Martin Welker
104
230,310
Volvo Backhoe Loader BL71 Service Repair Manual
Brand: Volvo
Model: Volvo BL71 Backhoe Loader
Number of Pages: 4623 Pages
Volvo BL71 and BL71 PLUS
Descriptions
Accumulator, description
Air conditioning, description
Alternator, description
Battery, description
Boom lock, description
Cab, description
Cable harnesses, description
Cable harnesses, description1
Cables, description
Climate control system, description
Component list, Distribution boxes and control units
Control pressure valve, description
Cooling system, description
Counterweight, description
Cylinders backhoe unit, description
Cylinders loader unit, description
Description
Electrical symbols and designation
Electrical system, description
Electrical system, work instructions
Electronic control system, description
Engine, description
Fan shroud, additional sheet, installing
Fan shroud, replacing
Flow regulation valve, description
Frame, description
Fuel shut-off
Fuel system, description
Gearbox 4WD, description
Hammer, description
Hose rupture valve (safety valve) for boom cylinder, description
Hose rupture valve (safety valve) for dipper arm cylinder, description
Hose rupture valves (safety valves) for loader, description
Hydraulic oil tank, description
Hydraulic pump, description
Hydraulic system, component location
Lighting, description
Lubrication system, description
Parking brake, description
Power transmission, description
Preheating, description
Priority valve, description
Self level function, description
Service brake, specification
Service light
Servo pump, description
Side panel, installation
Side panel, removal
Side panel, removal1
Starter motor engagement
Starter motor, description
Steering axle and swivel-joint, description
Steering valve, description
Steering, description
Torque converter, description
Transmission control unit T-ECU, description
Turbocharger, description
Valve block, description
Valves, description
Window panes, glued, replacing
Windows, general
Working hydraulics, description
Diagrams
Hydraulic diagram 1-1
Hydraulic diagram full page 1
Hydraulic diagram, gearbox 4WD full page
Hydraulic diagram, Powershift transmission 1
Hydraulic diagram, Powershift transmission-fullpage
Hydraulic diagram
Wiring diagram 1
Wiring diagram 1-1
Wiring diagram 1-2
Wiring diagram 2
Wiring diagram 2-1
Wiring diagram 2-2
Wiring diagram 3
Wiring diagram 3-1
Wiring diagram 4
Wiring diagram 4-1
Wiring diagram 4-2
Wiring diagram 5
Wiring diagram 5-1
Wiring diagram 5-3
Wiring diagram 6
Wiring diagram 6-1
Wiring diagram 6-2
Wiring diagram 7
Wiring diagram 7-1
Wiring diagram 8
Wiring diagram 8-1
Wiring diagram 9
Wiring diagram 9-1
Wiring diagram 9-2
Wiring diagram 10
Wiring diagram 10-1
Wiring diagram 10-2
Wiring diagram 11
Wiring diagram 11-1
Wiring diagram 11-2
Wiring diagram 12
Wiring diagram 12-1
Wiring diagram 13
Wiring diagram 13-1
Wiring diagram 14
Wiring diagram 15
Wiring diagram 17
Wiring diagram 17-1
Wiring diagram 17-2
Wiring diagram 20
Wiring diagram 20-1
Wiring diagram 21
Wiring diagram 22
Wiring diagram 22-1
Wiring diagram 23
Wiring diagram 25
Wiring diagram 26
Wiring diagram 27
Wiring diagram 28
Wiring diagram 28-1
Wiring diagram 29
Wiring diagram 30
Wiring diagram 31
Wiring diagram 32
Wiring diagram 33
Wiring diagram 34
Installation instructions
Backhoe safety valves for boom-dipper arm cylinders
Heavy duty spring kit
Hose rupture valve, installing new
Interior rear view mirror
ISO - pattern
Loader attachment bracket
Mechanical quick attachment
MP fork kit
Overload indicator
Radio Preparation Kit
Ride control, installing new
Rotating beacon
SAE - pattern
Safety valves for loader and bucket cylinders
Speedometer
The Mechanic must always read the instructions in the Service Manual's booklet Safety and Environment booklet before proceeding.
