Valtra Tractor S293 Parts Catalog 3906330
Brand: Valtra
Model: Valtra S293 Tractor (Tier 4I/ 84 AWI Engine - Tier 2/ 84 WI Engine)
Serial Number: B194028 - G257052
Number of Pages: 1021 Pages
Engine & Equipment
Engine & Equipment - Engine Tier 2
Cylinder-Block
Cylinder-Block - Engine Tier 2
Timing Gear Housing
Flywheel & Flywheel Housing
Crankshaft, Pistons & Piston Rod
Camshaft & Valve Mechanism
Cylinder Head - Engine Tier 2
Cylinder Head Cover
Oil Sump
Oil Sump - Engine Tier 2
Oil Cooler & Filter
Engine Breather
Injection System
Low Pressure Fuel System
Intake & Exhaust Manifold
Turbocharger - Pipes
Electronic Engine Management
Belt Tensioner
Engine Parts
Engine Repair Kits - Piston- Cylinder Head With Valves
Engine Gaskets Sets
Alternator And Bracket - Engine With Air Compressor
Heater Engine Block - 220 V
Heater Engine Block - 220 V - Engine Tier 2
Cab Heating System - Engine Tier 2
Cab Heating System - Engine Part
Fuel Tank & Attachments
Fuel Tank & Attachments - Engine Tier 2
Fuel Tank (Components)
Fuel Tank (Components) - Engine Tier 2
Urea Tank - (Components)
Additional Tank - (Components)
Fuel Tank - Connecting Pipe
Fuel Tank - Breather Line
Breather Line - Engine Tier 2
Fuel System
Fuel System - Fuel Filter
Cooling System - Air Conditioned Installation
Air Conditioner Compressor - (Components)
Cooling System - Engine
Air Cooler
Oil Recovery
Oil Recovery - Engine Tier 2
Air Filter - Dry - Dual Element
Exhaust - Vertical - Engine Tier 2
Exhaust - Vertical - (Components)
Exhaust - Vertical
Pollution Control
Throttle Controls
Weight Frame And Tow Pin
Front Weight
Belly Weight
Front Axle 4 Wheel Drive - Bracket
Front Axle 4 Wheel Drive - Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle 4 Wheel Drive - Clutch
Front Axle 4 Wheel Drive - Housing
Front Axle 4 Wheel Drive - Final Drive
Front Axle 4 Wheel Drive - Auto Guide Sensor
Hydraulic Valve Block - Suspended Axle
Steering Wheel & Telescopic Column
Steering Column - (Components)
Steering Hydraulic Lines - With Auto-Guide
Steering Pump - (Components)
Auto Guide
Steering Pump - Auto Guide
Front Spacer
Clutch Control
Transmission - Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Transmission Control - Emergency Control - Drive Line
Transmission Control - Emergency Control - Range
Control Armrest
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Rear Axle Housings - Inner Final Drive Gear
Lift Arms
Angle Sensor
Brake Pedals
Brakes High Pressure - Pipes And Fitting - Pipes And Fitting
Brake Valve - (Components)
Trailor Brake - Pneumatic Feeding
Trailor Brake
Disc Brakes
Handbrake
Compressed Air System
Air Compressor
Air Compressor - (Components)
Front Suspension Hydraulic Lines
Hydraulic Brake Assy
Pump Drive
Oil Pump - Filter
Feed Pump - System Comfort
Gear Box Lubrication
Hydraulic Circuit - Transmission
Hydraulic Valve Block - Pressure Filter
Hydraulic Valve Block - Solenoid Valve
Auxiliary Hydraulics
Hydraulic Block
Hydraulic Block - (Components)
Auxiliary Distributors Installation
Auxiliary Distributor - 4 Distributors Electrodynamique
Auxiliary Distributor - 6 Distributors Electrodynamique
Auxiliary Distributor - (Components)
Hydraulic Lift Valve
Hydraulic Lift Valve - (Components)
Hydraulic Coupler - 4 Distributors Electrodynamique
Hydraulic Coupler - 6 Distributors Electrodynamique
Hydraulic Coupler - (Components)
Hydraulic Coupler
Batteries & Cables
Fuse Box - (Components)
Instrument Panel & Instruments
Lighting & Power Shuttle Drive
Side Console Switches
External Controls Fitted On The Rear Fenders
Engine Harness - Tier 4i Engine
Engine Harness - Tier2 Engine
Instrument Panel Harness
Plate Relay & Fuse Holder
Plate Relay & Fuse Holder - Decal
Roof Harness
Field Lights Harness
Auto-Guide
Pillar Harness
Front Lighting Harness
Rear Lightning Harness
Harness Front Electrical Plug
Electronic Lift - Console
Spool Valves Harness - 6 Spool Valves
Spool Valves Harness - 4 Spool Valves
Auto-Guide - Autoguide 3000
Aboard Computer
Plate Lighting Equipement
Speed Radar
Electronic Equipment - Sensors
Harness Isobus
Front Axle Harness - Without Front Linkage
Front Axle Harness
Control Box Harness & Cab Controls
Transmission Main Harness
Transmission Main Harness - Semi Active Suspension
Lighting Equipment - Front
Roof Lighting
Working Light
Traffic Warning
Traffic Warning - Driving Position Opposite
