Martin Welker
104
230,310
Volvo Dump Truck A25G Service Repair Manual
Brand: Volvo
Type of Machine: Dump Truck
Model: Volvo A25G Dump Truck
Number of Pages: 5800 Pages
1 Volvo A25G
Description
ACM, I O list
A–frame
Air-conditioning, component location
Alternator, description
Anti-theft device, description
ATC, description
Automatic brake description
Automatic central lubrication
Auxiliary brake (engine braking), description
Auxiliary steering backwards, description
Axle suspension, description
Back-up alarm, description
Basic check, transmission
Basic checks
Battery, charging
Battery, description
Bleed pump, user instructions
Brake cooling oil tank, description
Brake cooling system, description
Brake system, component location
Braking system, description
Cab description
Cab heat ventilation timer, description
Cab, lifting points
CareTrack Telematics system
CE-marking, EMC-directive
Charge air cooling system, description
Climate control system, description
Clutches, brakes and planet stages, description
Collection of basic data
Complete machine, descriptions
Component position 2 Engine
Component position 3 Engine Aftertreatment System (EATS)
Component position 4 Transmission
Component position 7
Component position 11
Component position 14 Grounding points
Component position Gearbox
Compressed air system, pressure build-up
Compression brake, description
Connectors, position
Control system, description
Control system
Control unit, description
Control units, voltage supply
Coolant with anti-freeze and corrosion protection, recommendation
Cooling fan speed control, description
Cooling system, component location
Cooling system, description
Cooling system
Crankcase ventilation, description
Cylinder block, description
Damping cylinder, description
Data bus system
Delayed stop, description
Diagnostic tools, description
Display, description
Door open, description
Dosage valves, description
Drive axles, description
Driver's seat, description twin steer
Drivetrain, description
Dump function, description
ECM, I O list
Electrical system, special instructions for servicing, actions when working on machine
Electrical system, special instructions for servicing, electrical components, batteries
Electrical system, special instructions for servicing, electronic components
Electrical system, special instructions for servicing, general
Electronic accelerator pedal, description
Engine- and cab heater, description
Engine and transmission overspeed protection, description
Engine hood, description
Engine timing gear, description
Engine, description
Engine, sensor locations
Entrance lighting, description
Exhaust Aftertreatment System, component location
Exhaust Aftertreatment System, description
Exhaust gas recirculation (EGR), component location
Exhaust Gas Recirculation (EGR), description
Exhaust pressure governor
External activation of central warning, description
Face seals (slide ring seals), cleaning and installing
Fire suppression system, component description
Fire suppression system, functional description
Foot brake valve, description
FOPS and ROPS
Frame joint, description
Frame, description
Fuel level, description
Fuel system, description
Gear selector
Gear shifting strategy
Gearshifting, description
General vehicle electronics
Heat exchanger, description
Hoist cylinder, description
Hydraulic brake system, pressure build-up
Hydraulic components, cleanliness when handling
Hydraulic components, storage and transport
Hydraulic oil tank, description
Hydraulic oil, description
Hydraulic oil, storing and handling
Hydraulic pump flow regulation, description
Hydraulic pump, description
Hydraulic system component location
Hydraulic system, description
Hydraulic system, repair of hydraulic components in workshop
Hydraulic system, work instructions
Inclination, description
Information display unit, summary
Information display, axles brakes
Information display, cycle info
Information display, electrical system
Information display, engine
Information display, general
Information display, hydraulics
information display, machine information
Information display, operating display
Information display, service
Information display, settings
Information display, transmission
Information display, vehicle messages
Infrared Thermometer
Inlet and exhaust system, component location
Inlet and exhaust system, description
