Martin Welker
104
230,310
Volvo Dump Truck A35D Service Repair Manual
Brand: Volvo
Type of Machine: Dump Truck
Model: Volvo A35D Dump Truck
Number of Pages: 5374 Pages
1.A35D
Descriptions 1
Air cleaner, description
Air conditioning AC, basic principles
Alternator, description
Brakes A35D wet brakes and A40D, description
Brakes A35D, description
Cab, lifting points
Component and description
Compressed air system, pressure build-up
Connectors, overview
Coolant circulation, description
Coolant pump, description
Cooling system, principle illustrations
Crank mechanism, description
Cylinder block, description
Cylinder head, description
Cylinder liner, description
Damping cylinder
Description, retarder
Description
Drivetrain, description
Dropbox, general
Dump lever, description
Electrical distribution box, description
Electrical system, special instructions for servicing, general
Engine control unit
Engine D12, description
Engine, identification
Exhaust pressure governor
Fan system, description
Filter head D12D, description
Foot brake valve, description
Fuel feed pump, description
Fuel filter housing, description
Fuel filter, description
Fuel flow D12C
Fuel flow, description
Fuel system, description
Fuel system's components
Function of the valves
Function of unit injectors
Gear F1
Gear F2
Gear F3
Gear F4
Gear F5
Gear F6
Hitch, specifications
Hitch, tightening torque
Hoist cylinder, description
Hub end, cross-section 1
Hydraulic brake system, pressure build-up
Hydraulic pump, description
Hydraulic system, description
Hydraulic tank, description
Input and Output terminals
Instruments and controls, climate control panel
Instruments and controls, left instrument panel
Instruments and controls, main instrument
Instruments and controls, overview
Instruments and controls, right instrument panel
Intercooler, description
Intermediate shaft, cut-away view
Internal Exhaust Gas Recirculation (IEGR), description
Lifting machine, A35D
Load unit frame
Lubrication system, principle
Mechanical release of parking brake
Oil and seals AH64J-AH64L
Oil pump and oil cooler
Other fuses and relays, description
Pistons, description
Planetary gear
Preheating coil
Pressure accumulation
Pressure build-up, engine-dependent pumps, description
Pressure check connections, description 1
Propeller shaft
Protection against electromagnetic interference
Radiator, description
Repair instructions
Reverse gear R1
Reverse gear R2
Rocker arm piston, D12C
Section 4, content, structure
Steering and dumping valve, description
Steering cylinder, description
Steering system, description
Suspension, description
Thermostat, description
Thermostat, primary system, description
Thermostat, secondary system, description
Tractor unit frame
Transmission PT1860, cut-away
Transmission PT1862, cut-away view
Transmission, clutches and brakes
Turbocharger, overview illustration
Turbocharger
Unit injector, Bosch, description
Unit injector, Delphi, description
Valve mechanism, description
VEB, activation
VEB, description
Water trap, description
Windows, general
Diagrams 1
Brake cooling oil system, diagram
Compressed air diagram
Explanation of wiring diagrams
Explanations to hydraulic diagram
Hydraulic diagram PT 1
Hydraulic diagram, brake system, dry brakes
Hydraulic diagram, complete full page
Hydraulic diagram, complete v1
Hydraulic diagram, complete v2 full page
Hydraulic diagram, hood opening
Steering and dumping valve, overview illustration
Wiring diagram A01
Wiring diagram A01-1
Wiring diagram A01-2
Wiring diagram A01-3
Wiring diagram A01-4
Wiring diagram A02
Wiring diagram A02-2
Wiring diagram A03
Wiring diagram A03-1
Wiring diagram A03-2
Wiring diagram A04
Wiring diagram A04-1
Wiring diagram A04-2
Wiring diagram A04-3
Wiring diagram A04-4
Wiring diagram A05
Wiring diagram A05-1
Wiring diagram A05-2
Wiring diagram A05-3
Wiring diagram A06
Wiring diagram A06-1
Wiring diagram A07
Wiring diagram A07-1
Wiring diagram A07-2
Wiring diagram A07-3
Wiring diagram A08
Wiring diagram A08-1
Wiring diagram A08-2
Wiring diagram A09
Wiring diagram A09-1
Wiring diagram A09-2
Wiring diagram A10
Wiring diagram A10-1
Wiring diagram A10-2
Wiring diagram A11
