Martin Welker
104
230,310
Volvo Excavator ECR58 Parts and Service Repair Manual
Brand: Volvo
Type of Machine: Excavator
Type of Manual: Parts Catalog, Service Repair Manual, Wiring Diagram
Model: Volvo ECR58 Excavator
Number of Pages: 4636 Pages
1 Volvo ECR58
Description
2 stage port relief valve, adjustment
2 stage port relief valve, description1
2 stage port relief valve, description2
Actuator, foot face driver1
Actuator, foot face driver2
Air cleaner restriction switch, description
Air conditioning unit, description1
Air conditioning unit, description2
Air distribution, description
Air pre-heater, description
Alternator, description
Auxiliary start
Basic check
Battery disconnector switch, description1
Battery disconnector switch, description2
Battery disconnector switch, specifications
Battery, description
Boom holding valve, description
Bottom roller, description
Camshaft, description
Center passage, description
Center passage, troubleshooting
Checking electrical cabling and connectors
Coil resistor1
Coil resistor2
Cold start device, description
Collection of basic data
Compressor
Condenser
Connectors, configuration
Control pattern selector valve, description
Coolant temperature sender for needle gauge, description
Crankshaft, description
Cylinder block, description
Cylinder head, description
Cylinder, description
Cylinder, inspection and maintenance standard
Cylinder, troubleshooting
DC current measurement
DC voltage measurement
Diagnosis for malfunction symptoms
Digging unit, description
Diode check procedure
Drying filter
Electric horn, description
Electrical system, description
Electrical system, special instructions for servicing electronic components
Electrical system, special instructions for servicing, action when working on machine
Electrical system, special instructions for servicing, electrical components, alternator and charging regulator
Electrical system, special instructions for servicing, electrical components, batteries
Electrical system, special instructions for servicing, general
Engine oil pressure switch, description
Engine start and stop circuit
Engine timing gear, description
Engine, description
Engine, tightening torque
Evaporator1
Evaporator2
Examples, hydraulic system
Examples, power transmission
Expansion valve
Flow control valve, description
Fuel filler pump, description
Fuel injection nozzle
Fuel injection pump, description
Fuel level sender for needle gauge, description
Fuel lines, description
Fuel system, description
Fuel tank, description
Fuse box, description1
Fuse box, description2
Hydraulic circuits, ports
Hydraulic components, description
Hydraulic components, location Figure 1
Hydraulic components, location Figure 2
Hydraulic components, location Figure 3
Hydraulic diagram, schematic
Hydraulic lines, return piping
Hydraulic quickfit, description
Hydraulic tank, description
Idler, description
Idler, description1
Injectors, description
Instrument panel, description
Instrument panel, electrical circuit
Instrument panel, operation
Intake and exhaust system, description
Line rupture valve (boom arm), description
Line rupture valve (boom arm), hydraulic circuit
Line rupture valve (boom), troubleshooting
Line rupture valve relief pressure, adjustment
Location of components
Lubricating system, description
Main control valve, description
Main relief valve, description
Main spool, description
Maintenance standards
Measuring components
Overload warning pressure switch, description
Pistons, description
Port relief valve, description
Power transmission, description
Precautions when handling plug connectors
Precautions
Preheating relay, description
Preheating system, description
Pressure accumulator, description
Pressure compensation valve, description
Pressure relief valve, troubleshooting
Pump, description
Pump, troubleshooting
Quickfit system, operation
Radiator, description
Radio with tape player, description
Receiver drier, changing