Leak detector 951 1207, new model
Load and dump brake, description
Load unit frame
Lock-up clutch
Lubrication and oil system
Lubrication system, description
Main oil filter
Oil level
Oil pump, description
Oil temperature
Parameter settings
Parking brake, function description
Personal competence and accreditation
Preheating description
Pressure build up, steering
Pressure monitor, description
Pressure monitor, description1
Product plates
Propeller shaft, description
PT Transmission Figure 1
PT Transmission
PTO (Power Take Off), description
Pump unit, description
Rear view monitor, service menu
Red extra central warning, description
Retarder, description
SAE J1708 (Information bus)
SAE J1939 CAN-bus (control bus)
Safety when handling AdBlue® DEF
Safety when working with air-conditioning refrigerant
Seat belt supervision, description
Secondary steering, description
Sensors and monitors, description
Sensors, description
Service connection and programming connection
Service mode, description
Service1
Service2
Shift valve, description
Software parameters, description
Speed limitation, description
Start electronics, description
Starter motor, description
Steering and dumping valve, description
Steering cylinder, description
Steering system, description twin steer
Stop electronics, description
Supervision data bus communication, description
Suspension cylinder (GHS), description
Suspension, description
System voltage, description
Tailgate, wire, description
Tech Tool, operations
Thermostat, secondary system, description
Torque converter
Tractor unit frame
Transfer gearbox, description
Transmission, description
Troubleshooting strategy
Vehicle speed, description
Warning screens, general
Wheel brake, description
Working lights, description
Diagrams
Brake cooling oil system, diagram
Compressed air diagram1
Compressed air diagram2
Electrical component list
Electrical distribution box, description
Explanation of wiring diagrams
Explanations to hydraulic diagram
Hydraulic diagram PT
Hydraulic diagram, complete1 Figure 1
Hydraulic diagram, complete2 Figure 1
Hydraulic diagram, complete3 Figure 1
Hydraulic diagram, complete4 Figure 1
Hydraulic diagram, complete5 Figure 1
Hydraulic diagram, complete6 Figure 1
Steering and dumping valve, overview illustration
Wiring diagram WD201-1
Wiring diagram WD201-2
Wiring diagram WD202
Wiring diagram WD203
Wiring diagram WD204
Wiring diagram WD205
Wiring diagram WD206
Wiring diagram WD207
Wiring diagram WD208
Wiring diagram WD240
Wiring diagram WD241
Wiring diagram WD242
Wiring diagram WD243
Wiring diagram WD244
Wiring diagram WD301
Wiring diagram WD302
Wiring diagram WD303
Wiring diagram WD304
Wiring diagram WD305-1
Wiring diagram WD305-2
Wiring diagram WD306
Wiring diagram WD307
Wiring diagram WD308
Wiring diagram WD309
Wiring diagram WD310
Wiring diagram WD311
Wiring diagram WD312
Wiring diagram WD313
Wiring diagram WD314
Wiring diagram WD315
Wiring diagram WD316
Wiring diagram WD317
Wiring diagram WD318
Wiring diagram WD319
Wiring diagram WD320
Wiring diagram WD321
Wiring diagram WD322
Wiring diagram WD323
Wiring diagram WD324
Wiring diagram WD325
Wiring diagram WD327
Wiring diagram WD328
Wiring diagram WD329
Wiring diagram WD330
Wiring diagram WD401
Wiring diagram WD402
Wiring diagram WD403
Wiring diagram WD501
Wiring diagram WD502
Wiring diagram WD503
Wiring diagram WD504
Wiring diagram WD801
Wiring diagram WD802
Wiring diagram WD803
Wiring diagram WD804
Wiring diagram WD805
Wiring diagram WD901
Wiring diagram WD902
Wiring diagram WD903
Wiring diagram WD905-1
Wiring diagram WD905-2
Wiring diagram WD906
Wiring diagram WD907
Wiring diagram WD908
Wiring diagram WD909
Wiring diagrams
Installation Instruction
Air cleaner, heavy duty, EON, installing new
Body heating, installing new
Cab heater connection 120 V, installing new
Cab heater connection 240 V, installing new
CareTrack, installing new
Decal set, installing new
Engine heater 120V, installing new
Engine heater 240V, installing new
Extra front spill guard, installing new
Fuel filter extra, installing new
Hauler chassis, hydraulic, controlled by lever, installing new
Hauler chassis, hydraulic, controlled by switch, installing new
Pre-cleaner cyclone type, installing new
Pre-cleaner oil bath type, installing new
Radio, installing new
Rear view camera, installing new
Strobe light, installing new1
Strobe light, installing new2
