 Non-return valve, replace 2
24417-3 2449-03-03-03 Hose break valve, replace
24418-3 2446-03-03-01 Level indicator, replace
24420-3 2449-03-03-04 Relief valve, replace
24421-3 2441-06-03-01 Gas system, leakage test 1
24421-3 2441-06-03-01 Gas system, leakage test 2
24422-3 2449-03-03-05 Filler receptacle, replace 1
24422-3 2449-03-03-05 Filler receptacle, replace 2
24423-3 2449-03-03-06 Tank valve, service kit, replace
24424-3 2441-03-03-04 Gas tanks, venting
24425-3 2441-16-03-01 Gas system, draining
25102-2 2512-03-02-01 Gaskets, intake manifold, replace 1
25102-2 2512-03-02-01 Gaskets, intake manifold, replace 2
25103-3 2512-03-03-01 Gaskets for inlet manifold, replace 1
25103-3 2512-03-03-01 Gaskets for inlet manifold, replace 2
25103-3 2512-03-03-01 Gaskets for inlet manifold, replace 3
25104-2 2516-03-02-02 Gaskets, exhaust manifold, replace 1
25104-2 2516-03-02-02 Gaskets, exhaust manifold, replace 2
25104-2 2516-03-02-02 Gaskets, exhaust manifold, replace 3
25116-5 2515-03-05-01 Gasket kit, exhaust manifold, replace 1
25116-5 2515-03-05-01 Gasket kit, exhaust manifold, replace 2
25142-1 2516-02-01-01 Clamps and sealant rings exhaust manifold, install
25605-3 2569-06-03-01 Pressure drop indicator, check
25614-3 2511-06-03-01 Inlet pipe, check 1
25625-3 2562-03-03-02 Secondary air filter, replace
25627-3 2562-03-03-01 Filter insert, air cleaner, replace 1
25627-3 2562-03-03-01 Filter insert, air cleaner, replace 2
25710-3 2571-03-03-01 Separator, crankcase ventilation, replace 1
25710-3 2571-03-03-01 Separator, crankcase ventilation, replace 2
25713-3 2571-03-03-02 Housing, separator crankcase ventilation upper, replace
25715-3 2571-03-03-04 Valve, separator crankcase ventilation, replace 1
25715-3 2571-03-03-04 Valve, separator crankcase ventilation, replace 2
25803-2 2589-03-02-01 AdBlue tank, replace 1
25803-2 2589-03-02-01 AdBlue tank, replace 2
25803-2 2589-03-02-01 AdBlue tank, replace 3
25803-2 2589-03-02-01 AdBlue tank, replace 4
25807-2 2581-03-02-01 Pump unit, replace 1
25807-2 2581-03-02-01 Pump unit, replace 2
25807-2 2581-03-02-01 Pump unit, replace 3
25809-2 2589-03-02-20 Aftertreatment control unit, replace
25811-2 2585-03-02-01 Dosage unit, replace 1
25811-2 2585-03-02-01 Dosage unit, replace 2
25813-1 2585-01-01-01 Dosage unit, remove 1
25813-1 2585-01-01-01 Dosage unit, remove 2
25814-1 2585-02-01-01 Dosage unit, install 1
25814-1 2585-02-01-01 Dosage unit, install 2
25815-2 2589-03-02-03 Exhaust temperature sensor, replace 1
25815-2 2589-03-02-03 Exhaust temperature sensor, replace 2
25815-2 2589-03-02-03 Exhaust temperature sensor, replace 3
25815-2 2589-03-02-03 Exhaust temperature sensor, replace 4
25820-4 2586-06-04-01 SCR catalytic converter, check 1
25820-4 2586-06-04-01 SCR catalytic converter, check 2
25821-2 2589-03-02-11 NOX Sensor and control module, replace
25822-2 2583-03-02-01 Filter, AdBlue, replace 1
25822-2 2583-03-02-01 Filter, AdBlue, replace 2
25822-2 2583-03-02-01 Filter, AdBlue, replace 3
25823-2 2583-03-02-02 Filter cover, urea, replace
