Volvo Bus Olympian Service and Repair Manual
Brand: Volvo
Type of Machine: Bus
Type of Manual: Service and Repair Manual, Electrical Diagram
Model: Volvo Olympian Bus
Number of Pages: 1554 Pages
ABS, fault tracing
Accelerator pedal control
Accelerator pedal control 1
Accelerator pedal control 2
Accelerator pedal valve and control cylinder, checking, cleaning and lubricating
Adapter 9990020
Air cleaner
Air cleaner 1
Air cleaner 2
Air drier and cooling coil, warranty claim handling, additional information
Air drier, valve unit replace
Air drier
Air drier 1
Air drier 2
Air drier 3
Air filter handling
Air pressure brake system, components
Air pressure brake system, components 1
Air pressure brake system, components 2
Air pressure brake system, components 3
Air pressure brake system, components 4
Air pressure brake system, components 5
Air pressure brake system, components 6
Air pressure brake
Air suspension
Alternator drive belt, adjust
Alternator drive belt, adjust 1
Alternator drive belt, adjust 2
Alternator drive, insufficient charge current
Alternator location
Alternator location 1
Alternator location 2
Alternator, tightening torques
Alternator 1
Alternator 2
Angle gear, tightening torque
Angle gear
Anti-lock brake system (ABS)
Automatic cruise control
Balancing the propeller shaft
Balancing the propeller shaft 1
Balancing the propeller shaft 2
Balancing the propeller shaft 3
Basic check
Basic data gathering, general
Basic service
Basic service 1
Basic service 2
Battery analyser, 7200, user manual
Battery analyzer, 88890075 EXP, user manual
Battery analyzer, 88890075 EXP, user manual 1
Battery analyzer, 88890075 EXP, user manual 2
Bead diodes on the terminal block
Bleed valve, newinstall
Brake drum, machining
Brake lever stroke — check adjust
Brake shoe initial setting
Brake shoes, alignment with dial indicator (one wheel)
Brake valve and other valves
Brake valve and other valves 1
Brake valve and other valves 2
Brakes
Cables clamping
Carbon monoxide (CO) in coolant system, check
Centering the steering
Centering the steering 1
Centering the steering 2
Charge air cooler
Charge air cooler 1
Charge air cooler 2
Charging regulator, replace
Charging test, in vehicle
Chart missing for driver 9051
Chart missing for driver 9052
Chassis painting
Check card storage maintenance
Checking and adjusting the rear wheel bearings
Chemical products catalogue
Compressed-air tank
Compressor, parts
Compressor
Compressor 1
Compressor 2
Control unit
Coolant pump, overhaul
Coolant pump
Coolant pump 1
Coolant pump 2
Coolant requirements
Coolant requirements 1
Coolant requirements 2
Cooling coil, replace
Cooling system, drain and refill coolant
Cooling system
Cooling system 1
Cooling system 2
Cooling system 4
Cooling system 5
Crank mechanism
Crank mechanism 1
Crank mechanism 2
Crankshaft 1
Crankshaft 2
CRT system
CRT, fault tracing
CRT-filter, fault reporting
Cylinder balancing, check
Cylinder block
Cylinder block 1
Cylinder block 2
Cylinder Compression, test
Cylinder head, cleaning
Cylinder head, remove (first)
Cylinder head, removing cleaning
Cylinder head
Cylinder head 1
Cylinder head 2
Cylinder head 3
Cylinder liner and piston
Cylinder liner and piston 1
Cylinder liner and piston 2
Cylinder liner seat, milling (first)
Description of the fault
Design Instrument
Diagnosis, fault codes
Diesel fuel
Diesel test standards
Diesel test standards 1
Diesel test standards 2
Disassembly instructions, complete vehicle
Dismantling alternator
Dismantling the left-hand outer casing assembly
Display fault 9010
Drawer 9060
EDC engines without cruise control
EDC-accelerator pedal, adjusting
Electric air pre-heater
Electric air pre-heater 1
Electric air pre-heater 2
Engine components
Engine components 1
Engine components 2
Engine designation
Engine mounting, inspect
Engine transmission
Engine transmission 1
Engine transmission 2
Engine, clean
Engine, drawing
Engine, drawing 1
Engine, drawing 2
Engine, lubrication
Error during sensor communication A423
