Martin Welker
104
230,310
Volvo Skid Steer Loader MC95C Service and Repair Manual
Brand: Volvo
Type of Machine: Skid Steer Loader
Type of Manual: Electrical and Hydraulic Diagrams, Service and Repair Manual
Model: Volvo MC95C Skid Steer Loader
Number of Pages: 4291 Pages
1 Volvo MC95C
Description
Battery isolator
Collection of basic data
Description, complete machine
Drive motor, description
Drive motor, description1
Electronic control unit (ECU), description
Explanation of wiring diagrams
Explanations to hydraulic diagram
Fan reversing valve, description
Fault code list
Fault tracing on hydraulic system
Fuses
Gear pump, description
Gear pump, description1
Hydraulic contamination
Hydraulic cylinders, description
Hydraulic service procedures
Main control valve, description
Main valve block, description
Maintenance service, daily
Maintenance service, every 50 hours
Maintenance service, every 2000 hours
Multimeter
Operator's platform, lowering
Operator's platform, raising
Relays
Road lights, description
Self level valve, description
Service position 1
Service position 2
Throttle control
Transmission circuit, description
Transmission pumps, description
Troubleshooting, general
Windows, general
Wire and harness identification
Diagrams
Component list, Fuses1
Component list, Fuses2
Component list, Miscellaneous1
Component list, Miscellaneous2
Component list, Motors1
Component list, Motors2
Component list, Relays1
Component list, Relays2
Component list, Sensors1
Component list, Sensors2
Component list, Solenoid valves1
Component list, Solenoid valves2
Component list, Switches1
Component list, Switches2
Hydraulic diagram1
Hydraulic diagram2
Wiring diagram 1-1
Wiring diagram 1-2
Wiring diagram 2-1
Wiring diagram 2-2
Wiring diagram 3-1
Wiring diagram 3-2
Wiring diagram 4-1
Wiring diagram 4-2
Wiring diagram 5-1
Wiring diagram 5-2
Wiring diagram 6-1
Wiring diagram 6-2
Wiring diagram 7-1
Wiring diagram 7-2
Wiring diagram 8-1
Wiring diagram 8-2
Wiring diagram 9-1
Wiring diagram 9-2
Wiring diagram 10-1
Wiring diagram 10-2
Wiring diagram 11
Wiring diagram 12
Installation Instruction
Air conditioning kit, installing new
Air conditioning kit, installing new1
Attachment bracket, installation
Attachment bracket, installation1
Auxiliary hydraulic option, installing new
Boom suspension system, installing new
Cab sealing kit, installing new
Cab, installing
Cab, installing1
CareTrack, installing new
Door guard kit, installing new
Foot throttle control kit, installing new
FOPS (Falling Object Protecting Structure), installing new
Front screen guard kit, installing new
Lexan(TM) front screen kit, no wiper, installing new
Multi-function joystick kit, installing new
Right hand screen guard kit, installing new
Road lights kit, right hand dip, installing new
Road lights kit, right hand dip, installing new1
Smooth ride system kit, installing new
Repair
Air cleaner dust valve, changing1
Air cleaner dust valve, changing2
Air cleaner inner element, changing
Air cleaner inner element, replacing
Air cleaner outer element, changing
Air cleaner outer element, replacing
Air conditioning filters, changing1
Air conditioning filters, changing2
Alternator belt, checking
Alternator, installing
Alternator, removing
Alternator, testing
Attachment bracket cylinder, installing
Attachment bracket cylinder, removing
Axle hub, installing
Axle hub, removing
Battery isolator, checking
Battery, maintenance1
Battery, maintenance2
Battery, replacing
Boom suspension system accumulator, charging
Boom suspension system accumulator, discharging
Cab door, installing
Cab door, removing
Cab, installing
Cab, removing
Cleaning of the machine
Compressor belt, checking
Coolant level, checking
Coolant, changing
Coolant, draining
Coolant, filling
Cooling package, installing
Cooling package, removing
Door handle, replacing
Drain line screen filter adapter, replacing
Drive chain case oil level, checking1
Drive chain case oil level, checking2
Drive chain case oil, changing1
Drive chain case oil, changing2
Drive chain, installing
Drive chain, removing
Drive motor, installing
Drive motor, installing1
Drive motor, removing
Drive motor, removing1
Engine air cleaner system integrity, checking
Engine oil filter, replacing1
Engine oil filter, replacing2
Engine oil level, checking
Engine oil, changing
Engine oil, draining
Engine oil, filling
Engine, installing
Engine, installing1
Engine, removing
Engine, removing1
Front end accessory drive (FEAD) belt condition, checking
Front end accessory drive (FEAD) belt, adjusting
Front end accessory drive (FEAD) belt, replacing
Front idler wheel, assembling
Front idler wheel, disassembling
Fuel filter element, changing
Fuel filter element, replacing
Fuel system, bleeding
Fuel system, bleeding1
Fuel system, bleeding2
Fuel water separator, draining1
