705,263
Valtra Tractor S354 Smart Touch Parts Catalog 6246593
Brand: Valtra
Model: Valtra S354 Smart Touch Tractor (Engine: Tier 4F-2)
Serial Number: HB193059 - 999999
Number of Pages: 1277 Pages
Fan & Shroud
Air Filter Dry Element
Air Filter - Dry - Dual Element
Engine V835277880 84 Cwi2
Engine Assemblies
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Oil Pump And Sump
Oil Cooler And Filter
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters
Electronic Engine Management
Belt Tensioner
Engine Overhaul Parts
Special Overhaul Parts
Engine V835277748 84 Awf-Hla
Cylinder Block - Up To Engine Serial Number C66572
Cylinder Block - Starting From Engine Serial Number C73097
Exhaust Manifold - M12 Turbo Mounting Stud Bolts
High Pressure Turbocharger - M12 Turbo Mounting Stud Bolts
Low Pressure Turbocharger And Icac - M12 Turbo Mounting Stud Bolts
Oil Cooler And Filter - Up To Engine Serial Number D75011
Oil Cooler And Filter - Starting From Engine Serial Number D75012 Jld291001
Coolant Piping
Belt Tensioner - Up To Engine Serial Number D79603
Belt Tensioner - Starting From Engine Serial Number D79604
Exhaust Aftertreatment
Engine Acw4193000 84 Awf-Hla
Engine Acw3398800 84 Awf-Hla
Engine Assemblies - Engine Serial Number Range E51552-Jld515205
Exhaust Gas Recirculation (Egr) - Up To Engine Serial Number E69999
Exhaust Gas Recirculation (Egr) - Starting From Engine Serial Number Jld291001
Oil Cooler And Filter - Up To Engine Serial Number E69999
Oil Cooler And Filter - Starting From Engine Serial Number Jld291001
Coolant Piping - Up To Engine Serial Number E69999
Coolant Piping - Starting From Engine Serial Number Jld291001
Engine Installation
Engine, Startermotor And Shields - Tier2 Engine
Engine, Startermotor And Shields - Engine Tier 4f Stage 4
Engine, Startermotor And Shields - Tier4f Stage4 Engine
Alternator Bracket And Belt - Engine With Air Compressor - 2 Alternators
Heater Engine Block - 220 V
Cab Heating System - Engine Part
Fuel Tank & Attachments - Engine Tier 2
Fuel Tank & Attachments - Engine Tier 3 & 4f
Fuel Tank & Attachments - Additional Fuel Tank
Fuel Tank (Components) - Engine Tier 2
Fuel Tank (Components) - Engine Tier 3 & 4f
Def Tank - (Components)
Additional Fuel Tank - (Components)
Fuel Tank & Attachments - Breather Line
Fuel System
Fuel System - With Fuel Filter - Without Front Loader
Air Conditioned Installation
Cooling System - Tier2 Engine
Cooling System - Engine
Cooling System - Plugs
Oil Recovery
Exhaust - Vertical - Engine Tier 4f Stage 4
Exhaust - Vertical - Engine Tier 2
Exhaust - Vertical - (Components)
Pollution Control
Throttle Controls
Throttle Controls - Driving Position Opposite
Front Weight Frame - With Belly Weight - 820 Kg
Front Weight - 22 X 55 Kg + 60 Kg
Front Weight - Chain And Pin
Front Weight - 900 Kg
Front Weight - 1500 Kg
Front Weight - 2300 Kg
Belly Weight - 345 Kg
Guard And Transmission Shaft - Suspended Axle
Bracket
Front Axle 4 Wheel Drive - Bracket - Plugs
Suspended Axle - Type 770 639
Bearing Carrier - Suspended Axle
Housing - Suspended Axle
Final Drive - Suspended Axle
Double Joint - (Components)
Auto Guide Sensor - Suspended Axle
Front Axle 4 Wheel Drive - Hydraulic Valve Block
Steering Wheel & Telescopic Column
Steering Column - (Components)
Steering Wheel & Telescopic Column - Driving Position Opposite
Load Sensing Hydraulic - With Auto-Guide
Steering Pump - (Components)
Pump Support - With Auto-Guide
Engine - Gear Box Assembling - Damper
Control Armrest - Module Fingertip For Distrib With Electrodyn Control
Control Armrest - Without Front Pto Switch
Control Armrest - Front Pto Switch
Control Armrest
Armrest - Components
Control Armrest - Without Joystick
Gearbox-Housing
Rear Axle Housing
Oil Level Indicator
Oil Level Indicator - Decal
Final Drive
Final Drive - Protection
Disc Brake
Actuating Cylinder
Gear
Suspension
Suspension - Gear Box
Duct Plate - Valves
Adjusting Device
Pipelines - Transmission
Piping - Gear
Bevel Drive
Group Gear Shifting
Shifting
Transmission Control - Angle Drive
Engine P.T.O.
