Martin Welker
104
230,310
Volvo Excavator EC35 Service Repair Manual
Brand: Volvo
Type of Machine: Excavator
Model: Volvo EC35 Excavator
Number of Pages: 4842 Pages
1 Volvo EC35
Description
Adjusting the track sagging Figure 2
Adjusting the track sagging Figure 3
Adjusting the track sagging Figure 3-
Adjusting the track sagging Figure 5
Adjusting the track sagging Figure 6
Adjustment of fuel injection pump
Applying the brake Figure 1
Applying the brake
Auxiliary block with stand-by valve
Auxiliary pressure block
Battery, description Figure 1
Boom cabin weather roof Figure 1
Boom cabin weather roof Figure 2
Brake valve (counter balance valve) Figure 1
Brake valve (counter balance valve) Figure 2
Brake, description
Cabin door, description Figure 1
Cabin door, description Figure 2
Change engine oil, replace filter Figure 1
Changing the hydraulic oil Figure 1
Changing the hydraulic oil Figure 2
Changing the hydraulic oil Figure 3
Changing the hydraulic oil filter Figure 1
Changing the hydraulic oil filter Figure 2
Changing the hydraulic oil filter Figure 3
Cleanliness, braking and hydraulic system
Colour codes
Control valve
Cooling system, description, from serial nr. EC 35 #283.18963, EC #45 284 17 799
Description engine Figure 1
Description engine
Description fuel system Figure 1
Design centre passage, lines Figure 1
Design of axial piston motor Figure 1
Design of travel motor
Designations of electrical components from serial nr. EC 35 #283 18 963; EC 45 #284 17 799
Diagnostics
Electric system, trouble shooting
Electric welding
Electrical components (hydraulic system side) Figure 1
Electrical components (hydraulic system side)1 Figure 1
Electrical components (machine side) Figure 1
Electrical components (machine side) Figure 2
Electrical components (machine side) Figure 3
Electrical components (machine side) Figure 4
Electrical components (machine side) Figure 5
Electrical components (machine side) Figure 6
Electrical system, description
Electronic multi-function switch PUMA (ECU1) Figure 1
Engine air filter unit Figure 1
Engine performance diagram (measuring values for one hour with fan) Figure 1
Engine trouble shooting
Engine, description
Engine, tightening torques
error codes
Fuel injection nozzle from serial nr. EC 35 #283 18 963, EC 45 #284 17 799
Fuel injection pump, description
Function centre passage, lines
Fuses for cabin equipment
Fuses for machine equipment
General description frame Figure 1
General notes to be observe when working on power transmission assemblies
General notes to be observe when working on power transmission assemblies1
General pressure limiting valve
Generator Figure 1
Generator Figure 3
Generator
High speed solenoid valve Figure 1
High speed solenoid valve Figure 2
Hose rupture valve on boom cylinder
Hose rupture valve on dipper
Hydraulic components, cleanliness during handling
Hydraulic components, storing and transporting
Hydraulic motor – slewing of superstructure Figure 1
Hydraulic oil, description
Hydraulic oil, storage and handling
Hydraulic safety solenoid valve
Hydraulic system, capacities
Hydraulic system, description Figure 1
Hydraulic system, replacement of hydraulic filter element1 Figure 1
Hydraulic system, replacement of hydraulic filter element1 Figure 3
Identification of lines
Identification of plug connectors lines1
Identification of plug connectors lines2
Inside of machine cabin light cabin illumination weather roof; fan cabin heater - variant 1 Figure 1
Inside of machine cabin light cabin illumination weather roof; fan cabin heater - variant 2 Figure 1
Inside of machine cabin light cabin illumination weather roof; fan cabin heater - variant 2-1 Figure 1
Jump starting
Key-operated engine shut down system with EDD-solenoid Figure 1
Load capacity tables EC 35 Figure 1
Load capacity tables EC 45 Figure 1
Lubricating system, description Figure 1
Lubricating system, description1
Maintenance instructions
Maintenance standards
Marking of plug connectors
Minus connection
Operating control elements on driver’s platform Figure 1
Operating control elements on driver’s platform Figure 2
Plus connection
Position of components Figure 1
Precautions when handling plug connectors Figure 1
Precautions
Pressure regulator (hydraulic control elements)
Pressure relief valves
