Martin Welker
104
230,792
Volvo Skid Steer Loader MC70C Service and Repair Manual
Brand: Volvo
Type of Machine: Skid Steer Loader
Type of Manual: Electrical and Hydraulic Diagrams, Service and Repair Manual
Model: Volvo MC70C Skid Steer Loader
Number of Pages: 4213 Pages
1 Volvo MC70C
Description MC70C
Air cleaner restriction light, description
Air cleaner restriction switch, description
Alternator light, description
Alternator, description
Alternator, test
Attachment bracket, description
Attachment tilt spool control, with optional self level, description
Attachment tilt spool control, without optional self level, description
Auxiliary hydraulic cable, inspection
Auxiliary hydraulic cable, installation
Auxiliary hydraulic cable, removal
Auxiliary hydraulic system control, description
Auxiliary Spool Control, description
Axle assembly, axle sprocket and drive sprocket, description
Back-up alarm, operation
Battery, safety
Bearings
Charge implement pump, description
Charge pump, MC70 with optional 'High flow', description
Charge pump, MC70 with optional 'High flow', description1
Cleaning prior to repair
Component terminology
Control lockout (lift and tilt functions), description
Control lockout solenoid valve (lift and tilt functions) description
Control Terminology
Coolant with anti-freeze and corrosion protection
Cooling system, description
Description, complete machine
Disclaimer
Driver's seat, description
Drivetrain component terminology
Drivetrain, description and operation
Electrical system, special instructions for servicing, actions when working on machine
Electrical system, special instructions for servicing, electrical components, alternator and charging regulator
Electrical system, special instructions for servicing, electrical components, batteries
Electrical system, special instructions for servicing, general
Electrical troubleshooting
Engine Crankcase oil, specification
Engine Crankcase oil, specification1
Engine manufacturer manuals
Engine oil pressure light, description
Engine oil pressure switch, description
Engine shut down solenoid, description
Engine water temperature light, description
Engine water temperature switch, description
Exhaust system, description
Extending attachment tilt cylinder circuit
Final drive components, Model MC60 and MC70, description
Foot pedal, cable removal
Frame and track unit, description
Fuel gauge, description
Fuel system, description
Fuel system, specifications
Fuel system, specifications1
Fuses, specification
Fuses
General part replacement
Grounding points (chassis ground)
High flow couplers, description
High flow electrical system, description and operation
High flow gauge, description
High flow hydraulic supply, return and cooling circuits, MC70 optional 'High flow' only
High flow switch, description
High flow system (optional), description
High flow system hydraulic circuit
High flow system wiring harness
High flow system wiring harness1
Hoses and tubes
Hourmeter, operation
Hydraulic circuit
Hydraulic cylinders, description
Hydraulic oil cooler, description
Hydraulic oil filter restriction light, description
Hydraulic oil temperature light, description
Hydraulic oil temperature switch, description
Hydraulic system oil contamination
Hydraulic system oil contamination1
Hydraulic testing schedule
Hydrostatic drive, specification
Hydrostatic drive, specification1
Ignition switch, description and operation
Ignition switch, testing
Implement High flow pump, description
Loader arm cylinder retracting circuit
Loader arm spool control, with optional self level, description
Loader arm spool control, without optional self level, description
Machine hydraulic circuits, MC60, MC70 with self level valve
Machine hydraulic circuits, MC60, MC70 wo optional self level
Machine hydraulic circuits, MC70 with optional 'High flow' wo optional self level
Main control valve, description
Main hydrostatic travel control pump, description
Main hydrostatic travel control pump, description1
Main relief valve, description
Manual lifting of loader arm
Neutral centring and control lever adjustment
Neutral centring test
Operator's protective structure, tilt position
Optional auxiliary hydraulic cable, installation
Optional auxiliary hydraulic cable, removal
Optional auxiliary hydraulic pedal lock control
Park lock pin, inspection
Park lock, inspection
Park lock, operation
Parking lock, troubleshooting
Power train, specification
Pressure testing
Radiator pressure cap, description
Recommended lubricants
Replacement parts
Restraint bar, inspection
Retracting attachment tilt cylinder circuit
Self level valve, description
Service methods
Service
Standard tightening torques
Throttle Control Description
Transmission drive assembly, description
Transporting and lifting the machine