Tailgate, overhung, linkage-operated, installing new
Tailgate, overhung, wire-operated, installing new
Tailgate, underhung, installing new
Towing hitch
Repair
Accumulator removed, checking charging pressure
Accumulator, discarding
Accumulator, replacing
ACM (After treatment control module), replacing, non-Programd
ACM (After treatment control module), replacing, pre-Programd
AdBlue® DEF dosing injector, replacing
AdBlue® DEF pump unit filter, replacing
AdBlue® DEF pump unit, replacing
AdBlue® DEF quality, checking
AdBlue® DEF tank, breather filter, replacing
AdBlue® DEF tank, tank armature, replacing
AdBlue® DEF, draining
A-frame bushing, front on load unit, changing
A-frame bushing, rear on load unit, changing
A-frame bushing, tractor unit, replacing
Air drier cartridge, replacing
Air in fuel system, checking
Alternative exit, checking
Alternator, replacing incl function check1
Alternator, replacing incl function check2
Automatic central lubrication filter, replacing
Automatic lubrication pump unit, reconditioning
Auxiliary heater, replacing
Auxiliary steering, adjusting working- and stand-by pressure
Auxiliary steering, hydraulic pump, installation
Auxiliary steering, hydraulic pump, removing
Axle breather filters, replacing
Basic service
Batteries, replacing
Bleeding air
Bogie beam, changing rubber bushing on removed beam
Bogie beam, changing rubber spring, one side (front)
Brake cooling circulation, function check
Brake cooling oil level, checking
Brake cooling oil tank breather filter, replacing
Brake cooling oil, changing
Brake cooling tank return oil filter and magnetic rods, cleaning and replacing
Brake disc, replacing
Brake system pressure oil filter, replacing
Brake system, basic check
Brake system, bleeding
Brake system, checking function, hydraulic
Brake system, relieve pressure
Cab asbestos filter, replacing
Cab heating cab ventilation timer, pump, replacing
Cab main filter, replacing
Cab prefilter, replacing
Cab, installing
Cab, removing
Camshaft setting, checking
Camshaft, replacing
Carbon dioxide in coolant system, checking
Carbon dioxide in fuel system, check
CareTrack antenna, replacing
Centre gear , removing and fitting
Centre gear, removing and fitting
Centre gear, removing and fitting1
Change of lubrication interval
Component position 1 Cab
Component position 5 ECUs and control units
Component position 6 Sensor
Component position 8 Working hydraulics
Component position 9 Brake cooling oil system
Component position 10 Air conditioning unit
Component position 12 Pump, Alternator, horn
Component position 13 Fuel system
Component position 15 Fuses, circuits
Compressed air system, component location
Compression test
Compressor operator’s seat, replacing
Compressor, replacing incl draining and filling
Condenser, replacing incl draining and filling
Condition test and maintenance program
Control units, changing
Coolant freezing point, checking
Coolant, changing
Cooling fan motor, intercooler, checking adjusting high rpm
Cooling fan motor, intercooler, checking adjusting low rpm
Cooling fan motor, radiator, checking adjusting low rpm
Cooling fan motor, radiator, checking high rpm
Cooling unit, performance test
Crankcase ventilation separator, replacing
Crankshaft, axial clearance, checking
Crankshaft, replacing front oil seal
Crankshaft, replacing rear oil seal
Cross stay, installing
Cross stay, installing1
Cross stay, removing
Cross stay, removing1
Cross stay, rubber bushing, replacing
Cross stay, rubber bushing, replacing1
Cylinder, rear flap, gas pressure, checking and adjusting
Damping cylinder, changing seal
Damping cylinder, checking spring force
Differential lock longitudinal, adjustment of sender unit
Dog clutch 6-wheel drive, adjusting
Door lock, replacing
Door window, replacing
Door, gas spring, replacing
Door, replacing
Dosage valve, checking internal leakage
Draining Filling pump, user instructions
Drive axles and hubs oil, changing
Drive axles leakage, checking
Drive belts, checking
Dropbox and front axle, breather filter, replacing
Dropbox leakage, checking
Dropbox oil, changing
Dropbox rubber bushing, replacing
Dropbox, installing
Dropbox, removing
Dropbox, replacing seal for front otput shaft
Dropbox, replacing seal for rear output shaft
Dump body alternative, lowering
Dump body alternative, lowering1
Dump body angle sensor, calibration