Error in the sensor key serial number signal A822
Exhaust back pressure, measure (vehicle standing still)
Exhaust back pressure, measure (vehicle standing still) 1
Exhaust back pressure, measure (vehicle standing still) 2
Exhaust back pressure, measurement (vehicle in motion)
Exhaust pressure governor
Face-grinding the cylinder head
Fault code troubleshooting
Fault during SAE J1939 transmission 900A
Fault tracing, solenoid valves and sensors (connections connectors)
Fault tracing
Filter, replacing cleaning
Filter, replacing cleaning 1
Filter, replacing cleaning 2
Final drive, design
Four-circuit protection valve, replace
Front axle
Front hub, components
Front sealing ring
Front sealing ring 1
Front sealing ring 2
Front wheel suspension
Front wheel suspension 1
Front wheel suspension 2
Fuel filters
Fuel system and used lubricant oil analysis, fault tracing
Fuel system
Fuel system 1
Fuel system 2
Fuel system 3
Fuel system 4
Function-check, fan drive
Gearbox oil and filter, replace
Gearbox, automatic, drawing
Gearbox, automatic, drawing 1
Gearbox, automatic, drawing 2
Gearbox, hydraulic
General Automatic transmission
General data
General Engine
General quality requirements
Governor
Hubs
Hydraulic fan drive
Hydraulic fan drive 1
Hydraulic fan drive 2
Hydraulic fan drive 3
Induction sensor for input speed (n1) turbine rotor and output speed (n2), checking
Injection pump
Injection pump 1
Injection pump 2
Injection pump 3
Injection pump, installing
Injection pump, remove
Injection pump, replace
Injection pump
Injector fuel volume, check
Injector, drawing
Injector
Injector 1
Injector 2
Injector 3
Inlet and exhaust system
Inlet and exhaust systems, check
Inspecting the steering gear
Inspection
Installing the cylinder head
Installing the final drive assembly into the bus
Instrument, system description
Instrumentation, component placement
Instrumentation
Intermediate housing, assembling installing
Intermediate housing, disassembling
Intermediate housing, removing
Internal communication fault A00C
Internal recording error 9061-9062-9063
Introduction
Low idling speed EDC
Lubricating and oil system
Lubricating and oil system 1
Lubricating and oil system 2
Lubrication and oil system
Lubrication and oil system 1
Lubrication and oil system 2
Magnetic coil in control valve block (valve bodies control system), checking
Main diodes and auxiliary diodes
Manual slack adjuster, assembling
Manual slack adjuster, disassembling
Manual slack adjuster, installation
Manual slack adjuster, removal
MID 234 In and output signals status, test
MID 234 Instrumentation, fault codes
MID 234 PID 117 Brake pressure, circuit 1
MID 234 PID 118 Brake pressure, circuit 2
MID 234 PID 120 Oil temperature, retarder
MID 234 PID 158 Battery voltage
MID 234 PID 175 Oil temperature, engine
MID 234 PID 177 Oil temperature, gearbox
MID 234 PPID 91 Brake pressure, circuit 3
MID 234 PSID 1 Diode, fuel level
MID 234 PSID 2 Alarm, activation
MID 234 PSID 3 Buzzer, danger
MID 234 PSID 4 Buzzer, warning
MID 234 SID 240 Program memory
MID 234 SID 250 SAE J1708 Information link
MID 234 SID 253 Calibration memory, EEPROM
MID 234 SID 254 Control unit
Most important characteristics of the EST 18 control unit
Oil and oil filter, instructions for changing
Oil and water separator, overhaul
Oil level, checking
Oil pressure, checking
Oil pump
Oil pump 1
Oil pump 2
Oil sump, removing installing
Oil sump, removing installing 1
Oil sump, removing installing 2
Oil temperature sensor, checking changing
Output B7, 9430
Output shaft speed sensor (n2), changing
Overhauling the final drive
Parking brake valve
Parking brake valve 1
Parking brake valve 2
Particulate filter insert, clean
Particulate filter insert, clean 1
Particulate filter insert, clean 2
Particulate filter
Performance check, basic
Performance curves
Pipes, hoses and fittings
Piston piston rings
Piston piston rings 1
Piston piston rings 2
Planetary gear, disassembling assembling
Power loss A400
Power path
Power steering gear, exploded view
