Martin Welker
104
230,310
Volvo Dump Truck BM A25C Service Repair Manual
Brand: Volvo
Type of Machine: Dump Truck
Model: Volvo BM A25C Dump Truck
Number of Pages: 580 Pages
1 Volvo BM A25C
A25C 4x4 Turn-around wheels
A-frame rubber bushing brackets, adjusting front bracket 1
Air conditioning, checking function
Air spring for operator's seat, changing
Anti-throttle cylinder for throttle pedal, adjusting
Before operating
Bogie beam, changing rubber bushing (one side)
Bogie beam, changing rubber springs
Brake caliper, changing (per caliper)
Brake caliper, reconditioning
Brake disc, changing
Brake pads, changing (one wheel) 1
Brake system, changing brake fluid
Change intervals
Charging of batteries
Circuit 0–6
Circuit 7–13
Circuit 14–36
Circuit 37a–37e
Circuit 37f–37l
Circuit 38–53A
Circuit 53B–75
Circuit 66 and 77
Circuit 76–89
Circuit 90–91
Circuit index
Cleanliness, hydraulic systems
Codes in wiring diagrams
Compressed air diagram A25C, 4x4 turn-around wheels
Connector A
Connector B
Connector BN1-X3
Connector BN2-X4
Connector BS1
Connector CA
Connector CB
Connector CC
Connector CD
Connector CE
Connector CF
Connector CG
Connector CH
Connector CJ
Connector CK
Connector CL
Connector CM
Connector CN
Connector CO
Connector CP
Connector CR
Connector CRC
Connector CRR
Connector CS sep
Connector CS+CS sep
Connector CT
Connector CU
Connector CX
Connector CY
Connector D
Connector DY
Connector E
Connector ECU2
Connector EE
Connector EF
Connector F
Connector FF
Connector GA
Connector GB
Connector GV1
Connector GV3
Connector GV5 (X7-A6)
Connector GV6 (X5-A3)
Connector GV7
Connector H
Connector HU
Connector I8
Connector I9
Connector J
Connector KA
Connector KB
Connector KC
Connector L
Connector M
Connector M1
Connector M2
Connector M7
Connector M19
Connector M20
Connector N
Connector NA
Connector O
Connector P
Connector PA
Connector PB
Connector PC
Connector R11 engine speed
Connector S
Connector SO
Connector SW8
Connector TR3
Connector U
Connector UA
Connector UB
Connector UT
Connector UU
Connector V
Connector V7
Connector V9 (2 pcs)
Connector V10 (2 pcs)
Connector V16
Connector V17
Connector V23
Connector X1-A1
Connector X2-A2
Connector X3-BN1
Connector X4-BN2
Connector X5-A3
Connector X6-A4
Connector X7-A6
Connector X8-Y1
Connector X25-A1
Connector XA
Connector XC
Connector Y
Connector YA
Connector YB
Connector Z
Connector ZA
Connector ZB
Connector ZC (only A20C)
Connector ZZ
Contronic Information Display Unit
Contronic Service Display Unit
Coolant filter, changing
Coolant, changing
Dangers in connection with polymer materials
Description 1
Description 2
Description 3
Description, steering system
Description
Diagnosis using error codes on the Contronics Service display unit
Diodes
Draining refrigerant R134a
Drawings of E-tools that can be made in your own workshop
Electric welding 1
Electric welding
Electrical symbols
E-tools
Explanations of wiring diagrams
Fan motor, changing
Filling refrigerant R134a
Fire prevention measures
Foreword Time Guide
Frame joint, changing hitch
Frame joint, changing metallic bearing 1
Frame joint, checking and adjusting clearance 1
Front axle complete, removing
Front axle, changing rubber spring (bushing)
Front or rear bogie axle torsion bar, adjusting
Front or rear torsion bar, adjusting
Front rubber springs, changing all
Functional description, hydraulic retarder
Functional description, transmission
Headlight, complete, changing 1 headlight incl. adjusting alignment
Headlights and other lights, placement
Headlights, adjusting against wall or fender
Headlights, alignment
Heat control valve, changing
Heater, changing
Heating coils
Hitch (steering and frame joint), changing 1
Hub, changing seals (one side)
Hydraulic diagram 1
Hydraulic diagram A25C 4x4 with turn-around wheels
Hydraulic diagram A25C 6x6
Hydraulic diagram
Hydraulic system and component positions
Hydraulic system, bleeding air
Information display unit, displays
Information display unit, summary
Information on the service display unit
Instrument panel
Intermediate propeller shaft and-or bearing, changing (in frame joint)
Load unit A-frame, changing rubber spring (bushing)
Magnetic clutch
Miscellaneous
On completion of service work or when the machine is parked for a longer period of time
Operator's seat, adjusting height of attachment
Operator's seat, air suspension
Operator's seat, maintenance instructions
Operator's seat, spring suspension
Piston rod seals, fitting
Pressure checking connections for hydraulic system
Propeller shaft between transmission and
Propeller shaft for front bogie axle, changing
Propeller shaft for rear bogie axle, changing
Propeller shaft in frame joint, changing
Propeller shaft, front output shaft on dropbox, changing
Protection against electro-magnetic interference
Radiator, changing 1
Radiator, changing
Recommended lubricants 1
Recycling station FRS-10GS 1
Refrigerant for air conditioning units
Relay base (connection) BR2
Relay base R12 load body up
Relay base R13 anti-throttle
Relay base R23 brake hydraulics
Relay base R27 back-up light
Relay base R28 level water tank
Relay base R29 exhaust retarder
Relay base R30 key dependent feed control unit ECU
Relay base R32 reduced retarder 1st gear
Relay base R33 reduced retarder high temperature
Relay base R34 buzzer relay
Relay base R36 cooling fan
Relay base R38 only A20C dumping limitation
Relay connector R37 cooling fan
Repair and service of hydraulic systems 1
Retarder circuit
Retarder engagement
Rubber spring, front axle, changing
Rules for batteries
Rules for inflating tires
Rules of service work
Safety functions
Safety rules 1
Safety rules
Service Display Unit, summary
Service position
Service
Solenoid valves
Special instructions for servicing the electrical system
Special tools for the drivetrain
Specifications 1
Specifications 2
Specifications
Starting with booster batteries
Steering joint, changing spherical bearing
Steering joint, changing spherical bearings
Steering joint, checking clearance
Steering linkage, changing roller bearing in front lever
Steering linkage, changing roller bearings in rear lever
Steering linkage, checking and adjusting 1
Steering linkage, checking and adjusting 2
Suspension rubber springs and anti-sway pad, changing
Suspension
Switches
Template for pin numbers connector X1-A1
Throttle pedal, anti-throttle cylinder, adjusting
Time Guide 1
Time Guide
Torsion bar and-or rubber bushing, changing on load unit
Torsion bar, checking and adjusting 1
Towing
Transmission PT1051, general description
Transmission, general troubleshooting
Transporting the machine
Troubleshooting chart 1
Troubleshooting chart, transmission
Troubleshooting
Voltage converter base SOM
When the engine is running
When there is a risk of overturning
Window pane, changing 1
Wiring diagram, transmission electronics, circuits 37a–l
