Martin Welker
104
230,310
Volvo Drum Compactor DD90 Service Repair Manual
Brand: Volvo
Type of Machine: Drum Compactor
Model: Volvo DD90 Drum Compactor
Number of Pages: 878 Pages
1 Volvo DD90
2 Equipment Repair and Maintenance DD90
DD – 90 DD – 90 HF
Slide Number 2
Slide Number 3
Slide Number 4
Slide Number 5
Slide Number 6
Slide Number 7
Slide Number 8
Slide Number 9
Slide Number 10
Slide Number 11
Slide Number 12
Slide Number 13
Slide Number 14
Slide Number 15
Slide Number 16
Slide Number 17
Slide Number 18
Slide Number 19
Slide Number 20
Slide Number 21
Slide Number 22
Slide Number 23
Slide Number 24
Slide Number 25
Slide Number 26
Slide Number 27
Slide Number 28
Slide Number 29
Slide Number 30
Slide Number 31
Slide Number 32
Slide Number 33
Slide Number 34
Slide Number 35
Slide Number 36
Slide Number 37
Slide Number 38
Slide Number 39
Slide Number 40
Slide Number 41
Slide Number 42
Slide Number 43
Slide Number 44
Slide Number 45
Slide Number 46
Slide Number 47
Slide Number 48
Slide Number 49
Slide Number 50
Slide Number 51
Slide Number 52
Slide Number 53
Slide Number 54
Slide Number 55
Slide Number 56
Slide Number 57
Slide Number 58
Slide Number 59
Slide Number 60
Slide Number 61
Slide Number 62
Slide Number 63
Slide Number 64
Slide Number 65
Slide Number 66
Slide Number 67
Slide Number 68
Slide Number 69
Slide Number 70
Slide Number 71
Slide Number 72
Slide Number 73
Slide Number 74
Slide Number 75
Slide Number 76
Slide Number 77
Slide Number 78
Slide Number 79
Slide Number 80
Slide Number 81
Slide Number 82
Slide Number 83
Slide Number 84
Slide Number 85
Slide Number 86
Slide Number 87
Slide Number 88
Slide Number 89
Slide Number 90
Slide Number 91
Slide Number 92
Slide Number 93
Slide Number 94
Slide Number 95
Slide Number 96
Slide Number 97
Slide Number 98
Slide Number 99
Slide Number 100
Slide Number 101
Slide Number 102
Slide Number 103
Slide Number 104
Slide Number 105
Slide Number 106
Slide Number 107
Slide Number 108
Slide Number 109
Slide Number 110
Slide Number 111
Slide Number 112
Slide Number 113
Slide Number 114
Slide Number 115
Slide Number 116
Slide Number 117
Slide Number 118
Slide Number 119
Slide Number 120
Slide Number 121
Slide Number 122
Slide Number 123
Slide Number 124
Slide Number 125
Slide Number 126
Slide Number 127
Slide Number 128
Slide Number 129
Slide Number 130
Slide Number 131
Slide Number 132
Slide Number 133
Slide Number 134
Slide Number 135
Slide Number 136
Slide Number 137
Slide Number 138
Slide Number 139
Slide Number 140
Slide Number 141
Slide Number 142
Slide Number 143
Slide Number 144
Slide Number 145
Slide Number 146
Slide Number 147
Slide Number 148
Slide Number 149
Slide Number 150
Slide Number 151
Slide Number 152
Slide Number 153
Slide Number 154
Slide Number 155
Slide Number 156
Slide Number 157
3 Part Catelog DD90
TABLE OF CONTENTS DD-90/91/91HF
MAIN FRAME
TANK
ENGINE
CONSOLE
DRUM
HOSING
ELECTRICAL
WATER SYSTEM
INTERNAL BREAKDOWN
OPTIONS
DECALS
Adjustable steering column, replacing
Air cleaner, description
Air cleaner, installing
Air cleaner, primary filter replacing
Air cleaner, removing
Air cleaner, secondary filter replacing
Alternator, description
Alternator, installing
Alternator, removing
Amplitude sensor, adjusting
Batteries, replacing
Battery disconnect switch (main switch), check
Battery maintenance
Breather, replacing
Cable; Battery isolation switch
Carrier bearings, replacing
Charge air cooler pipe, installing
Charge air cooler pipe, removing
Charge air cooler, description
Charge air cooler, installing
Charge air cooler, removing
