Martin Welker
104
230,792
Volvo Buses B10L Service Repair Manual
Brand: Volvo
Type of Machine: Buses
Model: Volvo B10L Buses
Number of Pages: 2627 Pages
Bulletins - Information
Adapter 62 pin 9998699-1
Adapter 62 pin 9998699-2
Adapter 9990020
Cable 88890304
New board system and laminate
Service tool Class 1
Special Tool General information
Special Tools, changes
Tidying up the tool database
Tool database
Trouble shooting equipment
VBEAT 9990832
Description, Design and Function
Abbreviations
ABS-ASR with D-version control unit
Accelerator pedal control
Air drier
Analysis of engine oil
Anti-lock brake system (ABS)
ASR-Anti Spin Regulation
Brake fluid
Cables clamping
Check ignition timing (basic setting)
Component locations
Components
Compressor
Consumables
Control system EDC
Control unit
Coolant
Cooling system
CRT system
Cylinder block
Cylinder head
Cylinder liner and piston
Cylinder liner
Diesel fuel
Disassembly instructions, complete vehicle
Door operation, electrical pneumatic
ECS system, special features
Electrical system
Electronic control system
Electronically controlled air suspension
Engine controls
Engine oil
Exhaust pressure governor
Filler valve Accumulator block
Four-circuit protection valve
Front air suspension, components
Front wheel suspension
Fuel system, natural gas
Fuel system
Gas pipe system
Gearbox, automatic, drawing
Gearbox
General quality requirements
General
Grease
Handling lubricants
Headlamps
Hydraulic fan drive
Hydraulic system
Ignition system
Injection timing adjuster
Inlet and exhaust system
Instrument, system description Design
Instrument, system description Explanation of pins
Instrument, system description Function
Instrumentation, component placement
Introduction
Joint angle sensor
Lubricants, fluids and oil analysis
Lubrication and oil system
Master ID, connectors
Mechanical system
MID 128 Engine control unit
Most important characteristics of the EST 18 control unit
Multiplexed electrical system
Oil reservoir
Oil water separator on B10L-BLE
Oils
Pipes, hoses and fittings
Pistons
Power path
Power steering gear, exploded view
Power steering gear
Power steering pump
Power steering system
Pressure regulator
Pressure sensor
Propeller shaft
Proportional valve
R3 - Group 0
R3 - Group 64
Rear axle, crown wheel and pinion
Rear axle, differential
Rear axle, general
Rear axle, reduction gear
Rear axle
Recommendations for Volvo Trucks
Rubber sealings, general
Safety system
Sensor, fuel supply regulation
Shock absorbers
Software download
Speed signal
Starter motor
Starting process
Steering column
Steering knuckle
Steering wheel
Stop hazard turn lamps, simplified schematic
Storage instructions
Storage
Tank system 5000
Teach-In of lock-up
Technical data
Throttle housing
Toolbox
Towing information
Transmission oil
Turbocharger
Turn table
Updating VDA
Valves
Vehicle control unit
Viscosity
Warning signals
Wheel alignment
Wheel brake, diagram
Wheel brake
Diagnostics
900A Fault during SAE J1939 transmission
900B SAE J1939 Control link, interruption
900F Tachograph buttons not working
9010 Display fault
9051 Chart missing for driver
9052 Chart missing for driver
9053 Time indicator fault
9060 Drawer
9061, 9062, 9063 Internal recording error
9064 Tachograph chart drive circuit
9430 Output B7
A00C Internal communication fault
A050 Trip without chart for driver
A400 Power loss
A423 Error during sensor communication
A822 Error in the sensor key serial number signal
ABS ECU measurement box, translation table
ABS, fault tracing 1
ABS, fault tracing 2
Air drier, function check
Air drier
Basic check
Basic data gathering 1
Basic data gathering 2
Battery analyser, 7200, user manual
Battery analyzer, 88890075 EXP, user manual
Boost pressure, test drive
Cables and connectors, fault tracing
Carbon monoxide (CO) in coolant system, check
Chassis ECM (CECM-C), check
Checklist A, EBS control unit
Control unit parameters 1
Control unit parameters 2
Control unit PIN configuration 1
Control unit PIN configuration 2
CRT, fault tracing
Cylinder balancing, check
Cylinder Compression, test
Data links, fault tracing
