Valtra Tractor T4 Series T214A Parts Catalog VFT214A
Brand: Valtra
Model: Valtra T214A Tractor (T4 Series)
Number of Pages: 1107 Pages
Engine V835077357 74 Awf
Engine Assemblies - Engine Serial Number Range A75447-C60151
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons - Up To Engine Serial Number B65499
Crankshaft And Pistons - Starting From Engine Serial Number B65500 Jld291001
Camshaft And Valve Mechanism
Valve Rocker Cover - Up To Engine Serial Number B65459
Valve Rocker Cover - Starting From Engine Serial Number B65460
Intake Manifold
Oil Pump And Sump
Oil Cooler And Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters - Starting From Engine Serial Number B50000 Jld291001
Electronic Engine Management
Starter Motor
Belt Tensioner
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine V835077358 74 Awf
Fuel Filters
Engine V835077740 74 Awf
Engine Assemblies - Engine Serial Number Range C60695-D69318
Valve Rocker Cover
Engine V835077741 74 Awf
Engine Assemblies - Engine Serial Number Range C57286-D70055
Closed Crankcase Ventilation (Ccv) - Up To Engine Serial Number D68091
Closed Crankcase Ventilation (Ccv) - Starting From Engine Serial Number D68092
Engine V835077865 74 Awf
Engine Assemblies
Engine V835077866 74 Awf
Engine Installation
Blanking Plugs
Air Intake System
Intercooler
Pillar Exhaust Pipe
Piping, Def
Container, Def
Wiring Set, Def
Fuel Radiator And Piping
Speed Levers
Wiring Set, Engine
Engine Heater
Steering Cylinder 4wd
Steering Hydraulics
Front Axle 4wd
Joint Casing 4wd
Drive Shaft 4wd
Planetary Gear Set 4wd
Bevel Pinion Shaft 4wd
Differential 4wd
Piping, Differential Lock
Brakes 4wd
Brake Pipes, Front Axle
Propeller Shaft 4wd
Axle Mounting
Suspension Of Front Axle
Front Mudguards
Front Mudguards, Flexible
Steering Valve And Piping 4wd
Mirror, Reverse Drive System
Speed Levers, Rear
Clutch Pedal
Drive Plate
Gearbox Housing
Gearbox
Shift Lever
Main Shaft
Intermediate Shaft
Bevel Pinion Shaft
Gear Housing
Creep Speed Gear
Shuttle-Unit
Coupling 4wd
Piping
Filterblock
Valve
Valve Block Assembly
Valve, Lubricating
Pump Drive Gear
Lubrication System
Shift-On-The-Go
Final Drive 750
Brake Pedals
Brake Pipes
Brake Valve
Air Pressure Brake
Compressed Air System
Pneumatic Appliances
Compressor
Suction Piping
Ls Pump
Working Hydraulics
Oil Cooler Heat Exchanger
Hydraulics
Oil Filling And Measurement
Valve Group
Mechanical Valve Package
Directional Control Valve
Front Quick Couplers, Left
Front Quick Couplers, Right
Front Valve
On Off Extra Valves
Power Beyond Couplings
Main Switch
Radar
Backbuzzer
Electrical Equipment
Wiring Set, Cab
Cab Frame
Cab Support
Cab Suspension
Rear Mudguards
Spilling Guard
Left Hand Door
Right Hand Door
Roof
Inner Roof
Roof Tube
Roof Window Wiper
Trough
Registration Plate Mounting
Windshield
Windshield Wiper
Side Window And Wiper
Side Windows
Rear Window
Rear Window, Heated
Rear Window, Polycarbonate
Rear Window Wiper
Wiring Set, Roof
Wiper Controls
Cab Upholstery
Storage Box
Steering Wheel Console
Sound Insulation
Dashboard
Fuel-Operated Heater
Sidemirrors
Sidemirrors, Electric
Safety Camera
Flexible Mount
Safety Belt
Air-Suspended Driver's Seat
Stand
Arm Support Right
Control Lever
Arm Support
Armrest
Occasional Seat
Fold-Out Platform
Selectors On Side Panel
Control Handle
Controls
Emergency Brake
Radio
Rotating Light
Rear Working Lights
Extremity Lights
Step And Trailer Hitch Lights
Pto Rear Start Stop
Implement Signal Interface
Isobus
Isobus Terminal
First-Aid Kit
Powder Extinguisher
Safety Hammer
Warning Triangle
Heating Unit
Air Conditioning
Cab Lower Heater
Cabin Heater
Front Part
Front Weight Frame
Hood Protection
Center Frame
Engine Hood