Thumb, quick attachment, installing new
Thumb, standard bucket, installing new
Recomended special tools
Repair
500 hour service light
Accelerator control cable, changing 1
Accelerator control cable, replacement
Action to be taken in case of abnormal lubricating oil consumption
Adapter for T-ECU Limp Home mode in Phase 3 machines
Additional counterweight, installing
Additional counterweight, removing
Additional spring for hand throttle cable
Air cleaner, secondary filter replacing
Air conditioning gaskets 1
Alternative lubricants for axles with wet brakes
Axle breather, cleaning 1
Axle hubs, changing oil 1
Axle hubs, checking oil level
Axle suspension, adjusting axial clearance
Axle, installing
Axle, removing
Axles, changing oil 1
Axles, changing oil
Axles, checking oil level
Backhoe Loader new generation - Phase II
Backhoe Loader new generation - Phase III'
Battery, changing
Battery, checking electrolyte
Bolted joints, check tightening torque
Boom bushing, removal
Boom bushings, changing
Boom cylinder, installation
Boom cylinder, removal
Boom cylinder, renovation
Boom lock cylinder, reconditioning
Boom lock functions, check
Boom suspension accumulator, check and adjusting
Boom Suspension System, precharging pressure in accumulators, checking and adjusting
Boom, part No. VOE11889178, crack on Phase 2 and Phase 3 machines 1
Brake discs, checking wear
Brake system, bleeding 2
BRAKE TEST
Brake valve, installing
Brake valve, removal
Bucket assembly, replacing
Bucket cylinder, installation
Bucket cylinder, removal
Bucket cylinder, renovation
Cab, service position
CareTrack factory option
CareTrack Telematics system
Component list Alternator, batteries, code lock, radio, V–ECU
Component list, Alternator, batteries, code lock, radio
Component list, Diodes 2
Component list, Fuses
Component list, Heating coils
Component list, Instruments
Component list, LED Indicators 2
Component list, LED Indicators 3
Component list, Lights
Component list, Motors
Component list, Relays 1
Component list, Resistors
Component list, Sensors
Component list, Solenoid valves
Component list, Sounders 1
Component list, Switches
Coolant hose cut by AC V-belt in D5D engine machines
Coolant level, check
Counterweight, fitting 1
Counterweight, removing 1
Dipper arm cylinder, installation
Dipper arm cylinder, removal 1
Dipper arm cylinder, renovation
E 1708, Checking point
E1820
Electrical troubleshooting, Powershift transmission
Engine exhaust stud failure
Engine hood, installing 1
Engine hood, removing 2
Engine mounts, changing
Engine oil and filter, changing
Engine oil in the cooling system or coolant in the oil system and external oil or radiator leakage
Engine radiator, oil cooler and condensor (if installed), clean
Engine speed
Engine, air cleaner filter, replacing
Engine, changing oil and filter 1
Engine, changing oil and filter 2
Engine, installation
Engine, installing
Engine, removal
Engine, removing 1
Excavator pin, change 1
Exhaust flexible tube cracks on D5D engines
Exhaust pipe, flexible tube, replacing
Expansion tank contact with engine lifting eye in Phase 3 machines
Expansion tank crack on D5D engine
Expansion tank, replacing 1
Extendible dipper arm cylinder, installation
Extendible dipper arm cylinder, removal
Extendible dipper arm cylinder, renovation
Fan belt, replacement
Fan motor, installing
Fan motor, removing
Feed pump, checking feed pressure
Flow regulation valve, changing
Front axle, removing
Front panel, installing
Front panel, removal
Front wheel, installation
Front wheel, removal 2
Fuel feed pump, installation
Fuel feed pump, removal
Fuel filters, primary and secondary filter, replace
Fuel filters, water trap
Fuel sampling, method
Fuel system, bleeding 1
Fuel system, water trap, check drain
Fuel tank, installing
Fuel tank, removing
Fuel, coolant and oil leakage, check
Gas springs, doors, rear window, check function
Gear selector switch, testing
Gearbox 4WD, checking oil pressure 1
Hammer (if installed) hydraulic circuit, check flow and pressures
Hammer, connection
Hammer, disconnection
Hammer, hydraulic hoses and connections, check
Hammer, seals and accumulator membranes, replace
Headliner, installing
Headliner, removing
Hose rupture valve, checking
Hydraulic cylinders, check for oil leakage
Hydraulic cylinders, cleaning
Hydraulic locking cylinders for sideshift mechanism, check (BL61, BL71, BL61 Plus, BL71 Plus)
Hydraulic noise
Hydraulic oil cooler, installation
Hydraulic oil cooler, removal 1
Hydraulic oil tank breather filter, replace
Hydraulic oil tank, installing
Hydraulic oil tank, removing
Hydraulic pressure, setting
Hydraulic pump drive spline wear
Hydraulic pump, installation
Hydraulic pump, removal
Hydraulic pump, replacing
Hydraulic system, bleeding air
Hydraulic system, changing oil
Hydraulic system, checking oil level
Hydraulic system, pressure release 1
Hydraulic system, replacing filter
Improved AC system efficiency in Phase 3 machines
Incorrect loader joystick
Leakage at engine oil pump gasket 1
Lift cylinder, reconditioning
Loader bucket teeth shimming 1
Lowering of backhoe with hose rupture valves (safety valves)
Lubrication oil pressure, checking
Lubrication
Main control valve, proportional valve electrical checking and cleaning
Main valve block, installation
Main valve block, removal
Maintenance service, daily
Maintenance service, every 50 hours