Wiring diagram A12
Wiring diagram A13
Wiring diagram A14
Wiring diagram A15
Wiring diagram A16
Wiring diagram A17
Wiring diagram A18
Wiring diagram A19
Wiring diagram A20
Wiring diagram A21
Wiring diagram A22
Wiring diagram A23 1
Wiring diagram A23
Wiring diagram A24
Wiring diagram A25
Wiring diagram A26
Wiring diagram A27
Wiring diagram A28
Wiring diagrams
Installation Instructions 1
Air cleaner, installing
Air conditioning
Back up alarm, installing new
Cab heater connection 120 V, installing new
Cab heater connection 240 V, installing new
CareTrack, installing new
CareTrack
Connection for cab heater outlet
Engine heater 240v
Engine hood electric opening
Extra front spill guard, installing new
Fuel fast fill
Load body heating
Protection plate
Radio installation kit
Radio, installing new
Rear view camera, installing new
Rear view mirror, installing new
Rotating beacon
Tachograpf
Tailgate overhung cable
Worklamp rear
Worklight
Repair 1
4-pin DIN-connectors, remounting
88830051 User Instruction
Accumulator, checking
Accumulator, discarding
Adjusting, general
Air in fuel system, checking
Air suspension operator's seat, adjusting
Alternator, changing
Auxiliary steering, replacing hydraulic pump
Batteries, replacing
Bogie member, replacing incl. Bearing, replacing
Bogie member, replacing one rubber element
Brake caliper, reconditioning
Brake disc
Brake system, basic check
Brake system, bleeding 2
Brake system, checking function, hydraulic
Brake system, relieve pressure
Cab door, installing door catch
Cab door, removing door catch
Cab, installing
Cab, removing
Camshaft setting, checking
Camshaft, replacing
Carbon dioxide in fuel system, check
CareTrack antenna, replacing
C-ECU, MID178, changing non-Programd ECU
C-ECU, MID178, changing pre-Programd ECU
Checking for leaks with inspection light
Checking of main, torque converter and lubricating oil pressure
Checking stalling speed
Combined control by steering wheel, changing
Component position 1
Component position 2
Component position 4
Component position 5
Component position 6
Component position 7
Component position 8
Component position 9
Component position 10
Components, list and positions
Compression test
Compressor, replacing
Coolant filter, changing
Coolant pump removed, reconditioning
Coolant, changing
Cooling fan motor, intercooler, checking adjusting high rpm
Cooling fan motor, intercooler, checking adjusting low rpm
Cooling fan motor, radiator, checking adjusting high rpm
Cooling fan motor, radiator, checking adjusting low rpm
Cooling system, flushing
Cooling unit, performance test
Crankshaft, replacing rear oil seal
Cylinder, rear flap, gas pressure, checking and adjusting
Damping cylinder, changing seal
Damping cylinder, checking pre-load
Differential carrier assembly, replacing
Dog-clutch for six-wheel drive (6x6), checking and adjusting
Door lock, replacing
Door window, replacing
Door, replacing
Dropbox, mounting
Dropbox, removing
Dump body alternative, lowering
Dump body joint, changing tipping bearing
Dump body position indicator, adjusting
Dump body, adjusting against frame
Dump lever, changing 1
Dumping lever, checking pressure
E-1750
E-1763
E-2000
E-2502
E-2516
E-2519
E-ECU, changing
E-ECU, MID 128, changing non-Programd ECU
E-ECU, MID 128, changing pre-Programd ECU 1
Electric hood pump, changing 1
Electrical system, basic check
Engine and transmission, mounting
Engine and transmission, removing
Engine hood, installing
Engine hood, removing
Engine mounting rear, changing
Engine rotation speed sensor (camshaft), replacing
Engine speed sensor, changing
Engine, basic check
Engine, installing
Engine, removing
Evaporator, replacing incl draining and filling
Fan belt and or alternator belt, checking and adjusting tension 1
Fan motor, replacing
Feed pump, checking feed pressure
Foot brake valve, replacing
Frame joint, separating the machine
Front output shaft on dropbox, changing seal
Front underbody skid plate, mounting
Front underbody skid plate, removing
Fuel pump (valves), inspection
Fuel pump, inspection
Fuel system, bleeding 1
Gearshift selector, changing
General instructions for controls, replacing.