Recommended lubricants
Refrigerant hoses
Regeneration valve, description
Relay and relay box, description1
Relay and relay box, description2
Relay and relay box, description3
Remote control valve (dozer blade), description
Remote control valve (Lever), description
Remote control valve (Lever), troubleshooting
Remote control valve (pedal), description
Remote control valve (pedal), troubleshooting
Resistance measurement
Rotating beacon, description
Rotator (X3 Line option), description
Rotator (X3 Line option), hydraulic circuits and principle of operation
Safety limit switch, description
Safety start relay, description
SE2303, description and measuring
SE2307, description and measuring
SE2502, description and measuring
SE2606, description and measuring
SE2701, description and measuring
Selection of track shoes
Service positions
Slew flow control valve, description
Slew motor, troubleshooting
Slow blow fuse, description
Solenoid valve, description
Special tools for troubleshooting
Special tools
Start switch, description
Starter motor, description
Starting engine with booster cables
Stop solenoid, description
SW2701, description and measuring
SW9161, description and measuring
SW9162, description and measuring
Swing motor, description
Swing ring gear, description
Thermostat
Three point relay
Top roller, description
Track chain, description1
Track chain, description2
Track gearbox, description
Track gearbox, precautions for operation
Track gearbox, troubleshooting
Track motor, description
Track motor, operating checks
Track motor, precautions for operation
Track motor, tools
Track motor, troubleshooting
Travel alarm pressure switch, description
Travel alarm, description
Troubleshooting chart
Troubleshooting, assistant devices
Troubleshooting, diagnosing procedure
Troubleshooting, general
Undercarriage, description
V-ECU function, auto return to idle
V-ECU function, boom offset
V-ECU function, fuel cutoff solenoid drive
V-ECU function, preheating
V-ECU function, proportional control
V-ECU function, quickfit
Vehicle control unit V-ECU, functional description
Warning buzzer, description
Water temperature switch for indicator, description
Windscreen wiper, components location
Windscreen wiper, description
Wiper motor, description
Work lights and extra lights, description
X1 Line, description
Diagrams
Components, list and positions1
Components, list and positions2
Control pattern selector valve, hydraulic circuits
Electrical circuit, air conditioner heater
Explanation of wiring diagrams
Grounding points (frame connections)
Hydraulic circuits, arm
Hydraulic circuits, boom lower
Hydraulic circuits, boom raise
Hydraulic circuits, boom slew (switch operated)
Hydraulic circuits, bucket
Hydraulic circuits, dozer blade
Hydraulic circuits, neutral
Hydraulic circuits, slew
Hydraulic circuits, standard1
Hydraulic circuits, standard2
Hydraulic circuits, travel (low auto shift)
Hydraulic circuits, with option components1
Hydraulic circuits, with option components2
Hydraulic diagram, X1 line
Positive feed
Wiring diagram SCH01-2
Wiring diagram SCH02-1
Wiring diagram SCH02-2
Wiring diagram SCH03-1
Wiring diagram SCH03-2
Wiring diagram SCH03-3
Wiring diagram SCH04
Wiring diagram SCH05-1
Wiring diagram SCH05-2
Wiring diagram SCH06-1
Wiring diagram SCH06-2
Wiring diagram SCH07-1
Wiring diagram SCH07-2
Wiring diagram SCH07-3
Wiring diagram SCH08-1
Wiring diagram SCH08-2
Wiring diagram SCH09-1
Wiring diagram SCH09-2
Wiring diagram SCH09-3
Wiring diagram SCH09-4
Wiring diagram SCH10-1
Wiring diagram SCH10-2
Wiring diagram SCH011
Wiring diagram SCH22
Wiring diagram SCH25
Wiring diagrams
Installation Instructions
380mm Shoe-steel U-C
400mm Shoe-steel U-C
Anti theft device, installing new
Anti-theft
Arm piping with Q-fit1
Arm piping with Q-fit2
Arm piping
Boom piping1
Boom piping2
Care Track1
Care Track2
FOG (Falling Object Guard), installing new
FOPS level2
Grapple piping1
Grapple piping2