Maintenance service, every 250 hours
Maintenance service, every 500 hours
Maintenance service, every 1000 hours
Maintenance service, every 1500 hours
Maintenance service, every 2000 hours
Maintenance service, every 3000 hours
Malfunction of RHS panel in the cab
Measurement of deformation and cleaning procedure of stabilizers inner leg 1
Modification of 4in1 bucket
Modification of PTO shaft on transmissions
MS.Internal.Documents
Multi-purpose bucket cylinder, changing
New back up alarm as field solution
New bonnet lock
New cable for main battery switch
New coolant
New design of Air Conditioning rear drain hoses
New design of Phase 2 rear axle planetary gear
New design of Phase I rear axle pinion
New design of spools and new material of lip seals in main control valve
New design, rear axle bolts mounting
New dipper cylinder with improved piston-rod connection
New dog clutch drive gear for powershuttle transmission
New excavator bucket cylinder for A series machines
New excavator buckets 1
New excavator pilot controls option
New extendible dipper cylinder with support
New fasteners for centre plate on swing system 1
New foot brake switch
New fuel level sensor
New hand throttle cable
New hydraulic hoses on connection boom and dipper
New hydraulic tubes for excavator quick attach
New hydraulic tubes
New input shaft seal in front axle
New locking circlip and pin for stabilization leg cylinder
New locking system for connection stab inner leg and foot on side shift machines 1
New material of boots on steering rods in front axle
New swing post with tighten manufacturing tolerances
New transmission harness for Power-shuttle transmissions
New transmission oil filter
New turbo oil return line and pressure line for D5D engines – Phase3
New, adjustable upper king pin for light and heavy duty front axles
Noise generated by cab mounts play
Oil analyses
Operator's seat, installation
Operator's seat, removal
Paint comes off from side plate on the cab, LHS rear
Parking brake cable, adjustment
Parking brake cable, changing
Parking brake, adjusting 2
Phase 3 engine fan guard fixation
Phase III bonnet lock
Pipes, couplings and hoses, check
Play in the front axle mounting
Power transmission, troubleshooting
Powershift transmission, checking hydraulic pressures
Powershuttle transmission F-R seal ring
Propeller shaft, lubrication
Radiator hose upper, replacing 2
Radiator, changing
Radiator, hose lower, replacement
Radiator, hose upper, replacement
Radiator, installation
Radiator, removal
Rear axle bolts loosening
Rear wheel, installing
Rear wheel, removing
Recommended Special tools
Reinforcement plates for inner dipper 1
RHS dashboard (engine overheating indication in Phase 3 machines)
Self level adjustment
Service brake, bleeding
Service brake, checking pressure
Service points
Service positions 1
Service positions
Servo pump, installing
Servo pump, removal
Servo valve, adjusting control
Servo valve, electrically controlled, reconditioning
Servo valve, replacing
Silencer, replacing 2
Silencer, replacing
Solenoids, testing
Special tools
Stabiliser foot breaking
Stabiliser legs, check wear pads (BL61B, BL71B)
Stabiliser legs, cleaning
Stabiliser wear pads, replacing
Stabilisers, adjusting wearpads
Stabilisers, loader, backhoe, front axle oscillation pivot and front axle steering pivots, lubricate
Stabilisers, reconditioning hydraulic cylinder
Stabilizer cylinder, installation
Stabilizer cylinder, removal
Steering angle, adjustment
Steering angle, checking and adjusting
Steering cylinder, installation 0
Steering cylinder, installing
Steering cylinder, removal
Steering cylinder, removing 2
Steering cylinders, locking of pivot pins, check
Steering valve, installation
Steering valve, removal
Steering, troubleshooting
Swing cylinder hose 1
Swing cylinder hose
Swing cylinder plug 1
Swing cylinder plug
Swing cylinder, renovation
Test-run and check 1
Test-run and check
Tilt cylinder, reconditioning
Toe - in, checking and adjusting 1
Torque converter, installation
Torque converter, removal
Transmission breather filter, replacing
Transmission including torque converter, check pressure
Transmission mounts, changing
Transmission oil leak through the breather on powershift transmissions, part No. VOE11887381
Transmission oil level, checking
Transmission oil pressure, checking
Transmission oil
Transmission solenoid, replacing
Transmission suction filter, replacing
Transmission, changing oil 1
Transmission, oil filter, changing
Transmission, replacing oil filter
Turbocharger inclusive inlet and exhaust systems, leakage, check
Tyres, wear and air pressure, checking
Using HB440 Volvo hammer with a mechanical attachment bracket
Vacuum pump, connection 1
Vacuum pump, connection 2
Vacuum pump, disconnection
Valve block, changing seal in dipper and slew spools.
Valve block, installation
Valve block, removal
Valves, adjusting 1
Valves, adjusting 2
Valves, adjusting
Volvo Hydraulic Safeguard System
Wheel nuts, torque, check
Wires, testing
Special tool catalog
General
Index
Hooks
1. Enviroment and Safety equipment
2. Measuring equipment
3. Tightening and Loosening tools
4. Lifting equipment
5. Pullers and Pressing equipment
6. Drifts
7. Guide pins and Guide sleeves
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
Time Guide Current generation
Time Guide Old generation