Check list after fire or heat exposure
Cleaning engine compartment
Cleaning of the machine
Component list, Fuses
Component list, Relays
Connectors, position
Control unit, description
Conversion tables
Coolant level, check
Coolant mixture
Coolant, changing
Cooling fan, changing
Cooling system, description
Description, complete machine
Drive motor, installing
Drive motor, removing
Drum carrier, changing oil
Drum drive motor hollow center shaft repair procedure
Drum drive motor speed sensor, replacing
Drum drive motor, description
Drum eccentric, changing oil
Drum eccentric, checking oil level
Drum eccentric, description
Drum shock mount, replacing 1
Drum shock mounts, checking
Drum, checking
Drum, description
Drum, installing
Drum, removing
Eccentric shaft coupling, replacing
Eccentric weight bearings, replacing
Eccentric weight, installing
Eccentric weight, overhaul
Eccentric weight, removing
Electric and hydraulic control unit, replacing
Electric welding
Electrical components, engine side
Electrical troubleshooting
Engine difficult to start
Engine does not start
Engine hood, changing gas spring
Engine hood, installing
Engine hood, removing
Engine mounts, replacing
Engine oil level, check
Engine overheated
Engine, air cleaner maintenance
Engine, changing oil and filter
Engine, description
Engine, installing
Engine, removing
Environmental requirements
Environmentally safe handling 1
Fan belt, check
Fan shroud, replacing
Fault code 1-1-3 – Sensor voltage #1 circuit
Fault code 1-2-2 – Machine type input circuit
Fault code 1-2-3 – Machine model input circuit
Fault code 1-2-4 and 1-2-5 – System status lamp circuit
Fault code 2-1-1 and 2-1-2 – Fuel solenoid release circuit
Fault code 2-1-3 – Fuel solenoid release circuit
Fault code 2-3-5 – Park brake command switch circuit
Fault code 2-4-1 – Engine running input circuit
Fault code 3-1-1 – Eccentric drum direction switch circuit
Fault code 3-1-2 – Eccentric drum select switch circuit
Fault code 3-1-3 – Impact spacing auto threshold circuit
Fault code 3-1-4 – Front VIB FWD CW solenoid circuit
Fault Code 3-1-5 – Front VIB FWD CW Solenoid Circuit
Fault code 3-2-1 – Front VIB REV CCW solenoid circuit
Fault code 3-2-2 – Front VIB REV CCW solenoid circuit
Fault code 3-2-3 – Rear VIB FWD CW solenoid circuit
Fault code 3-2-4 – Rear VIB FWD CW solenoid circuit
Fault code 3-2-5 – Rear VIB REV CCW solenoid circuit
Fault code 3-3-1 – Rear VIB REV CCW solenoid circuit
Fault code 3-3-3 – Troubleshooting circuit
Fault code 3-4-2 – Front eccentric VPM sensor circuit
Fault code 3-4-3 – Front eccentric VPM and drum speed sensors circuit
Fault codes 1-1-1 and 1-1-2 – System voltage circuit
Fault codes 1-1-4 – Sensor voltage #1 circuit
Fault codes 1-1-5 and 1-2-1 – Sensor voltage #2 circuit
Fault codes 2-1-4 and 2-1-5 – High throttle hold circuit
Fault codes 2-2-1 and 2-2-2 – Drive enable circuit
Fault codes 2-2-3 and 2-2-4 – High throttle pull circuit
Fault codes 2-2-5 and 2-3-1 – Park brake release circuit
Fault codes 2-3-2 and 2-3-3 – Operator absent circuit
Fault codes 2-3-4 – Park brake test circuit
Fault codes 3-3-2 and 3-3-4 – Vibration ON lamp circuit
Fault codes 3-3-5 and 3-4-1 – Impact spacing meter circuit
Fire prevention measures
Frame, description
Fuel filters, replacing
Fuel level sender, replacing
Fuel line, water separator, check and drain
Fuel system, bleeding
Fuel tank, description
Fuel, coolant and oil leaks, checking
Hand rail, installing
Hand rail, removing
Handling hazardous materials
Heavy exhaust smoke development
Hydraulic brake system, description
Hydraulic diagram, schematic