Hose rupture valve Boom
Hose rupture valve
Long arm 1.94m-1
Long arm 1.94m-2
Piping clamp for Q-fit
Piping clamp
Q-F piping for 1.94m arm double type
Quick fit piping on boom, installing new
Quick fit, installing new
Quickfit HYD
Quickfit HYD1
Radio-Cassette
Rotating beacon, installing new
Rotating Beacon
Rupture Valve
Safety net, installing new
Speed control Auto Decelation
Thumb, quick attachment, installing new
Thumb, standard bucket, installing new
Track assembly, installing new
Travel Alarm
Work light rear, installing new
Work Light1
Work Light2
X3 piping long arm
X3 piping standard arm1
X3 piping standard arm2
Parts Manual
Air conditioning line, cooling and heater 1
Air conditioning unit, cooling and heater
Air duct in cabin and cabin floor 1
Alternator with assembling details
Antitheft system
Attachment bracket, quickfit 1
Attachment bracket, quickfit 8292430
Back-up warning unit
Battery with assembling details
Belt transmission
Boom and grease piping
Boom cylinder
Boom swing cylinder
Boom swing system
Bottom roller 1
Bottom roller
Bucket 1
Bucket 2
Bucket 3
Bucket 4
Bucket 5
Bucket cylinder
Bucket
Bucket6
Cab mount 1
Cab mount 2
Cab mount
Cabin floor 8278703 SN 12694-13393
Cabin floor
Cable and wire harness, instrument panel 1
Cable and wire harness, main
Cable harness, engine
Cable harnesses, cab
Cables, battery
Camshaft
Cassette radio recorder with mounting details 1
Connecting rod and piston
Control links, dozer blade
Control valve with fitting parts.
Cooling fan mounting
Cooling system 8278697,8278698
Counterweights 1
Counterweights
Cowl frame, cover and hood 1
Cowl frame
Cylinder block
Cylinder head
Decal, inner location
Decal, outer location
Decal, Volvo Emblem
Dipper arm and grease piping with piping seat 1
Dipper arm cylinder
Door, operator's cab 1
Dozer blade cylinder
Dozer blade
Electrical distribution box 8278703 SN -13393
Electrical relay
Electrical sensor
Engine mount
Exhaust manifold
Exhaust system
Fan drive
Flywheel housing
Flywheel
Fops, protecting equipment
Front idler 1
Front idler 2
Front idler
Fuel filling pump
Fuel pipe - Fuel tank
Fuel pipes, fuel injec.pump-fuel filter
Fuel pipes-injector
Fuel tank with fitting parts
Grading bucket 1
Grading bucket 2
Grading bucket
Hatches under engine, hydr.pumps, cooler, m.valve and fuel tank.
Heating line 1
Heating line
Horn
Hydraulic lines bracket-quickfit, rotator, hose repture
Hydraulic oil tank
Hydraulic pump
Hydraulic system, attachment line
Hydraulic system, control valve to boom and swing
Hydraulic system, dozer blade front
Hydraulic system, return lines
Hydraulic system, suction line
Injection pump 1
Injection pump 2
Injection pump
Injector
Inlet manifold
Inlet system 8278696
Instrument panel, control panel 1
Instrument panel, control panel 8278703 SN 12694-13393
Instrument panel, warning unit and information unit
Key system
Lifting eye 1
Lifting eye
Lighting, front
Linkage for no bucket
Links to boom
Links to bucket 8282735,8284745,8284749,8284750,8284751,8284752,84753
Links to connecting rod
Links to dipper arm 8278731,8278733,8279157,8279158,8287960,8287961
Lubricating oil system
Main control valve 1
Main control valve 2
Main control valve
Oil sump
Operator seat with fitting parts 1
Operator's cab 1
Operator's cab 2
Operator's cab SN 12694-13393
Operator's cab
Operator's seat 1
Operator's seat 8278705, 8278706, 8291431, 8293044, 8293045, 8294949
Operator's seat
Potentiometer 8281088 SN 10977-
Product identification plate
Protecting plate
Protective plate for travel motor
Pump gearbox with assembling parts
Pump installation
Quickfit, mechanical 11839695
Rear view mirror
Regulator, hydraulic pump
Remote control valve pedal with fitting parts
Remote control valve pedal, travel motor
Repair kits for engine
Rocker arm
Rotating beacon
Servo hydraulics, hammer hydr. on base machine
Servo system, auto deceleration
Servo system, changing lever function 8279166,8286119
Servo system, control valve piping.
