Martin Welker
104
230,310
Volvo Backhoe Loader BL70B Parts Manual
Brand: Volvo
Model: Volvo BL70B Backhoe Loader
Number of Pages: 468 Pages
Brakes
Brake pedal 11294033, 11298485, 11298487, 11298489
Multi-disc brake, rear 11887363
Parking brake 11887363
Parking brake
Wheel brake, rear
Elec, Warning, Information, Instruments
Alternator with assembling details 11895376, 11895377
Back-up warning unit 11895365
Battery cable and main switch 11895362
Battery cable and main switch 11895363
Battery with assembling details 11895362, 11895363
Cable and wire harness, instrument panel 11895696
Cable harness between electrical distribution box, fuse box, and starter motor
Cable Harness cab int. roof 11298303, 11298350
Cable Harness cab int. roof SN - 2121919
Cable Harness cab int. roof SN 2121910
Cable harness chassis
Cable harness for transmission 11895342, 11895343
Cable harness, control panel, Rh 11895696
Cable harness, hand tool hydraulic
Cable harness, lighting US
Cable harness, Loader Quick Attach 11895636
Cable harness, parking brake adjustment 11294033
Cable Harness, return to dig
Cable harness, wiper motor rear
Cable harnesses, instrument panel 11895342, 11895343
Cable harnesses, rear
Control Lever with Cable
Electrical distribution box
Electrical system automatic power shift 11895696
Electronic unit 11294033
Electronic unit 11895696
Equipment excluding roadlight 11298446
Foot switch, hammer hydraulics 11895573
Fuse box
Hour recorder 11298361
Instrument panel 11895342, 11895343, 11895636, 11895358, 11895359
Interior lamp
Lighting,rear US LED
Lighting,rear US
Loader controls
Radio kit 11298368, 11298369, 11298434
Rotating beacon
Starter motor with assembling details 11895376, 11895377
Switch panel 11294033
Switch panel
System for wireless electronic controlled communication (telematics)
Windshield washer
Windshield wiper, front
Windshield wiper, rear
Work lamp 11294033, 11298357
Engine with Mounting and Equipment
Air filter 11895354, 11895355
Air filter with fitting parts 11895354
Air filter with fitting parts 11895355
Belt transmission 11895376, 11895377
Cab heating 11895390, 11895388
Cable harness, Engine
Cooler protection
Cooling system
Crankcase ventilation 11895376, 11895377
Crankshaft and related parts 11895376, 11895377
Cylinder block 11895376, 11895377
Cylinder head 11895376, 11895377
Cylinder liner and piston 11895376, 11895377
Delivery pipe - injector 11895376, 11895377
Engine 11895376, 11895377
Engine mounting 11895376, 11895377
Engine mounting TM NO - 2326543
Engine mounting TM NO 2326544 -
Exhaust system, silencer
Expansion tank with fitting parts E PROD
Expansion tank with fitting parts L PROD
Fan 11895382
Fan
Flywheel housing 11895376, 11895377
Fuel filter 11895376, 11895377
Fuel injection pump with fitting parts 11895376, 11895377
Fuel pipes, fuel pump 11895376, 11895377
Fuel pump 11895376, 11895377
Fuel system
Fuel tank E PROD
Fuel tank L PROD
Fuel tank with fitting parts E PROD
Fuel tank with fitting parts L PROD
Heater 11895360
Heater 11895361
Inlet manifold and exhaust manifold 11895376
Lubricating oil system 11895376, 11895377
Oil cooler 11895376, 11895377
Oil filter 11895376, 11895377
Oil sump 11895376, 11895377
Pump drive power take-off 11895376, 11895377
Regulator 11895376, 11895377
Shutdown device 11895376, 11895377
Throttle control 11294033
Throttle control
Timing gear casing 11895376, 11895377
Turbocharger with fitting parts 11895376, 11895377
Valve mechanism 11895376, 11895377
Water pump and thermostat housing 11895376,
Frame, Springs, Damping, Axle Suspension, Wheel-Track Unit
Counterweight
Frame 11892007
Protecting plates
Wheel
Hydraulic, Digging, Handling, Grading and Misc Equip
Attachment bracket, mechanical 11891299
Boom and dipper arm
Boom cylinder 11895291, 11895295.
Boom suspension system 11895638, SN - 2122162
Boom suspension system 11895638, SN 2122163 -
Boom swing system
Bucket cylinder 11895291, 11895295, SN - 2122115
Bucket cylinder 11895291, 11895295, SN 2122116 -
Control valve 11895301
Control valve 11895302
Control valve with fitting parts.
Dipper arm cylinder 11895291, 11895295.
