Volvo Buses B6 Service Repair Manual
Brand: Volvo
Type of Machine: Buses
Model: Volvo B6 Buses
Number of Pages: 2189 Pages
900A Fault during SAE J1939 transmission
900B SAE J1939 Control link, interruption
900F Tachograph buttons not working
7735-05-03-02 Front wheel bearing, adjust (one)
9010 Display fault
9051 Chart missing for driver 1
9052 Chart missing for driver 2
A00C Internal communication fault
Abbreviations
ABS, fault tracing
Accelerator pedal control
Adjusting unit assembly, front axle, replace
Air drier descr
Air drier non return valve, replace
Air drier specs
Air drier, drier insert, replace
Air drier, function check
Air drier, replace
Air drier, silencer replace
Air drier, valve unit replace
Air filter handling
Air in the fuel system, check
Air pressure brake system, components
Air pressure brake system, components1
Alternator belt, replace
Alternator check, clean and test-run on bench
Alternator drive belt, replace
Alternator, cleaning
Alternator, fault tracing
Alternator, install
Alternator, remove
Alternator1
Angle gear, overhaul
Anti-lock brake system (ABS)
Anti-roll bar, lever arm and rubber bushing, replace
Automatically adjustable steering limiter, replace
Basic service forms
Basic service
Batteries, replace (all)
Battery analyser 7200 user manual
Battery analyser, 7200, user manual
Battery analyzer, 88890075 EXP, user manual
Battery cable shoe, replace
Battery charging
Bearings, intermediate arm, replace
Bellow height, check measure
Bellow hight, adjust
Belt tensioner, alternator, replace
Belt tensioner, drive belt coolant pump, replace
Brake adjustment, check
Brake caliper front wheel, replace
Brake caliper rear wheel, replace
Brake caliper, install (one side)
Brake caliper, overhaul
Brake caliper, remove (one side)
Brake caliper, remove (one wheel)
Brake cylinder, replace (front)
Brake disc rear wheel, replace
Brake disc, front wheel, replace
Brake disc, measurement of thickness and side throw
Brake disc, measurement of thickness and side throw1
Brake drum, machining
Brake pad, measurement of play between outer lining plate and brake caliper
Brake pads, replace (two front wheels)
Brake pads, replace (two rear wheels)
Cable gear selector, replace
Cable harness engine, replace
Cable repair
Camshaft bearing, replace
Camshaft timing, check and adjust
Camshaft wear, check
Camshaft, replace
Camshaftsensor, replace
Carbon brushes, replace
Charge air cooler, check
Charging regulator, replace
Charging test, in vehicle
Chassis painting
Circuit breaker, start-stop, replace
Compressor, check and wear measurement
Compressor, function and leakage check
Compressor, overhaul
Compressor, replace
Connecting rod bearings, replace (all)
Control system, install
Control system, remove
Control unit, replace
Control valve, replace
Control valves JAK, replace
Coolant filter, replace
Coolant plug, cylinder head, replace (side or rear)
Coolant pump, replace
Coolant type, replace
Coolant, replace
Cooling coil, replace
Cooling system, drain and refill coolant
Crankshaft drive belt pulley, replace
Crankshaft seal, replace (front) 1
Crankshaft seal, replace (Front)
Crankshaft seal, replace (rear)
Crankshaft, replace
Cross stay front, replace
Cylinder head, install
Cylinder head, pressure test (first)
Cylinder head, remove
Cylinder head, transfer parts
Cylinder liner seals, replace ( All)
Cylinder liner seat, milling (first)
Cylinder liners and pistons, replace (All)
Delivery pipes, replace (all)
Differential carrier, install
Differential carrier, overhaul
Differential carrier, remove
Diodes and heat sinks
Distributor valve, replace
Drawer
Drive belts fan, replace
End plate front, overhaul
Engine controls E-GAS II `1
Engine mounting pad front, replace (one)
Engine parts, transferring
Engine, clean
Engine, install and remove from overhaul stand
Engine, install
Engine, remove
Evacuating valve, overhaul
Exhaust pressure governor
Expansion tank, replace
Fan blade, replace
Feed pump, replace
Filter insert, air cleaner, replace
Filter, water separator, replace
Filter, water separator, replace1