Diagnosis program 1
Diagnosis program 2
ECS system, using a PC for fault tracing
ECS, read fault codes
Engine control unit in out signals status, test 1
Engine control unit in out signals status, test 2
Engine controls E-GAS II 2
Engine controls E-GAS II 3
Engine controls E-GAS II-1
Exhaust back pressure, measure (vehicle standing still) 1
Exhaust back pressure, measure (vehicle standing still) 2
Exhaust back pressure, measurement (vehicle in motion)
Fault code fault tracing
Fault code troubleshooting 1
Fault code troubleshooting 2
Fault tracing, function testing and adjustments
Fault tracing, solenoid valves and sensors (connections connectors)
Fault tracing
Flywheel and camshaft signal, test
Fuel system and used lubricant oil analysis, fault tracing
Fuel system, fault tracing 1
Fuel system, fault tracing 2
Injector fuel volume, check
Inlet and exhaust systems, check
Master ID, fault tracing
MID 128 Engine control unit, fault codes
MID 136 Brake system, fault codes
MID 136 In and output signals status, test
MID 144 Vehicle control unit, fault codes
MID 164 CECM-C, chassis module, fault codes 1
MID 164 CECM-C, chassis module, fault codes 2
MID 210 Master ID
MID 210 Resistance measuring
MID 210 Voltage measuring
MID 234 In and output signals status, test
MID 234 Instrumentation, fault codes
MID 234 PID 120 Oil temperature, retarder
MID 234 PID 175 Oil temperature, engine
MID 234 PID 177 Oil temperature, gearbox
MID 234 PPID 91 Brake pressure, circuit 3
MID 234 SID 240 Program memory
Performance check, basic
Power steering, function check
Pressure accumulator, check
R3 - Group 37
R3 - Group 451
Sensor values, check
Starting heater, check
Tachograph, fault code table
Tachograph, fault codes, general information
Test drive, fault tracing
Throttle control, setting
Toolbox, tests
Trouble-shooting by error codes error numbers
Trouble-shooting by symptom and related error code
Trouble-shooting ignition system
Turntable, fault tracing 1
Turntable, fault tracing 2
Vehicle control unit, check
Work routine, fault tracing 1
Work routine, fault tracing 2
Forms
Charge air cooler, additional information claim handling
Check card storage maintenance
Control unit, warranty handling, protocol
Oil and fuel consumption, follow-up
Radiator, warranty claim handling, additional information
Repair
51020-4 5109-03-04-01 Brake linings, replace (one pair shoes)
Accelerator pedal, contact, adjust
Adjusting valves
Adjustment mechanism, brake caliper, overhaul
Air drier non return valve, replace
Air drier, drier insert, replace
Air drier, replace
Air drier, valve unit replace 1
Air drier, valve unit replace 2
Angle gear, overhaul
Angle sensor, check and adjust
Automatic transmission, modification
Balancing the propeller shaft 1
Balancing the propeller shaft 2
Balancing the propeller shaft 3
Ball joint play, link rods and track rods, check 1
Ball joint play, link rods and track rods, check 2
Battery analyzer user manual
Battery charging
Bearing housing, yoke plate, replace
Bellow height, check measure
Bellow hight, adjust
Brake anchorage front wheel, replace (one)
Brake caliper front wheel, replace
Brake disc, front wheel, replace
Brake drum, replace (one drive wheel)
Brake drum, replace (one front wheel) 1
Brake linings, wear check (one axle)
Brake pads, replace (two front wheels)
Brake shoes, alignment with dial indicator (one wheel) 1
Brake shoes, alignment with dial indicator (one wheel) 2
Brake shoes, replace (one wheel)
Bushings control arms lower, replace
Bushings control arms upper, replace
Bushings, yoke plate, repace
Camshaft, replace
Charge air cooler, leakage test (2)
Charge air cooler, replace
Charge pressure, check opening pressure of wastegate
Charging regulator, replace
Charging test, in vehicle
Checking with electric pressure gauge UT 41-11082
Checklist B, modulators
Companion flange, output shaft, replace
Compressor, check and wear measurement
Compressor, overhaul
Coolant filter, replace
Coolant pump, overhaul 1
Coolant pump, overhaul 2
Coolant system pressure test, including heater system
Cooling coil, replace