25827-2 2589-03-02-05 Level sensor, tank, replace
25828-4 2589-03-04-01 Combined tank unit, replace 1
25828-4 2589-03-04-01 Combined tank unit, replace 2
25828-4 2589-03-04-01 Combined tank unit, replace 3
25832-2 2589-03-02-42 Aftertreatment diesel exhaust fluid (DEF) tank, filler neck insert, replace
25837-2 2589-03-02-10 NOX sensor, replace 1
25837-2 2589-03-02-10 NOX sensor, replace 2
25837-2 2589-03-02-10 NOX sensor, replace 3
25840-2 2589-03-02-07 Solenoid valve, heating AdBlue tank, replace 1
25840-2 2589-03-02-07 Solenoid valve, heating AdBlue tank, replace 2
25845-4 2583-03-04-01 Heating coil, AdBlue tank, replace
25848-3 2583-03-03-02 Strainer, replace 1
25848-3 2583-03-03-02 Strainer, replace 2
25858-4 2589-11-04-01 AdBlue tank, clean 1
25858-4 2589-11-04-01 AdBlue tank, clean 2
25862-2 2586-03-02-01 SCR catalytic muffler, replace 1
25862-2 2586-03-02-01 SCR catalytic muffler, replace 2
25862-2 2586-03-02-01 SCR catalytic muffler, replace 3
25865-2 2589-03-02-09 AdBlue hose, electrical heated, replace (At Tank)
25866-2 2586-03-02-02 Ox-catalytic muffler, replace 1
25866-2 2586-03-02-02 Ox-catalytic muffler, replace 2
25871-3 2584-03-03-01 Injector, aftertreatment, replace
25872-3 2589-03-03-03 Shut-off valve, fuel, replace
25878-2 2584-11-02-01 Injector, aftertreatment, clean
25880-2 2589-03-02-15 Shut-off Valve, injector, aftertreatment, replace
25883-3 2585-11-03-01 Dosage unit, clean
25885-4 2589-03-04-02 Pressure sensor, replace 1
25885-4 2589-03-04-02 Pressure sensor, replace 2
25886-4 2589-03-04-03 Temperature sensor, replace
25887-4 2589-03-04-04 Control valve, replace
25903-2 2589-03-02-41 Air shut-off valve, aftertreatment system, replace
25921-2 2589-18-02-04 Urea hoses, new install
25936-4 2582-03-04-01 Valve, replace
25937-4 2582-03-04-02 Heater, replace
25938-4 2582-03-04-03 Pump, replace 1
25938-4 2582-03-04-03 Pump, replace 2
25940-4 2582-03-04-04 Actuator, replace
26006-2 2609-06-02-01 Cooling system, pressure test
26007-3 2609-11-03-01 Cooling system, clean
26010-2 2609-03-02-01 Coolant, change
26011-2 2609-03-02-03 Coolant type, replace
26012-2 2609-03-02-02 Cooling system, drain and refill
26106-2 2611-11-02-01 Radiator, external cleaning
26108-2 2611-03-02-01 Radiator, replace 1
26108-2 2611-03-02-01 Radiator, replace 2
26108-2 2611-03-02-01 Radiator, replace 3
26108-2 2611-03-02-01 Radiator, replace 4
26202-2 2621-03-02-01 Coolant pump, replace 1
26202-2 2621-03-02-01 Coolant pump, replace 2
26202-2 2621-03-02-01 Coolant pump, replace 3
26202-2 2621-03-02-01 Coolant pump, replace 4
26202-2 2621-03-02-01 Coolant pump, replace 5
26202-2 2621-03-02-01 Coolant pump, replace 6
26214-2 2627-03-02-01 Piston thermostat, replace 1
26214-2 2627-03-02-01 Piston thermostat, replace 2
26273-4 2627-06-04-01 Thermostats, test
26304-2 2634-03-02-04 Drive belt, replace 1
26304-2 2634-03-02-04 Drive belt, replace 2
26306-2 2631-03-02-01 Thermostat fan, replace 1
26306-2 2631-03-02-01 Thermostat fan, replace 2
26306-2 2631-03-02-01 Thermostat fan, replace 3
