Hyundai
86
176,834
Volvo Loader L60F L70F L90F Service Manual VOE21A1002950
Brand: Volvo
Type of Machine: Loader
Model: Volvo L60F L70F L90F Loader
Part Number: VOE21A1002950
Number of Pages: 140 Pages
STANDARD PARTS, SERVICE
LUBRICANT; FUEL; OTHER FLUID
General
Recommended lubricants, oils
SERVICE
General, common info about 171 - 179
Working on the electrical system of the machine
Repairing hydraulic system
Electric welding
Cleanliness, brake and hydraulic systems
Charging batteries
Explosion hazard
Corrosive sulphuric acid
Warranty service
Warranty inspection 100 hours
Test-run and check
Steering pressure, check
Tires as well as inflation pressure in tires, check
Wheel nuts and tightening torques, check
Axles, attaching bolts, tightening torques, check
Propeller shafts and support bearing, tightening torques, check
Leakage
Pipes and hoses
Coolant system, check the level
Cab, ventilation unit
Water trap, check
When draining, proceed as follows:
Drive belt, air conditioning, checking belt tension
Drive belt, alternator, checking and adjusting
Oil-bath pre-cleaner (optional equipment)
Hydraulic oil, check the level
Battery, electrolyte level, cables and connections, check
Transmission, oil filter, change
Transmission oil level, check
Framework, grease
Warranty inspection 1000 hours
Test-run and check
Matris read-off
Hydraulic pressure, check
Transmission incl. torque converter, pressure check
Brakes, checking
Transmission, oil, draining
Transmission, oil, filling
Front axle, oil change
Engine and engine oil filter, change
Rear axle, oil change
Fuel filter, primary and secondary filter, change
Steering cylinders, locks for pivot pins, left and right side, check
Hydraulic oil, draining sediment and level check
Air cleaner
Drive belts, air conditioning, checking and adjusting
Engine oil. filling
Rear axle, oil, filling
Cab ventilation unit
Front axle, oil, filling
Framework, grease
Cooling system, checking level and freezing point
Leakage
Pipes and hoses
Transmission, oil level, check
Engine, oil level, check
Maintenance
Maintenance service, daily
Test-run and check
Framework, grease
Maintenance service, every 50 hours
Test-run and check
Framework, grease
Engine oil, checking level
Coolant system, checking level
Maintenance service, every 250 hours
Test-run and check
Hydraulic system, checking hydraulic oil level
Framework, grease
Water trap, check
Leakage
Pipes and hoses
Radiator, engine, check
Maintenance service, every 500 hours
Test-run and check
Brakes, checking
Engine oil, changing
Engine oil filter, replacing
Drive belt, air conditioning, checking and adjusting
Engine, oil, filling
Transmission, checking oil level
Framework, grease
Leakage
Pipes and hoses
Condenser, check
Maintenance service, every 1000 hours
Test-run and check
Matris read-off
Brakes, checking
Air cleaner
Engine oil, filling
Framework, grease
Leakage
Pipes and hoses
Condenser, check
Maintenance service, every 2000 hours
Test-run and check
Matris read-off
Brakes, checking
Hydraulic oil, draining (applies when using bio-oil or engine oil)
Transmission, oil, change
Transmission oil filter, changing
Hydraulic system, draining sediment and checking hydraulic oil level
(applies when using hydraulic o ...
Breather filter, fuel tank
Air cleaner
Engine oil, filling
Hydraulic system's return oil filter, change
Hydraulic oil, filling
Breather filters, hydraulic system, and transmission
Breather filter, rear axle, change
Framework, grease
Breather filters, changes, Front axle
Valve clearance, checking and adjusting
Leakage
Pipes and hoses
Condenser, check
Maintenance service, every 4000 hours
Test-run and check
Matris read-off
Brakes, checking
Air cleaner
Engine oil, filling
Rear axle oil, filling
Framework, grease
Leakage
Pipes and hoses
Transmission, oil level, checking
Engine, oil level, checking
Condenser, check
Maintenance service, every 6000 hours
Coolant, changing
Emergency measures
Mechanical release of parking brake
Towing
GENERAL
Safety equipment, without own function group
Service position 1
Service position
Service position 2
Service position
