Valtra Tractor BH165 BR Parts Catalog C016501
Brand: Valtra
Model: Valtra BH165 Tractor (BR)
Number of Pages: 739 Pages
Flywheel And Housing
Valve Mechanism
Crankshaft Mechanism
Front Cover
Sump
Air Filter
Inlet And Exhaust Manifold
Muffler And Instalation Air Filter
Side Muffler
Turbocharger
Sedimentation Filter
Throttle System
Gasket Set - S1
Gasket Kit S1 + S2
Engine Repair Kit
Gear Housing
Flywheel And Flywheel Housing
Valves Mechanism
Engine Oil Sump
Oil Filter
Coolant Pump
Solenoid
Sedimenter Filter
Alternator And Starter
Gasket Set S1
Gasket Kit S2
Engine Overhaul Kits
Service Brake Control Drive
Control Brake System
Final Drives And Brakes
Differential Lock Drive
Front Axle - Zf As 3065 - 3m - Drive
Front Axle - Zf As 3065 - 3m - Diferential
Front Axle - Zf As 3065 - 3m - Spindle
Front Axle - Zf As 3065 - 3m - Front Spacer
Front Axle - Zf As 3065 - 3m - Articulation
Front Axle - Zf As 3065 - 3m - Wheel Shaft Housing
Front Axle - Zf As 3065 - 3m - Planet Carrier Assy
Front Axle - Zf As 3065 - 3m - Steering Cylinder
Front Axle - Zf As 3065 - 3m - Frame And Bearing
Frame, Bearing And Cardan
Differential And Axle Housing - 4wd Zf Apl-359
Swivel Housing Planetary Gear 4wd Zf Apl 359
Steering Cylinder And Arm 4wd Zf Apl-359
Frame And Bearing Of Front Axle Carraro
Articulation Housing Carraro 20.43up
Flange, Bevel Gear And Pinion Carraro
Double Joint Carraro-Pcr
Planetary Gear Housing Carraro
Front Drive Selecting
Differential - Carraro-Pcr
Cardan Shaft
Front Drive Selecting Lever
Steering Wheel And Column
Steering Wheel And Adjustable Column
Hydraulic Steering
Hydrostatic Steering Unit Danfoss
Tilt Sensor
Single Clutch
Double Clutch
Plateau Double Clutch
Single Clutch Control
Double Clutch Control
Gearbox Housing
Countershaft, Mainshaft, Bevel Pinion Shaft(Hd)
Gearbox Cooling
Levers Housing
Range And Speed Gear Levers
Gearbox Speed Multiplyer
Power Take Off 540 Rpm
Pto Lever System
Hydraulic Pump And Pipe System- Old
Hydraulic Valve, Load Sense Blocking
Gearbox Upper Cover
Hydraulic Lever System - New
Lift Cylinder
Lift Connection
Upper Link Rod And Pecker Lift
Trailer Hitch
Ball Pin Traction Kit
Auxiliary Lift Cylinder
Directional Control Valve
Auxiliary Cylinder D=76.2mm
Hydraulic Oil Container
Hydraulic System Of Variable Flow - 45l
Pressure Line
Variable Flow Pump
Suction Line
Load Sense Line
Return Line - Radiator X Tank
Respiration Aditional Tank
Return Command Line
Additional Tank
Hydraulic Command
Hydraulic Pump And Pipes System Dnc65
Remote Control Valve- Dnc65
Reservoir Oil-Dnc65
Directional Control Valves Levers-Dnc65
Side Hydraulic Pump- Hiflow
Side Pump Suction Pipe - Hiflow
Front Hydraulic Pump- Hiflow
Front Pump Suction Pipe- Hiflow
Pressure Pipe - Hiflow
Connection Block - Hiflow
Depart Control Valve - Hiflow
Remote Control Valve- Hiflow Dnc120
Hydraulic System Support - Hiflow
Hydraulic Oil Container - Hiflow
Hydraulic Oil Cooler - Hiflow
Front Cardan Of Pump (Dana) Hiflow
Front Cardan Of Pump (Nm) Hiflow
Eletronic Hilift
Eletronic Hilift Overflow
