Volvo Buses B58 Service Repair Manual
Brand: Volvo
Type of Machine: Buses
Type of Manual: Service Repair Manual, Brake circuit diagram
Model: Volvo B58 Buses
Number of Pages: 1249 Pages
Bulletins - Information
9985011 Densimeter
Communication connections VCADs Pro to vehicle
Description, Design and Function
23604-2 Pump coupling disc, replace (first)
31102-2 Batteries, replace (all)
31122-2 Battery, state of charge, check (Measure specific gravity)
Air drier
Articulation angle warning system
Batteries, maintenance
Battery charging
Battery Specifications
Battery troubleshooting
Battery, precautions
Battery
Clutch
Compressor, exploded view
Compressor1
Compressor2
Compressor3
Cooling system
Differences between the EV 81 B and EV 81 C
Differential carrier EV 81 B
Differential carrier, cross-section view
Differential carrier, design
Differential carrier, design1
Differential carrier, exploded view
Differential carrier, exploded view1
Differential carrier, function1
Differential carrier, section view
Differential lock
Differential lock1
Drive shafts
Electro-magnetic brake, drawing
Electro-magnetic brake1
Electro-magnetic brake2
Four-circuit protection valve
Fuel system
Gearbox
General
General1
General2
Hub reduction, exploded view
Hub reduction
Injection pump
Inlet and exhaust system
Lubrication system valves1
Lubrication system valves2
Lubrication system valves3
R3 - Group 00 Vehicle Identification Number VIN
Rubber sealings, general
Starter motor, exploded view
Starter motor
Steering knuckle
Tachograph
Thermostat
Thermostatic fan
Towing information
Tyre and inner tube
Updating VDA1
Updating VDA2
Water pump
Wheel alignment
Diagnostics
900A Fault during SAE J1939 transmission
900B SAE J1939 Control link, interruption
900F Tachograph buttons not working
9010 Display fault
9051 Chart missing for driver 1
9052 Chart missing for driver 2
9053 Time indicator fault
9060 Drawer
9061, 9062, 9063 Internal recording error
9064 Tachograph chart drive circuit
9430 Output B7
A00C Internal communication fault
A050 Trip without chart for driver 1
A400 Power loss
A423 Error during sensor communication
A822 Error in the sensor key serial number signal
Checking of the inductive sensor and solenoid valves
Compressor
Diagnostic Program for automatic transmissions ZF HP500, 590 Control
Electro-magnetic brake, fault tracing1
Electro-magnetic brake, fault tracing2
Electro-magnetic brake, fault tracing3
Fault-tracing, automatic transmissions ZF HP 500, 590
Fuel system and used lubricant oil analysis, fault tracing
General information, Battery analyser 7200
Malfunctions, causes and remedial actions
Malfunctions, causes and remedial actions1
Malfunctions, causes and remedial actions2
Tachograph, fault code table
Tachograph, fault codes, general information
ZF HP 500, 590 Automatic gearboxes with the EST-18 control unit
Forms
Air drier and cooling coil, warranty claim handling, additional information
Oil and fuel consumption, follow-up
Report for handling of warranty claims for air driers and cooling coils
Repair
21002-2 Cylinder compression test
21105-5 Valve seat, replace (one)
21170-1 Cylinder head, remove (first)
21171-4 Cylinder head, pressure test (first)
21172-1 Cylinder head, install (first)
21177-4 Cylinder head, transfer parts
21207-5 Threads in engine block, clean (one cylinder head)
21233-3 Flywheel housing, replace
21235-3 Flywheel housing run-out, check
21337-3 Cylinder liners, lap against block collar (each other cylinder liner)
21357-3 Piston and liner, replace (one)
21373-5 Piston or gudgeon pin, replace
21412-2 Valves, adjust
21493-4 Rocker arm mechanism, overhaul
21520-2 Sealing ring timing cover, replace
21521-3 Camshaft, replace
21531-3 Timing gears, replace (all)
21603-3 Main bearings, replace (all)
21607-3 Flywheel bearing, replace
21611-3 Connecting rod bearings, replace (all)
21631-3 Flywheel, check
21663-5 Crankshaft seal, replace (rear)
21687-5 Flywheel ring gear, replace
22111-3 Oil pump, remove-install
22171-4 Oil pump, overhaul
22207-3 Oil filter, engine, replace
22323-3 Oil cooler, replace
22325-5 Oil cooler, pressure test
23003-3 Fuel system, bleeding1