Pump Drive
Lube Oil Pump
Feed Pump
Gear Box Lubrication
Valve Unit
Valve Syst.Comfort
Tubes System Comfort
Front Wheel Drive Constant
Front Wheel Drive
Brake Pedals
Brake Pedals - Brake Pedals - Driving Position Opposite
Brakes High Pressure - Pipes And Fitting - With Hydraulic Pneumatic Braking Of Trailer
Brakes High Pressure - Pipes And Fitting - With Pneumatic Braking Of Trailer
Brakes High Pressure - Pipes And Fitting - With Hydraulic Braking Of Trailer
Brakes High Pressure - Pipes And Fitting - Without Hydraulic Trailer Brakes
Brakes High Pressure - Pipes And Fitting - Without Hydraulic Braking Of Trailer
Brakes High Pressure - Pipes And Fitting - Driving Position Opposite
Brake Valve - (Components)
Trailor Brake
Trailor Brake - Pneumatic Feeding
Trailer Brake - Pneumatic Feeding
Support - Without Pneumatic Trailer Braking
Without Trailer Brake
Park Brake - Without Hydraulic Braking Of Trailer
Park Brake - With Trailer Brake
Park Brake - With Hydraulic Braking Of Trailer
Park Brake - Valve Components
Compressed Air System
Air Compressor - Engine Tier 2
Air Compressor
Air Compressor - (Components)
Front Suspension Hydraulic Lines
Auxiliary Front Spool Valves - With Hydraulic Coupling
Auxiliary Front Spool Valves - Without Hydraulic Coupling
Hydraulic Lift Valve - Without Front Loader
Hydraulic Lift Valve - (Components)
Auxiliary Distributors Installation
Auxiliary Distributors Installation - With Hay Ladder - With Hydraulic Coupling
Auxiliary Distributor - 4 Distributors Electrodynamique
Auxiliary Distributor - 6 Distributors Electrodynamique
Spacer - (Components)
Distributor (Components)
Distributor - (Components)
Hydraulic Coupling - 4 Distributors Electrodynamique
Hydraulic Coupling - 6 Distributors Electrodynamique
Hydraulic Coupling - (Components)
Hydraulic Coupling
Oil Recovery - 4 Distributors Electrodynamique
Oil Recovery - 6 Distributors Electrodynamique
Auxiliary Hydraulics - With Automatic Hitch
Pump Installation
Auxiliary Hydraulics - Hydraulic Circuit
Auxiliary Hydraulics - Filter
Auxiliary Hydraulics - Pump
Pump - (Components)
Hydraulic Block
Without Front Quick Couplers
4 Quick Couplers - Hydraulic Lines
4 Quick Couplers - Free Return
Batteries & Cables - Battery Cover
Batteries & Cables - Engine Tier 2 & Tier 4f
Fuse Box - Engine Tier 2 & Tier 4f
Instrument Panel & Instruments
Instrument Panel & Instruments - Miscellaneous
Instrument Panel Harness
Side Console Switches
Side Console Switches - Cee
Side Console Switches - External Mirrors
Side Console Switches - Electric Rear View Mirror
Side Console Switches - Start Key
External Controls Fitted On The Rear Fenders
External Controls Fitted On The Rear Fenders - Lift Control
Lighting & Power Shuttle Drive - Reverse Drive System
Lighting & Power Shuttle Drive - Without Reverse Drive System
Plate Relay & Fuse Holder - Decal
Engine Harness - Engine Tier 2
Engine Harness - Engine Tier 4f
Transmission Main Harness - With Semi Active Suspension
Semi Active Suspension - Harness
Main Harness - Cab
Roof Harness - Manual Air Conditioner
Roof Harness - Automatic Air Conditioner
