Valtra Tractor S354 Parts Catalog 6246112
Brand: Valtra
Model: Valtra S354 Tractor
Serial Number: E188045 - VKKVP47GAHB244065
Number of Pages: 1004 Pages
Engine V835277503 84 Awf
Engine Assemblies - Engine Serial Number Range A51786-B53934
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Camshaft And Valve Mechanism
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
High Pressure Turbocharger
Low Pressure Turbocharger And Icac
Exhaust Gas Recirculation (Egr) - Up To Engine Serial Number B52897
Exhaust Gas Recirculation (Egr) - Starting From Engine Serial Number B53932
Oil Pump And Sump
Oil Cooler And Filter - Up To Engine Serial Number B52820
Oil Cooler And Filter - Starting From Engine Serial Number B52879
Coolant Piping - Up To Engine Serial Number B52897
Coolant Piping - Starting From Engine Serial Number B53932
Coolant Pump And Thermostat
Fuel Injection System
Fuel Filters - Starting From Engine Serial Number B50000 Jld291001
Electronic Engine Management
Belt Tensioner
Exhaust Aftertreatment
Engine Overhaul Parts
Special Overhaul Parts
Engine V835277610 84 Awf
Engine Assemblies - Engine Serial Number Range B53935-C55777
Cylinder Block - Up To Engine Serial Number C52250
Cylinder Block - Starting From Engine Serial Number C52251
Valve Rocker Cover - Up To Engine Serial Number B65459
Valve Rocker Cover - Starting From Engine Serial Number B65460
Coolant Piping - Up To Engine Serial Number B60075
Coolant Piping - Starting From Engine Serial Number B60076
Engine V835277777 84 Awf-Hla
Engine Assemblies - Engine Serial Number Range C58130-C69520
Coolant Piping
Fuel Filters
Engine V835277748 84 Awf-Hla
Engine Assemblies - Engine Serial Number Range C56626-E62458
Cylinder Block - Up To Engine Serial Number C66572
Cylinder Block - Starting From Engine Serial Number C73097
Exhaust Manifold - M12 Turbo Mounting Stud Bolts
High Pressure Turbocharger - M12 Turbo Mounting Stud Bolts
Low Pressure Turbocharger And Icac - M12 Turbo Mounting Stud Bolts
Oil Cooler And Filter - Up To Engine Serial Number D75011
Oil Cooler And Filter - Starting From Engine Serial Number D75012 Jld291001
Belt Tensioner - Up To Engine Serial Number D79603
Belt Tensioner - Starting From Engine Serial Number D79604
Engine Installation
Engine & Equipment
Alternator Bracket And Belt - Engine With Air Compressor - 2 Alternators
Heater Engine Block - 220 V
Cab Heating System - Engine Part
Fuel Tank & Attachments - Tier 3 4f Engine
Fuel Tank (Components) - Engine Tier 3 & 4f
Def Tank - (Components)
Additional Fuel Tank - (Components)
Fuel Tank - Breather Line
Fuel System
Cooling System - Air Conditioned Installation
Cooling System - Engine
Oil Recovery
Air Filter - Dry - Dual Element
Exhaust - Vertical - Engine Tier 4f Stage 4
Exhaust - Vertical - (Components)
Pollution Control
Throttle Controls
Weight Frame And Tow Pin
Belly Weight
Front Axle 4 Wheel Drive - Bracket
Front Axle 4 Wheel Drive - Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle 4 Wheel Drive - Clutch
Front Axle 4 Wheel Drive - Housing
Front Axle 4 Wheel Drive - Final Drive
Auto Guide Sensor - Suspended Axle
Hydraulic Valve Block - Suspended Axle
Steering Wheel & Telescopic Column
Steering Wheel & Telescopic Column - Driving Position Opposite
Steering Column - (Components)
Steering Hydraulic Lines
Steering Hydraulic Lines - With Auto-Guide
Auto Guide
Steering Pump - (Components)
Engine - Gear Box Assembling - Damper
Transmission - Housing
Gear Box
Inner Housing
Group Gear Shifting
Transmission Control - Emergency Control - Drive Line
Transmission Control - Emergency Control - Range
Control Armrest
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Rear Axle Housings - Inner Final Drive Gear
Angle Sensor
Brake Pedals
