Martin Welker
104
230,310
Volvo Skid Steer Loader MC60 Service and Repair Manual
Brand: Volvo
Type of Machine: Skid Steer Loader
Type of Manual: Service and Repair Manual, Electrical and Hydraulic Diagrams
Model: Volvo MC60 Skid Steer Loader
Number of Pages: 4161 Pages
2
1
Automatic stop
Care Track
Care Track1
Care Track2
Care Track3
Clearner
Descriptions
Air cleaner restriction light, description
Air cleaner restriction switch, description
Alternator light, description
Alternator, description
Alternator, test
Attachment bracket, description
Attachment tilt spool control, with optional self level, description
Attachment tilt spool control, without optional self level, description
Auxiliary hydraulic cable, inspection
Auxiliary hydraulic cable, installation
Auxiliary hydraulic cable, removal
Auxiliary hydraulic system control, description
Auxiliary Spool Control, description
Axle assembly, axle sprocket and drive sprocket, description
Back-up alarm, operation
Battery, safety
Bearings
Charge implement pump, description
Charge pump, MC70 with optional 'High flow', description
Charge pump, MC70 with optional 'High flow', description1
Cleaning prior to repair
Component terminology
Control lockout (lift and tilt functions), description
Control lockout solenoid valve (lift and tilt functions) description
Control Terminology
Coolant with anti-freeze and corrosion protection
Cooling system, description
Description, complete machine
Disclaimer
Driver's seat, description
Drivetrain component terminology
Drivetrain, description and operation
Electrical system, special instructions for servicing, actions when working on machine
Electrical system, special instructions for servicing, electrical components, alternator and charging regulator
Electrical system, special instructions for servicing, electrical components, batteries
Electrical system, special instructions for servicing, general
Electrical troubleshooting
Engine Crankcase oil, specification
Engine Crankcase oil, specification1
Engine manufacturer manuals
Engine oil pressure light, description
Engine oil pressure switch, description
Engine shut down solenoid, description
Engine water temperature light, description
Engine water temperature switch, description
Exhaust system, description
Extending attachment tilt cylinder circuit
Final drive components, Model MC60 and MC70, description
Foot pedal, cable removal
Frame and track unit, description
Fuel gauge, description
Fuel system, description
Fuel system, specifications
Fuel system, specifications1
Fuses, specification
Fuses
General part replacement
Grounding points (chassis ground)
High flow couplers, description
High flow electrical system, description and operation
High flow gauge, description
High flow hydraulic supply, return and cooling circuits, MC70 optional 'High flow' only
High flow switch, description
High flow system (optional), description
High flow system hydraulic circuit
High flow system wiring harness
High flow system wiring harness1
Hoses and tubes
Hourmeter, operation
Hydraulic circuit
Hydraulic cylinders, description
Hydraulic oil cooler, description
Hydraulic oil filter restriction light, description
Hydraulic oil temperature light, description
Hydraulic oil temperature switch, description
Hydraulic system oil contamination
Hydraulic system oil contamination1
Hydraulic testing schedule
Hydrostatic drive, specification
Hydrostatic drive, specification1
Ignition switch, description and operation
Ignition switch, testing
Implement High flow pump, description
Loader arm cylinder retracting circuit
Loader arm spool control, with optional self level, description
Loader arm spool control, without optional self level, description
Machine hydraulic circuits, MC60, MC70 with self level valve
Machine hydraulic circuits, MC60, MC70 wo optional self level
Machine hydraulic circuits, MC70 with optional 'High flow' wo optional self level
Main control valve, description
Main hydrostatic travel control pump, description
Main hydrostatic travel control pump, description1
Main relief valve, description
Manual lifting of loader arm
Neutral centring and control lever adjustment
Neutral centring test
Operator's protective structure, tilt position
Optional auxiliary hydraulic cable, installation
Optional auxiliary hydraulic cable, removal
Optional auxiliary hydraulic pedal lock control
Park lock pin, inspection
Park lock, inspection
Park lock, operation
Parking lock, troubleshooting
Power train, specification
Pressure testing
Radiator pressure cap, description
Recommended lubricants
Replacement parts
Restraint bar, inspection
Retracting attachment tilt cylinder circuit
Self level valve, description
Service methods
Service
Standard tightening torques
Throttle Control Description
Transmission drive assembly, description
Transporting and lifting the machine
Travel hydraulics, troubleshooting
Travel motor, description
Travel motor, operation
Travel Steering Levers, description
Travel system, hydraulic components, description
Travel system, mechanical drive components, description
Warning lights test Worklight switch
Warning lights, general
Wrist control cable, installation and adjustment
Wrist control cable, removal
Wrist hydraulic controls (optional), description
Diagrams
Hydraulic schematic MC60, MC70 w fig 1o Self level
Hydraulic schematic MC60, MC70 wo Self level
Hydraulic schematic MC60,MC70 w Self level fig 1
Hydraulic schematic MC70, with optional 'High flow', w o Self level fig 1
Hydraulic schematic MC70, with optional 'High flow', w Self level fig 1
Hydraulic schematic MC70, with optional 'High flow', wo Self level
Wiring diagram M01
Wiring diagram M02
Wiring diagram M03
Wiring diagram M04
Wiring diagram M05
Wiring diagram M06
GRD G700B LabourTimeGuide
G700B Labour Time Guide Foreword.pdf
Heater Engine
Heater
Insulation
Repair
Attachment bracket, installation