Roof Harness - Electric Rear View Mirror
Aboard Computer
Front Axle Harness - With Suspended Front Axle
Front Harness - Without 7 Pin Socket
Front Harness - With 7 Pin Socket
Harness Isobus
Harness Isobus - Cee
Harness Isobus - With Abs Plug
Flasher Unit & Harness - Cee
Rear Lightning Harness - Sae Standard
Front Lighting Harness
Speed Radar
Front Lighting - Road Lights - Left Driving
Front Lighting - Road Lights - Led
Front Lighting
Front Lighting Harness - Handrail
Handrail Lighting
Handrail Lighting - Road Lights & Auxiliary Lights
Handrail Lighting - Road Lights & Auxiliary Lights Led
Rear Lighting
Rear Lighting Equipment - Italy
Rotating Light - Installation Without Rotating Light
Rotating Light - Standard Roof
Auxiliary Lights - Fenders
Roof Lighting
Rear Reflectors
Spool Valves Harness - 4 Spool Valves
Spool Valves Harness - 6 Spool Valves
Transmitter
Control
Traffic Warning
Traffic Warning - Driving Position Opposite
Cab Mountings - With Suspension
Tractor Cab
Glass
Doors - Left Side
Doors - Right Side
Rear Window Mechanism
Roof
Roof - Cladding
Tractor Cab - Cladding - Dressing Roof
Tractor Cab - Cladding - Right Side
Tractor Cab - Cladding - Left Side
Tractor Cab - Cab Insulation
Instrument Panel Cladding
Instrument Panel Cladding - Driving Position Opposite
Tractor Cab - Cladding - Sub Console Tidying
Tractor Cab - Plug
Tractor Cab - Fenders - For Wheelbase 2,45 M
Tractor Cab - Fenders - Fenders Extension - 100mm
Tractor Cab - Fenders - Fenders Extension - 100mm + 45mm
Tractor Cab - Fenders - Fenders Extension - 100mm + 70 Mm
Air Conditioner - Hose - Left Side
Air Conditioner - Hoses - Left Side
Air Conditioner - Hose - Right Side
Air Conditioner - Hoses - Right Side
Air Conditioner - Hoses - Without Additional Heater
Air Conditioner - Hoses - High Cold
Air Conditioner - Manual Air Conditioner
Air Conditioner - Automatic Air Conditioner
Air Conditioner - Additional Heater
Heater Control - Manual Air Conditioner
Heater Control - Automatic Air Conditioner
Cab Filter
Air Conditioner - Sensor
Canopy
Windscreen Wiper
Radio Installation
Radio Installation - Cd Radio + Bluetooth
Radio Installation - Mp3-Cd Radio + Usb + Bluetooth
Electrical Plug & Cigar Lighter - Cee
Ashtray
Internal Mirrors
Internal Mirrors - Rear View Mirror
External Mirrors - Wide Angle
Electric Rear View Mirror - Wide Angle
Tools - Mechanical Transmission Command
Seat - Deluxe
Seat - Reverse Drive
Seat - (Components)
Seat Suspension - (Components)
Secondary Seat - With Safety Belt
Sheet Metal - Grille
Sheet Metal - Hood
Sheet Metal - Hood Frame
Footstep
Tool Box
Tool Box - Additional Container
Literature - Engine Tier 4f
Literature - Engine Tier 2
Literature - Autoguide
Emblems
Decal Hydraulic Controls
Speed Charts
Decals - Safety
Front Disc Wheels - 18 X 28
Front Disc Wheels - 18 X 34
Front Disc Wheels - 20 X 30
Front Disc Wheels - 23 X 30
Front Disc Wheels - 23 X 34
Adjust. Front Wheels - 18 X 34
Adjust. Front Wheels - 23 X 30
Front Axle - 4 Wheel Drive - Wheels Fixing
Front Axle 4 Wheel Drive - Pivoting Mudguards Width 620mm And Supports
Front Axle 4 Wheel Drive - Pivoting Mudguards Width 700mm And Supports
