Martin Welker
104
230,310
Volvo Excavator EC240 LC Service Repair Manual
Brand: Volvo
Type of Machine: Excavator
Model: Volvo EC240 LC Excavator
Number of Pages: 4396 Pages
1 Volvo EC240 LC
Description EC240 LC
2 piece boom and cylinder, description
2 piece boom, description
2 piece boom, valve description
2 piece boom, valve disassembly
Additional counterweight & digging unit
Air cleaner restriction switch, description
Air cleaner restriction switch, specifications
Air heater, description
Air heater, specifications
Air horn, description
Air horn, specifications
Alarm, description
Alternator, description
Alternator, specifications
Auto manual switch, description
Auto manual switch, specifications
Automatic control system, description
Automatic engine warm-up, description
Automatic idling, description
Battery relay, description
Battery relay, specifications
Battery, description
Battery, specifications
Bottom roller, assembly
Bottom roller, description
Bottom roller, disassembly
Bottom roller, installation
Bottom roller, measurement of wear
Bottom roller, removal
Bottom roller, tools for disassembly and assembly
Brake, description
Buzzer stop & confirm switch, description
Charging, description
Chassis connection
Check valve, description
Components location, engine related sensors1
Components location, engine related sensors2
Components location, engine related sensors3
Components location, engine related sensors4
Components location, engine related sensors5
Components location, engine related sensors6
Condenser, description
Connector, configuration
Coolant temperature sensor, description
Coolant temperature sensor, specifications
Coolant temperature switch, description
Coolant temperature switch, specifications
Counterweight, installation
Counterweight, removal
Cylinder, description
Cylinder, disassembly and assembly
Cylinder, troubleshooting
DC–DC converter, description
DC–DC converter, specifications
Digging unit, description
Digging unit, maintenance
Disassembly and assembly, general
Disassembly and assembly, general1
Display unit (D-ECU), description
Electrical components
Electrical system, description
Electrical system, troubleshooting
Engine control
Engine coolant heater
Engine oil heater, description
Engine oil pressure switch, description
Engine oil pressure switch, specifications
Engine speed control switch, description
Engine speed control switch, specifications
Engine speed sensor, description
Engine speed sensor, specifications
Engine stop motor, description (EC210 only)
Engine stop motor, specifications (EC210 only)
Evaporator, description
Examples, hydraulic system
Examples, power transmission
Explanations to wiring diagrams
Flow control switch, description
Fuel cut-off relay (50A), description (EC240 only)
Fuel cut-off solenoid, description (EC240 only)
Fuel cut-off solenoid, specifications
Fuel filling pump, description
Fuel filling pump, specifications
Fuel level sensor, description
Fuel level sensor, specifications
Fuel lines, description
Fuel tank, description
Fuel warmer, description
Fuse box, description
Fuse, specifications
Heating control valve, description
Hydraulic oil pressure switch, description
Hydraulic oil pressure switch, specifications
Hydraulic quickfit, description
Idler, assembly
Idler, description
Idler, disassembly
Idler, installation
Idler, measurement of wear
Idler, removal
Idler, tools for disassembly and assembly
Inlet and exhaust system, description
Instrument panel (I-ECU), description
Instrument panel (I-ECU), gauge and indicator
Instrument panel (I-ECU), specifications
Left switch panel (9R), description
Line rupture valve (arm), assembly
Line rupture valve (arm), description
Line rupture valve (arm), disassembly
Line rupture valve (arm), specifications
Line rupture valve (boom), assembly
Line rupture valve (boom), description
Line rupture valve (boom), disassembly
Line rupture valve (boom), specifications
Line rupture valve (boom), troubleshooting
Line rupture valve, general
List of circuits
Lower line
Lubrication
Machine status indication
Main line
Master switch, description
Master switch, specifications
Measuring of bushing outer diameter wear
Measuring of clearance between links wear
Measuring of flange
Measuring of link height wear
Measuring of shoe grouser height wear
Measuring of top roller flange width wear
Measuring of top roller tread outer diameter wear
Measuring of track link pitch wear
Measuring of tread and flange wear
Mode selection & engine speed sensing power control, description
Mode selection & engine speed sensing power control, specification
NET 8940-00020 Replace tool for the radiator assembly
NET 8940-00170 Replace tool for the hydraulic tank and fuel tank
NET 8940-00180 Press disc for hydraulic pump cover seal
NET 8940-00190 Travel motor guide pin
NET 8940-00200 Replace tool for the remote control valve joint
NET 8940-00210 Inspection tool for the rotary switch