26306-2 2631-03-02-01 Thermostat fan, replace 4
26307-3 2634-03-03-02 Drive belts fan, replace
26308-3 2634-03-03-04 Fan belt tensioner, replace 1
26308-3 2634-03-03-04 Fan belt tensioner, replace 2
26308-3 2634-03-03-04 Fan belt tensioner, replace 3
26313-2 2634-03-02-01 Fan belt tensioner, replace 2
26323-2 2639-03-02-01 Fan hub, replace 1
26323-2 2639-03-02-01 Fan hub, replace 2
26323-2 2639-03-02-01 Fan hub, replace 3
26323-2 2639-03-02-01 Fan hub, replace 4
26323-2 2639-03-02-01 Fan hub, replace 5
26323-2 2639-03-02-01 Fan hub, replace 6
26373-4 2639-03-04-01 Bearing, fan hub, replace
26375-2 2639-03-02-03 Fan belt idler pulley, replace
26502-2 2651-03-02-01 Charge air cooler, replace 1
26502-2 2651-03-02-01 Charge air cooler, replace 2
26514-3 2652-06-03-01 Charge air pipe, check
26515-3 2651-06-03-03 Charge air cooler, check
26531-3 2651-06-03-05 Charge air cooler, leakage test 1
26531-3 2651-06-03-05 Charge air cooler, leakage test 2
26531-3 2651-06-03-05 Charge air cooler, leakage test 3
28421-2 2841-03-02-03 Control unit, replace
28504-3 2846-03-03-02 Oil pressure sensor, piston cooling, replace 1
28506-2 2846-03-02-08 Crankcase pressure sensor, replace
28508-3 2846-03-03-03 Exhaust back pressure sensor, replace
28510-3 2841-03-03-04 Control unit, replace
28603-2 2861-03-02-01 Wiring harness, replace 1
28603-2 2861-03-02-01 Wiring harness, replace 2
28913-2 2841-03-02-04 Control unit, replace
28926-5 2846-03-05-01 Oil level sensor, replace 1
28926-5 2846-03-05-01 Oil level sensor, replace 2
29307-2 2934-11-02-02 EGR Venturi tube, clean 1
29307-2 2934-11-02-02 EGR Venturi tube, clean 2
29307-2 2934-11-02-02 EGR Venturi tube, clean 3
29307-2 2934-11-02-02 EGR Venturi tube, clean 4
29307-2 2934-11-02-02 EGR Venturi tube, clean 5
29307-2 2934-11-02-02 EGR Venturi tube, clean 6
29307-2 2934-11-02-02 EGR Venturi tube, clean 7
29320-2 2932-11-02-01 EGR cooler, clean 1
29320-2 2932-11-02-01 EGR cooler, clean 2
29321-4 2932-11-04-01 EGR cooler, clean
29322-2 2934-03-02-03 EGR Inlet pipe cooler, replace 1
29322-2 2934-03-02-03 EGR Inlet pipe cooler, replace 2
29323-2 2932-06-02-01 EGR cooler, pressure test 1
29323-2 2932-06-02-01 EGR cooler, pressure test 2
29327-2 2939-03-02-02 EGR Temperature sensor, replace 1
29327-2 2939-03-02-02 EGR Temperature sensor, replace 2
29327-2 2939-03-02-02 EGR Temperature sensor, replace 3
29328-3 2931-03-03-01 EGR valve, replace 2
29328-3 2931-03-03-01 EGR valve, replace 3
29338-3 2933-03-03-01 Mixing chamber EGR, replace
29343-1 2937-01-01-02 EGR Venturi tube, remove 1
29343-1 2937-01-01-02 EGR Venturi tube, remove 2
29344-1 2937-02-01-02 EGR Venturi tube, install 1
29344-1 2937-02-01-02 EGR Venturi tube, install 2
29345-3 2937-03-03-01 EGR Venturi tube, replace 1
29345-3 2937-03-03-01 EGR Venturi tube, replace 2
29365-2 2932-18-02-01 EGR cooler, new install
31102-2 3111-03-02-01 Batteries, replace (all) 1
31102-2 3111-03-02-01 Batteries, replace (all) 2
31310-2 3131-03-02-01 Battery box, replace 1
31311-2 3131-03-02-06 Front battery box, replace 1