Side Plate
Shields
Fuel Tank Support
Fuel Tank, Steel
Protection Plate
Fuel Strainer
Stickers And Sign Plates
Stickers
Front Tyres
Front Disc Wheels
Rear Tyres
Disc Wheels Rear
Valve Protecting Cover
Implement Drive System
Rear Housing
Upper Shaft
Power-Take-Off Shaft
Front Pto
Front Pto Gearbox
Front Pto Clutch
Front Pto Pump
Proportional Ground Speed
Trailer Coupling, Automatic
Rear Hitch
Trailer Hitch Nordic
Trailer Hitch Euro
Drawbar + Bracket
Agricultural Drawbar
Trailer Hitch
Releaser Of Trailer Hitch
Implement Lift System Front
Front Lift
Front Lift, Piping
Top Link, Front Lift
Power Lift
Lower Links, Ball-Hitch
Side Regulator
Levelling Screw
Hydraulic Levelling
Top Link Ball-Hitch
Hydraulic Top Link
Accessory Kit
Front Rear Loaders
Mounting Frame
Beam Support
Front Loader Facility
Precision Farming Systems
Telemetry
Auto-Steering
Tachograph
Valtra Connect Readiness
Ballast Weights
Front Mudguards, Flexible (Optional Equipment)
Front Quick Couplers (Optional Equipment)
Front Valves (Optional Equipment)
Side Window Wiper (Optional Equipment)
Rear Window, Heated (Optional Equipment)
Occasional Seat (Optional Equipment)
Isobus (Optional Equipment)
Dealer Stocking List
Paints
Service Kit
Lock
Tools
Operator's Manual
Service Record Book
Service Manual
Brand: Valtra
Intake Manifold
Oil Pump And Sump
Starter Motor
Belt Tensioner
Fuel Filters
Valve Rocker Cover
Engine Assemblies
Engine Installation
Blanking Plugs
Air Intake System
Intercooler
Pillar Exhaust Pipe
Piping, Def
Container, Def
Wiring Set, Def
Speed Levers
Wiring Set, Engine
Engine Heater
Steering Hydraulics
Front Axle 4wd
Joint Casing 4wd
Drive Shaft 4wd
Differential 4wd
Brakes 4wd
Propeller Shaft 4wd
Axle Mounting
Front Mudguards
Speed Levers, Rear
Clutch Pedal
Drive Plate
Gearbox Housing
Gearbox
Shift Lever
Main Shaft
Intermediate Shaft
Bevel Pinion Shaft
Gear Housing
Creep Speed Gear
Shuttle-Unit
Coupling 4wd
Piping
Filterblock
Valve
Valve, Lubricating
Pump Drive Gear
Lubrication System
Shift-On-The-Go
Final Drive 750
Brake Pedals
Brake Pipes
Brake Valve
Air Pressure Brake
Compressor
Suction Piping
Ls Pump
Working Hydraulics
Hydraulics
Valve Group
Front Valve
On Off Extra Valves
Main Switch
Radar
Backbuzzer
Wiring Set, Cab
Cab Frame
Cab Support
Cab Suspension
Rear Mudguards
Spilling Guard
Left Hand Door
Right Hand Door
Roof
Inner Roof
Roof Tube
Roof Window Wiper
Trough
Windshield
Windshield Wiper
Side Windows
Rear Window
Rear Window, Heated
Rear Window Wiper
Wiring Set, Roof
Wiper Controls
Cab Upholstery
Storage Box
Sound Insulation
Dashboard
Sidemirrors
Safety Camera
Flexible Mount
Safety Belt
Stand
Arm Support Right
Control Lever
Arm Support
Armrest
Occasional Seat
Fold-Out Platform
Control Handle
Controls
Emergency Brake
Radio
Rotating Light
Rear Working Lights
Extremity Lights
Pto Rear Start Stop
Isobus
Isobus Terminal
First-Aid Kit
Powder Extinguisher
Safety Hammer
Warning Triangle
Heating Unit
Air Conditioning
Cab Lower Heater
Cabin Heater
Front Part
Front Weight Frame
Hood Protection
Center Frame
Engine Hood
Side Plate
Shields
Fuel Tank Support
Fuel Tank, Steel
Protection Plate
Fuel Strainer
Stickers
Front Tyres
Front Disc Wheels
Rear Tyres
Disc Wheels Rear
Rear Housing
Upper Shaft
Front Pto
Front Pto Gearbox
Front Pto Clutch
Front Pto Pump
Rear Hitch
Trailer Hitch Euro
Drawbar + Bracket
Trailer Hitch
Front Lift
Front Lift, Piping
Power Lift
Side Regulator
Levelling Screw
Hydraulic Levelling
Top Link Ball-Hitch
Hydraulic Top Link
Accessory Kit
Front Rear Loaders
Mounting Frame
Beam Support
Telemetry
Auto-Steering
Tachograph
Ballast Weights
Paints
Service Kit
Lock
Tools
Operator's Manual
Service Record Book
Service Manual