Recharging of batteries
Recommended lubricants
Relay group plug connector cabin plug connector cabin heater fan
Relay
Releasing the slewing brake
Repairing hydraulic system
Service and maintenance
Solenoid valve, attachment carrier Figure 1
Solenoid valve, attachment carrier Figure 2
Special tools
Sprocket, wear measurement
Starter relay Figure 1
Starter relay Figure 3
Starter relay
Starter, preheating relay, ignition switch Figure 1
Starter, preheating relay, ignition switch Figure 2
Starter, preheating relay, ignition switch Figure 4
Starter, preheating relay, ignition switch Figure 6
Starting process
Steering system, description
Technical data
Testing method
Tests before disassembly
Tightening torque
Travel gear Figure 1
Travel gear, oil change Figure 1
Travel gear
Troubleshooting chart
Valve block for slewing gear
Volvo standard tightening torques
Warning system
Way valve, control valve Figure 1
Windscreen
Working headlights and main headlights, description Figure 1
Working principle of the travel system Figure 1
Diagrams
Balancing valve (offset cylinder) Figure 1
Balancing valve (offset cylinder) Test and adjustment procedure
Complete wiring diagram (part 1) from serial nr. EC 35 #283 18 963; EC 45 # 284 17 799 Figure 1
Complete wiring diagram (part 2) Figure 1
Complete wiring diagram (part 2) Figure 2
Complete wiring diagram (part 2) Figure 3
Complete wiring diagram (part 2) Figure 5
Complete wiring diagram (part 2) Figure 7
Complete wiring diagram (part 2) from serial nr. EC 35 #283 18 963; EC 45 #284 17 799 Figure 1
Complete wiring diagram (part 2) from serial nr. EC 35 #283 18 963; EC 45 #284 17 799 Figure 2
Complete wiring diagram (part 2) from serial nr. EC 35 #283 18 963; EC 45 #284 17 799 Figure 3
Complete wiring diagram (part 2) from serial nr. EC 35 #283 18 963; EC 45 #284 17 799 Figure 5
Complete wiring diagram (part 2) from serial nr. EC 35 #283 18 963; EC 45 #284 17 799 Figure 7
Hose rupture valve on boom cylinder Figure 1
Hydraulic circuit for bucket Figure 1
Hydraulic circuit, boom Figure 1
Hydraulic circuit, dipper arm Figure 1
Hydraulic circuit, dozer blade Figure 1
Hydraulic circuit, slewing gear offset Figure 1
Hydraulic circuit, travel system Figure 1
Hydraulic diagram EC 35, complete Figure 1
Hydraulic diagram EC 45, complete
Hydraulic diagram, complete from serial nr. EC 35 # 283 18 963 Figure 1
Hydraulic diagram, complete from serial nr. EC 45 #284 17 799 Figure 1
Hydraulic system, auxiliary pressure block Figure 1
Hydraulic system, auxiliary pressure block from serial nr. EC 35 #283 18 963; EC 45 #284 17 799
Hydraulic system, function diagram Figure 1
Hydraulic system, function diagram from serial nr. EC 35 #283 18 963; EC 45 # 284 17 799
Line connections in the wiring loom Figure 1
Return flow, hydraulic circuit for accessories Figure 1
Return flow, hydraulic circuit for accessories from serial nr. EC 35 # 283 18 963; EC 45 # 284 17 799
Schematic cooling system Figure 1
Schematic exhaust Figure 1
Schematic exhaust
Servo hydraulics Figure 1
Servo hydraulics from serial nr. EC 35 # 283 18 963; EC 45 # 284 17 799
Servo hydraulics
Solenoid valve for hydraulic working unit Figure 1
Specifications Figure 1
Specifications
Wiring cabin - console left Figure 1
Wiring cabin - console right Figure 1
Wiring diagram - legend
Wiring engine - part 1 Figure 1
Wiring engine - part 2 Figure 1
Wiring engine - part 3 Figure 1
Installation Instruction
CareTrack
CareTrack1
Hydraulic quick coupling with single acting circuit on 1, 4 m arm
Hydraulic quick coupling with single acting circuit on 1, 7 m arm
Hydraulic quick coupling with single circuit on 1, 4 m arm and tool holder
Hydraulic quick coupling with single circuit on 1, 7 m arm and tool holder
Safety valve on boom and arm cylinder
Safety valve on boom cylinder
Repair
Assemble the generator
Assembling pistons and guide sleeves
Assembling the brake discs
Assembling the cabin Figure 1
Assembling the cabin Figure 3
Assembling the crawler track Figure 2
Assembling the crawler track Figure 3
Assembling the cylinder block
Assembling the fuel injection line
Assembling the guide sprocket
Assembling the hydraulic motor Figure 1
Assembling the hydraulic motor Figure 5
Assembling the hydraulic motor Figure 6
Assembling the hydraulic motor Figure 7