31311-2 3131-03-02-06 Front battery box, replace 2
31312-2 3131-03-02-07 Rear battery box, replace 1
31312-2 3131-03-02-07 Rear battery box, replace 2
31313-2 3131-03-02-08 Rubber bushings, front battery box, replace 1
31313-2 3131-03-02-08 Rubber bushings, front battery box, replace 2
31314-2 3131-03-02-09 Rubber bushings, rear battery box, replace
32002-2 3211-06-02-01 Charging test, in vehicle
32011-3 3211-06-03-01 Charging test in vehicle
32101-2 3211-03-02-01 Alternator, replace 1
32122-2 3219-03-02-01 Alternator drive belt, replace
32173-5 3212-03-05-01 Pulley, replace
32204-3 3221-03-03-01 Charging regulator, replace
33106-2 3311-03-02-01 Starter motor, replace
33115-2 3649-03-02-18 Jump start, replace
33316-2 3645-03-02-01 Relay, starting element, replace
33446-2 3340-03-02-01 Control unit, alco lock, replace
33448-2 3340-02-02-01 Alcolock, activation
35131-2 3513-03-02-01 High intensity discharge bulb, replace 1
35131-2 3513-03-02-01 High intensity discharge bulb, replace 2
35132-2 3513-03-02-02 Ignition loop high intensity discharge bulb, replace 1
35132-2 3513-03-02-02 Ignition loop high intensity discharge bulb, replace 2
35202-2 3521-05-02-01 Headlights, adjust
35210-4 3522-03-04-01 Circuit board, headlamp, replace
35222-2 3526-03-02-01 Lamp cluster complete, replace
35225-2 3520-03-02-01 Bushings, headlamp assembly, replace
35245-2 3521-03-02-09 Reflector, indicator lamp, replace (one)
35251-2 3521-03-02-02 Headlamp complete, replace (left hand side)
35252-2 3521-03-02-05 Headlamp complete, replace (right hand side)
35260-2 3521-03-02-10 Reflector, headlamp full dipped beam, replace (one)
35264-2 3521-03-02-08 Reflector, headlamp fog spotlight, replace (one) 1
35264-2 3521-03-02-08 Reflector, headlamp fog spotlight, replace (one) 2
35268-2 3561-05-02-01 Headlamp, adjust (fog lamp)
35270-2 3521-16-02-01 Head lamp, rebuild (right hand side)
35271-2 3521-16-02-02 Head lamp, rebuild (left hand side)
35272-2 3529-03-02-01 Wiring support bracket, replace
35641-2 3561-03-02-02 Fog lamp, replace
36201-2 3621-03-02-04 Air horn, replace
36204-2 3623-03-02-05 Slip contact, signal ring, replace 1
36204-2 3623-03-02-05 Slip contact, signal ring, replace 2
36314-2 3639-03-02-12 Rain sensor, replace
36405-2 3646-03-02-19 Switch, window lift, replace
36407-2 3645-03-02-12 Power relay, main switch, replace 1
36407-2 3645-03-02-12 Power relay, main switch, replace 2
36417-2 3645-03-02-13 Control unit, main switch, replace 2
36417-2 3645-03-02-13 Control unit, main switch, replace 3
36417-2 3645-03-02-13 Control unit, main switch, replace 4
36434-2 3646-06-02-06 Switch, feed pump drainage valve, check
36447-2 3646-03-02-10 Main switch, replace
36495-2 3649-03-02-09 Switch steering wheel buttons, replace
36655-2 3665-03-02-12 Bracket, camera, lane keeping system, replace
36666-2 3665-03-02-14 Indicator lamp, LCS system, replace
36672-2 3665-03-02-07 Control unit, adaptive cruise control, replace 1
36672-2 3665-03-02-07 Control unit, adaptive cruise control, replace 2
36672-2 3665-03-02-07 Control unit, adaptive cruise control, replace 3
