Valtra Tractor A Series A85 Parts Catalog VFAA85
Brand: Valtra
Model: Valtra A85 Tractor (A Series)
Number of Pages: 485 Pages
Cylinderblock
Flywheel And Housing
Valve Mechanism
Crank Mechanism
Gear Housing
Oil Sump
Oil Filter
Air Cleaner
Turbo-Charger
Intake- And Exhaust Pipe
Muffler
Feed Pump
Prefilter, Fuel
Fuel Pipes
Injector, Distributor Pump
Speed Levers
Speed Levers, Forest
Coolant Pump
Startermotor
Engine Repair Kit And Bearings
Steering Cylinder 2wd
Steering Cylinder 4wd
Front Axle 2wd
Front Axle 4wd
Joint Casing 4wd
Tie Rod 4wd
Drive Shaft 4wd
Planetary Gear Set 4wd
Bevel Pinion Shaft 4wd
Differential 4wd
Propeller Shaft
Steering System, Adjustable
Steering Hydraulics
Double Clutch
Clutch Control
Gearbox Housing And Shift Levers
Gear Lever System
Main Shaft 270
Main Shaft 272
Intermediate Shaft And 4wd Shaft 270
Intermediate Shaft And 4wd Shaft 272
Bevel Pinion Shaft 270
Bevel Pinion Shaft 272
Lever System, Differential
Lubrication System 270
Lubrication System 272
Creep Speed Gear
Lever System, Creep Speed Gear
Overdrive
Lever System, Overdrive
Shuttle-Unit
Lever System, Shuttle-Unit
Final Drive
Hi Shift Clutch (Optional Equipment)
Hi Shift Valve, Main Clutch (Optional Equipment)
Hi Shift Clutch, Pto (Optional Equipment)
Hi Shift Valve, Pto (Optional Equipment)
Hi Shift, Main Clutch + Pto Clutch (Optional Equipment)
Compressed Air System
Hydraulic Pipes
Directional Control Valve
Hydraulic Levelling (Optional Equipment)
Battery And Bracket
Electrical Equipment, Frame
Battery Charger (Optional Equipment)
Starter Socket (Optional Equipment)
Roof
Doors
Cab Windows
Cab Upholstery
Floor
Cab Equipment
Steering Wheel Console
Sidemirror
Flexible Mount
Occasional Seat
Electrical System For Cab
Dashboard
Windscreen Wiper And Washer
Control Parts, Eh Power Lift
Lights
Ashtray And Lighter (Optional Equipment)
Radio (Optional Equipment)
Valmet Agroline (Optional Equipment)
Front Working Lights (Optional Equipment)
Upper Headlights + Front Working Lights (Optional Equipment)
Openable Windscreen (Optional Equipment)
Heating Unit
Heating Unit, Roof (Optional Equipment)
Engine Bed And Front Part
Center Frame, Fuel Tank
Shields
Stickers And Sign Plates
Stickers And Paints
Stickers, Speed Chart, 540
Stickers, Speed Chart, 540 1000
Stickers, Speed Chart, 540 540e
Front Wheels
Implement Drive System
Rear Housing
Lever System
Trailer Coupling, Automatic (Optional Equipment)
Agricultural Drawbar (Optional Equipment)
Implement Lift System Front
Lift Cylinder, Front Lift (Optional Equipment)
Power Lift 25
Power Lift Eh
Control Valve, Power Lift Eh
Lift Cylinder 25
Lift Cylinder Eh
Auxiliary Cylinder
Control Links, Hydraulics
Lower Links
Top Link Support
Lift Link And Top Link (Lh)
Lower Links 980 + Top Link (Long) (Optional Equipment)
Lower Links, Ball-Hitch (Optional Equipment)
Top Link, Ball-Hitch (Optional Equipment)
Double Springs, Sensing (Optional Equipment)
Valve Bracket (Optional Equipment)
Symbol Lenses
Filters
Service Kit
Operator's Manual
Tools And Warning Triangle
Toolbox (Optional Equipment)