Assembled Eletrical Ehrb
Common Hilift
Planting Implement Kit
Sugar Cane Implement With Motor
Sugar Cane Implement Without Motor
Starter Motor - 4,2 Kw
Starter Motor - Iskra
Alternator Iskra 55a- Platform
Alternator Iskra 120a- Cab
Electrical Safety System Structure
Instruments
Lights
Front Electric System
Front Window Wiper
Battery And Support
Radio
Rear Window Wiper And Washer
Fog Light (Optional)
Light Number Plate (Optional)
Telemetry
Antenna
Roof
Cab Frame
Door And Glass Of The Cab
Front Glasses
Frame Glasses Estructure Assy
Rear Window And Glass Of The Cab
Windscreen
Insulating And Coating For Cab
Front Mudguards
Front Mudguard
Rear Mudguard
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Seat For Cab (Part 1) Optional
Seat For Cab (Part 2) Optional
Seat For Cab (Part 3) Optional
Instruments Panel
Plataform
Front Shields
Safety Frame And Roof (Optional )
Air Conditioning
Heating Unit
Intern Rear View Mirror
Adhesives (Portuguese)
Adhesives (Spanish)
Adhesives (English)
Decal
Front Wheel 4 X 4
Front Wheels - 18.4-26r1 10pr Tl
Front Wheel - 18.4-26r1 10pr Tl
Front Wheels 18.4 X 26 R1 10l - Optional
Rear Wheel
Rear Wheel (Optional)
Rear Wheels 30.5l32r1
Double Rear Wheel
Buffer And Front Counterweight
Rear Wheel Counterweight (Tyre 18.4 And 20.8)-Accessory
Rear Whell Counterweight (Tyre 24.5) - Accessory
Rear Wheel Counterweight (Tyre 23.1) - Accessory
Rear Wheels - 30.5 X 32 R1
Rear Wheel 23.1-30r1 12pr - Right
Rear Wheel 23.1-30r1 12pr - Left Side
Rear Wheels - 24.5 X 32 R1
Spanner
Front Mudguard - Zf - 370mm
Mud Flap Assembly, Front
Front Mudguard - Left Hand
Front Mudguard - Right
Front Mudguard - Zf - 470mm
Autoguide 3000
Gps Receptor
Support Canopy
Receiver
Ag3000 Autoguide Decimeter
Gx-45 Console Installation
Decimetric Autoguide
Electrical Kit
Chaff Spreader Kit - Auto Guide
Chaff Spreader Kit - Mounting Bracket
Monitor C3000 Assy
Monitor C3000 Assy - Advanced
Brand: Valtra
Valve Mechanism
Front Cover
Sump
Air Filter
Side Muffler
Turbocharger
Throttle System
Gasket Set - S1
Gasket Kit S1 + S2
Engine Repair Kit
Gear Housing
Valves Mechanism
Engine Oil Sump
Oil Filter
Coolant Pump
Solenoid
Sedimenter Filter
Gasket Set S1
Gasket Kit S2
Cardan Shaft
Hydraulic Steering
Tilt Sensor
Single Clutch
Double Clutch
Gearbox Housing
Gearbox Cooling
Levers Housing
Pto Lever System
Gearbox Upper Cover
Lift Cylinder
Lift Connection
Trailer Hitch
Pressure Line
Variable Flow Pump
Suction Line
Load Sense Line
Return Command Line
Additional Tank
Hydraulic Command
Reservoir Oil-Dnc65
Eletronic Hilift
Common Hilift
Instruments
Lights
Front Window Wiper
Battery And Support
Radio
Telemetry
Antenna
Roof
Cab Frame
Front Glasses
Windscreen
Front Mudguards
Front Mudguard
Rear Mudguard
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Instruments Panel
Plataform
Front Shields
Air Conditioning
Heating Unit
Adhesives (Spanish)
Adhesives (English)
Decal
Front Wheel 4 X 4
Rear Wheel
Double Rear Wheel
Spanner
Autoguide 3000
Gps Receptor
Support Canopy
Receiver
Electrical Kit
Monitor C3000 Assy