Fuel water separator, draining2
Fuel water separator, replacing
Gear pump, installing
Gear pump, installing1
Gear pump, removing
Gear pump, removing1
Greasing, daily1
Greasing, daily2
Guide roller, assembling
Guide roller, disassembling
Hydraulic cylinders, checking
Hydraulic oil charge filter, replacing
Hydraulic oil level, checking
Hydraulic oil return filter, replacing
Hydraulic oil tank breather filter, replacing
Hydraulic oil tank, draining1
Hydraulic oil tank, draining2
Hydraulic oil tank, filling1
Hydraulic oil tank, filling2
Hydraulic oil tank, installing
Hydraulic oil tank, removing
Hydraulic oil, changing1
Hydraulic oil, changing2
Hydraulic pressure, testing
Hydraulic return filter, replacing
Hydraulic screen filter adapter, replacing
Hydraulic service procedures1
In-line fuel filter, changing
Loader arm lift cylinder, removing
Loader arm, installing
Loader arm, removing
Main control valve, installing
Main control valve, removing
Maintenance service, every 500 hours
Maintenance service, every 500 hours1
Maintenance service, every 1000 hours
Maintenance service, every 1000 hours1
Maintenance service, every 1500 hours
Radiator and coolers, cleaning1
Radiator and coolers, cleaning2
Rear door, installing
Rear door, removing
Rear idler wheel, assembling
Rear idler wheel, disassembling
Self level valve, replacing
Service and Maintenance Introduction
Spark arrester, cleaning
Starter motor, installing
Starter motor, removing
Starter motor, testing
Stop pad, adjusting
Stop pad, adjusting1
Track tension, adjusting
Transmission pump, adjusting
Transmission pump, installing
Transmission pump, removing
Tyre, replacing
Tyres, checking air pressure
Tyres, wear and air pressure, checking
Wheel nuts torque, checking
Window pane, installation
Window pane, removal
Safety
A few simple safety rules
Before operating
Before service, read
Charging batteries
Cleanliness
Electrical system
General
Safety concerns everybody!
Safety when handling oil and fuel
Safety when lifting and supporting the machine
Service position
Service Bulletins
Air conditioning charge weights
Bucket, not level
C Series Line Bore Procedure
Cab door leak
Cab gas strut configuration
CareTrack Telematics system
Cleaning of engine compartment
ECU trouble shooting
Front Stop Pad and Centering Cup Shimming
Fuel sampling, method
Gauge to check attachment fitting
Improved Cab Door Sealing
Improved ignition switch
Improved lap bar
Improved top glass skylight seal
Left Hand Armrest Rotation
Loader and transmission control characteristics
Loader Arm Shimming
Loose wheel drive motor bolts and or leaks
New joystick stud with 25° angle
New Magnetic Flywheel Speed Sensor
New Skid Steer Loader models
New Skid Steer Loader models1
Oil ejected from exhaust system
Optional precleaner available
Paint fade and or color differences
Poor window adhesive
Rapid Assembly Hoses
Reporting of accidents and incidents
Reports
Required parts for C Series SSL service tool
Revised software for enhanced drive response
Small platform loader and transmission setup
Straight line travel adjustment
Tilt cylinder rod scoring
Top Window Leak
Updated Boom Guide and Stop Block
Wind screen washer bottle leaks
Window cracks and or breaks
Special Tools, Misc
GRD G700B LabourTimeGuide
Recommended Special Tools
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG
Special tool catalog
Time Guide Currrent generation
Time Guide Old generation
Specifications
Air conditioning, specifications
Boom suspension system (BSS) valve block, specifications
Boom suspension system (BSS) valve block, specifications1
Boom suspension system accumulator (BSS), specifications
Charge pump, specifications
Charge pump, specifications1
Conversion tables
Coolant, specifications
Engine, specification2
Engine, specification3
Engine, specifications1
Engine, specifications2
Fuel, lubricant and filling capacities
Fuel, specifications
Hydraulic connections, tightening torques1
Hydraulic connections, tightening torques2
Hydraulic cylinders, specifications
Hydraulic return line filter, specification
Hydraulic tank, specifications
Hydraulic tank, specifications1
Lights, specifications
Loader pump, specifications
Loader pump, specifications1
Main control valve, specifications
Main control valve, specifications1
Main valve block, specifications
Positional adapters
Push lock fittings
Quick release couplings1
Quick release couplings2
Radio, specifications
Radio, specifications1
Radio, specifications2
Rapid assembly fittings
Recommended lubricants
Return line filter, specifications
Self levelling valve, specifications
Self levelling valve, specifications1
Tightening torque, specifications
Transmission pump, specifications
Transmission pump, specifications1
Transmission pump, specifications2
Tyres, specifications