Flexible exhaust pipe, replace
Flywheel bearing, replace
Flywheel housing run-out, check
Flywheel housing, replace
Flywheel ring gear, replace
Flywheel sensor, replace
Flywheel, replace
Footbrake valve, replace
Four-circuit protection valve, replace
Friction plate, replace
Front air suspension, components
Front air suspension, components1
Front shock absorber bushings, replace
Front wheel bearing, adjust (one wheel)
Fuel distributor, replace
Fuel filter housing, replace
Fuel filter housing, replace1
Fuel filter, replace (one)
Fuel pressure sensor, replace
Fuel regulator, replace
Fuel system and used lubricant oil analysis, fault tracing
Fuel system, bleeding
Fuel system, leak test
Fuel tank strainer, clean and drain condensation water
Fuses
Gasket oil filter housing, replace
Gasket oil sump, replace
Gasket, separator crankcase ventilation, replace
Gaskets for inlet manifold, replace
Gaskets, exhaust manifold, replace
Gaskets, intake manifold, replace
Gaskets, timing gear cover, replace
Gear servo pump, replace
Guide sleeve seals, replace
Guide sleeves bushings and seals, replace
Heating coil, AdBlue tank, replace
Heating element, replace
Horn, replace
Hydraulic retarder
Impulse sensor, replace
Injection timing adjuster, replace
Injector pressure pipes, replace 1
Injectors, install (all)
Inledning
Internal recording error
JAK, replace
King pin journalling, adjust (one side)
Level sensor, air suspension driven axle, replace (one)
Level sensor, air suspension, replace (one)
Level valves, seizing at raised height level
Lifting a vehicle with air suspension
Lifting the front suspension
Lifting the rear suspension
Lining wear sensor, front, replace
Lubricants, fluids and oil analysis
Main bearings, replace (all)
Manual slack adjuster, assembling
Manual slack adjuster, disassembling
Manual slack adjuster, installation
Manual slack adjuster, removal
Measures in connection with repairs involving dismantling the wheelbrake mechanism
Modulator, front, replace
Modulator, rear, replace
Most important characteristics of the EST 18 control unit
Non-return valve, check
Non-return valve, replace
Oil and filter, power steering, replace
Oil and water separator, back pressure measurement
Oil and water separator, overhaul
Oil cooler, pressure test
Oil cooler, replace
Oil filter housing, replace
Oil filter, replace
Oil pan gasket, replace
Oil pump, remove-install
Oil pump, replace
Oil sump gasket, replace
Oil sump, install
Oil sump, remove
Oilfilter external, replace
Oilfilter, replace
Output B7
Output shaft seal, replace
Output shaft sealing ring, replace
Overflow valve, replace
Pinion sealing ring, replace
Piston seal, replace
Piston thermostat, replace
Piston, rings replace (all)
Pitman arm, replace
Power pump, remove
Power steering pump, replace
Pressure drop indicator, check
Pressure limiter valve, replace
Pressure limiting valve, replace
Pressure pipe, replace
Pressure pipes, replace (all)
Pressure regulator, adjust
Pressure sensor front axle, replace
Pressure sensor, driven axle, replace
Pressure sensor, replace
Propeller shaft 1
Propeller shaft rear, remove-install
Propeller shaft specs
Propeller shaft
Pulley, replace
Quick release valve, replace (front)
Quick-release valve, replace (rear)
Radiator, replace
Reaction rod, front, replace
Reaction rod, install (one)
Reaction rod, overhaul
Reaction rod, remove (one)
Rear axle, differential
Rear wheel bearing and seal, replace
Rear wheel hub UNIT, install
Rear wheel hub unit, remove
Rear wheel hub unit, replace
Relay, replace
Relay, starting element, replace
Replacing the propeller shaft fork or tubes
Replacing the propeller shaft fork or tubes1
Replacing the propeller shaft fork or tubes2
Retarder control air pressure, check
Retarder heat exchanger, install
Retarder heat exchanger, pressure test
Retarder heat exchanger, remove
Retarder safety-valve,check, adjusting valve and control air pressure
Retarder sealing ring rear end, replace
Retarder sinter-filter, clean
Retarder, dynamic pressure, check
Retarder, install
Retarder, remove