Assembling the hydraulic motor Figure 8
Assembling the hydraulic motor Figure 9
Assembling the hydraulic motor Figure 10
Assembling the hydraulic motor Figure 11
Assembling the hydraulic motor Figure 12
Assembling the hydraulic motor Figure 13
Assembling the hydraulic motor Figure 15
Assembling the hydraulic motor Figure 16
Assembling the hydraulic motor Figure 17
Assembling the hydraulic motor Figure 21
Assembling the hydraulic motor Figure 22
Assembling the hydraulic motor Figure 24
Assembling the hydraulic motor Figure 25
Assembling the hydraulic motor Figure 26
Assembling the hydraulic motor Figure 27
Assembling the hydraulic motor Figure 28
Assembling the hydraulic motor Figure 30
Assembling the hydraulic motor Figure 31
Assembling the hydraulic motor Figure 32
Assembling the hydraulic motor Figure 36
Assembling the hydraulic motor Figure 37
Assembling the oil distributor seals
Assembling the radial seals Figure 1
Assembling the roller bearings
Assembling the rubber track
Assembling the starter Figure 2
Assembling the starter Figure 3
Assembling the superstructure
Assembling the travel gear Figure 1
Assembling the travel gear Figure 3
Assembling the travel gear Figure 8
Assembling the travel gear Figure 9
Assembling the travel gear Figure 10
Assembling the travel gear Figure 11
Assembling the travel gear Figure 14
Assembling the travel gear Figure 15
Assembling the travel gear Figure 22
Assembling the travel gear Figure 26
Assembling the valve block Figure 1
Auxiliary pressure block Figure 1
Bleeding the fuel system
Changing the fuel filter Figure 1
Changing the V-belt
Characteristics of the glow plug system Figure 1
Characteristics of the glow plug system Figure 2
Checking and adjusting the breaker (volumetric capacity)
Checking and adjusting the dipper arm cylinder (volumetric capacity)
Checking and adjusting the FR pressure control valve Figure 1
Checking and adjusting the LS pressure relief valve Figure 1
Checking and adjusting the pilot pressure
Checking the glow plug
Checking the hydraulic oil level Figure 1
Checking the hydraulic oil level Figure 2
Checking the performance characteristics Figure 1
Checking the voltage regulation Figure 1
Compression pressure inspection Figure 1
Compression pressure inspection from serial nr. EC 35 #283 18 963, EC 45 #284 17 799
Control valve block for slewing gear, test and adjustment Figure 1
Control valve block for slewing gear, test and adjustment Figure 2
Cooling system, disassembly assembly, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799
Cooling system, maintenance, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799
Creeping of hydraulic cylinder Figure 1
Cylinder block, disassembly and assembly
Cylinder head, disassembly assembly
Cylinder speed
Deviation when travelling straight ahead Figure 2
Disassemble the generator Figure 1
Disassemble the generator Figure 4
Disassembling pistons and guide sleeves Figure 1
Disassembling the fuel injection line
Disassembling the fuel pump Figure 1
Disassembling the hydraulic motor Figure 1
Disassembling the hydraulic motor Figure 2
Disassembling the hydraulic motor Figure 6
Disassembling the hydraulic motor Figure 7
Disassembling the hydraulic motor Figure 8
Disassembling the hydraulic motor Figure 10
Disassembling the hydraulic motor Figure 11
Disassembling the hydraulic motor Figure 12
Disassembling the hydraulic motor Figure 13
Disassembling the hydraulic motor Figure 14
Disassembling the hydraulic motor Figure 16
Disassembling the hydraulic motor Figure 17
Disassembling the hydraulic motor Figure 19
Disassembling the hydraulic motor Figure 21
Disassembling the hydraulic motor Figure 22
Disassembling the hydraulic motor Figure 23
Disassembling the hydraulic motor Figure 25
Disassembling the hydraulic motor Figure 26
Disassembling the hydraulic motor Figure 27
Disassembling the hydraulic motor Figure 28
Disassembling the hydraulic motor Figure 29
Disassembling the hydraulic motor Figure 30
Disassembling the hydraulic motor Figure 31
Disassembling the hydraulic motor Figure 32
Disassembling the hydraulic motor Figure 35
Disassembling the hydraulic motor Figure 37
Disassembling the roller bearings
Disassembling the travel motor Figure 1
Dismantling the starter Figure 1
Dismantling the starter Figure 2