36673-2 3665-03-02-08 Yaw rate sensor and power supply unit, ACC, replace 1
36673-2 3665-03-02-08 Yaw rate sensor and power supply unit, ACC, replace 2
36673-2 3665-03-02-08 Yaw rate sensor and power supply unit, ACC, replace 3
36673-2 3665-03-02-08 Yaw rate sensor and power supply unit, ACC, replace 4
36678-2 3669-03-02-02 Antenna ring, replace
36685-2 3665-03-02-09 Camera, lane keeping system, replace
36686-2 3665-03-02-10 Control unit, lane keeping system, replace
36687-2 3665-03-02-11 Control unit DACU, gateway, replace 1
36687-2 3665-03-02-11 Control unit DACU, gateway, replace 2
37130-2 3719-03-02-01 Trailer connection, replace
37205-2 3721-03-02-01 Fuse and relay center, replace
37303-2 3730-03-02-01 Cable harness, headlamp, replace
38168-2 3811-03-02-10 Instrument complete, replace
38172-2 3811-03-02-12 Glass, instrumentation, replace
38305-6 3839-06-06-01 K-factor, check
38306-2 3835-03-02-01 Tachograph, replace 1
38306-2 3835-03-02-01 Tachograph, replace 2
38306-2 3835-03-02-01 Tachograph, replace 3
38602-2 3868-03-02-01 Sensor ampere gauge, replace
38606-2 3864-03-02-01 Sensor air pressure, replace 1
38606-2 3864-03-02-01 Sensor air pressure, replace 2
38626-2 3862-18-02-01 Fuel tank gauge sender, new install 1
38626-2 3862-18-02-01 Fuel tank gauge sender, new install 2
38626-2 3862-18-02-01 Fuel tank gauge sender, new install 3
39417-2 3942-18-02-02 Telephone fan, new install
39423-1 3949-02-01-01 Mobile telephone relay, install
39513-1 3956-01-01-01 Booster, remove
39514-1 3956-02-01-01 Booster, install
39546-2 3959-03-02-01 Voltage converter, replace 1
39546-2 3959-03-02-01 Voltage converter, replace 2
39546-2 3959-03-02-01 Voltage converter, replace 3
39708-2 3979-03-02-04 Display, replace 1
39708-2 3979-03-02-04 Display, replace 2
39712-2 3979-03-02-05 Dynafleet GPS antenna, replace
39713-2 3979-03-02-07 RDS TMC Antenna, replace
39714-2 3979-03-02-08 RDS TMC Receiver, replace
39716-2 3979-03-02-12 Control unit, tracking system, replace
39731-2 3979-03-02-11 Dynafleet Gateway, replace
39748-2 3979-03-02-10 Control unit, FMS gateway, replace
39792-2 3970-03-02-22 Telematic gateway, replace
39801-2 3989-16-02-01 Control unit TESP, replace
40151-2 4320-03-02-07 Electronic control unit (ECU) gear selector, replace
40167-4 4320-03-04-01 Pressure sensor, control housing, replace
40168-2 4322-03-02-03 Insulating plate, gear lever carrier, replace
41103-3 4117-03-03-01 Clutch disc, replace 3
41103-3 4117-03-03-01 Clutch plate, replace 1
41103-3 4117-03-03-01 Clutch plate, replace 2
41103-3 4117-03-03-01 Clutch plate, replace 3
41103-3 4117-03-03-01 Clutch plate, replace 4
41104-3 4111-06-03-02 Clutch, wear check 1
41104-3 4111-06-03-02 Clutch, wear check 2
41183-2 4119-03-02-01 Valve assembly, clutch, replace
41184-4 4111-03-04-03 Position sensor, clutch, replace
41204-3 4129-03-03-02 Bearing clutch fork, replace 1
41204-3 4129-03-03-02 Bearing clutch fork, replace 2
41283-5 4121-03-05-02 Release bearing, pulling clutch replace 1