General maintenance instructions
Grounding points (frame connections)
Headlamp, high and low beams, adjusting
Headlamp, high beam, replacing
Headlamp, low beam, replacing
Heat control valve, replacing
Heat control, replacing
Heater core, replacing
Hoist cylinder bearing, changing
Hoist cylinder removed, reconditioning
Hoist cylinder, installation
Hoist cylinder, removal
Hydraulic pump (removed), changing shaft seal
Hydraulic pump, checking and adjusting max working pressure 1
Hydraulic pump, checking and adjusting standby pressure
Hydraulic pump, replacing
Hydraulic system, bleeding air, version 1
Hydraulic system, bleeding air, version 2
Hydraulic system, relieve pressure
I-ECU, MID 140, changing non-Programd ECU
I-ECU, MID 140, changing pre-Programd ECU
Induction sensor for turbine speed, changing
Injectors, replacing copper sleeve in machine
Input shaft on dropbox, changing seal
Instructions for drilling in ROPS structure
Intercooler, replacing
Intermediate shaft and or bearing, changing
Load and dump brake, checking and adjusting working pressure
Longitudinal differential lock, checking and adjusting - from underneath
Lubrication oil pressure, checking with pressure gauge
Maintenance service, daily
Maintenance service, every 50 hours
Maintenance service, every 250 hours
Maintenance service, every 500 hours
Maintenance service, every 1000 hours
Maintenance service, every 2000 hours
Mechanical operator's seat, adjusting
Oil cooler, replacing
Oil level sensor, changing
Oil sump gasket, changing
Operator's seat, installing
Operator's seat, removing
Output shaft 6-wheel drive, changing bearing
Overflow valve, checking
Parking brake lever, changing
Parking brake, basic check
Parking brake, replacing brake disc
Parking brake, replacing brake pads
Position monitor high low range, adjusting
Power take-off, between engine and gearbox, reconditioning
Power transmission, basic check
Preheating coil, replacing
Pump regulator, checking
Radiator, adjusting
Radiator, installing
Radiator, mounting
Radiator, removing
Rear output shaft on dropbox, changing seal
Rear window pane, replacing
Receiver, replacing incl draining and filling
Rubber cushion, replacing
Seal for rear output shaft, replacing
Secondary steering, checking and adjusting max. pressure and stand-by pressure
Shift valve, checking
Shut-off P1 at low engine rpm (MA9102), checking function
Side window, replacing
Spindle, changing 1
Spindle, changing
Starter motor, replacing
Steering and dumping valve, changing
Steering and dumping valve, removed, reconditioning
Steering and hydraulics, basic check
Steering and tipping valve, installation
Steering and tipping valve, removal
Steering cylinder, reconditioning on machine
Steering cylinder, removed, reconditioning
Steering cylinder, replacing bearing, left-hand side
Steering gear, check.and adj.
Steering gear, replacing
Steering joint bearing, replacing
Steering joint spherical bearings, checking clearance
Steering linkage, checking and adjusting 1
Steering times, checking and adjusting
Steering valve, neutral position, checking and adjusting
T-ECU, MID 130, changing non-Programd ECU
T-ECU, MID 130, changing pre-Programd ECU
Thermostat, replacing
Timing gear case, fitting new gasket in machine
Transmission, installing from above
Transmission, installing from underneath
Transmission, removing downward
Transmission, removing upward
Transverse differential lock axle, checking and adjusting
Troubleshooting tips
Troubleshooting, air conditioning unit (AC)
Turbocharger, inspection
Turbocharger, replacing
Unit injector, adjusting pretension
Unit injector, replacing
Vacuum pump, connection
Valves, adjusting 1
Valves, adjusting 22
Valves, adjusting
V-ECU, MID 187, changing non-Programd ECU
V-ECU, MID 187, changing pre-Programd ECU
Warranty inspection 100 hours
Warranty inspection 1000 hours
Wheel alignment
Wheel, removing and fitting one
Windscreen wiper front, replacing motor
Windscreen, replacing
Working pumps, checking function
Service Bulletins 1
AC, time relay
Action for reducing risk of fire
Action to be taken in case of abnormal lubricating oil consumption
Adaptive gear shifting for machines with R2003
Air vent pipe, hydraulic tank
Altered wind shield washer tank installation, improved self bleeding
Alternative lubricants for axles with wet brakes
A-stay, new rubber bushing
Automatic transmission lubricants
Axle housing, seal
Batteries, service life
Battery and alternator test procedure
Bearing, output shaft, 1st bogie
Belt guard, new type
Brake cooling oil, altered interval between changes
Camshaft, checking wear
CareTrack Telematics system
Casing, new type for headlamps
Change of crankshaft seal
Changed software functions in Release 2002-3
Changing or repairing hydraulic pumps