Brakes High Pressure - Pipes And Fitting - Pipes And Fitting
Brake Valve - (Components)
Trailor Brake - Pneumatic Feeding
Trailor Brake
Hydraulic Brake Assy
Disc Brakes
Park Brake - With Trailer Brake
Park Brake - Without Trailer Brake
Handbrake - Valve Components
Compressed Air System
Air Compressor
Air Compressor - (Components)
Front Suspension Hydraulic Lines
Pump Drive
Oil Pump - Filter
Feed Pump - System Comfort
Gear Box Lubrication
Hydraulic Valve Block - Pressure Filter
Hydraulic Valve Block - Solenoid Valve
Auxiliary Hydraulics - Filter
Pump - (Components)
Hydraulic Block
Hydraulic Block - (Components)
Auxiliary Distributors Installation
Auxiliary Distributor - 4 Distributors Electrodynamique
Auxiliary Distributor - 6 Distributors Electrodynamique
Auxiliary Distributor - (Components)
Hydraulic Lift Valve - With Front Linkage
Hydraulic Lift Valve - Without Front Loader
Hydraulic Lift Valve - (Components)
Hydraulic Coupler - 4 Distributors Electrodynamique
Hydraulic Coupler - 6 Distributors Electrodynamique
Hydraulic Coupler - (Components)
Hydraulic Coupler
Oil Recovery - 4 Distributors Electrodynamique
Oil Recovery - 5 Distributors Electrodynamique
Oil Recovery - 6 Distributors Electrodynamique
Batteries & Cables
Fuse Box - (Components)
Instrument Panel & Instruments
Lighting & Power Shuttle Drive
Side Console Switches
Engine Harness - Engine Tier 4f
External Controls Fitted On The Rear Fenders
Instrument Panel Harness
Plate Relay & Fuse Holder
Plate Relay & Fuse Holder - Decal
Roof Harness
Auto-Guide
Field Lights Harness
Pillar Harness
Front Lighting Harness
Rear Lightning Harness
Harness Isobus
Harness Front Electrical Plug
Electronic Lift - Console
Spool Valves Harness - 6 Spool Valves
Spool Valves Harness - 4 Spool Valves
Aboard Computer
Speed Radar
Auto-Guide - Autoguide 3000
Plate Lighting Equipement
Front Axle Harness
Agcommand - Telemetry Antenna
Electronic Equipment - Sensors
Control Box Harness & Cab Controls
Transmission Main Harness
Transmission Main Harness - Semi Active Suspension
Front Lighting - Road Lights
Handrail Lighting
Rear Lighting
Roof Lighting
Working Light
Traffic Warning
Traffic Warning - Driving Position Opposite
Rotating Light
Cab Mountings - With Suspension
Tractor Cab
Glass
Doors - Left Side
Doors - Right Side
Rear Window Mechanism
Roof
Heating Hatchway
Roof - Cladding
Tractor Cab - Cladding
Instrument Panel Cladding
Instrument Panel Cladding - Driving Position Opposite
Tractor Cab - Cab Insulation
Tractor Cab - Fenders
Air Conditioner - Hose
Air Conditioner - Manual Air Conditioner
Air Conditioner - Automatic Air Conditioner
Air Conditioner - Additional Heater
Cab Filter
Heater Control - Manual Air Conditioner
Heater Control - Automatic Air Conditioner
Canopy
Windscreen Wiper
Radio Installation
Electrical Plug & Cigar Lighter
Internal Mirrors
External Mirrors
Electric Rear View Mirror
Seat Suspension - (Components)
Seat - (Components)
Secondary Seat
Sheet Metal - Grille
Sheet Metal - Hood
Sheet Metal - Hood Frame
Footstep
Tool Box
Literature
Literature - Auto Guide - Basic
Emblems
Decal Hydraulic Controls
Decals - Safety
Speed Charts
Front Disc Wheels - 4 Wheels Drive
Adjust. Front Wheels - 4 Wheels Drive
Front Axle 4 Wheel Drive - Mudguards And Supports
Disc Wheels Rear - Wheel Hub 10 Holes Assembling
Adjustab.Rear Wheels - Wheel Hub 10 Holes Assembling
Rear Wheels - Fixing By Cone - Shaft Diameter 110 Mm
Rear Wheel Weight 1 X 250 Kgf
Rear Wheel Weights 1 X 250 Kgf - With Steel Rim
Rear Wheel Weights 1 + 1 X 250 Kgf
Rear Wheel Weights 1 + 1 X 250 Kgf - With Steel Rim
Rear Wheel Weights 1 + 1 + 1 X 250 Kgf - With Steel Rim
Wheel Wedges
Implement Drive System
Independant Power Take Off Clutch
Engine P.T.O.