Cooling system, drain and refill coolant
Copper sleeve injector, replace ( one )
Crankshaft seal, replace (front)
Crankshaft seal, replace (rear)
Crankshaft wear, check
Cylinder block, check
Cylinder block, face grind
Cylinder compression test
Cylinder head, cylinder liner, valves
Cylinder head, install (first)
Cylinder head, pressure test (first)
Cylinder head, remove (first)
Cylinder head, removing cleaning
Cylinder liner seat, milling (first)
Delivery pipes, replace (all)
Deviations form the earlier testing
Diagnostics
Diodes and heat sinks
Distributor pipe, check
Draining oil
Drive belt, replace
Dump valve, check
Dust seals, brake housing, replace
ECS control unit, checklist before replacement
ECS control unit, replace
ECS customer parameter, setting
ECS system, calibration
EDC engines without cruise control
EGR valve, overhaul
End plate front, overhaul
Engine, remove
Exhaust pressure governor, overhaul
Fan motor, servicing
Fan speed, check
Flywheel bearing, replace
Flywheel housing run-out, check
Flywheel ring gear, replace
Flywheel sensor distance, check
Flywheel, check
Four-circuit protection valve, replace
Front axle 1
Front axle 2
Fuel feed pressure, check
Fuel filters, replace (two)
Fuel system, check
Gudgeon pin, connecting rod
Guide sleeves, bushings and seals, replace
Horn, replace
Hydraulic cylinder bushing, replace
Hydraulic cylinder, turntable, replace
Hydraulic system oil, replace
Hydraulic system, pressure setting and oil filling
Injection pump, check on test bench
Injection valves, clean
Injectors, replace (all)
Injectors
Level sensor
Low idling speed EDC
Oil and oil filter, instructions for changing
Oil and oil filters, changing
Oil and water separator, overhaul
Oil cooler, pressure test
Oil filter, replace
Oil level, checking
Oil pressure, check
Oil pressure, piston cooling
Oil pump, overhaul
Oil pump, remove-install
Oil pump, removing
Output shaft seal, replace
Particulate filter insert, clean 1
Particulate filter insert, clean 2
Pinion, assembly; measure pinion position and bearing preloading
Piston and liner, replace (one)
Piston piston rings
Piston seal, replace
Piston, rings replace (all)
Pitman arm, remove
Pressure box by-pass valve, check
Pressure pipe, replace
Pressure regulator, new install
Pressure regulator, remove
Pressure-testing cooling system 1
Pressure-testing cooling system 2
Propeller shaft
R3 - Group 28 Spark plug, rubber protection and special grease
Radiator, check
Reaction rod, overhaul
Rear axle drive wheel, measure bearing play
Rear axle, assembly
Rear axle, complete, replace
Rear axle, components, inspect
Rear axle, dismantle
Rear axle, remove
Relay, replace
Removing and installing rear engine
Replacing coolant filter
Replacing fuel filters
Replacing main thermostat sealing ring
Replacing seal, output shaft
Replacing the propeller shaft fork or tubes 1
Replacing the propeller shaft fork or tubes 2
Replacing the propeller shaft fork or tubes 3
Replacing the propeller shaft fork or tubes 4
Replacing the propeller shaft fork or tubes 5
Rocker arm, overhaul
Routine maintenance
Rubber protection, ignition coil, replace
Safety regulations 1
Safety regulations 2
Safety regulations 3
Screw joints, frame link, check
Screw joints, frame link, replace
Seal for crankcase, replace
Seal, output shaft, replace
Sealing ring, drive mechanism, replace
Sealing ring, timing gear cover, replace
Servicing the engine
Servo pump, remove 1
Servo pump, remove
Shutter housing, replace
Slack adjuster, check
Sleeve, injector, replace (One)
Smoke frequency, check
Spark plug, replace (one)
Spark plugs, replacing
Speedometer, clock and trip meter
Speedometer, clock trip meter
Starter motor, disassemble, inspect and assemble
Starter motor, remove
Starting element, replace
Starting pre-heater
Steering 1
Steering 2
Steering 3
Steering 4
Steering 5
Steering 6
Steering 7
Steering 8
Steering 9
Steering 10
Steering gear, renovation
Steering knuckle, overhaul (one) 1
Stroke, slack adjuster, check (two front and two drive wheels)
Tank system 5000
Tank system 7000
Testing injection pump
