Volvo Excavator EC15 XTV Parts and Service Repair Manual
Brand: Volvo
Type of Machine: Excavator
Type of Manual: Parts Catalog, Service Repair Manual, Wiring Diagram
Model: Volvo EC15 XTV Excavator
Number of Pages: 4537 Pages
1 Volvo EC15 XTV
Description
Adjusting the pressure and checking for leaks
Adjustment Figures
Adjustment
Assignment of elements
Basic objects of examination
Battery, description Figure 1
Battery, specification
Boom-cabin-weather roof Figures
Brake valve (counter balance valve) Figures
Brake, description
Caution sign - Diesel engine starting procedure
Caution sign - Emergency exit
Caution sign - Lashing Figure 1
Caution sign - Operation and maintenance
Caution sign - Track tension Figure 1
Checking and adjusting the breaker (volumetric capacity)
Checking and adjusting the dipper arm cylinder (volumetric capacity) Figures
Checking and adjusting the pilot pressure Figures
Checking and adjusting the pressure relief valve Figure 1
Colur codes
Console, left Figure 1
Console, left
Console, right Figure 1
Console, right
Control valve block for slewing gear Test and adjustment Figures
Dashboard Figures
Dashboard
Design Figure 1
Design
Designations of electrical components Figure 1
Diagnostics
Driver's cab Figure 1
Driver's cab Figure 2
Driver's cab
Electric system, trouble shooting
Electrical components (hydraulic system side) Figure 1
Electrical components (machine side) Figures
Electrical components (machine side)1 Figures
Electrical system, description
Engine trouble shooting
Engine, hydraulic system side Figure 1
Fault remedy
Frame and crawler unit
Frame and crawler unit1
Function
Fuse box Figure 1
Fuse box
Fuses for machine equipment Figures
General notes to be observe when working on power transmission assemblies
General notes to be observe when working on the hydraulic system
General
Generator Figures
Generator
High speed solenoid valve Figures
Hose rupture valve on dipper arm cylinder, leakage test Figure 1
Hose rupture valve on dipper cylinder Figures
Hydraulic circuit for boom Figure 1
Hydraulic circuit for bucket Figure 1
Hydraulic circuit for dipper arm Figure 1
Hydraulic circuit for dozer blade and adjustable track width Figure 1
Hydraulic circuit for dozer blade Figure 1
Hydraulic circuit for slewing gear and offset Figure 1
Hydraulic circuit
Hydraulic motor Figure 1
Hydraulic motor
Hydraulic safety solenoid valve Figure 1
Identification of lines
Identification of the engine Figures
Ignition switch Figures
Ignition switch, specification
Ignition switch
Installation of the solenoid Figure 1
Key-operated engine shut down system with EDD-solenoid Figure 1
Line connections in the wiring loom Figure 1
Load capacity tables
Lubrication system, description Figure 1
Machine identification Figure 1
Main dimensions EC15B Figure 1
Main dimensions EC20B Figure 1
Main wiring loom main plug connector cabin Figure 1
Maintenance instructions
Marking of plug connectors
Minus connection
Nominal lifting loads EC15B XR Figure 1
Nominal lifting loads EC15B XT Figure 1
Nominal lifting loads EC15B XTV Figure 1
Nominal lifting loads EC20B XT Figure 1
Nominal lifting loads EC20B XTV Figure 1
Operating control elements on driver's platform Figure 1
Operator side Figure 1
Operator side
Performance characteristics (measuring values for one hour with fan) Figure 1
Plus connection
Position of components Figure 1
Precautions when handling plug connectors Figures
Reach of the working attachment EC15B Figure 1
Reach of the working attachment EC20B Figure 1
Reach
Recommended lubricants
Relay ECU Figure 1
Relay ECU
Relay group Figure 1
Relay group
Return flow, hydraulic circuit for accessories EC15B Figure 1
Return flow, hydraulic circuit for accessories EC20B Figure 1
Schematic, fuel system Figure 1
Slewing offsetting Figures
Slewing offsetting
Socket Figures
Socket
Solenoid valve, slewing offsetting Figure 1
Specification, engine
Specification, filling capacities
Specification, weight
Stand-by pressure Figure 1
Stand-by pressure
Starter side Figure 1
Starter side
Starting process Figures
Starting process
Starting the engine with jump wires
Steering system, description
Strength class 8.8 Metric coarse and fine threads
Strength class 10.9 Metric coarse and fine threads
Technical data
Test and adjustment values for EC15B
Test and adjustment values for EC20B
Testing method Figures
Testing method
Tests and adjustments of the power control Figures
Tests and adjustments of the pressure relief valves
Tests before disassembly
