Valtra Tractor S274 Smart Touch Parts Catalog 6246534
Brand: Valtra
Model: Valtra S274 (Stage 5) Smart Touch Tractor
Serial Number: KB154015 - 999999
Number of Pages: 998 Pages
Engine Acw5310130 84 Lfvc
Instructions - Parts Lists And Illustrations
Engine Identification
Engine Assemblies - Engine Serial Number Range Kld034004-Kld414012
Cylinder Block - Service Parts
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Valve Mechanism - Service Parts
Cylinder Head - Service Parts
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
High Pressure Turbocharger
High Pressure Turbocharger - Service Parts
Low Pressure Turbocharger
Interstage Charge Air Cooler (Icac)
Exhaust Gas Recirculation (Egr) - Up To Engine Serial Number Kld131004
Exhaust Gas Recirculation (Egr) - Starting From Engine Serial Number Kld131005
Oil Pump And Sump
Oil Pump - Service Parts
Oil Cooler And Filter
Crankcase Ventilation
Crankcase Ventilation - Service Parts
Coolant Piping
Coolant Pump And Thermostat
Coolant Pump - Service Parts
Fuel Injection System
Fuel Injection Pump - Service Parts
Fuel Filters
Fuel Filters - Service Parts
Electronic Engine Management
Belt Tensioner
Exhaust Aftertreatment - Service Parts
Engine Gasket Kits
Engine Overhaul Parts
Special Overhaul Parts
Engine Acw531013a 84 Lfvc
Engine Assemblies
Engine Installation
Engine, Startermotor And Shields
Fan & Shroud
Alternator Bracket And Belt - Engine With Air Compressor - 2 Alternators
Heater Engine Block - 220 V
Cab Heating System - Engine Part
Fuel Tank (Components)
Fuel Tank & Attachments - Engine Tier 5 Stage 5
Def Tank (Components)
Fuel System - Without Front Loader
Air Conditioned Installation
Cooling System - Engine
Cooling System - Plugs
Oil Recovery
Air Filter - Dry - Dual Element
Exhaust - Vertical - Engine Stage 5
Exhaust - Vertical - (Components)
Pollution Control - Engine Stage 5
Throttle Controls
Throttle Controls - Driving Position Opposite
Weight Frame And Tow Pin - With Belly Weight - 820 Kg
Weight Frame And Tow Pin - Chain And Pin
Guard And Transmission Shaft - Suspended Axle
Front Axle 4 Wheel Drive - Bracket - Plugs
Bracket
Bearing Carrier - Suspended Axle
Suspended Axle - Type 770 638
Housing - Suspended Axle
Suspended Axle - Type 770 639
Final Drive - Suspended Axle
Double Joint - (Components)
Front Axle 4 Wheel Drive - Hydraulic Valve Block
Auto Guide Sensor - Suspended Axle
Steering Wheel & Telescopic Column
Steering Wheel & Telescopic Column - Driving Position Opposite
Steering Column - (Components)
Steering Hydraulic Lines - Tube Mounting Supports
Steering Hydraulic Lines - Load Sensing Hydraulic
Steering Hydraulic Lines - Auto Guide
Steering Pump - (Components)
Engine - Gear Box Assembling - Damper
Gearbox-Housing
Rear Axle Housing
Oil Level Indicator
Final Drive
Disc Brake
Actuating Cylinder
Gear
Suspension
Suspension - Gear Box
Bevel Drive
Duct Plate
Adjusting Device
Pipelines - Transmission
Piping - Gear
Group Gear Shifting
Shifting
Engine P.T.O.