41283-5 4121-03-05-02 Release bearing, pulling clutch replace 2
41301-3 4134-05-03-01 Clutch pedal stroke, adjust
41314-2 4134-03-02-03 Clutch cylinder, replace 1
41314-2 4134-03-02-03 Clutch cylinder, replace 2
41320-3 4134-03-03-01 Clutch cylinder, replace
41322-2 4136-04-02-01 Master cylinder for clutch complete, overhaul
41336-2 4134-18-02-01 Clutch servo, new install
41342-2 4139-05-02-01 Clutch system, bleed
41375-4 4134-04-04-01 Clutch servo, overhaul 1
43110-2 4313-03-02-01 Bearing, output shaft, replace
43130-2 4339-03-02-01 Output shaft sealing ring, replace
43131-4 4317-03-04-01 Sealing ring input shaft, replace 2
43131-4 4317-03-04-01 Sealing ring input shaft, replace 1
43133-1 4319-01-01-02 Oil filter housing, gearbox, remove 1
43133-1 4319-01-01-02 Oil filter housing, gearbox, remove 2
43134-1 4319-02-01-02 Oil filter housing, gearbox, install 1
43134-1 4319-02-01-02 Oil filter housing, gearbox, install 2
43135-3 4319-03-03-01 Oil filter gearbox, replace
43141-5 4319-04-05-01 Oil pump, overhaul
43156-2 4319-06-02-01 Splitter gear, check and adjust
43164-2 4328-04-02-01 Split cylinder, overhaul
43170-1 4311-01-01-01 Gearbox, remove 1
43170-1 4311-01-01-01 Gearbox, remove 2
43170-1 4311-01-01-01 Gearbox, remove 3
43170-1 4311-01-01-01 Gearbox, remove 4
43173-5 4313-04-05-01 Main shaft, overhaul 1
43173-5 4313-04-05-01 Main shaft, overhaul 2
43173-5 4313-04-05-01 Main shaft, overhaul 3
43173-5 4313-04-05-01 Main shaft, overhaul 4
43175-5 4319-04-05-02 Range gear, overhaul 1
43175-5 4319-04-05-02 Range gear, overhaul 2
43175-5 4319-04-05-02 Range gear, overhaul 3
43175-5 4319-04-05-02 Range gear, overhaul 4
43185-5 4313-05-05-01 Main shaft and countershaft, adjust
43186-2 4322-03-02-01 Cable gear selector, replace
43188-2 4322-03-02-02 Cable side control, replace
43195-5 4313-04-05-03 Reverse shaft, overhaul
43197-5 4313-04-05-04 Input shaft, overhaul 1
43197-5 4313-04-05-04 Input shaft, overhaul 2
43208-2 4321-03-02-02 Gear selector, replace
43222-1 4329-01-01-01 Control housing, remove 1
43222-1 4329-01-01-01 Control housing, remove 2
43224-1 4329-02-01-01 Control housing, install 1
43224-1 4329-02-01-01 Control housing, install 2
43231-4 4329-03-04-02 Speed sensor and cable harness, replace
43262-4 4329-03-04-03 Brasspin selector fork, replace (all)
43266-2 4319-04-02-01 Range cylinder, overhaul
43270-1 4321-01-01-01 Gear selector, remove
43271-4 4329-03-04-05 Upper cover, control housing, replace (complete)
43272-1 4321-02-01-01 Gear selector, install
43278-4 4329-04-04-05 Control housing, overhaul 1
43278-4 4329-04-04-05 Control housing, overhaul 2
43278-4 4329-04-04-05 Control housing, overhaul 3
43410-4 4341-13-04-01 Transfer gearbox, Disassemble
43412-4 4341-14-04-01 Transfer gearbox, Assemble
43421-1 4341-01-01-01 Transfer gearbox, remove
43422-1 4341-02-01-01 Transfer gearbox, install
43715-1 4376-02-01-01 Control system, install
43744-4 4379-04-04-02 Clutch housing 1, overhaul
43760-4 4379-04-04-05 Clutch housing 2, overhaul
43768-4 4379-03-04-02 Bushing sun gear, replace