NET 8940-00220 Inspection tool for the power shift valve
NET 8940-00230 Engine hood instrument
NET 8940-00240 Replace tool for the hydraulic tee fitting
NET 8940-00250 Replace tool for the hydraulic tee fitting
NET 8940-00260 Replace tool for the turning joint
NET 8940-00270 Replace tool for the slew ring gear
NET 8940-00290 Slew motor guide pin
NET 8940-00300 Slew ring gear guide pin
Positive feed
Power boost, description
Precaution of connector handling
Preheating controller, description
Preheating controller, specifications
Preheating relay, description
Preheating relay, specifications
Preheating system, description
Pump flow control (option), description
Pump flow control (option), specification
Radiator, description
Radio, description
Radio, specifications
Regulator, description
Relay box, specifications
Resistor box, description
Resistor box, specifications
Return and pump line
Right switch panel (4R), description
Right switch panel (6R), description
Roller flange width, measurement of wear
Roller tread diameter, measurement of wear
Safety limit switch, description
Safety limit switch, specifications
Safety start relay, description
Safety start relay, specifications
Safety start  stop, description
Selection of track shoes
Self diagnosing
Servo hydraulic line
Servo hydraulic selector valve, description
Servo hydraulic selector valve, specification
Shuttle valve block, description
Slew brake, description
Slew gearbox (EC210), assembly
Slew gearbox (EC210), description
Slew gearbox (EC210), disassembly
Slew gearbox (EC210), lubrication
Slew gearbox (EC210), maintenance standard
Slew gearbox (EC210), troubleshooting
Slew gearbox (EC240), assembly
Slew gearbox (EC240), description
Slew gearbox (EC240), disassembly
Slew gearbox (EC240), maintenance standard
Slew gearbox (EC240), principle of operation
Slew motor, adjustment
Slew motor, assembly
Slew motor, description
Slew motor, disassembly
Slew motor, lubrication and air purging
Slew motor, measurement of wear
Slew motor, principle of operation
Slew motor, troubleshooting
Slow blow fuse, description
Slow blow fuse, specifications
Spring package, assembly
Spring package, description
Spring package, disassembly
Start switch, description
Start switch, specifications
Starter motor, description
Starter motor, specifications
Starting engine with booster cables
Starting operation
Steering system, description
Thermo switch, description
Thermo switch, specifications
Tool attachment, adjustment
Top roller, assembly
Top roller, description
Top roller, disassembly
Top roller, installation
Top roller, measurement of wear
Top roller, removal
Top roller, tools for disassembly and assembly
Track chain, description
Track chain, installation
Track chain, measurement of wear
Track chain, removal
Track motor (EC210), assembly
Track motor (EC210), description
Track motor (EC210), disassembly
Track motor (EC210), maintenance standard
Track motor (EC210), operating checks
Track motor (EC210), precautions for operation
Track motor (EC210), troubleshooting
Track motor (EC240), description
Track, measurement of wear
Travel alarm, description
Travel alarm, specifications
Travel speed selection, description
Troubleshooting, diagnosing procedure
Troubleshooting, electrical system
Troubleshooting, electronic control system
Turning joint, description
Turning joint, disassembly and assembly
Turning joint, inspection and troubleshooting
Undercarriage, description
Undercarriage, tightening torque
Upper frame (Superstructure), installation
Upper frame (Superstructure), removal
Vehicle electronic control unit (V-ECU), description
Window limit switch, description
Window limit switch, specifications
Windscreen wiper, components location
Windscreen wiper, description
Wiper controller, description
Wiper motor, description
Wiper motor, specifications
Work lamp and head lamp, description
Work lamp and head lamp, specifications
Diagrams EC240 LC
Hydraulic circuits, arm in boom raise
Hydraulic circuits, arm in conflux
Hydraulic circuits, arm out
Hydraulic circuits, boom lower
Hydraulic circuits, boom raise conflux (internal)
Hydraulic circuits, bucket
Hydraulic circuits, neutral
Hydraulic circuits, ports
Hydraulic circuits, slew (left)
Hydraulic circuits, slew priority (slew right arm in)
Hydraulic circuits, standard
Hydraulic circuits, straight travel (low auto shift)
Hydraulic circuits, straight travel arm (straight travel auto shift, arm in)
Hydraulic circuits, with option parts
Hydraulic components, description
Hydraulic diagram, schematic
Wiring diagram 1, main diagram, positive feed chassis connection
Wiring diagram 2, positive feed chassis connection, control units
Wiring diagram 3, function group 2, engine
Wiring diagram 4, function group 2, engine
Wiring diagram 5, function group 2, engine
Wiring diagram 6, function group 2, engine
Wiring diagram 7, function group 2, engine
Wiring diagram 8, function group 3, electrical, lighting etc.
