Martin Welker
104
230,792
Volvo Excavator EC130 Service Repair Manual
Brand: Volvo
Type of Machine: Excavator
Model: Volvo EC130 Excavator
Number of Pages: 4443 Pages
1 Volvo EC130
A few simple safety rules when servicing
Adjusting of hydraulic pressure
Air conditioning
Allmänt
Biodiesel fuel for Volvo CE
Capacities
Central unit, A3
Changed sensor for end position damping
Charging batteries
Check method on engine oil consumption
Checking cable between battery disconnector and starter motor
Component lists and index for wiring diagrams
Control-pressure valve for track steering (12q)
Control-pressure valves 12a-b and 12c-d)
Cooling system
Counterweight
Crankcase ventilation, strainer replacement and cleaning in TD40GB and TD40KC type engines
Cylinder data
DEF AdBlue AUS32 sampling, method
Description EC130
Description of hydraulic systems
Description of slew brake
Description of track brake
Description
Diagram 1 Figure 1
Diagram 1
Diagram 2 Figure 1
Diagram 2
Diagram 3 Figure 1
Diagram 3
Diagram 4 Figure 1
Diagram 4
Diagram 5 Figure 1
Diagram 5
Diagram 6 Figure 1
Diagram 6
Diagram 7 Figure 1
Diagram 7
Diagram 8 Figure 1
Diagram 8
Diagram 9 Figure 1
Diagram 9
Diagram 10 Figure 1
Diagram 10
Diagram 11 Figure 1
Diagram 11
Diesel fuels - quality and function
Dieseling in hydraulic cylinders
Dipper arm
Display unit, A9
Distribution valve for P3 oil entering P2 circuit (8r)
ECU, functional check
Electrical distribution box, A2
ENGINE RECONDITIONING
Excavating data in metre and feet and inches
Exchange of slew brake
Explanations to wiring diagrams and component lists
Filtering hydraulic oil
Four-way float-position valve (5e-7a)
Four-way valves (5a-h)
Fuel sampling, method
Fuel tank General
Fuel tank
Fuse holder, A1
General Tracks
General
General1
General2
Handling spring package for track tensioner
Hose-rupture valve (7c)
Hydraulic diagram Figure 1
Hydraulic diagram
Hydraulic hose assembly leakage handling
Hydraulic oil cooler (18d)
Hydraulic oil tank
Hydraulic oil, environmental
Hydraulic pressure
Hydraulic pressure1
Hydraulic system flushing method
Hydraulic system, total
Hydraulics in undercarriage
Inspection Program, Arrival Inspection EXC PUB20039956
Inspection Program, Delivery Inspection EXC PUB20039957
Inspection Program, Delivery Instructions EXC PUB20039958
Inspection Program, Maintenance of Stored Machines EXC PUB20039959
Inspection Program
Inspection Program1
Inspection Program2
Inspection Program3
Instructions for shrinking
Instructions for vacuum pump
Instructions for work with the electrical system
Lead marking
List of components for hydraulic circuit diagrams
Location of electrical components
Lubrication and service chart
Machine model
Main dimensions
Main electrical components
Measures to prevent fire
Measuring backlash in slewing system
Measuring radial clearance in the digging equipment bearings
Measuring track tension
Measuring wear of crawler unit.
Measuring wear of track chain
Modification of CareTrack wire harness
Monitors and sensors
New fastener assortment
New product
New product1
Non-return valves for refilling (8g), (refilling valves or, anti-cavitation valves)
Oil sampling, method
Oil sampling, sampling points
Overhaul of batteries
Overhaul of charging system
Pins in connector for central unit (A3)
Pins in connector for display unit (A9)
Pressure adjusting and leak detection
Pressure-limiting valve ( 2b, 2c)
Pressure-limiting valve (2d)
Product Identification Signs
Propulsion
Pump gearbox
Pump
Rear crankshaft seal
Recommendations for cleanliness when working on hydraulic systems
Recommendations for hydraulic oil
Recommendations for Oil Sampling Intervals
Repairing fuel filling pump
Reports
Risk of accidents when handling counterweight
Risk of caustic burns to skin after contact with overheated viton seals
Routines for reporting cracks on Boom and Arm
Safety
Serial no. on ÅKERMAN - VOLVO models from 1974 - up to 2001
Serial number location on machine components
Service positions
Servo pump (1d)
Servo pump
Shock valves (3)
Shunt valve (7t)
Slew gearbox
Slewing gearbox Description
Slewing gearbox
Slewing pressure limiting valve (2f)
Slewing ring clearance
Slewing speed
Slewing valve block
Solenoid- and shuttle valves
Solenoid valves
Special Tools Recommendations
Starting with booster batteries
The control-pressure valve for travelling forward (12j) and rearward (12k)
The hydraulic cylinders of the digging equipment (6)
The hydraulic oil tank (19c)
The load-holding valve (8c)
Tightening torque for track shoe bolts
Tightening torques
Tightening torques1
Time Guide Current generation
Time Guide Old generation
Time Guide Old generation1
Torque for tightening hydraulic cylinder pistons
Track motors (4c)
Transportdata
Travel gearbox
Valve blocks for crawling and digging hydraulics
Vee belts
Weights
Weights1
Working pumps (1a-c)
Working with painted surfaces and polymer materials