Engine P . T . O - Pipes
Guard Power Take Off - Iso Standard
Front Pto - Drive
Front Pto - Housing
Ipto Clutch - (Components)
Front Pto - Pump
Lift Arms
Lift Cylinders
Lift Cylinders Feeding
Linkage
Levelling Box
Top Link With Hook End
Top Link With Hook End - Hydraulic
Top Link Lock
Sensing Pin
Transmitter
Lower Bar With Hook
Tube Stabilizers
Automatic Stabilisers
Swinging Drawbar Support - Ladder
Swinging Drawbar Support - With Hay Ladder And Drawbar Support
Swinging Drawbar
Swinging Drawbar - Iso Standard
Swinging Drawbar - With Automatic Hitch
Swinging Drawbar With Peak - Up To Serial Number G118037
Swinging Drawbar With Peak - From Serial Number G118038
Swinging Drawbar - Ball And Socket Hitch
Swinging Drawbar Tidying
Trailer Hitch - Except Italy
Trailer Hitch - Italy
Trailer Hitch - Germany
Trailer Hitch Automatic - (Components)
Trailer Hitch Automatic - With Remote Control
Without Automatic Hitch - Without Remote Control
Front Linkage 5000 Kg
Front Linkage
Front Linkage - Hydraulic Lines
Brackets - Without Front Quick Couplers
Front Rear Loaders
Loader - Hydraulic
Loader - Frame
Fuel Pipes - Water Fuel Separator
Heater Engine Block - Kit
Fuel Heater - Kit
Belt Shield Installation - Kit
Locking Cap - Kit
Load Sensing Booster Kit Installation - Kit
Relief Valve Kit
Trailor Brake - Kit
Coupler - Quick Attach Kit
Auxiliary Distributor - Kit
Hydraulic Coupler - Kit
Agcommand - Telemetry Antenna - Kit
Video Camera Kit
Lighting Equipment - Rear
Appliance Bracket Boarded For Cab - Kit
Additional Heater - Kit
Front Axle 4 Wheel Drive - Front Mudguards Kit
Front Pto - Kit
Front Pto Case - Kit
Front Linkage 5000 Kg - Kit
Front Linkage - Kit
Drawbar And Hitch - Kit
Swinging Drawbar With Peak - Kit
Trailer Hitch - Ball Pin Traction Kit
Front Loader - Kit
Dealer Stocking List
Brand: Valtra
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
Oil Pump And Sump
Belt Tensioner
Coolant Piping
Fuel Filters
Engine Installation
Engine & Equipment
Fuel System
Oil Recovery
Pollution Control
Throttle Controls
Belly Weight
Auto Guide
Gear Box
Inner Housing
Group Gear Shifting
Control Armrest
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Angle Sensor
Brake Pedals
Trailor Brake
Disc Brakes
Air Compressor
Pump Drive
Oil Pump - Filter
Pump - (Components)
Hydraulic Block
Hydraulic Coupler
Batteries & Cables
Roof Harness
Auto-Guide
Pillar Harness
Harness Isobus
Aboard Computer
Speed Radar
Front Axle Harness
Handrail Lighting
Rear Lighting
Roof Lighting
Working Light
Traffic Warning
Rotating Light
Tractor Cab
Glass
Doors - Left Side
Doors - Right Side
Roof
Heating Hatchway
Roof - Cladding
Cab Filter
Canopy
Windscreen Wiper
Radio Installation
Internal Mirrors
External Mirrors
Seat - (Components)
Secondary Seat
Sheet Metal - Hood
Footstep
Tool Box
Literature
Emblems
Decals - Safety
Speed Charts
Wheel Wedges
Engine P.T.O.
Front Pto - Drive
Front Pto - Housing
Front Pto - Pump
Lift Arms
Lift Cylinders
Linkage
Levelling Box
Top Link Lock
Sensing Pin
Transmitter
Lower Bar With Hook
Tube Stabilizers
Swinging Drawbar
Front Linkage
Front Rear Loaders
Loader - Hydraulic
Loader - Frame
Fuel Heater - Kit
Locking Cap - Kit
Relief Valve Kit
Trailor Brake - Kit
Video Camera Kit
Front Pto - Kit
Front Linkage - Kit
Front Loader - Kit