Pump Drive
Lube Oil Pump
Feed Pump
Gear Box Lubrication
Valve Unit
Valve Syst.Comfort
Tubes System Comfort
Front Wheel Drive Constant
Front Wheel Drive
Control Armrest
Armrest - Components
Control Armrest - Module Fingertip For Distrib With Electrodyn Control
Control Armrest - Without Front Pto Switch
Control Armrest - Front Pto Switch
Brake Pedals
Brakes High Pressure - Pipes And Fitting - With Hydraulic Pneumatic Braking Of Trailer
Brakes High Pressure - Pipes And Fitting - Without Hydraulic Trailer Brakes
Brakes High Pressure - Pipes And Fitting - With Pneumatic Braking Of Trailer
Brakes High Pressure - Pipes And Fitting - Driving Position Opposite
Brake Valve - (Components)
Trailor Brake
Trailor Brake - Pneumatic Feeding
Park Brake - Without Hydraulic Braking Of Trailer
Park Brake - With Hydraulic Braking Of Trailer
Park Brake - Valve Components
Compressed Air System
Air Compressor
Air Compressor - (Components)
Front Suspension Hydraulic Lines
Auxiliary Distributors Installation - With Hay Ladder - With Hydraulic Coupling
Lift Cylinders Feeding
Auxiliary Hydraulics - Cab Suspension
Auxiliary Distributor - 4 Distributors Electrodynamique
Auxiliary Distributor - 6 Distributors Electrodynamique
Spacer - (Components)
Distributor (Components)
Auxiliary Front Spool Valves - With Hydraulic Coupling
Hydraulic Lift Valve - Without Front Linkage
Hydraulic Lift Valve - (Components)
Distributor - (Components)
Hydraulic Coupler - 4 Distributors Electrodynamique
Hydraulic Coupler - 6 Distributors Electrodynamique
Hydraulic Coupler - (Components)
Hydraulic Coupler
Oil Recovery - 4 Distributors Electrodynamique
Oil Recovery - 6 Distributors Electrodynamique
Auxiliary Hydraulics - Without Automatic Hitch
Auxiliary Hydraulics - With Automatic Hitch
Auxiliary Hydraulics - Pump
Pump - (Components)
Auxiliary Hydraulics - Filter
Pump Installation
Hydraulic Block
Hydraulic Block - (Components)
Without Front Quick Couplers
4 Quick Couplers - Hydraulic Lines
4 Quick Couplers - Free Return
Batteries & Cables - Battery Box
Batteries & Cables - Engine Tier 2 Tier 4f Stage 5
Fuse Box - Engine Tier 2 Tier 4f Stage 5
Plate Relay & Fuse Holder
Instrument Panel & Instruments
Instrument Panel Harness
Instrument Panel & Instruments - Miscellaneous
Lighting & Power Shuttle Drive - Without Reverse Drive System
Lighting & Power Shuttle Drive - Reverse Drive System
Side Console Switches
Side Console Switches - Cee
Side Console Switches - Start Key
Side Console Switches - External Mirrors
Side Console Switches - Electric Rear View Mirror
External Controls Fitted On The Rear Fenders
External Controls Fitted On The Rear Fenders - Lift Control
Engine Harness - Engine Stage 5
Engine Harness - Alternator
Main Harness - Transmission
Main Harness - Cab
Cab Mounting - Sensor And Wiring
Aboard Computer
Aboard Computer - Datatronic 5
Roof Harness - Manual Air Conditioner
Roof Harness - Automatic Air Conditioner
Roof Harness - Electric Rear View Mirror
Front Axle Harness - With Suspended Front Axle
Front Harness - With 7 Pin Socket
Front Lighting Harness
Front Lighting - Working Light
Front Lighting - Working Light - Led
Front Lighting - Road Lights - Led
Handrail Lighting - Harness
Handrail Lighting
