Martin Welker
104
230,310
Volvo Excavator EC25 Service Repair Manual
Brand: Volvo
Type of Machine: Excavator
Type of Manual: Service Repair Manual
Model: Volvo EC25 Excavator
Number of Pages: 2804 Pages
Adjusting the fuel injection timing
Adjusting the pressure and checking for leaks
Adjusting the track sagging
Adjusting the valves
Applying the brake
Assembling the starter
Assembling the valve block
Assignment of elements
Balancing valve (offset cylinder) 1
Battery, description
Bleeding the fuel system
Boom
Brake valve (counter balance valve)
By-pass valve
Cab parts, change
Cabin, specification
CareTrack gen
CareTrack
Caution sign - Diesel engine starting procedure
center passage line
Changing the fuel filter
Changing the hydraulic oil filter
Chapter 2 Engine
Chapter 3 Electrical system
Chapter 4 Power transmission
Chapter 9 Hydraulic system
Characteristics of the glow plug system
Check valve inside MCV
Checking and adjusting the injection nozzles
Checking and adjusting the pressure relief valves
Checking the compression pressure
Checking the glow plug
Checking the hydraulic oil level
Checking the openings for clogging
Checking the voltage regulation
Cleaning the oil cooler
Control valve block for slewing gear Test and adjustment
Control valve
Creeping of hydraulic cylinders
Cylinder speed
Cylinder, improvement
Design of travel motor
Dipper arm welding improvement
Dipper arm welding process improvement
Dismantling and assembling the generator
Dismantling the starter
Dismantling the valve block
Electrical system, description
Engine performance diagram
Frame and crawler unit
Fuel sampling, method
Fuels Lubricants and filling capacities (litres)
General notes to be observe when working on the hydraulic system
General notes to be observed when working on power transmission assemblies
General
High speed solenoid valve
Hose rupture valve on boom cylinder Test and adjustment procedure
Hose rupture valve on boom cylinder, leak test
Hose rupture valve on dipper, leak test
Hydraulic circuit for boom
Hydraulic circuit for bucket
Hydraulic circuit for dozer blade
Hydraulic circuit for slewing gear and offset
Hydraulic circuit of travel motors
Hydraulic circuit
Hydraulic Diagram
Hydraulic motor 1 - travel system
Hydraulic safety solenoid valve
Identification of the engine
Idle speed, inspection and adjustment
Ignition switch
Installation of the solenoid
Installing the engine
Installing the glow plug
Installing the oil filter
Installing the valve block
Internal leakage dozer blade, tolerance
Key-operated engine shut down system with EDD-solenoid
Load capacity tables
Lubrication system, description
Lubrication system, specification
Machine identification
Main control valve leakage
Main dimensions
Maintenance instructions
Maintenance of Stored Machines
Measuring conditions
Measuring the play of the slewing bearing
Mechanical transmission - track gearbox
New coolant
New slew motor brake kit
Operator side
Option anti-theft, instruction
Part numbers for cylinder seal kits (new supplier)
Performance when travelling straight on
Position of components
Precautions when handling plug connectors
Pressure relief valve P1
Pressure relief valve P2
Pressure relief valve P3
Pump companion
Reach of the working attachment
Reach, unit
Recommended lubricants
Releasing the slewing brake
Removing and installing the cabin
Removing and installing the coolant pump
Removing and installing the generator
Removing and installing the guide sprocket
Removing and installing the oil pressure switch
Removing and installing the pressure relief valve
Removing and installing the rubber track
Removing and installing the starter
Removing and installing the superstructure
Removing and installing the thermostat housing
Removing and installing the track 1
Removing and installing the track drive
Removing and installing the track roller
Removing and installing the track supporting idler
Removing and installing the travel gear
Removing the engine
Removing the oil filter
Removing the valve block
Return flow, hydraulic accessories circuit
Schematic, fuel system
Secondary valves
Slew motor improvement
Slewing overtravel
Slewing speed
Solenoid valve for hydraulic working unit
Special tool catalog
General
Index
Hooks
1. Enviroment and Safety equipment
2. Measuring equipment
3. Tightening and Loosening tools
4. Lifting equipment
5. Pullers and Pressing equipment
6. Drifts
7. Guide pins and Guide sleeves
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Specification, engine
Starter side
Starting process
Starting the engine with jump wires
Test and adjustment mark for EC 25
Tests and adjustments of the power control
Tests before disassembly alternator
Tightening torques engine S3L-S3L2
Time Guide Current generation
Track drive, wear measurement
Track travel speed
Travel speed
Valve block for slewing gear
Working headlights and main headlights, description
Working principle of the travel system