Dump body joint, changing tipping bearing
Dump body, adjusting against frame
Dump function, checking pressure
Dump lever, changing
E-1763
E-2005
E-2511
E-2517
E-2518
E-2519
E-2524
E-2525
E-2526
E-2527
E-2528
E-2529
E-2530
E-2531
E-2532
E-2533
ECC, MID 146, changing non-Programd ECU
ECC, MID 146, changing pre-Programd ECU
E-ECU, MID 128, changing non-Programd ECU
E-ECU, MID 128, changing pre-Programd ECU
Electric hood pump, changing
Electrical system, basic check
Engine air cleaner primary filter, replacing
Engine air cleaner secondary filter, replacing
Engine and cab heater fuel filter, replacing1
Engine and cab heater fuel filter, replacing2
Engine and dropbox mounts, checking
Engine and transmission, mounting
Engine and transmission, removing
Engine Gateway, MID 165, replacing non-Programd ECU
Engine gateway, MID 165, replacing pre-Programd ECU
Engine hood, installing
Engine hood, removing
Engine mounting rear, changing
Engine oil and filter, changing
Engine rotation speed sensor (camshaft), replacing
Engine rotation speed sensor, replacing
Engine, basic check
Evaporator, cleaning
Evaporator, replacing incl draining and filling
Exhaust heated load body, checking, cleaning and greasing
Extra fuel prefilter, replacing
Fan motor, replacing
Feed pump, checking feed pressure
Filling lubricant
Fire suppression system, actions after activation
Fire suppression system, actions after manual activation
Fire suppression system, checking
Fire suppression system, component location
Flasher lamp front glass or bulb, replacing
Flasher lamp sidelight glass or bulb, replacing
Foot brake valve, replacing
Frame extension bolted joints torque, checking
Frame joint bearing, replacing (machine separated)
Frame joint bearings clearance, checking
Frame joint bearings, clearance, check
Frame joint, separating machine
Fuel filters, replacing
Fuel pump, inspection
Fuel system extra fuel pre- filter, draining
Fuel system, bleeding
Fuel system, component location
Fuel tank breather filter, replacing
Fuel tank sediment, draining
Headlight, complete, changing (high beam 1 pc.) incl. setting
Headlight, complete, changing (low beam 1 pc.) incl. setting adjustment
Headlights, adjusting
Heat control valve, replacing
Heat control, replacing
Heater core, replacing
Hitch, installing
Hitch, removing
HMIM, MID 140, changing non-Programd ECU
HMIM, MID 140, changing pre-Programd ECU
Hoist cylinder bearing, changing
Hoist cylinder removed, reconditioning
Hoist cylinder, installation
Hoist cylinder, removal
Hood pump, oil, changing
Hub reduction gear, disassembly and assembly
Hub reduction, installing
Hub reduction, removing
Hydraulic couplings
Hydraulic cylinder bushing, suspension system, replacing
Hydraulic cylinder, suspension system, overhaul
Hydraulic oil level, checking
Hydraulic oil tank breather filter, replacing
Hydraulic oil, changing
Hydraulic pump (removed), changing shaft seal
Hydraulic pump, checking and adjusting max working pressure
Hydraulic pump, checking and adjusting max working pressure1
Hydraulic pump, checking and adjusting standby pressure
Hydraulic system, bleeding
Hydraulic system, relieve pressure
Hydraulic tank return oil filter and magnetic rod, cleaning and replacing
Hydraulic tank sediment, draining
Induction sensor for turbine speed, changing
Injector sleeves, replacing
Input shaft seal, replacing
Input shaft, seal, replacing
Input shaft, seal, replacing1
Instructions for drilling in ROPS structure
Lamp bulb, replacing
Lever bracket, steering bearing, replacing
Load and Dump brake, function check
Load and Dump brake, servo pressure, checking
Load and dump brake, working pressure, checking and adjusting
Load body rubber cushions clearance, checking
Lubrication oil pressure, checking with pressure gauge
Lubrication points, central lubrication
Lubrication pressure rocker arm shaft, check
Lubrication system, component locations
Lubrication, every 250 hours
Lubrication, every 500 hours
Lubrication, every 1000 hours
Lubrication, every 2000 hours
Maintenance service, every 10 hours
Maintenance service, every 50 hours
Maintenance service, every 250 hours
Maintenance service, every 500 hours
Maintenance service, every 1000 hours
Maintenance service, every 2000 hours
Maintenance service, every 4000 hours
Maintenance service, every 6000 hours
Maintenance service, first 100 hours
Maintenance service, first 1000 hours
