Martin Welker
104
230,310
Volvo Excavator EC55B Service Repair Manual
Brand: Volvo
Type of Machine: Excavator
Model: Volvo EC55B Excavator
Number of Pages: 4065 Pages
1 Volvo EC55B
Descriptions
Additional counterweight or attachment
Air cleaner restriction switch, description
Air conditioning unit, description
Air conditioning unit, location of components
Air preheater, description
Alternator, description
Auxiliary start
Battery disconnector switch, description1
Battery disconnector switch, description2
Battery disconnector switch, specifications
Battery disconnector switch, specifications1
Battery, description
Bottom roller, description
Camshaft, description
Center passage, description
Center passage, troubleshooting
Cold start device, description
Compressor, description
Condenser, description
Connectors, configuration
Control lockout lever switch, description
Control valve, troubleshooting
Coolant temperature sensor, description
Cooling system, description
Cooling unit, description
Crankshaft, description
Cylinder block, description
Cylinder head, description
Cylinder, description
Cylinder, inspection and maintenance standard
Cylinder, troubleshooting
Digging unit, description
Drying filter, description
Electric horn, description
Electrical system, special instructions for servicing, action when working on machine
Electrical system, special instructions for servicing, electrical components, alternator and charging regulator
Electrical system, special instructions for servicing, electrical components, batteries
Electrical system, special instructions for servicing, electronic components
Electrical system, special instructions for servicing, general
Engine oil pressure switch, description
Engine start and stop circuit
Engine timing gear, description
Engine, description
Engine, tightening torque
Examples, hydraulic system
Expansion valve and evaporator, description
Fuel filler pump, description
Fuel injection nozzle
Fuel injection pump, description
Fuel level sender for needle gauge, description
Fuel lines, description
Fuel system, description
Fuel tank, description
Fuse box, description
GPS control unit GPS-ECU, description
Heater unit, description
Heating control valve, description
Hydraulic components, description
Hydraulic diagram, ports
Hydraulic diagram, schematic
Hydraulic quickfit, description
Hydraulic tank, description
Idler, description
Injectors, description
Instrument panel, description
Instrument panel, gauge and indicator
Intake and exhaust system, description
Line rupture valve (boom), troubleshooting
Lower line
Lubricating system, description
Machine view
Main control valve, description
Main control valve, operation
Main line
Main relief valve, description
Maintenance standards
Overload warning pressure switch, description
Pistons, description
Port relief valve, description
Power transmission, description
Precautions
Preheating relay, description
Preheating system, description
Pressure relief valve, troubleshooting
Quickfit system, operation
Radio with tape player, description
Recommended lubricants
Relay, description
Remote control valve (dozer blade), description
Right switch panel, description
Rubber pads2
Rubber shoe pad usage
Rubber tracks1
Safety start relay, description
Selection of track shoes
Servo hydraulic line
Slew gearbox, description
Slew gearbox, precautions for operation
Slew motor, precautions for installation
Slew motor, troubleshooting
Slew ring gear, description
Slow blow fuse, description
Special tools
Start switch, description
Start switch, specifications
Start switch, specifications1
Starter motor, description
Starting engine with booster cables
Stop solenoid, description
Swing motor, description
Temperature sensor, description
Top roller, description
Track chain, description1
Track chain, description2
Track gearbox, description
Track gearbox, precautions for operation
Track gearbox, troubleshooting
Track motor, description
Track motor, maintenance standard
Track motor, operating checks
Track motor, precaution for installation
Track motor, tools
Track motor, troubleshooting
Travel alarm pressure switch, description
Travel alarm, description
Travel limit switch, description
Troubleshooting chart
Troubleshooting, diagnosing procedure
Undercarriage, description
Warning buzzer, description
Window limit switch, description
Windscreen wiper, components location
Windscreen wiper, description
Wiper controller, description
Wiper motor, description
Work lights and headlights, description
Diagrams
Components list
Connectors, position
Control pattern selector valve, hydraulic circuits
Explanation of wiring diagrams
Ground connections
Hydraulic diagram, 10 series spool type for boom fix
Hydraulic diagram, 11 series spool type for boom offset
Hydraulic diagram, 11 series spool type for wood grab
Hydraulic diagram, arm in conflux
Hydraulic diagram, arm out
Hydraulic diagram, boom lower
Hydraulic diagram, boom raise conflux
Hydraulic diagram, boom slew (pedal operated)
Hydraulic diagram, boom slew (switch operated)
Hydraulic diagram, bucket
Hydraulic diagram, dozer blade
Hydraulic diagram, neutral
Hydraulic diagram, slew right
Hydraulic diagram, standard
Hydraulic diagram, straight travel arm in
Hydraulic diagram, travel (low speed)
Hydraulic diagram, with option components
Hydraulic diagram, X1 line
Line rupture valve (boom arm), hydraulic circuit
Lower line
Main line
Positive feed
Wiring diagram SCH01-1
Wiring diagram SCH01-2
Wiring diagram SCH02-1
Wiring diagram SCH02-2
Wiring diagram SCH03-1
Wiring diagram SCH03-2
Wiring diagram SCH04
Wiring diagram SCH05-1
Wiring diagram SCH05-2
Wiring diagram SCH06
Wiring diagram SCH07
Wiring diagrams
Installation Instructions
380mm shoe-steel + U-C
400mm shoe-rubber + U-C
Anti theft device
Arm hose rupture valve
Boom hose rupture valve
Boom hose rupture valve1