Thermostat valve, checking
Thermostats, test
Throttle potentiometer, check
Timing gears, replace (all)
Timing gears, replacing removing
Timing gears; Checking
Topping-up coolant
Topping-up oil
Transmission, assembling
Transmission, general instructions
Transmission, installing
Transmission, removing
Turbine rotor ring gear speed sensor (n3), changing
Turbocharger, install
Turbocharger, overhaul
Turbocharger, remove
Turbocompressor, removing installing
Turbocompressor, repairs
Valve clearance, adjust
Valve guides, replace (one cylinder head)
Valves grind and decarb (first cylinder head)
Valves, valve guides, replacing
Valves, valve seats
Venting fuel system
Wheel angles, check-measure (all)
Wheel speed sensor, replace (rear axle)
Wheel splay, check and adjust
Working pressure valve
Schematic Diagrams
Air pressure brake system, components 1
Air pressure brake system, components 2
Wiring diagram 1
Wiring diagram 2
Wiring diagram 3
Wiring diagram information 1
Wiring diagram information 2
Service and Maintenance
Air filter handling
Automatic speed limiter, setting
Body
Cables and clamping at turntable
Chassis painting
Chemical products catalogue
Cleaning of engine and sound absorber
Control unit EPROM 1
Control unit EPROM 2
Delivery and Warranty Service
Diagnostics and warning
Engine, clean
Fault code checks EDC system
Fuel system natural gas
Gas tank visual inspection
Gastank, visual inspection 1
Gearbox oil and filter, replace
General, warranty service
Inspection point EDC components and wiring
Lubricating oil and oil filter, changing
Lubrication chart 1
Lubrication chart 2
Non-return valve, check
Particulate filter
R3 - Groupd 17
Repair of wiring, example
Service and maintenance
Service instruction 1
Service instruction 2
Service instruction 3
Service interval for CRT system
Service points for gas line with valves and filter
Servicing points – gas line with valves and filters
Spring brake cylinder, inspect
Storage treatment of vehicles
Supplement to buses with natural gas engine GH10A245
Supplementary instruction for service and maintenance
Torque converter pressure, checking
Undercarriage protection maintenance procedure
Universal joints, lubrication
Specifications
Adhesive and sealant
Air drier
Anti-roll bar 1
Anti-roll bar 2
Brake equipment
Camshaft 1
Camshaft bearings 1
Camshaft bearings 2
CECM-C
Cleaning agent
Compressed air system
Compressor
Connecting rods
Cooling system
Cylinder block 1
Cylinder block 2
Cylinder head 1
Cylinder head 2
Cylinder liner 1
Cylinder liner 2
ECS bellows height
ECS, data sets
Electronic unit injectors
Engine control system
Exhaust brake, exhaust pressure governor
Flywheel
Fuel filters 1
Fuel filters 2
Fuel pump
Fuel system 1
Fuel system 2
Fuel system 3
Fuel system, natural gas 1
Gearbox, hydraulic
Gearbox
General 1
General 2
General 3
General 4
Gudgeon pin 1
Gudgeon pin 2
Hydraulic fan drive
Injection pump
Instrumentation
Intake and exhaust system
Kneeling and Ferry lift option
Lubricant
Lubricating and oil system
Lubrication 1
Lubrication 2
Lubrication 3
Main bearing journals
MID 128 Engine control unit, signal descriptions
Oil water separator on B10L BLE
Paint touch-up material
Piston rings 1
Piston rings 2
Pistons 1
Pistons 2
Pistons 3
Power steering pump 1
Power steering pump 2
Pressure-drop indicator
Propeller shaft
Shock absorber 1
Shock absorber 2
Specifications 1
Specifications 2
Speedometer sensor
Springs
Standard tightening torques
Steering gear 1
Steering gear 2
Steering system, tightening torques 1
Steering system, tightening torques 2
Tachograph 1
Tachograph 2
Tachograph, signal descriptions
Tightening torque
Tightening torques 1
Tightening torques 2
Tightening torques 3
Tightening torques and patterns
Tightening torques
Timing gears 1
Timing gears 2
Turbocharger
Turn table 1
Turn table 2
Valve guides
Valve mechanism 1
Valve mechanism 2
Valve mechanism 3
Valve mechanism 4
Valve springs 1
Valve springs 2
Valve springs 3
VECU
Wear tolerances 1
Wear tolerances 2
Wheel alignment 1
Wheel alignment 2
Wheel alignment 3
Wheel brakes
Wheel installation
