Valtra Tractor TC TCH Series T130CH Parts Catalog VFTC130H
Brand: Valtra
Model: Valtra T130CH Tractor (TC, TCH Series)
Number of Pages: 651 Pages
Cylinderblock
Flywheel And Housing
Valve Mechanism
Crank Mechanism
Gear Housing
Oil Filter
Oil Sump
Air Cleaner
Intake- And Exhaust Pipe
Intercooler
Turbocharger
Muffler
Fuel Pipes
Speed Levers
Coolant Pump
Startermotor
Eem Parts
Gasket Sets
Engine Repair Kit And Bearing
Adjusting Plate For Injector
Air Inlet, Taken Up (Optional Equipment)
Pillar Exhaust Pipe (Optional Equipment)
Steering Cylinder 4wd Dana 730, 733
Steering Cylinder 4wd Carraro
Front Axle 4wd Dana 730, 733
Front Axle 4wd Carraro 20.29 Hd (Ind.)
Drive Shaft 4wd Dana 730, 733
Drive Shaft 4wd Carraro
Planetary Gear Set 4wd Dana 730, 733
Bevel Pinion Shaft 4wd Dana 730
Differential 4wd Dana 730
Differential 4wd Hi-Lock Dana 733
Differential 4wd Carraro (Ind.)
Propeller Shaft 4wd
Steering Valve And Piping 4wd
F-R Shuttle Lever (Optional Equipment)
Drive Plate
Clutch Pedal
Gearbox
Gear Lever System
Main Shaft
Intermediate Shaft
Shaft 4wd
Drive Shaft
Coupling 4wd
Bevel Pinion Shaft
Valve
Pump Drive Gear
Lubrication System
Shuttle-Unit
Piping
Gears For Shift-On-The-Go
Final Drive 650
Valve (Optional Equipment)
Brake Control
Brake Pipes
Brakes 650
Compressed Air System
Hydraulic Pump And Pipes
Hydraulics
Working Hydraulics
Directional Control Valve
Radar
Mud Guard
Doors
Roof
Roof, Forest
Cab Windows
Cab Upholstery
Steering Wheel Console
Box Of Lever
Visor And Rearview Mirror
Sidemirrors
Flexible Mount
Turning Device
Occasional Seat
Dashboard
Windscreen Wiper And Washer
Control Parts, Eh Power Lift
Selectors On Side Panel
Lights, Forest
Windscreen Wiper, Forest
Ashtray (Optional Equipment)
Rear Window Wiper Forest (Optional Equipment)
Radio (Optional Equipment)
F-R Shuttle Lever And Combined Switch (Optional Equipment)
Fold-Out Platform (Equipment)
Isobus (Optional Equipment)
Heating Unit
Heating Unit, Forest
Front Part
Center Frame
Foot Board
Shields
Battery And Bracket
Battery Carrier And Tool Box (Optional Equipment)
Stickers And Sign Plates
Front Wheels
Implement Drive System
Rear Housing
Lever System
Gear Shaft
Upper Shaft
Upper Shaft Hd
Power-Take-Off Shaft
Bar (Optional Equipment)
Bracket (Optional Equipment)
Implement Lift System Front
Power Lift
Lift Cylinder
Lower Links, Ball-Hitch
Side Regulator
Top Link And Bracket
Lift Link Gear And Lift Link
Precision Farming Systems
Symbol Lenses
Filters
Service Kit
Tools And Warning Triangle
Brand: Valtra
Cylinderblock
Valve Mechanism
Crank Mechanism
Gear Housing
Oil Filter
Oil Sump
Air Cleaner
Intercooler
Turbocharger
Muffler
Fuel Pipes
Speed Levers
Coolant Pump
Startermotor
Eem Parts
Gasket Sets
Propeller Shaft 4wd
Drive Plate
Clutch Pedal
Gearbox
Gear Lever System
Main Shaft
Intermediate Shaft
Shaft 4wd
Drive Shaft
Coupling 4wd
Bevel Pinion Shaft
Valve
Pump Drive Gear
Lubrication System
Shuttle-Unit
Piping
Final Drive 650
Brake Control
Brake Pipes
Brakes 650
Hydraulics
Working Hydraulics
Radar
Mud Guard
Doors
Roof
Roof, Forest
Cab Windows
Cab Upholstery
Box Of Lever
Sidemirrors
Flexible Mount
Turning Device
Occasional Seat
Dashboard
Lights, Forest
Heating Unit
Front Part
Center Frame
Foot Board
Shields
Battery And Bracket
Front Wheels
Rear Housing
Lever System
Gear Shaft
Upper Shaft
Upper Shaft Hd
Power Lift
Lift Cylinder
Side Regulator
Symbol Lenses
Filters
Service Kit