Bracket for quickfit
CareTrack1
CareTrack2
Extra work lamp- front
Extra work lamp- rear
FOPS (Level 2)
Grapple piping for long arm 1,9m
Grapple piping for standard arm
Hydraulic quickfit for long arm 1,9m -
Hydraulic quickfit for long arm 1,9m -single type
Hydraulic quickfit for standard - double
Hydraulic quickfit for standard - double1
Hydraulic quickfit for standard arm - single type
Long arm 1,9m
Long arm 1,9m1
Pilot control change
Rear view side mirror
Rear view side mirror1
Rotating beacon
Travel alarm
X1 piping with long arm 1,9m
Repair
Adjusting operation
Air conditioning unit, maintenance
Air conditioning unit, refrigerant check and recharging
Alternator, inspection
Battery, charging
Bottom roller, measurement of wear
Bottom roller, removal and installation
Cab, installation
Cab, removal
Center passage, assembly
Center passage, disassembly
Center passage, maintenance standard
Center passage, tools
Coasting left and right swing
Compression pressure inspection
Control pattern selector valve, mode setting method
Coolant, checking anti-freeze resistance
Coolant, checking anti-freeze resistance1
Counterweight, installation1
Counterweight, installation2
Counterweight, removing1
Counterweight, removing2
Counterweight, removing3
Creeping of hydraulic cylinder
Cylinder speed
Cylinder, assembly
Cylinder, disassembly
Cylinder, removal and installation
Cylinder, tools
Digging unit, maintenance standard
Engine mounting
E-tools, NET 8940-00350 Replace tool for the swing motor assembly
E-tools, NET 8940-00370 Guide pin for track motor and swing ring gear
E-tools, NET 8940-00380 Replacement tool for swing ring gear
Fan belt and or alternator belt, checking and adjusting tension
Flexible coupling
Hydraulic pressure, measuring and adjustment
Idler, installation
Idler, measurement of wear
Idler, removal
Main control valve, assembly
Main control valve, disassembly
Main relief valve, adjustment
Main relief valve, assembly
Main relief valve, disassembly
Measuring condition
Measuring of swing bearing clearance
NET 8940-00200 Replace tool for the remote control valve joint
Periodic inspection and maintenance procedure
Periodic maintenance chart
Port relief valve pressure, measuring and adjusting
Port relief valve, assembly
Port relief valve, disassembly
Pump, assembly (Nachi pump)
Pump, assembly
Pump, disassembly
Pump, maintenance standard (Nachi pump)
Pump, tools (Nachi pump)
Pump, tools
Rubber track, installing
Rubber track, removing
Rupture valve, replacing (boom cylinder)
Rupture valve, replacing (dipper arm cylinder)
Slew ring gear, installation
Slew ring gear, removal
Solenoid valve, disassembly and assembly
Solenoid valve, inspection
Spring package, disassembly
Spring package, measurement of wear
Sprocket, installation
Sprocket, measurement of wear
Sprocket, removal
Straight traveling performance
Superstructure, installation
Superstructure, removal
Swing gearbox, assembly
Swing gearbox, disassembly
Swing gearbox, maintenance standard
Swing motor, assembly
Swing motor, disassembly
Swing motor, maintenance standard
Swing speed
Tools & equipment
Top roller, installation
Top roller, measurement of wear
Top roller, removal
Track chain, installation
Track chain, measurement of wear1
Track chain, measurement of wear2
Track chain, removal
Track gearbox, assembly
Track gearbox, disassembly
Track gearbox, maintenance standard
Track links, replacing
Track motor, assembly
Track motor, disassembly
Track motor, measurement
Track running speed
Track, adjusting track sag
Track, adjusting track sag1
Travel Speed
Valves, adjusting
Safety
Cautions during operation
General precautions
Move and operate machine safely
Preparations for work
Service Bulletins
Air conditioning compressor
Air conditioning unit, resistor
Air conditionning condenser fan shroud
Arm cylinder hose leakage
Arm cylinder lug, welding improvement
Boom support, expander bolts
Boom support, pivot play
Bottom roller improvement
Bucket cylinder hose
Bucket cylinder hose1
Change of swing ring gear greasing period
Cylinder head gasket
Dipper arm welding
Dozer blade valve
Engine mounting bracket, improvement
Exhaust white smoke improvement
Expansion tank, improvement
Expansion tank, improvement1
Fuel filler pump service kit
Fuel filter bracket
Fuel injection pump leakage
Fuel level indicator
Fuel sampling, method
Genuine coolant use
Horn relay, change
Hose (Main control valve to boom cylinder)
Idler bracket
Main oil pump, replacement
Main pump shaft seal
Maintenance of Stored Machines
Master switch change
New coolant
New horn
New product
New Radio Antenna
New slew ring gear seal
Option anti-theft, instruction
Rubber track improvement
Speaker change
Swing ring gear improvement
Swing ring gear seal improvement
Track gearbox internal damage
Turning joint internal leakage
Washer pump change
Water separator, change
Wiper motor link
Wire harness, improvement
Special Tools, Misc
GRD G700B LabourTimeGuide
Hammer hydraulic option, installing new
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
Special Tools Recommendations
Time Guide Current generation
Time Guide Old generation
Specifications
Air preheater, specifications
Alternator, specifications
Battery, specifications
Cooling system, specifications
Electric horn, specifications
Engine, specifications
Fuel filler pump, specifications
Fuel injection pump, specifications
Fuel system, specifications
Fuse box, specifications1
Fuse box, specifications2
Injectors, specification
Lubrication system, specifications
Preheating relay, specifications
Safety start relay, specifications
Slow blow fuse, specifications
Starter motor, specifications
Travel alarm, specifications
Valve system specifications
Window limit switch, specifications
Wiper controller, specifications
Wiper motor, specifications
Work lights and headlights, specifications
