Martin Welker
104
230,310
Volvo Tracked Paver PF6160 Service and Repair Manual
Brand: Volvo
Type of Machine: Tracked Paver
Type of Manual: Service and Repair Manual, Hydraulic and Electrical Diagrams
Model: Volvo PF6160 Tracked Paver
Number of Pages: 4904 Pages
Volvo PF6160
Description
Conversion tables
Description, complete machine
Diesel fuels - quality and function
Diesel fuels - quality and function1
Engine, description
Failure Mode
Fault code list
Fault tracing information
Fuel system, description
Fuel, lubricant and filling capacities
Hopper, installing
Hopper, removing
Hydraulic oil, specifications
Hydraulic system, description
Lubricant recommendation
Lubrication and oil system, general specifications
Machine identification
Overview of controls in operator's cab
Thread locking compound, application specifications
Diagrams
Component list, Control and warning lights
Component list, Diodes
Component list, instruments
Component list, lights
Component list, Miscellaneous
Component list, resistors
Component list, sensors
Component list, Sounders
Component list, Switches
Hydraulic diagram 1
Hydraulic diagram 1 Figure1
Hydraulic diagram 2
Hydraulic diagram 2 Figure1
Hydraulic diagram 3
Hydraulic diagram 3 Figure1
Hydraulic diagram 4
Hydraulic diagram 4 Figure1
Hydraulic diagram 5
Hydraulic diagram 5 Figure1
Hydraulic diagram 6
Hydraulic diagram 6 Figure1
Hydraulic diagram 7
Hydraulic diagram 7 Figure1
Hydraulic diagram 8
Hydraulic diagram 8 Figure1
Hydraulic diagram 9
Hydraulic diagram 9 Figure1
Hydraulic diagram 10
Hydraulic diagram 10 Figure1
Hydraulic diagram 11
Hydraulic diagram 11 Figure1
Hydraulic diagram 12
Hydraulic diagram 12 Figure1
Hydraulic diagram 13
Hydraulic diagram 13 Figure1
Hydraulic diagram 14
Hydraulic diagram 14 Figure1
Wiring diagram 1
Wiring diagram 2 Figure1
Wiring diagram 2
Wiring diagram 3
Wiring diagram 3 Figure 1
Wiring diagram 4
Wiring diagram 4 Figure1
Wiring diagram 5
Wiring diagram 5 Figure1
Wiring diagram 6
Wiring diagram 6 Figure1
Wiring diagram 7
Wiring diagram 7 Figure1
Wiring diagram 8
Wiring diagram 8 Figure1
Wiring diagram 9
Wiring diagram 9 Figure1
Wiring diagram 10
Wiring diagram 10 Figure1
Wiring diagram 11
Wiring diagram 11 Figure1
Wiring diagram 12
Wiring diagram 12 Figure1
Wiring diagram 13
Wiring diagram 13 Figure1
Wiring diagram 14
Wiring diagram 14 Figure1
Wiring diagram 15
Wiring diagram 15 Figure1
Wiring diagram 16
Wiring diagram 16 Figure1
Wiring diagram 17
Wiring diagram 17 Figure1
Wiring diagram 18
Wiring diagram 18 Figure1
Wiring diagram 19
Wiring diagram 19 Figure1
Wiring diagram 20
Wiring diagram 20 Figure1
Wiring diagram 21
Wiring diagram 21 Figure1
Installation Instruction
6 foot auger extension, installing new
8 foot auger extension, installing new
10 foot auger extension, installing new
12 foot auger extension, installing new
14 foot auger extension, installing new
16 foot auger extension, installing new
Conveyor floor plate conversion kit, installing new
Flow gates, installing new
General purpose valve rework kit, installing new
Truck hitch, installing new
Repair
0 General
1 Standard Parts, Service
2 Engine with Mounting & Equipment
3 Elect. Warning, Information, Instruments
4 Power Transmission
6 Steering
7 Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit
8 Machinery House, Cab, Exterior Trim Parts
9 Hydraulic, Digging, Handling, Grading Equipment, Misc
Safety
A few simple safety rules
Before operating
Before service, read
Charging batteries
Cleanliness
Decontamination
Electrical system
Environment
General
Safety concerns everybody!
Safety when handling oil and fuel
Safety when lifting and supporting the machine
Safety when working with batteries1
Safety when working with batteries2
Service positions
Some simple rules regarding tyre handling
Welding and grinding work
Service Bulletins
30 kW Alternator spline greasing
6000 Series Paver - rear GP tunnel circuit
6000 series paver light tower issues
Auger bearing installation procedure
Auger box slide bushings
Auger Tunnel Weld Repair
Biodiesel fuel for Volvo CE
Check method on engine oil consumption
Cold start device, description
Comer planetary seal upgrade
Conveyor Harness Resistor
Conveyor Sensor Wire Harness Routing
Conveyor System Conversion Kit
Door bushing replacement
Extra resistor in console harness
Fan pump flange gasket installation procedure
Flow gate option available
Fuel sampling, method
General System Software Update
Hard engine starting Auger conveyor pump de-stroking
Hopper chatters while lowering
Hydraulic Filter Installation Procedure
Hydraulic oil dye
Lifting and lowering function
Murphy display adjustments
New 6000 series paver auger flight w bearing cover
New arm rest
New fastener assortment
New replacement battery and battery hold down
New service analyzer program available
New style door holder availability
PF6000 Series Junction box Controller Changes
Preservation
Reports
Secondary approved hood latch option
Serial number location on machine components
Software Distribution Procedure
Tow arm rollers
Tow Point Hose Pulsation
Tow Point Valve Adjustment
Water in the auger box
Special Tools, Misc
Inspection Programme, Arrival Inspection PAW PUB20038980
Inspection Programme, Delivery Inspection PAW PUB20037867
Inspection Programme, Delivery Instructions PAW PUB20037884
Inspection Programme, Maintenance of Stored Machines PAW PUB20037901
Pavers Inspection Instructions
Pavers Report
Special tool Manual
Special Tools Recommendations
Time Guide Currrent generation
Time Guide Old generation
Specifications
Alternative fuels
Critical mounting torques
Hydraulic connections, tightening torques
Hydraulic cylinder specifications
Hydraulic cylinder specifications1
Hydraulic cylinder specifications2
Hydraulic cylinder, description
Hydraulic cylinder, description1
Hydraulic motor, specifications
Hydraulic motor, specifications1
Hydraulic motor, specifications2
Hydraulic motor, specifications3
Hydraulic motor, specifications4
Hydraulic motor, specifications5
Hydraulic pumps, specifications
Hydraulic pumps, specifications1
Hydraulic pumps, specifications2
Hydraulic pumps, specifications3
Hydraulic pumps, specifications4
Hydraulic pumps, specifications5
Hydraulic pumps, specifications6
Hydraulic system, specifications
Recommended lubricants
Tightening torque, specifications1
Tightening torque, specifications2