Dismantling the starter Figure 3
Dismantling the starter Figure 4
Dismantling the starter Figure 5
Dismantling the starter Figure 7
Dismantling the starter Figure 8
Dismantling the travel gear Figure 7
Dismantling the travel gear Figure 9
Dismantling the travel gear Figure 14
Dismantling the travel gear Figure 16
Dismantling the travel gear Figure 17
Dismantling the travel gear Figure 18
Dismantling the travel gear Figure 22
Dismantling the travel gear Figure 24
Dismantling the valve block Figure 1
Drive sprocket
Engine, adjusting operation
Fuel injection pump, disassembly and assembly
Gear train and camshaft, disassembly and assembly
Hose rupture valve on boom cylinder Test and adjustment procedure Figure 1
Hose rupture valve on boom cylinder Test and adjustment procedure Figure 2
Hose rupture valve on boom cylinder, leak test Figure 1
Hose rupture valve on dipper arm cylinder, leakage test Figure 1
Hydraulic lock, hose rupture valve Figure 1
Hydraulic motor 1, travel gear Figure 1
Idle speed, inspection and adjustment Figure 1
Idle speed, inspection and adjustment from serial nr. EC 35 283 18 963, EC 45 284 17 799 Figure 1
Inspection
Installation of the solenoid Figure 1
Installing the engine Figure 1
Installing the engine Figure 4
Installing the engine Figure 8
Installing the engine Figure 9
Installing the engine Figure 11
Installing the engine Figure 12
Installing the engine Figure 13
Installing the engine Figure 16
Installing the engine Figure 17
Installing the engine Figure 18
Installing the engine, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 6
Installing the engine, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 11
Installing the engine, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 17
Installing the fuel pump
Installing the generator Figure 1
Installing the glow plug Figure 1
Installing the hydraulic pump Figure 1
Installing the hydraulic pump Figure 2
Installing the hydraulic pump from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 1
Installing the hydraulic pump from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 2
Installing the travel motor Figure 1
Installing the valve block Figure 1
Installing the valve block, from serial nr. EC 35 # 283 18 963; EC 45 # 284 17 799
Lubrication system, disassembly and assembly
Measuring the play of the slewing bearing Figure 1
Measuring the play of the slewing bearing Figure 2
Measuring the play of the slewing bearing Figure 3
Measuring the play of the slewing bearing Figure 4
Oil cooler, removal and installation, from serial nr. EC 35 #283 18 963; EC 45 #284 17 799
Oil cooling system, cleaning, from serial nr. EC 35 #283 18 963; EC 45 #284 17 799
Operation numbers for additional work
Periodic inspection and maintenance procedure
Periodic maintenance chart
Power control pressure limiting valve (relief valves) Figure 1
Power control pressure limiting valve (relief valves) Figure 2
Radiator, removal and installation from serial nr. EC 35 #283 18 963, EC 45 #284 17 799
Removing the brake discs
Removing the cabin Figure 2
Removing the cabin Figure 5
Removing the cabin
Removing the coolant pump till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 1
Removing the coolant pump till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 2
Removing the coolant pump till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 4
Removing the coolant pump till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 5
Removing the crawler tracks
Removing the cylinder block Figure 1
Removing the engine Figure 1
Removing the engine Figure 3
Removing the engine Figure 5
Removing the engine Figure 8
Removing the engine Figure 9
Removing the engine Figure 10
Removing the engine Figure 12
Removing the engine Figure 13
Removing the engine Figure 17
Removing the engine, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 1
Removing the engine, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 8
Removing the engine, from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 13
Removing the engine
Removing the gear motor Figure 1
Removing the gear motor Figure 2
Removing the gear motor Figure 3
Removing the gear motor Figure 4
Removing the gear motor Figure 5
Removing the gear motor Figure 7
Removing the generator
Removing the guide sprocket
Removing the hydraulic oil pump Figure 2
