Martin Welker
104
230,792
Volvo Skid Steer Loader MC60C Service and Repair Manual
Brand: Volvo
Type of Machine: Skid Steer Loader
Type of Manual: Hydraulic and Electrical Diagrams, Service and Repair Manual
Model: Volvo MC60C Skid Steer Loader
Number of Pages: 3971 Pages
1.MC60C
Repair
Air cleaner dust valve, changing'
Air cleaner inner element, changing
Air cleaner inner element, replacing
Air cleaner outer element, changing
Air cleaner outer element, replacing
Air conditioning charge weights
Air conditioning filters, changing
Alternator belt, checking
Alternator, installing
Alternator, removing
Alternator, testing
Attachment bracket cylinder, installing
Attachment bracket cylinder, removing
Axle hub, installing
Axle hub, removing
Battery isolator, checking
Battery isolator
Battery, maintenance
Battery, replacing
Boom suspension system accumulator, charging
Boom suspension system accumulator, discharging
Bucket, not level
Cab door leak
Cab door, installing
Cab door, removing
Cab gas strut configuration
Cab, installing
Cab, removing
CareTrack Telematics system
Cleaning of engine compartment
Cleaning of the machine
Collection of basic data
Compressor belt, checking
Coolant level, checking
Coolant, changing
Coolant, draining
Coolant, filling
Cooling package, installing
Cooling package, removing
Description, complete machine
Door handle, replacing
Drain line screen filter adapter, replacing
Drive chain case oil level, checking 1
Drive chain case oil, changing 1
Drive chain, installing
Drive chain, removing
Drive motor, description
Drive motor, installing 1
Drive motor, removing
ECU trouble shooting
Electronic control unit (ECU), description
Engine air cleaner system integrity, checking
Engine oil filter, replacing
Engine oil level, checking
Engine oil, changing
Engine oil, draining
Engine oil, filling
Engine, installing 1
Engine, installing
Engine, removing 1
Engine, removing
Explanation of wiring diagrams
Explanations to hydraulic diagram
Fan reversing valve, description
Fault code list
Front end accessory drive (FEAD) belt condition, checking 1
Front end accessory drive (FEAD) belt, adjusting 1
Front end accessory drive (FEAD) belt, replacing 1
Front idler wheel, assembling
Front idler wheel, disassembling
Front Stop Pad and Centering Cup Shimming
Fuel filter element, changing
Fuel filter element, replacing
Fuel sampling, method
Fuel system, bleeding
Fuel water separator, draining
Fuel water separator, replacing
Fuses
Gauge to check attachment fitting
Gear pump, description
Gear pump, installing
Gear pump, removing 1
Gear pump, removing
Greasing, daily 1
Greasing, daily
Guide roller, assembling
Guide roller, disassembling
Hydraulic contamination
Hydraulic cylinders, checking
Hydraulic cylinders, description
Hydraulic oil charge filter, replacing
Hydraulic oil level, checking
Hydraulic oil return filter, replacing
Hydraulic oil tank breather filter, replacing
Hydraulic oil tank, draining 1
Hydraulic oil tank, filling 1
Hydraulic oil tank, installing
Hydraulic oil tank, removing
Hydraulic oil, changing 1
Hydraulic pressure, testing
Hydraulic return filter, replacing
Hydraulic screen filter adapter, replacing
Hydraulic service procedures
Improved Cab Door Sealing
Improved ignition switch
Improved lap bar
Improved top glass skylight seal
In-line fuel filter, changing
Left Hand Armrest Rotation
Loader and transmission control characteristics
Loader arm lift cylinder, installing
Loader arm lift cylinder, removing
Loader Arm Shimming
Loader arm, installing
Loader arm, removing
Loose wheel drive motor bolts and or leaks
Main control valve, description
Main control valve, installing
Main control valve, removing
Main valve block, description
Maintenance service, daily
Maintenance service, every 50 hours
Maintenance service, every 500 hours 1
Maintenance service, every 1000 hours
Maintenance service, every 1500 hours
Maintenance service, every 2000 hours
New joystick stud with 25° angle
New Magnetic Flywheel Speed Sensor