Rocker arm mechanism, inspect
Rocker arm shaft, install
Rocker arm shaft, remove
Rocker arms, replace (all)
Routine maintenance
SCR catalytic converter, check
Seal, output shaft, replace
Seal, rear wheel hub UNIT, replace
Sealant, oil pan, replace
Sealing ring, output shaft, replace
Sealing, coolant pump housing, replace
Sealings steering gear, replace
Seals, guiding sleeves, front axle, replace
Secondary air filter, replace
Sensor camshaft, replace
Sensor oil pressure, replace
Sensor temperature, replace
Sensor, oil temperature, replace
Sensor, speedometer, replace
Separator, crankcase ventilation, replace
Servo pump, remove
Servo pump, replace
Shutter housing, replace
Sleeve injectors, replacement (Others each)
Sleeve, injector, replace (one)
Sliding sleeves, wear measurement
Solenoid valve exhaust brake, replace
Solenoid valve in control system, replace
Solenoid valve JAK, replace
Specification RS0818SV and RS1026SV
Specifications
Speed limiter
Spring brake cylinder drive axle, replace
Standard tightening torques
Starter button, replace
Starter motor, install
Starter motor, remove
Starter motor, replace
Steering gear, install
Steering gear, remove
Steering knuckle, overhaul (one)
Stop hazard turn lamps, simplified schematic
Storage instructions
Tachograph chart drive circuit
Tachograph, replace
Temperature sensor for inhibitor and torque converter, replace
Tension puller, alternator belt, replace
Tension pulley, drive belt coolant pump, replace
Thermostat fan, replace
Thermostats, test
Tightening on wheels
Tightening torque suspension
Tightening torques, wheel nuts
Time indicator fault
Towing information
Trouble shooting equipment
Turbocharger, install
Turbocharger, remove
Turbocharger, replace
Unit pump, replace
Universal joints, lubrication
Universal joints, replace (each)
Updating VDA
Valve body, level control, replace
Valve clearance, adjust
Valve cover gasket, replace (first)
Valve guide wear, check
Valve stem seals, replace 1
Valves and JAK, adjust
Valves, adjust
Valves, remove and install (one cylinder)
Vibration dampener, replace
Water separator, water draining
Wheel speed sensor, front, replace
Wheel straight-ahead position, adjust
Wheelbrakes, checking and adjusting
Wheelstud, front, replace
Wheelstud, rear, replace (one)
Wiring diagram
Brand: Volvo
9010 Display fault
Abbreviations
ABS, fault tracing
Air drier descr
Air drier specs
Air drier, replace
Air filter handling
Alternator, install
Alternator, remove
Alternator1
Basic service forms
Basic service
Battery charging
Cable repair
Camshaft, replace
Chassis painting
Compressor, replace
Coolant, replace
Crankshaft, replace
Drawer
Engine, clean
Engine, install
Engine, remove
Fan blade, replace
Feed pump, replace
Flywheel, replace
Fuses
Horn, replace
Hydraulic retarder
Inledning
JAK, replace
Oil cooler, replace
Oil filter, replace
Oil pump, replace
Oil sump, install
Oil sump, remove
Oilfilter, replace
Output B7
Pitman arm, replace
Power pump, remove
Propeller shaft 1
Propeller shaft
Pulley, replace
Radiator, replace
Relay, replace
Retarder, install
Retarder, remove
Routine maintenance
Servo pump, remove
Servo pump, replace
Specifications
Speed limiter
Tachograph, replace
Thermostats, test
Towing information
Unit pump, replace
Updating VDA
Valves, adjust
Wiring diagram
- Volvo Truck Service Manual All
- Volvo D11 D13 D16 Service Manual
- Volvo Trucks MID Fault Codes
- Volvo FM12, D12D420 New engine variants -Sensor
- Volvo FM12, D12F500 Specifications- Sensor-EBR-VEB Valves and unit injectors, adjust. Valve cov
- Volvo NH Valves and unit injectors, adjust
- Specifications Volvo Engine D12D
- Volvo Service Manual Truck - Wiring Diagram FM9, FM12, FH12, FH16, NH12
- Volvo FM12, D12C 420 Engine
- Volvo Truck Service Manual Trucks Wiring Diagram FL7,FL10 LHD
- Volvo Engine Trucks D13 Service Manual
- Volvo Truck F10 F12 F16 1998 Service Manual
- Volvo Truck Service Manual & Electrical Schematic
- Volvo Bus B7,B9,B12 Wiring Diagram
- Volvo FM12, D12D460 Cylinder head, install EBR-EPG Valves and unit injectors, adjust. Valve cover