Mudguards And Supports - Pivot
Disc Wheels Rear - 20 X 38
Disc Wheels Rear - 23 X 38
Disc Wheels Rear - 23 X 42
Disc Wheels Rear - 25 X 38
Disc Wheels Rear - 25 X 42
Disc Wheels Rear - 27 X 38
Disc Wheels Rear - 28 X 42
Adjustab.Rear Wheels - 23 X 38
Adjustab.Rear Wheels - 23 X 42
Adjustab.Rear Wheels - 25 X 38
Adjustab.Rear Wheels - Twin Wheels - 23 X 42
Rear Wheel Weight 1 X 250 Kgf
Rear Wheel Weights 1 + 1 X 250 Kgf
Rear Wheel Weights 1 + 1 + 1 X 250 Kgf
Rear Wheel Weights 1 X 250 Kgf - With Steel Rim
Rear Wheel Weights 1 + 1 X 250 Kgf - With Steel Rim
Rear Wheel Weights 1 + 1 + 1 X 250 Kgf - With Steel Rim
Rear Wheels - Fixing By Cone - Shaft Diameter 110 Mm
Wheel Wedges
Implement Drive System
Pto Shaft - Flange
Engine P.T.O. - Shaft
Guard Power Take Off - Sae Standard
Engine P . T . O - Flange
Front Pto - Drive
Front Pto - 6 Splines
Housing - (Components)
Ipto Clutch - (Components)
Lift Cylinders Feeding
Angle Sensor - Guard
Power Lift
Sensor
Linkage
Levelling Box - Without Automatic Hitch
Top Link With Hook End - Category 3
Top Link With Hook End - Category 4
Top Link With Hook End - Toggle
Top Link With Hook End - Hydraulic
Top Link Lock - Support
Sensing Pin
Lower Bar With Hook - Category 3
Lower Bar With Hook - Category 4
Lower Bar With Hook - Toggle
Lower Bar With Hook - Cone Ball
Tube Stabilizers
Automatic Stabilisers
Swinging Drawbar Support - With Hay Ladder And Drawbar Support
Swinging Drawbar - Iso Standard - With Hay Ladder
Swinging Drawbar Support - Ladder
Swinging Drawbar Support - Sae Standard
Swinging Drawbar With Peak
Swinging Drawbar - Ball And Socket Hitch
Swinging Drawbar - Sae Standard
Trailer Hitch - Germany
Trailer Hitch - Italy
Trailer Hitch - Except Italy
Without Automatic Hitch - Without Remote Control
Front Linkage 5000 Kg
Front Linkage - Hydraulic Lines
Front Linkage - Controls And Switches
Precision Farming Systems
Agcommand - Telemetry Antenna
Agcommand - Telemetry Module
Autoguide Bracket Installation
Auto-Guide Installation - Auto-Guide Ready
Novatel - Auto-Guide Installation - Centimetric+Rtk
Novatel - Auto-Guide Installation - Submetric Gprs
Trimble - Auto-Guide Installation - Centimetric+Rtk
Trimble - Auto-Guide Installation - Submetric Gprs
Fuel Pipes - Water Fuel Separator
Fuel Heater - Kit
Heater Engine Block - Kit
Air Intake - Kit
Belt Shield Installation - Kit
Locking Cap - Kit
Trailor Brake - Kit
Load Sensing Booster Kit Installation - Kit
Coupler - Quick Attach Kit
Axle Kit Follower
Auxiliary Distributor - Kit
Hydraulic Coupling - Kit
Abs - Plug
Reverse - Kit
Aboard Computer - Stand Alone Kit
Aboard Computer - Stand Alone Kit - With Isobus
Novatel - Autoguide Kit
Trimble - Autoguide Kit
Software Group - Kit
Appliance Bracket Boarded For Cab - Kit
Additional Heater - Kit
Front Pto - Kit
Front Pto Case - Kit
Hydraulic Top Link - (Components)
Hydraulic Top Link - Kit
Swinging Drawbar - Kit
Drawbar And Hitch - Kit
Swinging Drawbar With Peak - Kit
Trailer Hitch - Ball Pin Traction Kit
Trailer Hitch - Switzerland Version Kit
Front Linkage 5000 Kg - Kit
Front Linkage - Kit