New Skid Steer Loader models
Operator's platform, lowering
Operator's platform, raising
Optional precleaner available
Paint fade and or color differences
Poor window adhesive
Radiator and coolers, cleaning
Rapid Assembly Hoses
Rear door, installing
Rear door, removing
Rear idler wheel, assembling
Rear idler wheel, disassembling
Relays
Reporting of accidents and incidents
Reports
Revised software for enhanced drive response
Road lights, description
Self level valve, description
Self level valve, replacing
Service and Maintenance Introduction
Service position 1
Service position 2
Small platform loader and transmission setup
Spark arrester, cleaning
Starter motor, installing
Starter motor, removing
Starter motor, testing
Stop pad, adjusting 1
Stop pad, adjusting
Straight line travel adjustment
Throttle control
Tilt cylinder rod scoring
Top Window Leak
Track tension, adjusting
Transmission circuit, description
Transmission pump, adjusting
Transmission pump, installing
Transmission pump, removing
Transmission pumps, description
Troubleshooting, general
Tyre, replacing
Tyres, checking air pressure
Tyres, wear and air pressure, checking
Updated Boom Guide and Stop Block
Wheel nuts torque, checking
Wind screen washer bottle leaks
Window cracks and or breaks
Window pane, installation
Window pane, removal'
Windows, general
Wire and harness identification
Diagrams
Component list, Fuses 1
Component list, Miscellaneous 1
Component list, Motors 1
Component list, Relays 2
Component list, Sensors 1
Component list, Solenoid valves 1
Component list, Switches 1
Explanations to hydraulic diagram descr
Hydraulic diagram 1
Hydraulic diagram 1-1
Hydraulic diagram
Hydraulic diagram
Wiring diagram 1
Wiring diagram 1-1
Wiring diagram 2
Wiring diagram 2-1
Wiring diagram 3
Wiring diagram 3-1
Wiring diagram 4
Wiring diagram 4-1
Wiring diagram 5
Wiring diagram 5-1
Wiring diagram 6
Wiring diagram 6-1
Wiring diagram 7
Wiring diagram 7-1
Wiring diagram 8
Wiring diagram 8-1
Wiring diagram 9
Wiring diagram 9-1
Wiring diagram 10
Wiring diagram 10-1
Wiring diagram 11
Wiring diagram 12
Install Instructions
Attachment bracket, installation
Auxiliary hydraulic option, installing new
Cab sealing kit, installing new
Cab, installing
CareTrack, installing new
Door guard kit, installing new
Foot throttle control kit, installing new
FOPS (Falling Object Protecting Structure), installing new
Front screen guard kit, installing new
Lexan(TM) front screen kit, no wiper, installing new
Multi-function joystick kit, installing new
Right hand screen guard kit, installing new
Road lights kit, right hand dip, installing new 1
Smooth ride system kit, installing new
Specifications
Air conditioning, specifications
Boom suspension system (BSS) valve block, specifications
Boom suspension system accumulator (BSS), specifications
Charge pump, specifications
Conversion tables
Coolant, specifications
Engine, specification 1
Engine, specifications
Fuel, lubricant and filling capacities
Fuel, specifications
Hydraulic connections, tightening torques 1
Hydraulic cylinders, specifications
Hydraulic return line filter, specification
Hydraulic tank, specifications
Lights, specifications
Loader pump, specifications
Main control valve, specifications
Main valve block, specifications
Positional adapters
Push lock fittings
Quick release couplings
Radio, specifications
Rapid assembly fittings
Recommended lubricants
Return line filter, specifications
Self levelling valve, specifications
Thread locking compound, application specifications
Tightening torque, specifications
Transmission pump, specifications
Tyres, specifications
Special tool catalog
General
Index
Hooks
1. Enviroment and Safety equipment
2. Measuring equipment
3. Tightening and Loosening tools
4. Lifting equipment
5. Pullers and Pressing equipment
6. Drifts
7. Guide pins and Guide sleeves
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Time Guide Currrent generation
Time Guide Old generation