43780-4 4379-03-04-03 Bushing planetary gear carrier, replace
43782-4 4379-03-04-04 Bushing planetary gear carrier 2, replace
43786-5 4379-03-05-09 Bearing intermediate gear PTO, replace
59203-3 5929-04-03-01 Air vent valve, overhaul
59206-3 5929-06-03-01 Air vent valve, check
59212-2 5922-03-02-01 Control valve, replace 1
59212-2 5922-03-02-01 Control valve, replace 2
59215-5 5921-06-05-01 Retarder heat exchanger, pressure test
59227-3 5929-11-03-01 Retarder sinter-filter, clean
59253-4 5920-03-04-01 Rotor and stator kit, replace
59270-1 5921-01-01-01 Retarder, remove 1
59270-1 5921-01-01-01 Retarder, remove 2
59272-1 5921-02-01-01 Retarder, install 1
59272-1 5921-02-01-01 Retarder, install 2
59274-1 5929-01-01-01 Retarder heat exchanger, remove 1
59274-1 5929-01-01-01 Retarder heat exchanger, remove 2
59276-1 5929-02-01-01 Retarder heat exchanger, install 1
59276-1 5929-02-01-01 Retarder heat exchanger, install 2
59282-2 5929-03-02-03 Sensor, oil temperature, replace
59284-2 5929-03-02-04 Sensor, water temperature, replace
59286-2 5929-03-02-05 Pressure sensor, replace
59298-2 5921-16-02-01 Pressure sensor, retarder, modification 1
59310-5 5939-03-05-01 Sensor wheel, replace 1
59310-5 5939-03-05-01 Sensor wheel, replace 2
59332-2 5931-03-02-02 EBS control unit, replace 1
59332-2 5931-03-02-02 EBS control unit, replace 2
59335-5 5939-03-05-02 Sensor wheel, replace 1
59335-5 5939-03-05-02 Sensor wheel, replace 2
59335-5 5939-03-05-02 Sensor wheel, replace 3
59336-2 5939-03-02-08 Solenoid control valve, replace 1
59336-2 5939-03-02-08 Solenoid control valve, replace 2
59336-2 5939-03-02-08 Solenoid control valve, replace 3
59338-3 5939-03-03-01 Wheel speed sensor, replace 1
59338-3 5939-03-03-01 Wheel speed sensor, replace 2
59338-3 5939-03-03-01 Wheel speed sensor, replace 3
59348-2 5939-03-02-09 Wheel speed sensor, front, replace
59350-2 5939-03-02-02 Wheel speed sensor, replace (rear axle) 1
59350-2 5939-03-02-02 Wheel speed sensor, replace (rear axle) 2
59363-2 5939-03-02-07 Wheel speed sensor, replace (tag axle)
59365-2 5931-03-02-08 Sensor, yaw rate, replace
59373-3 5931-03-03-01 Steering angle sensor, replace 1
59373-3 5931-03-03-01 Steering angle sensor, replace 2
60108-2 6010-06-02-07 Wheel alignment, check
60113-3 6010-05-03-08 Curve angles, one axle, adjust
60115-3 6010-05-03-09 Curve angles, two axles, adjust
60121-3 6010-06-03-01 Wheel angles, check (All)
60131-3 6010-05-03-01 Toe-in, adjust 1
60131-3 6010-05-03-01 Toe-in, adjust 2
60131-3 6010-05-03-01 Toe-in, adjust 3
61114-2 6113-05-02-01 King pin journalling, adjust (one side) 1
61114-2 6113-05-02-01 King pin journalling, adjust (one side) 2
Cable grommet cab
Cable repair
Clutch plate, marking
Disassembly instructions, complete vehicle
Dynafleet, checklist before replacement
Fan speed, check
Front axle
Gear selector, modification
Load Indicator, calibration
Safety regulations 1
Safety regulations 2
Split gear, jump out
Splitter valve, operation check
Stop when gear shifting from first to second gear
Transmission control unit, programming