Power steering pump
Power transmission
Pre-delivery inspection form
Pressure governor
Propeller shaft general
Propeller shaft
Propeller shaft 1
Propeller shaft 2
R3 - Group 00
R3 - Group 0
R3 - Group 20
R3 - Group 030
R3 - Group 437
R3 - Group 451
Radiator 1
Radiator 2
Rear air suspension
Rear axle, lubrication
Reassembling the left-hand outer casing assembly
Reassembly
Regulator Specification
Relay, replace
Removal of shock absorbers
Removing and installing the engine gearbox
Removing the final drive assembly from the bus
Removing the final drive assembly from the bus 1
Removing the final drive assembly from the bus 2
Replacing a faulty diode
Replacing the fuel filters
Replacing the heating coil
Replacing the Panhard rod bushes (front and tag axles)
Replacing the propeller shaft fork or tubes
Rocker arm mechanism, replacing the bushings
SAE J1939 Control link, interruption 900B
Sealing ring, output shaft, changing
Sensor values, check
Separating the final drive into its major components
Servicing the engine
Servo brake cylinder and mounting
Servo brake cylinder and mounting 1
Servo brake cylinder and mounting 2
Setting toe-in
Shock absorber
Shock absorber 1
Shock absorber 2
Slack adjuster, check
Slack adjuster
Solenoid valve
Speed sensor for input speed (n1), changing
Speedometer sensor
Speedometer, clock and trip meter
Speedometer, clock, trip meter
Spring brake cylinder, inspect
Spring brake cylinder, three-axle bus
Spring control equipment
Springs
Standard tightening torques
Starter motor
Starter motor 1
Starter motor 2
Starter motor 3
Starter motor 4
Starter motor, disassemble, inspect and assemble
Starter motor, remove
Starting heater
Steering removing and installing
Steering column
Steering column 1
Steering column 2
Steering disassembling
Steering gear
Steering knuckle
Steering removing
Steering symptom
Steering system, tightening torques
Steering wheel adjustment
Stop hazard turn lamps, simplified schematic
Storage treatment of vehicles
Tachograph buttons not working 900F
Tachograph chart drive circuit 9064
Tachograph
Tachograph 1
Tachograph 2
Tachograph, fault code table
Tachograph, fault codes, general information
Tachograph, signal descriptions
Teach-In of lock-up
Testing alternator on test bench
Testing the air suspension system
Testing the injection pump
The purpose of basic checks, fault tracing
Thermostat
Thermostat 1
Thermostat 2
Thermostat 3
Thermostat 4
Thermostats, test
Tightening on wheels
Tightening torques
Tightening torques 1
Tightening torques 2
Tightening torques 3
Tightening torques 4
Tightening torques 5
Tightening torques 6
Tightening torques 7
Tightening torques 8
Tightening torques hubs
Time indicator fault 9053
Timing gears
Timing gears 1
Timing gears 2
Toe-in, adjust
Topping-up the coolant
Topping-up the oil
Torque converter pressure, checking
Towing information
Transmission, assembling
Transmission, disassembling
Transmission, general instructions
Transmission, general instructions 1
Transmission, general instructions 2
Transmission, installing
Transmission, installing 1
Transmission, installing 2
Transmission, removing
Transmission, removing 1
Transmission, removing 2
Trip without chart for driver A050
Trouble shooting equipment
Turbine rotor ring gear speed sensor (n3), changing
Turbine rotor ring gear speed sensor (n3), changing 1
Turbine rotor ring gear speed sensor (n3), changing 2
Turbocharger
Turbocharger 1
Turbocharger 2
Turbocharger 3
Turbocharger 4
Two-way valve
Two-way valves
Tyre and inner tube
Tyre and inner tube 1
Tyre and inner tube 2
Tyre changing instructions
Undercarriage protection maintenance procedure
Universal joints, lubrication
Unloading valves, checking and adjusting
Updating VDA
Updating VDA 1
Updating VDA 2
Valve mechanism
Valve mechanism 1
Valve mechanism 2
Valves, adjusting
Valves, valve seats
Valves, valve seats 1
Valves, valve seats 2
Wastegate, checking the opening pressure
Wear tolerances
Wear tolerances 1
Wear tolerances 2
Wheel alignment