Attachment bracket, maintenance
Attachment bracket, removal
Attachment, installation removal
Axle assemblies, reconditioning
Axle assembly, installation
Axle assembly, removing
Back-up alarm, testing and adjustment
Batteries, replacing
Battery, charging
CareTrack Telematics system
Charge Implement pump charge relief test
Charge Implement pump flow displacement test
Charge Implement pump, removal and installation
Charge pump charge relief test
Charge pump flow displacement test
Charge Pump, removal and installation 1
Check method on engine oil consumption
Cleaning of engine compartment
Control lever crossmember removal installation
Control lever removal and installation
Control lockout (lift and tilt functions), components testing and adjustment
Control lockout (lift and tilt functions), testing and adjustment
Door, installing, without jumper harness
Door, installing
Door, removal, without jumper harness
Door, removal
Drive chain case, oil change
Drive chain tension, adjustment
Drive chain, drive- and axle-sprocket, installation
Drive chain, drive- and axle-sprocket, removal
Drive chain, oil level and tension check
Drive motor, change
Electrical component list
Engine oil pressure switch, testing
Engine shut down solenoid, testing and adjustment
Engine water temperature switch, testing
Engine, installing
Engine, removing
Fan belt and or alternator belt, checking and adjusting tension
Fan protector, improvement
Fuel gauge testing
Fuel gauge, installation
Fuel gauge, removal
Fuel level sender removal
Fuel level sender, installation
Fuel level sender, testing
Fuel sampling, method
Fuel system, bleeding
High flow electrical system, component tests
High flow electrical system, components
High flow valve relief test
High flow valve, installation
High flow valve, maintenance
High flow valve, removal
Hydraulic component terminology
Hydraulic cylinders, general maintenance
Hydraulic drive motor mounting frame repair
Hydraulic oil cooler, installing
Hydraulic oil cooler, maintenance
Hydraulic oil cooler, removing
Hydraulic oil filter restriction switch, testing
Hydraulic oil temperature switch, testing
Hydrostatic control pump drive relief cartridge, replacement
Hydrostatic drive motor test 1
Implement High flow pump flow displacement test
Implement high flow pump, removal installation
Instrument panel removal and installation
Lift cylinder removed, repacking
Lift cylinder, installing 1
Lift cylinder, removing 1
Linkage rod spring centring link removal installation
Locking lever and pin, assembly
Locking lever and pin, disassembly
Main control valve system relief test
Main control valve, cables, adjustment 1
Main control valve, cables, adjustment 2
Main control valve, installation
Main control valve, maintenance
Main control valve, removal
Main pressure relief valve, replacing
Main travel control pump (High flow), installation
Main travel control pump (High flow), removal
New Auxiliary Hydraulic Lock Pin
New boom cylinder hose routing
New hydraulic oil cooler
New joystick stud with 25° angle
Operator's seat, removing
Park lock pin, adjustment
Park lock, installation
Park lock, removal
Recommended Special tools
Reporting of accidents and incidents
Reports
Seal service kit – Main control valve
Self level valve, adjustment
Self level valve, bypass, reconnection
Service and maintenance
Service position 2
Starter motor, tests
Starter system, tests
Startup after hydraulic repair 1
Teminology
Thermo start plug, description
Thermo start plug, testing
Thermostat, replacing
Tilt cylinder removed, repacking
Tilt cylinder, installing
Tilt cylinder, removing
Transmission drive assembly, replacement
Transmission pump, drive relief test
Transmission pump, flow displacement test
Transmission pump, installing
Transmission pump, removing
Travel motor, removing
Warning Light Cluster Bulb Replacement
Wheel nuts, check torque
Wheel, removing and fitting one
Wiring harnesses
Working hydraulics, troubleshooting
RM Compaction ABG Time Guide Old
Foreword
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Compaction Time guide old version
Drum
Hydraulic
Electrical
Structural
Drive system
Water
RM Paving Systems ABG Time Guide Old
Foreword
Screeds
Hydraulics
Structural
Drive system
Electrical
Seat belt
Side windows
Special tool catalog
General
Index
Hooks
1. Enviroment and Safety equipment
2. Measuring equipment
3. Tightening and Loosening tools
4. Lifting equipment
5. Pullers and Pressing equipment
6. Drifts
7. Guide pins and Guide sleeves
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Special tools recommendations
Specifications
37° Flared fitting (steel) (Tube or hose to fitting)
Adjustable straight thread O-Ring fitting (fitting to port)
Air cleaner restriction switch, specification
Alternator, specifications
Back-up alarm, Switch, specification
Battery, specification
Drivetrain capacities, specification
Drivetrain, tightening torques
Engine cooling system, specification
Engine oil pressure, specification
Engine shut down solenoid, specification
Engine water temperature switch, specification
Engine, general specification
F.F.F.T Method (Flats From Finger Tight)
Fuel level sensor, specifications
Grease, recommendation
Hydraulic oil filter restriction switch, specification
Hydraulic oil temperature, specification
Hydraulic pumps MC60, specifications
Hydraulic pumps MC70 optional 'High flow', specifications
Hydraulic pumps MC70, specifications
Hydraulic system, specification
Lighting front, specifications
Lightning rear, specification
Loader buckets
Loader cycle times
Machine dimensions
Machine weights
Main control valve, specifications
Main fuse, specification
Operating data
Relays, specification
Specification, Control lamp
Starter motor, specifications
Thermo start plug, specifications (MC60-MC70)
tires
Travel speeds
Time Guide Currrent generation
Time Guide Old generation
Top windows