Hydraulic hose schematic
Hydraulic motor, specifications 1
Hydraulic oil cooler, description
Hydraulic oil cooler, installation
Hydraulic oil cooler, removal
Hydraulic oil dye
Hydraulic oil filter, replacing
Hydraulic oil suction strainer, cleaning
Hydraulic oil tank, changing oil
Hydraulic oil tank, description
Hydraulic oil tank, vacuum-pumping, connecting and disconnecting pump
Hydraulic pump, replacing
Hydraulic system, checking oil level
Hydraulic system, startup procedure
Hydrostatic controller, installing
Hydrostatic controller, removing
Hydrostatic pump, description
Hydrostatic pump, installing
Hydrostatic pump, removing
Instruments and controls, overview
Large DD Carrier, new design on carrier assembly
Loop flushing valve, description
Loop flushing valve, replacing
Low engine oil pressure
Low voltage
Lubricant recommendation
Lubrication and service schedules
Machine identification
Maintenance service, daily
Maintenance service, every 50 hours
Maintenance service, every 500 hours
Maintenance service, every 1000 hours
Maintenance service, general
Multi function brake valve solenoid and cartridge, replacing 1
Multi-function brake valve, description 1
Multi-pin breakout box, connecting
Oil and filtration 1
Oil and filtration
Operator's platform mounts, replacing
Operator's protective structure, component locations
Operator's protective structure, description
Operator's seat, installing
Operator's seat, removing
Paint and Finish
Parking brake performance
Parking brake pressure switch, replacing 1
Periodic maintenance
Power train, troubleshooting
Power Transmission, Propulsion
Precaution when working on the electrical system
Pump coupling, installing
Pump coupling, removing
Pump de-stroke valve and solenoid, description
Radiator and coolers, cleaning
Radiator, replacing
Reverse alarm, replacing
ROPS (Roll Over Protection), installing
ROPS (Roll Over Protection), removing
Routine for return of technical goods
Safe operation of the machine
Safety concerns everybody!
Safety when lifting and supporting complete machine
Safety when servicing
Safety when working on hydraulic system
Safety when working on the electrical system
Seat safety belt, replacing
Service position
Silencer, replacing
Smart functions, description
Smooth drum scrapers, replacing
Starter motor, description
Starter motor, replacing
Starter switch (engine start switch), replacing
Starting with booster batteries
Steering Control Unit - Installation
Steering Control Unit - Removal
Steering control unit, description and operation
Steering cylinder, replacing
Steering pressure, checking and adjusting
Steering system, description
Steering system, troubleshooting
Stopping
Swivel joint (horizontal and vertical) pins, torque
Torque hub, installing
Torque hub, removing
Towing a disabled machine
Towing procedures
Transporting the machine
Travelling on public road
Two speed valve solenoid and cartridge, replacing
Vibration controls not functioning
Vibration hydraulic circuit, description
Vibration motor, description
Vibration motor, installing
Vibration motor, removing
Vibration pump, description
Vibration pump, installing
Vibration pump, removing 1
Vibration speed sensor, replacing
Water filter, changing 1
Water pump strainer, checking
Water pump, description
Water pump, installing
Water pump, removing
Water spray system, description
Water tank and spray bars, drain and flush
Water tank level, checking
Water tank, installing
Water tank, removing
Wiring diagram 1
Wiring diagram 2
Wiring diagram 3
Wiring diagram 4
Wiring diagram 10
Wiring diagram 11