Wiring diagram 9, function group 3, electrical, lighting etc.
Wiring diagram 10, function group 3, electrical, lighting etc.
Wiring diagram 11, function group 8, cab
Wiring diagram 12, function group 8, cab
Wiring diagram 13, function group 8, cab
Wiring diagram 14, function group 9, hydraulics
Wiring diagram 15, function group 9, hydraulics
Wiring diagram 16, function group 9, hydraulics
Wiring diagram 17, communication
Wiring diagram 18, automatic greasing system
Hammer hydraulic option, installing new
Repair EC240 LC
Bucket cylinder, description
Bucket cylinder, disassembly and assembly
Bucket cylinder, installation
Bucket cylinder, removal
Bucket cylinder, specifications
Bucket, adjustment of bucket clearance
Bucket, installation
Bucket, removal
Coasting left and right slew
Connectors, location
Creeping of hydraulic cylinder
Cylinder speed
Dipper arm, installation
Dipper arm, removal
Engine mounting
Flexible coupling
General, inspection
General, precautions
General, tools
Link, installation
Link, removal
Measuring condition
Measuring of slew bearing clearance
Measuring of sprocket tooth profile
Measuring of sprocket tooth width
Periodic maintenance table
Periodic maintenance table2
Slew speed
Sprocket, installation
Sprocket, measurement of wear
Sprocket, removal
Straight traveling performance
Time Guide1
Time Guide2
Track gearbox (EC210), assembly
Track gearbox (EC210), description
Track gearbox (EC210), disassembly
Track gearbox (EC210), maintenance standard
Track gearbox (EC210), precautions for operation
Track gearbox (EC210), troubleshooting
Track gearbox (EC240), assembly
Track gearbox (EC240), description
Track gearbox (EC240), disassembly
Track gearbox (EC240), maintenance standard
Track gearbox (EC240), precautions for operation
Track gearbox (EC240), tools
Track gearbox (EC240), troubleshooting
Track gearbox, installation
Track gearbox, removal
Track running speed
Track, adjusting track sag
Travel speed
Valve clearance adjustment
Service bullentin EC240 LC
Biodegradable hydraulic oil
CareTrack Telematics system
CareTrack, new software version 2008w6
Check method on engine oil consumption
DEF AdBlue AUS32 sampling, method
ECU, functional check
Fuel sampling, method
Hydraulic hose assembly leakage handling
Hydraulic system flushing method
Improvement of Main pump hose assembly
KOR service bulletin number change
Machine model
Modification of CareTrack wire harness
New product
New product1 (2)
New product1
Oil sampling, method
Oil sampling, sampling points
Operator's seat support change
Recommendations for Oil Sampling Intervals
Reports
Routines for reporting cracks on Boom and Arm
Track link repair kit
Special tools, misc EC240 LC
GRD G700B LabourTimeGuide Old version
RM Compaction ABG Time Guide Old
RM Compaction Time guide old version
RM Paving Systems ABG Time Guide Old
Special tool catalog
Special tools recommendations
Time Guide Current generation
Time Guide Old generation
Specifications EC240 LC
Air conditioning unit, description
Air conditioning unit, maintenance
Air conditioning unit, refrigerant check and recharging
Air conditioning unit, related components
Air conditioning unit, specifications
Boom lifting cylinder, description
Boom lifting cylinder, disassembly assembly
Boom lifting cylinder, installation
Boom lifting cylinder, specifications
Boom, installation
Boom, removal
Boom, specifications
Cab, installation
Cab, removal
Cab, specifications
Compressor, description
Compressor, specifications (V-5, R 134a)
Cooling system, specifications
Dipper arm cylinder, description
Dipper arm cylinder, disassembly and assembly
Dipper arm cylinder, installation
Dipper arm cylinder, removal
Dipper arm cylinder, specifications
Dipper arm, specifications
Drying filter, description
Drying filter, Specifications
Engine, description (EC210)
Engine, description (EC240)
Engine, specifications
Frame and track unit, specifications
Fuel injection system
Fuel system, specifications
Gearbox, specifications
General dimensions
Hydraulic oil, specifications
Hydraulic pressure, specifications
Hydrostatic drive, specifications
Location of components
Lubricating system, description
Lubricating system, specifications
Measurement conversion tables
Radiator and hydraulic oil cooler, description
Slew ring gear, removal installation
Slew ring gear, specifications
slew(slew) ring gear seals, installation
Specifications, general
Standard tightening torque
Stepping motor, description
Stepping motor, specifications
Viscose mount, description
Viscose mount, installation
Viscose mount, removal
