Martin Welker
104
230,310
Volvo Dump Truck A25G Parts Manual
Brand: Volvo
Type of Machine: Dump Truck
Model: Volvo A25G Dump Truck
Number of Pages: 928 Pages
0 General
2 Engine with Mounting and Equipment
Egr system, actuator, assembly 15185530, 15185531
Fuel System
Ignition and Control System
Inlet, Exhaust System
Lubricating System
Pedal 11371242, 11371246
3 Elec, Warning, Information, Instruments
Battery
Cable, Fuse, Relay
Instrument, Sensor, Warning and Information
Lighting
Miscellaneous
Other Electrical Equipment
Starting System
4 Power Transmission
Front Axle, Rear Axle
Gearbox
Oil cooler
Power Take Off
Propeller Shaft
Torque converter and oil pump 22436
Transmission, Hydraulic Control
5 Brakes
Compressed-Air Brake
Hydraulic Brake System
Wheel Brake
6 Steering
Auxiliary steering system 11371301
Auxiliary steering system 11371302
Control valve with fitting parts SN - 320009, - 340369
Control valve with fitting parts SN 320010 -, 340370 -
Damping cylinder with fitting parts
Damping cylinder
Drag rod
Hydraulic cylinder with fitting parts
Hydraulic cylinder
Steering system 11371299
Steering system 11371300
Steering system 11371409
Steering system
Steering system1
Steering system2
Steering wheel and column 11371242, 11371246
7 Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit
Bogie 11371443
Bogie 11371468
Bogie suspension
Frame Extension 11371441
Frame Extension 11371442
Frame joint, horizontal bearing
Frame joint, vertical bearing
Frame
Front axle suspension
Protecting plates
Superstructure
Wheel 81080, 81120
Wheel 81317, 11371177
Wheel 81318, 11371176
Wheel 81319
Wheel 84344, 84345
8 Machinery House, Cab, Exterior Trim Parts
Air Conditioning Unit
Cab Interior-Upholstery
Cab, Naked, Canopy
Doors, Hatch, Cover Plate
Engine Hood, Mudguard, Foot Step
Interior Equipment
Miscellaneous
Protective Equipment
Trim Part, Outside, Glass, Sealing Moulding
9 Hydraulic, Digging, Handling, Grading and Misc Equip
Load Carrier
Miscellaneous
Towing brace 91861
Working Hydraulics, Servo Hydraulic
