Valtra Tractor BH180 BR Parts Catalog C018001
Brand: Valtra
Model: Valtra BH180 Tractor (BR)
Number of Pages: 413 Pages
Flywheel And Housing
Valve Mechanism
Crankshaft Mechanism
Front Cover
Sump
Air Filter
Air Filter - Old Model
Inlet And Exhaust Manifold
Muffler And Instalation Air Filter
Turbocharger
Sedimentation Filter
Throttle System
Gasket Set - S1
Gasket Kit S1 + S2
Engine Repair Kit
Service Brake Control Drive
Control Brake System
Final Drives And Brakes
Differential Lock Drive
Front Axle - Carraro
Front Axle Carraro - 20.43 - Front Axle Housing - Carraro
Front Axle Carraro - 20.43 - Articulation
Front Axle Carraro - 20.43 - Timing Gear Case
Front Axle Carraro - 20.43 - Differential - Carraro
Front Axle Carraro - 20.43 - Crosshead
Front Axle Carraro - 20.43 - Gears For Shift-On-The-Go
Front Drive Selecting
Articulation Housing Carraro 20.43up
Frame And Bearing Of Front Axle Carraro
Double Joint Carraro-Pcr
Planetary Gear Housing Carraro
Differential - Carraro-Pcr
Flange, Bevel Gear And Pinion Carraro
Frame, Bearing And Cardan
Differential And Axle Housing - 4wd Zf Apl-359
Swivel Housing Planetary Gear 4wd Zf Apl 359
Steering Cylinder And Arm 4wd Zf Apl-359
Cardan Shaft
Front Axle Selecting Lever
Steering Wheel And Column
System Of Direction Complete
Hydraulic Steering
Hydrostatic Steering Unit Danfoss
Single Clutch
Double Clutch
Plateau Double Clutch
Clutch Control
Double Clutch Control
Gearbox Housing
Gearbox Housing And Shift Levers
Countershaft, Mainshaft, Bevel Pinion Synchronized
Countershaft, Mainshaft, Bevel Pinion Shaft(Hd)
Gearbox Cooling
Levers Housing
Range And Speed Gear Levers
Gearbox Speed Multiplyer
Power Take Off 540 Rpm
Hydraulic Pump And Pipe System
Hydraulic Pump And Pipe System - Optional
Hydraulic Valve, Load Sense Blocking
Gearbox Upper Cover
Old Hydraulic Lever System
Hydraulic Lever System - New
Lift Cylinder
Lift Connection
Upper Link Rod And Pecker Lift
Trailer Hitch
Auxiliary Lift Cylinder
Auxiliary Cylinder D=65mm
Directional Control Valve
Auxiliary Cylinder D=76.2mm
Auxiliary Cylinder D= 80mm
Planting Implement Kit
Sugar Cane Implement With Motor
Sugar Cane Implement Without Motor
Planting Implement Kit Hi- Confort
Sugar Cane Implement With Motor-Hi-Confort
Sugar Cane Implement Without Motor- Hi-Confort
Sugar Cane Implement With Motor - Hi Confort
Sugar Cane Implement Without Motor - Hi Confort
Starter Motor - Bosch
Starter Motor - 4,2 Kw
Starter Motor - Iskra
Alternator Bosch - 75a
Alternator Bosch - 90a
Rear Eletrical System For Cab
Electrical Safety System Structure
Instruments
Lights
Panel Eletric System
Front Electric System
Rotating Light (Optional )
Radio (Optional )
Windscreen Wiper And Washer
Rear Window Wiper And Washer
Rear Fog Light (Optional )
Light Number Plate (Optional )
Roof
Open Cab
Cab Frame
Door And Glass Of The Cab
Frame Glasses Estructure Assy
Rear Window And Glass Of The Cab
Windscreen
Insulating And Coating For Cab
Cab Insulator
Muldguards And Plate Floor
Front And Rear Mudguards- Axle Zf359
Front And Rear Mudguards- Carraro
Front Mudguard
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Seat For Cab (Part 1) Optional
Seat For Cab (Part 2) Optional
Seat For Cab (Part 3) Optional
Instruments Panel
Front Shields
Safety Frame
Air Conditioning
Heating Unit
Fan Of Condenser
Adhesives (Portuguese)
Adhesives (Spanish)
Adhesives (English)
Decal
Front Wheel 4 X 4
Rear Wheel
Rear Wheel (Optional)
Double Rear Wheel
Rear Wheels 30.5l32r1
Buffer And Front Counterweight
Rear Wheel Counterweight (Tyre 18.4 And 20.8)-Accessory
Rear Whell Counterweight (Tyre 24.5) - Accessory
Rear Wheel Counterweight (Tyre 23.1) - Accessory
Rear Whell Counterweight (Tyre 710 65x38)
Front Wheels - 18.4-26r1 10pr Tl
Front Wheel - 18.4-26r1 10pr Tl
Rear Wheels - 30.5 X 32 R1
Spanner