Tightening torque
Travel gear Figure 1
Travel gear
Travel operation Figures
Travel operation
Valve block for slewing gear Figure 1
Valve timing
Variable track (only XTV design) Figures
Volvo standard tightening torques
Warning and information decals
Warning sign - Open engine hood only with engine stopped Figure 1
Warning sign - Safety distance from the movement area Figure 1
Warning sign - Safety distance from the work area Figure 1
Warning system Figures
Warning system
Wiring looms Figure 1
Wiring looms
Working headlights and main headlights, description
Working headlights and main headlights, specification
Working principle of the travel system Figure 1
Diagrams
Balancing valve (offset cylinder) Figure 1
Balancing valve (offset cylinder) Measurement Figure 1
Complete wiring diagram (part 1) Figure 1
Complete wiring diagram (part 2) Figure 1
Complete wiring diagram (part 3) Figure 1
Hydraulic circuit of travel motors Figure 1
Hydraulic diagram EC15B XR Figure 1
Hydraulic diagram EC15B XT Figure 1
Hydraulic diagram EC15B XTV Figure 1
Hydraulic diagram EC20B XT Figure 1
Hydraulic diagram EC20B XTV Figure 1
Solenoid valve for hydraulic working unit Figure 1
Parts Catalog
Elec, Warning, Information, Instruments1
Engine with Mounting and Equipment1
Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit1
Hydraulic, Digging, Handling, Grading and Misc Equip1
Machinery House, Cab, Exterior Trim Parts1
Power Transmission1
Repair
Adjusting the track sagging Figures
Adjusting the valves
Adjustment of secondary valves
Assembling the coolant pump Figures
Assembling the cylinder for adjustable track width
Assembling the radiator
Assembling the sliding bar Figure 1
Assembling the starter Figures
Assembling the thermostat housing
Assembling the valve block Figure 1
Bleeding the fuel system
Cabin (closed) Figure 1
Cabin (closed)
Changing the fuel filter Figures
Changing the hydraulic oil Figures
Changing the hydraulic oil filter Figures
Characteristics of the glow plug system Figures
Checking and adjusting the injection nozzles Figures
Checking the compression pressure
Checking the glow plug
Checking the hydraulic oil level Figures
Checking the openings for clogging Figure 1
Checking the performance characteristics Figure 1
Checking the voltage regulation Figure 1
Cleaning the oil cooler Figure 1
Creeping of hydraulic cylinders
Cylinder speed
Deviation when travelling straight ahead
Disassembling the fuel pump Figure 1
Disassembling the hydraulic motor
Disassembling the travel motor
Dismantling and assembling the generator Figures
Dismantling the starter Figures
Dismantling the travel gear
Dismantling the valve block Figure 1
Fuel injection timing
Hose rupture valve on boom cylinder Figure 1
Hose rupture valve on boom cylinder Figure 2
Hose rupture valve on boom cylinder Figures
Hose rupture valve on boom cylinder Test and adjustment procedure Figures
Hose rupture valve on boom cylinder, leak test Figure 1
Hydraulic motor – slewing of superstructure Figure 1
Hydraulic motor 1, travel gear Figure 1
Hydraulic motor, assembling swivelling
Hydraulic motor, dismantling swivelling
Idle speed, inspection and adjustment
Installing the engine Figures
Installing the fuel pump
Installing the glow plug
Installing the oil filter Figure 1
Installing the oil pressure switch
Installing the valve block Figures
Measuring conditions
Measuring the play of the slewing bearing
Removing and installing the pressure relief valve
Removing the coolant pump Figures
Removing the crawler tracks
Removing the cylinder for adjustable track width
Removing the engine Figures
Removing the engine
Removing the gear motor
Removing the generator Figures
Removing the guide sprocket
Removing the hydraulic pump Figures
Removing the oil cooler
Removing the oil filter Figure 1
Removing the oil pressure switch
Removing the radiator
Removing the rubber track Figures
Removing the sliding bar Figure 1
Removing the starter Figures
Removing the superstructure
Removing the thermostat housing
Removing the track drive
Removing the track roller Figures
Removing the valve block Figure 1
Roll over protection structure Figures
Slewing overtravel
Slewing speed
Tests before disassembly Figures
Track drive, wear measurement Figure 1
Track travel speed
Travel speed
Safety
CE marking and declaration of conformity
Decontamination
Environmentally hazardous fluids
Environmentally safe handling
Fire prevention measures
Pressure setting and leak detection
Safety concerns everybody!
