Martin Welker
104
230,310
Volvo Dump Truck A25C Parts Manual
Brand: Volvo
Type of Machine: Dump Truck
Model: Volvo A25C Dump Truck
Number of Pages: 677 Pages
0 General
2 Engine with Mounting and Equipment
Engine Control
Fuel System
Inlet, Exhaust System
Lubricating System
3 Elec, Warning, Information, Instruments
Alternator, Charge Regulator
Battery
Cable, Fuse, Relay
Instrument, Sensor, Warning and Information
Lighting
Miscellaneous
Other Electrical Equipment
Starting System
4 Power Transmission
Clutch, Torque Converter
Front Axle, Rear Axle
Gearbox
Miscellaneous
Propeller Shaft
Transmission, Hydraulic Control
5 Brakes
Compressed-Air Brake
Hydraulic Brake System
Wheel Brake
6 Steering
Check valve with fitting parts
Check valve
Control valve with fitting parts
Damping cylinder with fitting parts
Drag rod
Front axle suspension
Hydraulic pump with fitting parts
Pressure sensor
Rack gear
Rack gear1
Steering cylinder with fitting parts
Steering cylinder
Steering linkage
Steering system CAB - 5802
Steering system CAB 5803 -
Steering system, pipes and hoses
Steering system
Steering unit
Valve, circuit body and return valve
7 Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit
Bogie mounting block Front
Bogie mounting block, rear
Front frame with assemblyparts
Hitch
Rear axle suspension. 4 x 4
Rear frame with assembly parts
Wheels 20,5-25
Wheels 23,5-25 - 29,5-25
Wheels 23,5-25
8 Machinery House, Cab, Exterior Trim Parts
Air Conditioning Unit
Cab Interior-Upholstery
Cab, Naked, Canopy
Doors, Hatch, Cover Plate
Engine Hood, Mudguard, Foot Step
Interior Equipment
Miscellaneous
Protective Equipment
Trim Part, Outside, Glass, Sealing Moulding
9 Hydraulic, Digging, Handling, Grading and Misc Equip
Load Carrier
Mechanical Equipment - Attachment
Miscellaneous
Working Hydraulics, Servo Hydraulic