MATRIS and Tech Tool, reading
NOx sensor, replacing1
NOx sensor, replacing2
Operator's seat, air bellows, replacing1
Operator's seat, air bellows, replacing2
Operator's seat, installing1
Operator's seat, installing2
Operator's seat, removing1
Operator's seat, removing2
Operator's seat, shock absorber, replacing
Output shaft, bearing and seal, replacing
Overflow valve, replacing
Parking brake function, checking
Parking brake pads, checking1
Parking brake pads, checking2
Parking brake, adjusting
Parking brake, basic check
Parking brake, function checking
Parking brake, manually releasing
Parking brake, manually releasing1
Parking brake, replacing brake disc
Parking brake, replacing brake pads
Power take-off suction strainer, cleaning
Power transmission, basic check
Pressure check connections, description
Pressure check connections, description1
Pressure release
Pressure testing
Propeller shaft movement, checking
Propeller shafts, removing
Protecting plate, installation
Protecting plate, removal
Pump regulator, checking
Pump unit brake cooling, replacing
Pump, installation
Pump, removal
PWM-valve control system, changing
Quick coupling compressed air, replacing
Radiator, adjusting
Radiator, cleaning
Rear window, replacing
Receiver, replacing incl draining and filling
Refrigerant, draining
Refrigerant, filling incl vacuum pumping
Relief Cut-in pressure, adjusting
Relief Cut-in pressure, check
Restoring from serviceposition
Restoring of the machine
Rotation speed sensor, adjusting
Rubber connection, suction line, replacing
Rubber cushion, replacing
SCR system, dosing test
Seal for rear output shaft, replacing
Secondary steering, checking
Service brake disc wear, checking
Service points
Service position 1
Shift valve, checking
Side window, rear, replacing
Side window, replacing
Spring brake cylinder, replacing
Stall speed, checking
Starter motor, replacing
Starting with booster batteries
Steering and dumping valve, removed, reconditioning
Steering and hydraulics, basic check
Steering and tipping valve, installation
Steering and tipping valve, removal
Steering angle, checking and adjusting
Steering cylinder bearings clearance, checking
Steering cylinder removed, reconditioning excl replacing bearings
Steering cylinder, installing
Steering cylinder, removing
Steering cylinder, replacing bearings1
Steering cylinder, replacing bearings2
Steering gear, check.and adj.
Steering gear, replacing
Steering joint bearing, checking
Steering joint bearing, replacing (Hitch removed)
Steering joint, replacing bearings
Steering linkage, checking and adjusting
Steering linkage, checking and adjusting1
Steering system, bleeding
Steering times, checking and adjusting
Steering valve, neutral position, checking and adjusting
Suspension cylinder (GHS) oil, changing
Suspension cylinder (GHS) rubber bearings, checking
Suspension cylinder (GHS), checking and adjusting
Suspension cylinder (GHS), discarding
Suspension cylinder (GHS), oil changing
Suspension cylinder, installation
Suspension cylinder, removal
System test
Tail lamp, replacing
Tech Tool, operations1
Transmission breather filter, replacing
Transmission oil filter, replacing
Transmission oil pressure, checking
Transmission oil, changing
Transmission, fitting on a non mounted engine
Transmission, installing
Transmission, remove from a non mounted engine
Transmission, removing
Transverse differential lock axle, checking and adjusting
Troubleshooting, air conditioning unit (AC)
Turbocharger, inspection
Turbocharger, replacing
Tyre wear and air pressure, checking
Unit injector, replacing
Unit injectors, adjusting pretension
User instruction
V2-ECU, MID 249, changing non-Programd ECU
V2-ECU, MID 249, changing pre-Programd ECU
Vacuum pump, connection
Vacuum pump, disconnection
Valves, adjusting
Valves, adjusting1
V-ECU, MID 187, changing non-Programd ECU
V-ECU, MID 187, changing pre-Programd ECU
Wear indicator, adjusting
W-ECU, MID142, changing non-Programd ECU
W-ECU, MID142, changing pre-Programd ECU
Wheel alignment
Wheel, installing
Wheel, removing
Windscreen wiper front, replacing motor
Windscreen, replacing
Working pumps, checking function
Safety
Checking function
Decontamination
Environment
Environmentally hazardous fluids
Environmentally safe handling
Fire prevention measures
Recovering and towing
Rules when handling tyres
Safety concerns everybody!