23003-3 Fuel system, bleeding2
23302-2 Feed pump, replace
23302-2 Feed pump, replace1
23304-2 Fuel filters, replace (two)1
23304-2 Fuel filters, replace (two)2
23312-2 Filter, water separator, replace
23314-2 Water separator, water draining
23378-2 Fuel feed pressure, check1
23378-2 Fuel feed pressure, check2
23397-4 Fuel feed pump, overhaul1
23397-4 Fuel feed pump, overhaul2
23415-3 Fuel tank strainer, clean and drain condensation water
23670-1 Injection pump, remove
23671-4 Injection pump, adjust
23672-1 Injection pump, install
23701-5 Sleeve, injector, replace (One)
23702-2 Injectors, replace (all)
23771-4 Injectors, overhaul and test (each)
23775-4 Injectors opening pressure, adjust (each)
25507-3 Turbocharger, axial and radial play, check
25510-2 Boost pressure measuring, with manometer
25624-2 Filter insert, air cleaner, replace
26006-2 Cooling system, pressure test
26007-3 Cooling system, clean
26012-2 Cooling system, drain and refill
26271-4 Coolant pump, overhaul
26273-4 Thermostats, test1
26273-4 Thermostats, test2
26298-2 Thermostats, replace
26330-2 Support bearing housing, front, overhaul
26335-4 Support bearing housing, overhaul
26504-2 Charge air cooler, leakage test
36202-2 Horn, replace
38314-3 Tachograph, calibration1
38314-3 Tachograph, calibration2
41103-3 Clutch disc, replace
41277-5 Clutch fork and clutch shaft, replace
41283-5 Release bearing, pulling clutch replace
41314-2 Clutch cylinder, replace1
41314-2 Clutch cylinder, replace2
41322-2 Master cylinder for clutch complete, overhaul
41342-2 Clutch system, bleed
41375-4 Clutch servo, overhaul1
41375-4 Clutch servo, overhaul2
43131-4 Sealing ring input shaft, replace
43145-4 Sealing ring for output shaft, replace
43173-5 Main shaft, overhaul
43181-5 Intermediate shaft, overhaul
43187-4 Gearbox, disassemble-inspect-assemble
43197-5 Input shaft, overhaul
43278-4 Control housing, overhaul
46514-2 Pinion sealing ring, replace
46570-1 Differential carrier, remove1
46570-1 Differential carrier, remove2
46571-4 Differential carrier, overhaul
46571-4 Differential carrier, overhaul1
46572-1 Differential carrier, install1
46572-1 Differential carrier, install2
46656-2 Hub reduction, overhaul (one side)
51087-4 Spring brake cylinder, overhaul
56153-5 Compressor, check and wear measurement
56171-4 Compressor, overhaul1
56171-4 Compressor, overhaul2
59104-4 Bearings and sealings electro-magnetic brake, replace
59106-4 Coil electro-magnetic brake, replace (one)1
59106-4 Coil electro-magnetic brake, replace (one)2
59170-1 Electro-magnetic brake, remove
59172-1 Electro-magnetic brake, install
60124-2 Toe-in, check
60131-3 Toe-in, adjust
61103-3 Steering knuckle, overhaul (one)
61270-1 Front axle complete, remove
61272-1 Front axle complete, install
64105-2 Steering shaft sealing ring, replace
64106-2 Steering shaft bearings upper and lower, replace
64116-2 Steering shaft universal joint, replace
64122-2 Steering wheel adjuster, overhaul
64150-1 Steering column, remove
64152-1 Steering column, install
64170-1 Steering wheel, remove
64172-1 Steering wheel, install
64238-2 Angle gear, overhaul
64252-2 Pressure point, steering gear, check and adjust
64273-5 Sealing ring, sector shaft, replace
64277-4 Steering gear, overhaul
64282-1 Steering gear, remove
64284-1 Steering gear, install
64306-2 Intermediate arm with roller bearings, overhaul
64312-2 Link rod, replace
64357-5 Track rod end, replace (one)
64370-1 Track rod, remove
64372-1 Track rod, install
64512-4 Power steering pump, overhaul
64525-3 Oil filter, power steering, replace
64570-1 Power pump, remove
64572-1 Power pump, install
77014-2 Driving wheels, remove-install (one side)
77018-2 Front wheel, remove-install (one side)
Articulation angle warning system, adjust
Ball joint play, link rods and track rods, check
Battery charging
Camshaft wear, check
Clutch service life
Clutch, service life check
Coolant return pipe, new install
Crankshaft wear, check
Curve angles, adjust
Cylinder head, check
Differential carrier, Assemble
Differential carrier, overhaul. Removed
Differential carrier, overhaul. Removed1
Electronic tachograph, new install