Safety for work on hydraulic systems
Safety rules when servicing
Safety when handling oils and fuel
Safety when lifting and supporting the machine
Service position 1
Service position 2
Service position 3
Starting with booster batteries
Waste handling
Working in environmentally contaminated areas
Working on the electrical system of the machine
Service Bulletins
Boom
Check valve inside MCV
Cylinder, improvement
Dipper arm welding improvement
Dipper arm welding process improvement
Fuel sampling, method
Internal leakage dozer blade, tolerance
Main control valve leakage
Maintenance of Stored Machines
New coolant
Option anti-theft, instruction
Part numbers for cylinder seal kits (new supplier)
Pilot valve coil
Slew motor
Slewing motor, change
Special Tools, Misc
RM Compaction ABG Time Guide
RM Compaction Time guide
RM Paving Systems ABG Time Guide
Special tool catalog
Special Tools Recommendations
Time Guide Currrent generation
Time Guide Old generation
TimeGuide GRD G700B Labour
Specifications
Cabin, specification
Chapter 2 Engine
Chapter 3 Electrical system
Chapter 4 Power transmission
Chapter 9 Hydraulic system
Fault rectification on hydraulic motor
Fuels, lubricants and filling capacities (litres)
Fuels, lubricants and filling capacities (litres)1
Gear motor for slewing
Hydraulic motor 1 - travel system
Hydraulic motor 1 – travel system
Lubrication system, specification
Mechanical transmission - track gearbox
Mechanical transmission – track gearbox
Plugs with tapered thread
UNC-threads, coarse pitch
Brand: Volvo
1 Volvo EC15 XTV
Description
Adjustment Figures
Adjustment
Brake, description
Colur codes
Console, left
Console, right
Dashboard Figures
Dashboard
Design Figure 1
Design
Diagnostics
Driver's cab
Fault remedy
Function
Fuse box Figure 1
Fuse box
General
Generator Figures
Generator
Hydraulic circuit
Hydraulic motor
Ignition switch
Minus connection
Operator side
Plus connection
Reach
Relay ECU Figure 1
Relay ECU
Relay group
Slewing offsetting
Socket Figures
Socket
Stand-by pressure
Starter side
Starting process
Technical data
Testing method
Tightening torque
Travel gear
Travel operation
Valve timing
Warning system
Wiring looms
Diagrams
Parts Catalog
Power Transmission1
Repair
Cabin (closed)
Cylinder speed
Removing the engine
Slewing overtravel
Slewing speed
Track travel speed
Travel speed
Safety
Decontamination
Service position 1
Service position 2
Service position 3
Waste handling
Service Bulletins
Boom
New coolant
Pilot valve coil
Slew motor
Special Tools, Misc
Specifications
Chapter 2 Engine
- Volvo Construction Equipment All Training Set (8.5Gb)
- Volvo Wheel Loader L60F L70F L90F Service Manual
- Volvo PTT 2.01 KG
- Volvo FM10 D10B-360 Engine-MID-128
- Volvo Wheel Loader L110E/L120E shop manual
- VOLVO EXCAVATOR EC210B Training
- Volvo Excavator EC340D,EC380D,EC480D Service Training
- Volvo EW160B Error
- Volvo FM D13A 480 Engine parts, transferring
- Volvo Training EC55B-08 Hydraulic Circuit
- VOLVO Premium Tech Tool 2.03.40 (MEGA LINK)
- VOLVO L120F Service manual Persian
- Volvo Impact 2016 - Torrent
- Volvo EC210 LC Diagram
- Volvo PROSIS manuals