Handrail Lighting - Road Lights & Auxiliary Lights Led
Handrail Lighting - Germany
Roof Lighting
Roof Lighting - Standard Roof
Rear Lightning Harness - Cee
Rear Lightning Harness - Sae Standard
Rear Lighting
Rear Lighting Equipment - Italy
Auxiliary Lights - Fenders
Flasher Unit & Harness - Cee
Flasher Unit & Harness - Sae Standard
Rotating Light - Standard Roof
Rear Reflectors
Spool Valves Harness - 4 Spool Valves
Spool Valves Harness - 6 Spool Valves
Isobus Harness
Isobus Harness - Cee
Isobus Harness - Sae Standard
Speed Radar
Transmitter
Control
Cab Mounting
Cab Mounting - Guards
Cab Mountings - With Suspension
Tractor Cab
Tractor Cab - Driving Position Opposite
Glass
Doors - Left Side
Doors - Right Side
Rear Window Mechanism
Roof
Roof - Cladding
Tractor Cab - Cladding - Dressing Roof
Tractor Cab - Cladding - Right Side
Tractor Cab - Cladding - Sub Console Tidying
Tractor Cab - Cladding - Left Side
Tractor Cab - Cladding - Driving Position Opposite
Instrument Panel Cladding
Instrument Panel Cladding - Driving Position Opposite
Tractor Cab - Cab Insulation
Tractor Cab - Plug
Tractor Cab - Fenders - For Wheelbase 2,45 M
Fenders Extension
Tractor Cab - Fenders - Fenders Extension - For Wheelbase 2,45 M
Air Conditioner - Hoses - Left Side
Air Conditioner - Hoses - Right Side
Air Conditioner - Hoses - Without Additional Heater
Air Conditioner - Hoses - High Cold
Air Conditioner - Manual Air Conditioner
Air Conditioner - Automatic Air Conditioner
Air Conditioner - Additional Heater
Air Conditioner - Sensor
Cab Filter
Heater Control - Manual Air Conditioner
Heater Control - Automatic Air Conditioner
Canopy
Windscreen Wiper
Radio Installation
Radio Installation - Mp3-Cd Radio + Usb + Bluetooth
Radio Installation - Mp3-Cd Radio + Usb + Bluetooth + Dab
Electrical Plug & Cigar Lighter - Eec Standard
Ashtray
Internal Mirrors
Internal Mirrors - Rear View Mirror
External Mirrors - Wide Angle
Electric Rear View Mirror - Wide Angle
Tools - Mechanical Transmission Command
Seat - Deluxe
Seat - Reverse Drive
Seat - (Components)
Seat Suspension - (Components)
Secondary Seat - With Safety Belt
Secondary Seat - (Components)
Sheet Metal - Grille - Stage 5
Sheet Metal - Hood - Stage 5
Sheet Metal - Hood Frame - Stage 5
Footstep - Left Side
Footstep - Right Side
Toolbox
Literature - Engine Stage 5
Literature - Autoguide
Emblems
Decal Hydraulic Controls
Speed Charts
Decals - Safety
Plate Relay & Fuse Holder - Decal
Front Disc Wheels - 18 X 28
Front Disc Wheels - 20 X 30
Front Disc Wheels - 23 X 34
Adjust. Front Wheels - 18 X 28
Adjust. Front Wheels - 20 X 30
Adjust. Front Wheels - 23 X 30
Front Axle - 4 Wheel Drive - Wheels Fixing
Front Axle 4 Wheel Drive - Rigid Mudguards Width 620mm And Supports
Front Axle 4 Wheel Drive - Pivoting Mudguards Width 700mm And Supports
Mudguards And Supports - Pivot
Disc Wheels Rear - 20 X 38 - Offset 75mm
Disc Wheels Rear - 23 X 38
Disc Wheels Rear - 23 X 42
Disc Wheels Rear - 25 X 42
Adjustab.Rear Wheels - 23 X 42
Rear Wheels - Fixing By Cone - Shaft Diameter 110 Mm
Rear Wheel Weights 1 X 250 Kgf - With Steel Rim
Rear Wheel Weights 1 + 1 X 250 Kgf - With Steel Rim
Wheel Wedges
Implement Drive System
Engine P . T . O - Flange
Pto Shaft - Flange