Servo system, control valve to remote control valve pedal
Servo system, control valve to solenoid valve and swing motor.
Servo system, hammer and shear
Servo system, remote control valve
Servo system, travel alarm
Speed control 1
Speed control
Sprocket
Starter motor, mounting
Sun visor interior
Swing motor with mounting parts
Swing motor
Swing system
Switch, Auto Idle
Switch, quickfit control
Switch
Thermostat housing 1
Thermostat housing
Timing gear casing
Timing gear
Tools
Top roller
Travel gearbox
Travel motor with mounting parts
Travel motor
Turning joint line, control valve to turning joint
Turning joint line, turning joint to travel motor
Turning joint, mounting
Turning joint
Undercarriage frame
Undercarriage, spring package
Undercarriage, track guards 8278729,8278832,8286386,8295201
Undercarriage, track with shoes 1
Undercarriage, track with shoes 2
Upper frame
Valve cover
Windows
Windshield washer 8278703,8289612,8278696
Windshield wiper
Windshield
Work lights, extra
Working hydraulic, boom cylinder
Working hydraulic, boom rupture valve mount
Working hydraulic, covers
Working hydraulic, dipper arm cylinder on boom.
Working hydraulic, dipper arm rupture valve mount.
Working hydraulic, hammer and shear for boom
Working hydraulic, hammer and shear for dipper arm
Working hydraulic, quick fit on boom
Working hydraulic, quick fit on dipper arm
Working hydraulic, quick fit on upper frame
Working hydraulic, slope and rotator on boom
Working hydraulic, slope and rotator on dipper arm
Working hydraulic, slope and rotator on upper frame
Working hydraulics, grab system on work equipment
Working lamp on boom
Repair
2 stage port relief valve, disassembly and assembly
Adjusting operation
Alternator, inspection
Battery, charging
Boom holding valve, disassembly and assembly
Bottom roller, measurement of wear
Bottom roller, removal and installation
Bushing general, replacing
Cab, installation
Cab, removal
Cautions during operation
CE marking and declaration of conformity
Center passage, assembly
Center passage, disassembly
Center passage, maintenance standard
Center passage, tools
Check the static brake torque
Coasting left and right swing
Compression pressure inspection
Control pattern selector valve, mode setting method
Coolant, checking anti-freeze resistance
Counterweight, installation
Counterweight, removing 1
Creeping of hydraulic cylinder
Cylinder speed
Cylinder, assembly
Cylinder, disassembly
Cylinder, removal and installation
Cylinder, tools
Digging unit, maintenance standard
Engine control
Engine mounting
Fan belt and or alternator belt, checking and adjusting tension
Flexible coupling
Flow control valve, disassembly and assembly
General precautions 1
General precautions
Hydraulic pressure, measuring and adjustment
Idler, installation
Idler, measurement of wear
Idler, removal
Load check valve, disassembly and assembly
Load sensing check valve, disassembly and assembly
Main relief valve, disassembly and assembly
Main spool, disassembly and assembly
Measuring condition
Measuring of swing bearing clearance
Move and operate machine safely
Periodic inspection and maintenance procedure
Periodic maintenance
Port relief valve pressure, measuring and adjusting
Port relief valve, disassembly and assembly
Preparations for work
Pressure compensation valve, disassembly and assembly
Pump, adjustment
Pump, assembly
Pump, disassembly
Pump, maintenance standard
Pump, tools
Regeneration valve, disassembly and assembly
Remote control valve (Lever), maintenance standard
Remote control valve (Lever), removal installation
Remote control valve (Lever), repair procedures
Remote control valve (pedal), assembly
Remote control valve (pedal), disassembly
Remote control valve (pedal), maintenance standard
Rubber track, installing
Rubber track, removing
Safety concerns everybody!