Safety during electric welding
Safety when handling accumulators
Safety when handling oils and fuel
Safety when lifting and supporting the machine
Safety when using lifting equipment
Safety when working on hydraulic systems
Safety when working on pressurized systems
Safety when working on the machine's electrical system
Safety when working with air conditioning refrigerant
Service position 1
Transporting the machine
Waste handling
Working in environmentally contaminated areas
Service Bulletins
Action to be taken in case of abnormal lubricating oil consumption
Alternative lubricants for axles with wet brakes
Automatic transmission lubricants
Battery and alternator test procedure
DEF AdBlue AUS32 sampling, method
Fuel sampling, method
Information on Bio-diesel fuel (RME-fuel)
New Articulated Haulers F- and G-series
New tip lever
Oil sampling, method
Quality of illustrations in technical reports
Recommendations for Oil Sampling Intervals
Reports
TechTool 2 communication
Transmission, functional check
Transmission, inspection form
Tyres, various types
Water in engine compartment
Special Tools, Misc
Special tool catalog
Special Tools Recommendations
Time Guide Current generation
Time Guide Old generation
Specifications
AC system, specifications
Accumulator, specification
AdBlue® DEF Information
AdBlue® DEF
Alternator, specifications
Alternator, tightening torques
Automatic lubrication system, specifications
Axle suspension, tightening torque
Battery, specifications
Brake cooling system, capacities
Brake pressure
Brakes, specifications1
Brakes, specifications2
Cabin, specification
Compressed-air system, specifications1
Compressed-air system, specifications2
Coolant
Cooling system, specification
Cooling system, tightening torques
Damping cylinder, specification
Drive axles, tightening torques
Drive shafts, specifications
Drive train capacities
Dropbox, specifications
Dump lever, specifications
EGR system, tightening torques
Engine hood, specification
Engine transmission, specification
Engine, capacities
Engine, specification
Fire suppression system, specification
Fire Suppression System, tightening torques
Flywheel, tightening torques
Frame extension, specification
Frame joint, tightening torque
Frame, weight
Fuel system, specifications
Grease
Hitch, specifications
Hoist cylinder, specifications
Hydraulic connections, tightening torques
Hydraulic pressure, specifications
Hydraulic pumps, specifications
Hydraulic system, capacities
Hydraulic transmission, specification
Inlet and exhaust system, specification
Inlet and exhaust system, tightening torques
Lighting, specifications
Load carrier, specifications
Lubrication system, specifications
Lubrication system, tightening torques
Oil cooler, tightening torques
Parking brake, specifications1
Parking brake, specifications2
Parking brake, tightening torque1
Parking brake, tightening torque2
Power outlet, specifications
Power take-off, tightening torque
Power transmission, specifications
Propeller shaft, tightening torque
Protective plate, weight
Pump unit, specification
Pump unit, tightening torque
Recommended lubricants
Recommended lubricants1
Rocker arm shaft, tightening torques
Secondary steering, specification
Standard tightening torques
Starter motor, specification
Starter motor, tightening torques
Steering and dumping valve, specifications
Steering and dumping valve, tightening torques
Steering cylinder, specifications
Steering gear, specifications
Steering linkage, tightening torque
Steering system, specifications
Suspension cylinder (GHS), specifications
Tailgate, specifications
Tightening torque Drop box
Tightening torque, cylinder head1
Tightening torque, cylinder head2
Tightening torque, fuel system
Tightening torques, engine mounts
Tightening torques, valve cover
Tipping system, specification
Transmission oil pressure, specifications
Transmission, tightening torques
Tyre equipment and recommended tyre pressures
Valve mechanism, specifications1
Valve mechanism, specifications2
Valve mechanism, specifications3
Voltage converter, specification
Weights
Wheel, tightening torque
Windscreen wiper motor, tightening torques