Lighting Equipment - Rear
Rotating Light
Cab Mountings - With Suspension
Tractor Cab
Doors - Left Side
Doors - Right Side
Glass
Rear Window Mechanism
Emergency Equipment
Roof
Heating Hatchway
Tractor Cab - Cladding
Instrument Panel Cladding
Instrument Panel Cladding - Driving Position Opposite
Tractor Cab - Cab Insulation
Tractor Cab - Fenders
Air Conditioner - Hose
Air Conditioner
Cab Filter
Heater Control
Windscreen Wiper
Canopy
Radio Installation
Electrical Plug & Cigar Lighter
Internal Mirrors
External Mirrors
Electric Rear View Mirror
Seat - (Components)
Seat Suspension - (Components)
Secondary Seat
Seat Belt
Sheet Metal - Grille
Sheet Metal - Hood
Sheet Metal - Hood Frame
Tool Box
Footstep
Literature
Literature - Auto Guide - Basic
Emblems
Speed Charts
Decals - Safety
Front Disc Wheels - 4 Wheels Drive
Adjust. Front Wheels - 4 Wheels Drive
Front Axle 4 Wheel Drive - Mudguards And Supports
Disc Wheels Rear - Wheel Hub 10 Holes Assembling
Adjustab.Rear Wheels - Wheel Hub 10 Holes Assembling
Rear Wheels - Fixing By Cone - Shaft Diameter 110 Mm
Rear Wheel Weight 1 X 250 Kgf
Rear Wheel Weights 1 X 250 Kgf - With Steel Rim
Rear Wheel Weights 1 + 1 X 250 Kgf
Rear Wheel Weights 1 + 1 X 250 Kgf - With Steel Rim
Rear Wheel Weights
Wheel Wedges
Implement Drive System
Independant Power Take Off Clutch
Engine P.T.O.
Engine P . T . O - Pipes
Guard - Pto
Front Pto - Drive
Front Pto - Housing
Front Pto - Pump
Ipto Clutch - (Components)
Lift Cylinders
Lift Cylinders Feeding
Linkage
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Lower Bar With Toogle
Top Link With Hook End
Top Link With Hook End - Hydraulic
Tube Stabilizers
Automatic Stabilisers
Swinging Drawbar Support
Swinging Drawbar
Swinging Drawbar - With Automatic Hitch
Swinging Drawbar With Peak
Swinging Drawbar - Ball And Socket Hitch
Swinging Drawbar Tidying
Long Hay Ladder
Long Hay Ladder - Without Automatic Hitch
Hitch - Italy
Hitch
Hitch - Germany
Hitch - Europe Only
Trailer Hitch Automatic - With Remote Control
Without Automatic Hitch - Without Remote Control
Front Linkage 5000 Kg
Front Linkage
Front Linkage - Hydraulic Lines
Front Rear Loaders
Loader - Frame
Loader - Hydraulic
Transmission Heater
Heater Engine Block - Kit
Fuel Heater - Kit
Belt Shield Installation - Kit
Air Intake - Kit
Locking Cap - Kit
Fuel Filter Water Separator
Fuel Pipes - Water Fuel Separator
Front Pto
Loader
Trailer Hitch
Trailer Hitch - Ball Pin Traction Kit
Auxiliary Distributor - Kit
Relief Valve Kit
Trailor Brake - Kit
Autoguide 3000 - Complemantary Products
Video Camera Kit
Appliance Bracket Boarded For Cab - Kit
Front Axle 4 Wheel Drive - Front Mudguards Kit
Dealer Stocking List
Brand: Valtra
Engine & Equipment
Cylinder-Block
Timing Gear Housing
Cylinder Head Cover
Oil Sump
Oil Cooler & Filter
Engine Breather
Injection System
Belt Tensioner
Engine Parts
Engine Gaskets Sets
Fuel System
Air Cooler
Oil Recovery
Exhaust - Vertical
Pollution Control
Throttle Controls
Front Weight
Belly Weight
Auto Guide
Front Spacer
Clutch Control
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Control Armrest
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Lift Arms
Angle Sensor
Brake Pedals
Trailor Brake
Disc Brakes
Handbrake
Air Compressor
Pump Drive
Oil Pump - Filter
Hydraulic Block
Hydraulic Coupler
Batteries & Cables
Roof Harness
Auto-Guide
Pillar Harness
Aboard Computer
Speed Radar
Harness Isobus
Front Axle Harness
Roof Lighting
Working Light
Traffic Warning
Rotating Light
Tractor Cab
Doors - Left Side
Doors - Right Side
Glass
Emergency Equipment
Roof
Heating Hatchway
Air Conditioner
Cab Filter
Heater Control
Windscreen Wiper
Canopy
Radio Installation
Internal Mirrors
External Mirrors
Seat - (Components)
Secondary Seat
Seat Belt
Sheet Metal - Hood
Tool Box
Footstep
Literature
Emblems
Speed Charts
Decals - Safety
Rear Wheel Weights
Wheel Wedges
Engine P.T.O.
Guard - Pto
Front Pto - Drive
Front Pto - Housing
Front Pto - Pump
Lift Cylinders
Linkage
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Swinging Drawbar
Long Hay Ladder
Hitch - Italy
Hitch
Hitch - Germany
Hitch - Europe Only
Front Linkage
Front Rear Loaders
Loader - Frame
Loader - Hydraulic
Transmission Heater
Fuel Heater - Kit
Air Intake - Kit
Locking Cap - Kit
Front Pto
Loader
Trailer Hitch
Relief Valve Kit
Trailor Brake - Kit
Video Camera Kit