Charge air pressure, diesel engines
Claim routines
Compressed air drier, service solution
Connector for cooling fan PWM valves
Contronic socket, mounting plate
Crimping Tool Set, part no. 9993880
D9B and D12D Stage 3, valve adjustment, camshaft marking
D12C D12D, Belt protector, new bracket
D12C, New connecting rod
D12D Stage III, new turbo installation
Diesel fuels - quality and function
Dipstick, transmission
Door lock
Drive axles, new hub seal
Dropbox FL1002 FL992, new differential casing
Dropbox, new differential
Dropbox, new housing for longitudinal differential lock
Dropbox, position sensor high-low
Dropbox, service solution, reinforcement of bracket
Engine cable harness D12C 1
Engine oil diluted by fuel
Engine oil requirements
Engine oil, altered time for the first oil change
Engine oil, interval between changes
Engine reconditioning
Exhaust system suspension, rubber cushion
Fan regulator, PWM2601 and PWM2602
Fan, new type
FL1002 and FL992, new seals
Fuel filter and water separator replacement interval change
Fuel sampling, method
Grease with molybdenum disulphide additive (MoS2)
Grease-lubricated hitch
Guide pins D12D
Headlamp, new light bulb
Hub reduction gear, new seal and spacer ring
Hub reduction gear, planet carrier, new design
Hydraulic oil filter, changing
Hydraulic system, service update
Hydraulic system, updating
Improvements, frame joint
Information on Bio-diesel fuel (RME-fuel)
Information on classification of oils
Intermediate shaft A35D A40D, new bearing and grease
Intermittent retarder function, PT1563, 1863
KAB Seat, heater range
Lap belts
Lifting tool, new marking
Lifting tool, new type
Lifting tool, transmission
Lubricant, Biodegradable Hydraulic Fluid
Measuring nipples, new type
New AC hoses and new attaching rail
New Caretrack WECU2
New clamping on coolant pipe
New coolant 1
New coolant
New cross stay, trailer unit
New display screen for transmission oil level
New dropbox
New engine hood
New fan installation
New floor panel and floor mat
New fuel filter housing
New gas spring
New hauler, A35D
New haulers, A25D and A30D
New hoist cylinder
New Intercooler Hoses
New keypad
New main fuel filter, D9, D12 and D16
New non-return valve with back-pressure function, MTRV1
New oil dipstick
New oil sump and level temp sensor for D12D engine
New pressure sensors
New rear camera system
New rear LED flasher
New resistor for the alternator's charging circuit
New seals for steering joint bearings
New sensor for accelerator and retarder pedal
New starter switch
New TechToolVCADS Pro interface
New tipping spool, valve block
New tool Electrical repair kit, part No. 11666200
New transmission
New transmissions 1
New turbocharger for the D12 engine
New unit injectors
New VCB valve, MA2503
New warranty routines for Bosch diesel equipment
New water trap
New wiper motor
Noise reduction kit
Oil analyses
Oil jet nozzle eliminated from the D12D and D9B exhaust double rocker arm
Oil leakage from the engine cable harness grommet
Oil sampling, method
Oil sampling, sampling points
Parking brake, new brake pads
Pipe for dipstick for transmission
Pipe, secondary water pump
Pressure tables, transmissions
Product development 1
Product development
Product update Dropbox FL1002 992, Longitudinal differential lock
PT2509, 1563, 1863, reinforced planet kit, stage 1
PT2509, PT1563 and PT1863 new design of spring pins in planet kit stage 2 and 3
PTO, gear shaft assembly update
PTO, o-rings update
Quality of illustrations in technical reports
Recommendations for Oil Sampling Intervals
Repair kit, part no. 11666145, for service display
Replacement of pivot pin for accelerator pedal and retarder pedal
Replacement of solenoid valve MA9102
Replacing damping cylinder
Reports
Rubber bearings, cross stay
Service and maintenance of batteries
Service Manual, supplement
Service solution for high altitude
Special tools
Spring for longitudinal differential lock in dropbox
Steering cylinder bearing, introduction of grease nipples
Steering joint, vertical joint, introduction of grease nipples
Thrust washer and wear ring, axles
Transmission PowerTronic, new B2 drum
Transmission PowerTronic, new gasket
Transmission PT1663, reinforced bolted joint, converter housing
Transmission, adaptive gear shifting
Transmission, functional check
Transmission, improved retarder
Transmission, inspection form
Tyres, various types
Valve spring update, D9, D12 and D16
Volvo Product incidentaccident report & Interview Form
Special tool catalog
General
Index
Hooks
1. Enviroment and Safety equipment
2. Measuring equipment
3. Tightening and Loosening tools
4. Lifting equipment
5. Pullers and Pressing equipment
6. Drifts
7. Guide pins and Guide sleeves
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Time Guide Current generation
Time Guide Old generation