Removing the hydraulic oil pump Figure 3
Removing the hydraulic oil pump from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 2
Removing the hydraulic oil pump from serial nr. EC 35 #283 18 963, EC 45 #284 17 799 Figure 3
Removing the oil distributor seals Figure 1
Removing the radial seals
Removing the radiator Figure 1
Removing the radiator Figure 2
Removing the radiator Figure 5
Removing the radiator Figure 6
Removing the rubber track
Removing the starter Figure 1
Removing the starter Figure 2
Removing the superstructure Figure 1
Removing the thermostat housing till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 1
Removing the thermostat housing till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 2
Removing the thermostat housing till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 3
Removing the thermostat housing till serial nr. EC 35 #283 18 462, EC 45 #284 17 298 Figure 6
Removing the track roller Figure 2
Removing the track roller Figure 3
Removing the track supporting idler
Removing the valve block Figure 1
Removing the valve block, from serial nr. EC 35 # 283 18 963; EC 45 # 284 17 799
Slewing overtravel Figure 1
Slewing overtravel Figure 2
Slewing overtravel Figure 3
Slewing overtravel
Stand-by pressure Figure 1
Stand-by pressure
Swing speed Figure 1
Swing speed
Tensioning the V-belt
Track running speed
Travel Speed Figure 2
Travel Speed
Valves adjustment from serial nr. EC 35 #283 18 963, EC 45 #284 17 799
Valves, adjusting Figure 1
Valves, adjusting Figure 2
Valves, adjusting
Safety
General precautions
Move and operate machine safely
Preparations for work
Safety concerns everybody!
Safety measures during operation
Service Bulletins
Biodiesel fuel for Volvo CE
Check method on engine oil consumption
Cylinder, improvement
Fuel sampling, method
Internal leakage dozer blade, tolerance
Maintenance of Stored Machines
New fastener assortment
New slew motor brake kit
Relief valve, change
Vibrations after exchanging rubber tracks
Special Tools, Misc
Special tool Manual
Special Tools Recommendations
Time Guide Current generation
Time Guide Old generation
Specifications
Alternative fuels
Basic objects of examination
Battery, specification
Cabin, specification
Cabin, tightening torques
Caution sign - Diesel engine starting procedure
Caution sign - Emergency exit
Caution sign - Lashing
Caution sign - Lifting the machine
Caution sign - Operation and maintenance
Caution sign - Track tension
Cooling system
Drive gear, tightening torque
Electrical system, technical data
Electrical system
Engine, specifications
Frame, technical data
Fuels, lubricants and filling capacities (litres)
Fuels, lubricants and filling capacities (litres)1
Hydraulic motor 1 - travel system
Hydraulic motor 1 – travel system
Hydraulic motor, slewing
Hydraulic oil tank, filling capacity
Hydraulic system EC 35
Hydraulic system EC 45
Identification of the engine EC 35, EC 45
Identification of the engine, from serial nr. EC 35 #283 18 963, EC 45 284 17 799 Figure 1
Machine identification Figure 1
Main dimensions EC 35 Figure 1
Main dimensions EC 45 Figure 1
Mechanical transmission - track gearbox
Mechanical transmission - track gearbox1
Miscellaneous
Plugs with tapered thread
Plugs with tapered thread1
Power transmission
Reach EC 35
Reach EC 45
Reach of the working attachment EC 35 Figure 1
Reach of the working attachment EC 45
Slewing ring, tightening torques
Slewing ring, tightening torques1
Specification, engine1
Specification, engine2
Specification, filling capacities
Specification, filling capacities1
Specification, weight
Specification, weight1
Start switch, specifications
Strength class 8.8 Metric coarse and fine threads
Strength class 10.9 Metric coarse and fine threads
Test and adjustment values EC 35
Test and adjustment values EC 45 from serial nr. # 284 17 799
Test and adjustment values EC 45-1
Tightening torques, engine
Tightening torques, engine1
Track pad, tightening torque
Track roller, tightening torque
Track supporting idler, tightening torque
UNC-threads, coarse pitch
Valve timing
Valve timing1
Warning and information decals
Warning sign - Open engine hood only with engine stopped
Warning sign - Safety distance from the work area
Working headlights and main headlights, specification