Travel hydraulics, troubleshooting
Travel motor, description
Travel motor, operation
Travel Steering Levers, description
Travel system, hydraulic components, description
Travel system, mechanical drive components, description
Warning lights test Worklight switch
Warning lights, general
Wrist control cable, installation and adjustment
Wrist control cable, removal
Wrist hydraulic controls (optional), description
Diagrams MC70C
Hydraulic schematic MC60, MC70 wo Self level
Hydraulic schematic MC60,MC70 wSelf level
Hydraulic schematic MC70, with optional 'High flow', wo Self level
Hydraulic schematic MC70, with optional 'High flow', wSelf level
Wiring diagram M01
Wiring diagram M02
Wiring diagram M03
Wiring diagram M04
Wiring diagram M05
Wiring diagram M06
Installation Instruction MC70C
Automatic stop
Care Track
Care Track1
Care Track2
Care Track3
Clearner
Heater Engine
Heater
Insulation
Seat belt
Side windows
Top windows
Repair MC70C
Attachment bracket, installation
Attachment bracket, maintenance
Attachment bracket, removal
Attachment, installation removal
Axle assemblies, reconditioning
Axle assembly, installation
Axle assembly, removing
Back-up alarm, testing and adjustment
Batteries, replacing
Battery, charging
Charge Implement pump charge relief test
Charge Implement pump flow displacement test
Charge pump charge relief test
Charge pump flow displacement test
Charge Pump, removal and installation
Charge Pump, removal and installation1
ChargeImplement pump, removal and installation
Control lever crossmember removal installation
Control lever removal and installation
Control lockout (lift and tilt functions), components testing and adjustment
Control lockout (lift and tilt functions), testing and adjustment
Door, installing, without jumper harness
Door, installing
Door, removal, without jumper harness
Door, removal
Drive chain case, oil change
Drive chain tension, adjustment
Drive chain, drive- and axle-sprocket, installation
Drive chain, drive- and axle-sprocket, removal
Drive chain, oil level and tension check
Electrical component list
Engine oil pressure switch, testing
Engine shut down solenoid, testing and adjustment
Engine water temperature switch, testing
Engine, installing
Engine, removing
Fan belt and or alternator belt, checking and adjusting tension
Fuel gauge testing
Fuel gauge, installation
Fuel gauge, removal
Fuel level sender removal
Fuel level sender, installation
Fuel level sender, testing
Fuel system, bleeding
High flow electrical system, component tests
High flow electrical system, components
High flow valve relief test
High flow valve, installation
High flow valve, maintenance
High flow valve, removal
Hydraulic component terminology
Hydraulic cylinders, general maintenance
Hydraulic oil cooler, installing
Hydraulic oil cooler, maintenance
Hydraulic oil cooler, removing
Hydraulic oil filter restriction switch, testing
Hydraulic oil temperature switch, testing
Hydrostatic control pump drive relief cartridge, replacement
Hydrostatic drive motor test
Hydrostatic drive motor test1
Implement High flow pump flow displacement test
Implement high flow pump, removal installation
Instrument panel removal and installation
Lift cylinder removed, repacking
Lift cylinder, installing
Lift cylinder, removing
Linkage rod spring centring link removal installation
Locking lever and pin, assembly
Locking lever and pin, disassembly
Main control valve system relief test
Main control valve, cables, adjustment
Main control valve, cables, adjustment1
Main control valve, cables, adjustment2
Main control valve, installation
Main control valve, maintenance
Main control valve, removal
Main pressure relief valve, replacing
Main travel control pump (High flow), installation
Main travel control pump (High flow), removal
Operator's seat, installation
Operator's seat, removing
Park lock pin, adjustment
Park lock, installation
Park lock, removal
Self level valve, adjustment
Self level valve, bypass, reconnection
Service and maintenance
Service position 2
Starter motor, tests
Starter system, tests
Startup after hydraulic repair
Startup after hydraulic repair1
Teminology
Thermo start plug, description
Thermo start plug, testing
Thermostat, replacing
Tilt cylinder removed, repacking
Tilt cylinder, installing
Tilt cylinder, removing
Transmission drive assembly, replacement
Transmission pump, drive relief test
Transmission pump, flow displacement test
Transmission pump, installing
Transmission pump, removing
Travel motor, removing
Warning Light Cluster Bulb Replacement
Wheel nuts, check torque
Wheel, removing and fitting one
Wiring harnesses
Working hydraulics, troubleshooting
Safety MC70C
Checklist after a fire or exposure to other intense heat
Fire prevention measures
Raising and blocking
Rules when handling tyres
Safety concerns everybody!
