VOLVO FAULT CODES
VOLVO FAULT CODES
system:
AW 30-43 / AW 50-42
Mode: 1
111 - No fault detected diagnostic system.
112 - Short to power in the electromagnet S1.
113 - Faulty transmission control.
114 - Open circuit or short to power in the mode switch.
121 - Short to "mass" in the electromagnet S1 or malfunction of the control unit.
122 - Open circuit in the solenoid S1.
123 - Short to power supply to the solenoid STH.
124 - Malfunction or short to "mass" in the mode switch.
131 - Open circuit, short circuit to the "mass" in the electromagnet STH or failure of the control unit.
132 - Malfunction of transmission control.
134 - Invalid load signal from the fuel system.
141 - Short to "mass" in the oil temperature sensor.
142 - Open circuit in the oil temperature sensor.
143 - Malfunction or short to "mass" switch function "kick-down".
211 - Malfunction of transmission control.
212 - Short to power in the electromagnet S2.
213 - Too high signal throttle position.
221 - Short to "mass" in the electromagnet S2 or malfunction of the control unit.
222 - Open circuit in the solenoid S2.
223 - Too low signal throttle position.
231 - Irregular signal throttle position.
232 - No signal speedometer.
233 - Invalid signal speedometer.
235 - Oil temperature too high.
245 - Short circuit or open circuit signal reduction of torque.
311 - No signal speed of the crankshaft of the engine and gearbox.
312 - Invalid signal speed of the crankshaft of the engine and gearbox.
313 - Invalid signal from the sensor selected gear.
321 - Too slow shifting.
322 - Incorrect gear ratio.
323 - Safety clutch slips or is not included.
331 - Short to power in the electromagnet SL.
332 - Open circuit in the solenoid SL or failure of the control unit.
333 - Short to "mass" in the electromagnet SL or failure of the control unit.
Mode 2
144 - Gear selector in position R - OK.
214 - Gear selector in position D - ok.
224 - Gear selector in position 3 - OK.
234 - Gear selector in position L - ok.
241 - Gear selector in position N - ok.
242 - Gear selector in position P - ok.
243 - Uncertain signal with the mode switch.
244 - Regulations economy mode - in order.
314 - Regulation of the sport mode in order.
324 - Regulation of the winter mode in order.
334 - The switch signals brakes - ok.
341 - Switch the "kick-down" - in order.
Mode 3
Fires solenoid S1.
Fires solenoid S2.
Fires solenoid SL.
Fires solenoid STH.
Blinking LED indicator in the instrument cluster.
Flashing indicator light engine trouble.
At idle signals are tested for motion compensation and torque control.
The engine speed of the engine changes.
Mode 4
311 - Normal speed.
312 - Two-time speed.
313 -, ten speed.
342 - Solenoid S1.
343 - solenoid S2.
344 - Solenoid SL.
411 - Solenoid STH.
412 - The indicator light.
414 - Compensation for movement (P and N)
422 - Torque control (TC2)
423 - Torque control (TC1)
431 - Indicator light engine trouble.
432 - Upravleni6e torque (TCT)
Mode: 5
115 - Oil temperature
125 - The nature of the signal Throttle
135 - Character-time
424 - Speed
434 - Shaft speed gearbox
444 - degree of throttle opening
Mode 6
125 - Resetting the throttle signal.
135 - Resetting on time.
system:
AW 30-43 / AW 50-42
Mode: 1
Mode 2
Mode 3
Fires solenoid S1.
Fires solenoid S2.
Fires solenoid SL.
Fires solenoid STH.
Mode 4
311 - Normal speed.
313 -, ten speed.
342 - Solenoid S1.
343 - solenoid S2.
344 - Solenoid SL.
411 - Solenoid STH.
Mode: 5
424 - Speed
Mode 6
- Volvo Truck Service Manual All
- Volvo D11 D13 D16 Service Manual
- Volvo Trucks MID Fault Codes
- Volvo FM12, D12D420 New engine variants -Sensor
- Volvo FM12, D12F500 Specifications- Sensor-EBR-VEB Valves and unit injectors, adjust. Valve cov
- Volvo NH Valves and unit injectors, adjust
- Specifications Volvo Engine D12D
- Volvo Service Manual Truck - Wiring Diagram FM9, FM12, FH12, FH16, NH12
- Volvo FM12, D12C 420 Engine
- Volvo Truck Service Manual Trucks Wiring Diagram FL7,FL10 LHD
- Volvo Engine Trucks D13 Service Manual
- Volvo Truck F10 F12 F16 1998 Service Manual
- Volvo Truck Service Manual & Electrical Schematic
- Volvo Bus B7,B9,B12 Wiring Diagram
- Volvo FM12, D12D460 Cylinder head, install EBR-EPG Valves and unit injectors, adjust. Valve cover