Excavator boom, extendible dipper arm 11895295
Excavator controls
Excavator lock system
Extendable dipper cylinder 11895295
Hydraulic attachment bracket 11895636, SN 2123226 -
Hydraulic attachment bracket 11895636-1
Hydraulic attachment bracket 11895637
Hydraulic attachment bracket 11895727
Hydraulic attachment bracket digger 11895432
Hydraulic attachment bracket digger 11895433
Hydraulic cylinder, quick attachment 11895636
Hydraulic oil cooler
Hydraulic oil tank
Hydraulic pump 11895342, 11895343, 11895696
Hydraulic system, excavator EXT DIPPER
Hydraulic system, excavator STD DIPPER
Hydraulic system, excavator1
Hydraulic system, hammer 11895407
Hydraulic system, hammer 11895408
Hydraulic system, loader 11895393, 11895397
Hydraulic system, loader 11895393, 11895397-1
Hydraulic system, loader 11895397
Hydraulic system, loader 11895397-1
Hydraulic system, lock cylinder
Hydraulic system, return line
Hydraulic system, stabiliser legs
Hydraulic system, suction line 11895342, 11895343.
Hydraulic system, suction line 11895696
Inlet valve 11895393, 11895397
Lift cylinder 11895393, 11895397
Lifting framework with assembly parts 11895393, 11895397
Loader controls
Mechanical self levelling tilt mechanism 11895393, 11895397
Optional hydraulic equipment 11895574
Pedal 11895302
Pins for mounting bucket 11895393, 11895397
Stabiliser cylinder
Stabiliser cylinder1
Stabilisers
Swing cylinder
Swing system
Tilt cylinder 11895393, 11895397
Transport bracket without front bucket 11891350
Valve body with fitting parts 11895301
Valve body with fitting parts 11895302
Valve body with fitting parts 11895393
Valve body with fitting parts 11895397
Valve section 11895301, 11895302
Valve section 11895301, 11895302-1
Valve section 11895301, 11895302-2
Valve section 11895301, 11895302-3
Valve section 11895301, 11895302-4
Valve section 11895301, 11895302-5
Valve section 11895302
Valve section 11895393, 11895397
Valve section 11895393, 11895397-1
Valve section 11895397
Machinery House, Cab, Exterior Trim Parts
Air conditioning unit, cooling and heater 11298308, SN - 2123100
Air conditioning unit, cooling and heater 11298308, SN 2123101 -
Assembly hoses Evaparator, receiver drier, condenser. 11895388
Cab body roof and floor panel. 11294033
Cab heater 11298307
Cab mounting block
Casing loader controls
Door with fitting parts
Door with fitting parts1
Engine hood insulation SN - 2121933
Engine hood insulation SN 2121934 -
Engine hood SN - 2121933
Engine hood SN 2121934
Fenders
Glass panes 11298350, 11298303
Heater and air conditioning installation
Hinge. 11895354, 11895355 SN - 2121933
Hinge. 11895354, 11895355 SN 2121934 -
Instrument panel 11294033
Instrument panel 11294033-1
Instrument panel
Instrument panel1
Instrument panel2
Insulating matting. 11892007 SN 2121809
Insulating matting.
Insulating matting
Interior components 11298349
Interior components 11298353
Interior components 11298365
Lock device, engine hood SN - 2121933
Lock device, engine hood SN 2121934 -
Mudflap 11895697
Operator's seat 11298320
Operator's seat
Radiator casing 11892007
Rear view mirror
Sign plates and decals
Sign plates and decals1
Step handle canopy
Toolbox
Tools
Vandalism kit 11298362
Windows 11298303 SN 2121972-
Windows 11298334, 11298381
Windows
Power Transmission
2wd Front Axle 11887359
Clutch shaft forward reverse 16205791, 11895696
Clutch shaft forward reverse 16206725, 16206728
Control valve 16205791, 11895696
Differential , front axle 11895578
Differential lock 11887363
Differential lock
Differential. Rear 11887363
Drive axle 11895577
Drive axle 11895578
Front axle 11895577
Gear box housing with fitting parts
Gear selector 16206725, 16206728
Gearshifting 16206725, 16206728
Hub reduction, rear axle 11887363
Hydraulic clutch, 4wd 16205791, 11895696
Hydraulic clutch, 4wd 16206725
Hydraulic transmission with fitting parts 16205791, 11895696
Hydraulic transmission with fitting parts 16206725, 16206728
Oil cooler, transmission
Oil filler and dipstick
Oil pump 16205791, 11895696
Oil pump 16206725, 16206728
Pinion 11887363
Pinion 11895578
Pinion
Planet axles with fitting parts 11887359, 11887363
Planet axles with fitting parts 11887360, 11887363
Planet shaft, rear 11887363
Planetary axle, front 11895578
Planetary gear 11895578, 11887362, 16214835, 16226687
Propeller shaft, mounting
Propeller shaft, mounting1
Range selector valve 16206725, 16206728
Reverse and primary shaft 16205791, 11895696
Reverse and primary shaft 16206725, 16206728
Secondary shaft 16205791, 11895696
Secondary shaft 16206725, 16206728
Solenoid valve 4wd 16206725
Torque converter with fitting parts
Wheel hub 11887359
Wheel hub 11895578
Wheel hub
Product identification plate
Steering
Steering column with fitting parts
Steering system 11895578
Steering system
Steering system1
Steering system2