Servo hydraulic pressure, adjustment
Shim adjustment method
Slew flow control valve, disassembly and assembly
Slew ring gear, installation
Slew ring gear, removal
Solenoid valve, disassembly and assembly
Solenoid valve, inspection
Solenoid valve, troubleshooting
Spring package, disassembly
Spring package, measurement of wear
Sprocket, installation
Sprocket, measurement of wear
Sprocket, removal
Straight traveling performance
Superstructure, installation
Superstructure, removal
Swing motor, disassembly assembly
Swing motor, maintenance standard
Swing speed
Tools & equipment
Top roller, installation
Top roller, measurement of wear
Top roller, removal
Top roller, replacing one
Track chain, installation
Track chain, measurement of wear 1
Track chain, removal
Track gearbox, assembly
Track gearbox, disassembly
Track gearbox, maintenance standard
Track guard, replacing one
Track links, replacing
Track motor, assembly
Track motor, disassembly
Track running speed
Track shoe, replacing one
Track, adjusting track sag 1
Travel Speed
Valves, adjusting
Service Bulletins
Additional counterweight
Adjustable X1 flow control
Air conditioning compressor mounting bolt
Air conditioning evaporator
Air conditioning heater valve
Air conditioning switch
Air conditioning unit, blower motor
Arm rest latch improvement
Boom offset
Boom support, pivot play
Bottom roller improvement
Cab door latch
Cluster (engine overheating indication)
Compensator spool
Cylinder head gasket
Dozer blade valve
Expansion tank, improvement Q
Flow control valve clogging
Fuel filter bracket
Fuel sampling, method
Hose leakage
Left console support, improvements
Maintenance of Stored Machines
Master switch change
Muffler cracks
New air cleaner bracket
New coolant
New horn
New product
New Radio Antenna
New slew ring gear seal
Option anti-theft, instruction
Prevent high piloting pressure
Quickfit solenoid valve
Radiator coolant leakage
Rubber track improvement
Slew motor improvement
Speaker change
Swing ring gear seal improvement
Swing valve, improvements
Throttle cable
Travel alarm
Travel kit for improved controllability
Turning joint internal leakage
V-ECU failure
Wire harness, improvement
X1 option line back pressure improvement
Special Tools, Misc
GRD G700B LabourTimeGuide
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
Special tools recommendations
Time Guide Currrent generation
Time Guide Old generation
Specifications
Air cleaner restriction switch, specifications
Air conditioning unit, specifications1
Air conditioning unit, specifications2
Air preheater, specifications
Alternator, specifications
Battery, specifications
Cab, specifications
Coolant temperature sender for needle gauge, specifications
Cooling system, specifications
Cooling system, specifications1
Cylinder, specifications
Electric horn, specifications1
Electric horn, specifications2
Engine oil pressure switch, specifications
Engine, specifications
Engine, specifications1
Frame and track unit, specifications
Fuel filler pump, specifications
Fuel injection pump, specifications
Fuel injection pump, specifications1
Fuel level sender for needle gauge, specifications
Fuel system, specifications
Fuse box, specifications1
Fuse box, specifications2
Hydraulic oil, specifications
Hydraulic pump, specifications
Hydraulic tank, specifications
Injectors, specification
Injectors, specification1
Instrument panel, specifications
Line rupture valve (boomarm), specifications
Lubrication system, specifications
Lubrication system, specifications1
Main control valve, specifications1
Main control valve, specifications2
Measurement conversion tables
Overload warning pressure switch, specifications
Preheating relay, specifications
Pressure accumulator, specifications
Relays, specification
Relays, specification1
Relays, specification2
Remote control valve (Lever), specifications
Remote control valve (pedal), specifications
Safety limit switch, specifications
Safety start relay, specifications
Slow blow fuse, specifications
Solenoid valve, specifications
Standard tightening torques
Starter motor, specifications
Swing motor, specifications
Swing ring gear, specifications
Track gearbox, specifications
Track motor, specifications
Travel alarm pressure switch, specifications
Travel alarm, specifications
Undercarriage, tightening torque
Valve system specifications
Valve system specifications1
Warning buzzer, specifications
Wiper motor, specifications
Work lights and extra lights, specifications