Wheel brake
Wheel brakes
Wheel installation
Wheel nuts, check tightening (all)
Wheel speed sensor, replace (rear axle)
Wheel
Wheelbrakes, checking and adjusting
Wiring diagram information
Working pressure valve
Z-cam brakes
Z-cam brake overheat
Z-cam brakes — Heat resistant grease
Z-cam brakes, maintenance lubrication
Brand: Volvo
ABS, fault tracing
Adapter 9990020
Air cleaner
Air cleaner 1
Air cleaner 2
Air drier
Air drier 1
Air drier 2
Air drier 3
Air filter handling
Air pressure brake
Air suspension
Alternator location
Alternator 1
Alternator 2
Angle gear
Basic check
Basic service
Basic service 1
Basic service 2
Brakes
Cables clamping
Charge air cooler
Charge air cooler 1
Charge air cooler 2
Chassis painting
Compressed-air tank
Compressor, parts
Compressor
Compressor 1
Compressor 2
Control unit
Coolant pump
Coolant pump 1
Coolant pump 2
Cooling system
Cooling system 1
Cooling system 2
Cooling system 4
Cooling system 5
Crank mechanism
Crank mechanism 1
Crank mechanism 2
Crankshaft 1
Crankshaft 2
CRT system
CRT, fault tracing
Cylinder block
Cylinder block 1
Cylinder block 2
Cylinder head
Cylinder head 1
Cylinder head 2
Cylinder head 3
Design Instrument
Diesel fuel
Display fault 9010
Drawer 9060
Engine components
Engine components 1
Engine components 2
Engine designation
Engine transmission
Engine, clean
Engine, drawing
Engine, drawing 1
Engine, drawing 2
Engine, lubrication
Fault tracing
Final drive, design
Front axle
Front sealing ring
Fuel filters
Fuel system
Fuel system 1
Fuel system 2
Fuel system 3
Fuel system 4
Gearbox, hydraulic
General data
General Engine
Governor
Hubs
Hydraulic fan drive
Injection pump
Injection pump 1
Injection pump 2
Injection pump 3
Injection pump
Injector, drawing
Injector
Injector 1
Injector 2
Injector 3
Inspection
Instrumentation
Introduction
Oil level, checking
Oil pump
Oil pump 1
Oil pump 2
Output B7, 9430
Parking brake valve
Particulate filter
Performance curves
Piston piston rings
Power loss A400
Power path
Power steering pump
Power transmission
Pressure governor
Propeller shaft
Propeller shaft 1
Propeller shaft 2
R3 - Group 00
R3 - Group 0
R3 - Group 20
R3 - Group 030
R3 - Group 437
R3 - Group 451
Radiator 1
Radiator 2
Rear air suspension
Reassembly
Relay, replace
Setting toe-in
Shock absorber
Shock absorber 1
Shock absorber 2
Slack adjuster
Solenoid valve
Speedometer sensor
Springs
Starter motor
Starter motor 1
Starter motor 2
Starter motor 3
Starter motor 4
Starting heater
Steering column
Steering column 1
Steering column 2
Steering gear
Steering knuckle
Steering removing
Steering symptom
Tachograph
Tachograph 1
Tachograph 2
Teach-In of lock-up
Thermostat
Thermostat 1
Thermostat 2
Thermostat 3
Thermostat 4
Thermostats, test
Tightening torques
Timing gears
Timing gears 1
Timing gears 2
Toe-in, adjust
Topping-up the oil
Towing information
Turbocharger
Turbocharger 1
Turbocharger 2
Turbocharger 3
Turbocharger 4
Two-way valve
Two-way valves
Tyre and inner tube
Updating VDA
Updating VDA 1
Updating VDA 2
Valve mechanism
Valve mechanism 1
Valve mechanism 2
Valves, adjusting
Valves, valve seats
Wear tolerances
Wear tolerances 1
Wear tolerances 2
Wheel alignment
Wheel brake
Wheel brakes
Wheel installation
Wheel
Z-cam brakes
- Volvo Truck Service Manual All
- Volvo D11 D13 D16 Service Manual
- Volvo Trucks MID Fault Codes
- Volvo FM12, D12D420 New engine variants -Sensor
- Volvo FM12, D12F500 Specifications- Sensor-EBR-VEB Valves and unit injectors, adjust. Valve cov
- Volvo NH Valves and unit injectors, adjust
- Specifications Volvo Engine D12D
- Volvo Service Manual Truck - Wiring Diagram FM9, FM12, FH12, FH16, NH12
- Volvo FM12, D12C 420 Engine
- Volvo Truck Service Manual Trucks Wiring Diagram FL7,FL10 LHD
- Volvo Engine Trucks D13 Service Manual
- Volvo Truck F10 F12 F16 1998 Service Manual
- Volvo Truck Service Manual & Electrical Schematic
- Volvo Bus B7,B9,B12 Wiring Diagram
- Volvo FM12, D12D460 Cylinder head, install EBR-EPG Valves and unit injectors, adjust. Valve cover