Feed pump R3 - Group 23
Front axle member (removed), check measuring
Gearbox retarder, disassembly and assembly
How to measure the disc thickness
Inspection after the seat grinding
Main bearing cap, replacement
Power steering system, function check
Preheating resistance, replacement
Push rod wear, check
Rear axle, adjust
Retarder coils, replacement
Retarder, disassembly
Retarder, installation
Special tools
Special tools1
Steering shaft, replace
Switch protection bushing, replacement
Turbo failure on charge air cooler engines, inspect
Turbocompressor, disassembly
Turbocompressor, installation
Vehicle operation test
Welding requirements
Schematic Diagrams
Brake circuit diagram 4x2 vehicles
Brake circuit diagram 4x2 vehicles1
Brake circuit diagram 4x2 vehicles2
Brake circuit diagram Articulated vehicles
Brake circuit diagram Biarticulated vehicles
Brake circuit diagram1
Brake circuit diagram2
Coloured code for the pneumatic diagrams
Extra equipment
Service and Maintenance
17523-3 Gearbox oil and filter, change
17527-3 Final drive oil, change
Air filter handling1
Chassis, lubrication
Chemical products catalogue
Clutch, lubrication
Coolant, change intervals
Engine, clean
Engine, lubrication
General information on service and maintenance
Kingpin axial play, check
Kingpin radial play, check
Oil-lubricated trailing axle hub, lubrication
Protocol overview
Removing questions
Starter and rotor gap, electromagnetic retarder, adjust
Universal joints, lubrication
Specifications
Brake equipment
Compressor, tightening torques
Compressor1
Compressor2
Compressor3
Cooling system
Crank mechanism
Electro-magnetic brake3
Engine flywheel, inspection
Final drive
Frame, springs, dampers and wheels
Frame, springs, dampers and wheels1
Front axle and steering1
Front axle and steering2
Fuel system
Gearbox, automatic
Gearbox
General
General1
Hub reduction
Injection pump
Intake and exhaust system
Lubricating and oil system
Oil cooler screws, tightening torques
Performance curves
Rear axle
Specifications
Speedometer sensor
Standard tightening torques
Starter motor
Tachograph, signal descriptions
Tachograph
Tightening torques and patterns
Tightening torques
Tightening torques1
Valve mechanism
Wearing tolerance
Wheel installation
Brand: Volvo
9985011 Densimeter
Air drier
Battery charging
Battery
Clutch
Compressor1
Compressor2
Compressor3
Cooling system
Differential lock
Differential lock1
Drive shafts
Fuel system
Gearbox
General
General1
General2
Hub reduction
Injection pump
Starter motor
Steering knuckle
Tachograph
Thermostat
Thermostatic fan
Towing information
Tyre and inner tube
Updating VDA1
Updating VDA2
Water pump
Wheel alignment
Diagnostics
9010 Display fault
9060 Drawer
9430 Output B7
A400 Power loss
Compressor
Forms
Repair
Battery charging
Clutch service life
Rear axle, adjust
Special tools
Special tools1
Schematic Diagrams
Extra equipment
Clutch, lubrication
Engine, clean
Engine, lubrication
Protocol overview
Removing questions
Specifications
Brake equipment
Compressor1
Compressor2
Compressor3
Cooling system
Crank mechanism
Final drive
Fuel system
Gearbox, automatic
Gearbox
General
General1
Hub reduction
Injection pump
Performance curves
Rear axle
Specifications
Speedometer sensor
Starter motor
Tachograph
Tightening torques
Tightening torques1
Valve mechanism
Wearing tolerance
Wheel installation
- Volvo Truck Service Manual All
- Volvo D11 D13 D16 Service Manual
- Volvo Trucks MID Fault Codes
- Volvo FM12, D12D420 New engine variants -Sensor
- Volvo FM12, D12F500 Specifications- Sensor-EBR-VEB Valves and unit injectors, adjust. Valve cov
- Volvo NH Valves and unit injectors, adjust
- Specifications Volvo Engine D12D
- Volvo Service Manual Truck - Wiring Diagram FM9, FM12, FH12, FH16, NH12
- Volvo FM12, D12C 420 Engine
- Volvo Truck Service Manual Trucks Wiring Diagram FL7,FL10 LHD
- Volvo Engine Trucks D13 Service Manual
- Volvo Truck F10 F12 F16 1998 Service Manual
- Volvo Truck Service Manual & Electrical Schematic
- Volvo Bus B7,B9,B12 Wiring Diagram
- Volvo FM12, D12D460 Cylinder head, install EBR-EPG Valves and unit injectors, adjust. Valve cover