Safety during electric welding
Safety rules when servicing
Safety when handling oils and fuel
Safety when servicing
Safety when working on hydraulic systems
Safety when working on the machine's electrical system
Safety when working with batteries1
Service position 1
Working under raised loader arm
Service Bulletins MC70C
CareTrack Telematics system
Cleaning of engine compartment
Drive motor, change
Fan protector, improvement
Fuel sampling, method
Hydraulic drive motor mounting frame repair
New Auxiliary Hydraulic Lock Pin
New boom cylinder hose routing
New hydraulic oil cooler
New joystick stud with 25° angle
Recommended Special tools
Reporting of accidents and incidents
Reports
Seal service kit – Main control valve
Special Tools, Misc MC70C
GRD G700B LabourTimeGuide
RM Compaction ABG Time Guide Old
RM Compaction Time guide old version
RM Paving Systems ABG Time Guide Old
Special tool catalog
Special tools recommendations
Time Guide Currrent generation
Time Guide Old generation
Specifications MC70C
37° Flared fitting (steel) (Tube or hose to fitting)
Adjustable straight thread O-Ring fitting (fitting to port)
Air cleaner restriction switch, specification
Air cleaner restriction switch, specification1
Air cleaner, specification
Alternator, specifications
Alternator, specifications1
Back-up alarm, Switch, specification
Back-up alarm, Switch, specification1
Battery, specification
Battery, specification1
Dealers retrofitter´s responsibility
Drivetrain capacities, specification
Drivetrain capacities, specification1
Drivetrain, tightening torques
Drivetrain, tightening torques1
Engine cooling system, specification
Engine cooling system, specification1
Engine oil pressure, specification
Engine oil pressure, specification1
Engine shut down solenoid, specification
Engine shut down solenoid, specification1
Engine water temperature switch, specification
Engine water temperature switch, specification1
Engine, general specification
Engine, general specification1
F.F.F.T Method (Flats From Finger Tight)
Fuel level sensor, specifications
Fuel level sensor, specifications1
Grease, recommendation
Hydraulic oil filter restriction switch, specification
Hydraulic oil filter restriction switch, specification2
Hydraulic oil temperature, specification
Hydraulic oil temperature, specification1
Hydraulic oil temperature, specification2
Hydraulic pumps MC60, specifications
Hydraulic pumps MC60, specifications1
Hydraulic pumps MC70 optional 'High flow', specifications
Hydraulic pumps MC70 optional 'High flow', specifications1
Hydraulic pumps MC70, specifications
Hydraulic pumps MC70, specifications1
Hydraulic system, specification
Hydraulic system, specification1
Hydraulic system, specification2
Lighting front, specifications
Lighting front, specifications1
Lightning rear, specification
Lightning rear, specification1
Loader buckets
Loader cycle times
Loader cycle times1
Machine dimensions
Machine weights
Main control valve, specifications
Main control valve, specifications1
Main fuse, specification
Operating data
Relays, specification
Specification, Control lamp
Specification, Control lamp1
Starter motor, specifications
Starter motor, specifications1
Thermo start plug, specifications (MC60-MC70)
Thermo start plug, specifications (MC60-MC70)1
tires
Travel speeds