Engine P.T.O. - Protection
Guard Power Take Off - Iso Standard
Front Pto - Drive
Front Pto
Front Pto - Housing
Ipto Clutch - (Components)
Angle Sensor - Guard
Power Lift
Sensor
Linkage
Levelling Box - Without Automatic Hitch
Levelling Box - With Automatic Hitch
Top Link With Hook End - Category 3
Top Link With Hook End - Toggle
Top Link Lock - Support
Sensing Pin
Lower Bar With Hook - Category 3
Lower Bar With Hook - Toggle
Lower Bar With Hook - Cone Ball
Top Link With Hook End - Hydraulic
Tube Stabilizers
Automatic Stabilisers
Swinging Drawbar Support - Ladder
Swinging Drawbar Support - With Hay Ladder And Drawbar Support
Swinging Drawbar - Iso Standard
Swinging Drawbar - Iso Standard - With Hay Ladder
Swinging Drawbar - With Automatic Hitch
Swinging Drawbar - Ball And Socket Hitch
Swinging Drawbar With Peak
Swinging Drawbar Tidying - Front
Trailer Hitch - Germany
Trailer Hitch - Except Italy
Trailer Hitch - Italy
Without Automatic Hitch - Without Remote Control
Trailer Hitch Automatic - Controls And Switches
Trailer Hitch Automatic - With Remote Control
Trailer Hitch Automatic - (Components)
Front Linkage 5000 Kg
Front Linkage - Hydraulic Lines
Front Linkage - Controls And Switches
Plugs - Without Pto
Precision Farming Systems
Auto-Guide Installation - Auto-Guide Ready
Autoguide Bracket Installation
Decal - Auto Guide
Trimble - Auto-Guide Installation - Submetric Gprs
Novatel - Auto-Guide Installation - Submetric Gprs
Novatel - Auto-Guide Installation - Centimetric
Fuel Heater - Kit
Locking Cap - Fuel Cap
Trailor Brake - Kit
Load Sensing Booster Kit Installation - Kit
Auxiliary Distributor - Kit
Aboard Computer - Stand Alone Kit - With Isobus
Software Group - Kit
Novatel - Autoguide Kit
Trimble - Autoguide Kit
Cab Filter - Carbon Filter
Additional Heater - Kit
Hydraulic Top Link - Kit
Hydraulic Top Link - (Components)
Trailer Hitch - Ball Pin Traction Kit
Front Linkage - Kit
Brand: Valtra
Valve Rocker Cover
Intake Manifold
Exhaust Manifold
Oil Pump And Sump
Coolant Piping
Fuel Filters
Belt Tensioner
Engine Gasket Kits
Engine Assemblies
Engine Installation
Fan & Shroud
Oil Recovery
Throttle Controls
Bracket
Gearbox-Housing
Rear Axle Housing
Oil Level Indicator
Final Drive
Disc Brake
Actuating Cylinder
Gear
Suspension
Bevel Drive
Duct Plate
Adjusting Device
Piping - Gear
Group Gear Shifting
Shifting
Engine P.T.O.
Pump Drive
Lube Oil Pump
Feed Pump
Valve Unit
Valve Syst.Comfort
Front Wheel Drive
Control Armrest
Brake Pedals
Trailor Brake
Air Compressor
Hydraulic Coupler
Pump - (Components)
Pump Installation
Hydraulic Block
Main Harness - Cab
Aboard Computer
Handrail Lighting
Roof Lighting
Rear Lighting
Rear Reflectors
Isobus Harness
Speed Radar
Transmitter
Control
Cab Mounting
Tractor Cab
Glass
Doors - Left Side
Doors - Right Side
Roof
Roof - Cladding
Tractor Cab - Plug
Fenders Extension
Cab Filter
Canopy
Windscreen Wiper
Radio Installation
Ashtray
Internal Mirrors
Seat - Deluxe
Seat - (Components)
Toolbox
Emblems
Speed Charts
Decals - Safety
Wheel Wedges
Pto Shaft - Flange
Front Pto - Drive
Front Pto
Front Pto - Housing
Power Lift
Sensor
Linkage
Sensing Pin
Tube Stabilizers
Plugs - Without Pto
Decal - Auto Guide
Fuel Heater - Kit
Trailor Brake - Kit
Front Linkage - Kit
