Valtra Tractor 65 Series 255 Parts Catalog VF65255
Brand: Valtra
Model: Valtra 255 Tractor (65 Series)
Number of Pages: 346 Pages
Stickers And Sign Plates
Stickers And Paints
Filters
Cylinderblock
Flywheel And Housing
Valve Mechanism
Crank Mechanism
Gear Housing
Oil Sump
Oil Filter
Air Cleaner
Oil Bath Air Filter
Intake- And Exhaus Pipe
Muffler
Feed Pump
Fuel Pipes
Injector
Speed Levers
Speed Levers, Forest
Coolant Pump
Gasket Sets
Engine Repair Kit And Bearing
Startermotor
Battery And Bracket
Electrical System For Cab
Dashboard
Lights
Windscreen Wiper And Washer
Other Electrical Equipment
Light, Number Plate
Control Parts, Eh Power Lift
Radio (Optional Equipment)
Front Working Lights (Optional Equipment)
Ashtray And Lighter (Optional Equipment)
Implement Control Syst. (Optional Equipment)
Velocity Meter And Clock (Optional Equipment)
Power Transmission
Double Clutch
Clutch Control
Gearbox Housing And Shift Levers
Gear Lever System
Main Shaft
Interm. Schaft And 4wd Shaft
Propeller Shaft
Bevel Pinion Shaft
Leversystem, Differential
Lubrication System
Creep Speed Gear
Lever System, Creep Speed Gear
Final Drive
Rear Housing
Linkage Pto
Pto-Brake (Optional Equipment)
Dust Protection For Clutch (Optional Equipment)
Brakes
Steering Hydraulics
Steering Hydraulics, Priority Valve
Steering Cylinder 2wd
Steering Cylinder 4wd
Steering System, Adjustable
Front Axle 2wd
Front Axle 4wd
Joint Casing 4wd
Tie Rod 4wd
Drive Shaft 4wd
Planetary Gear Set 4wd
Bevel Pinion Shaft 4wd
Differential 4wd
Frame And Wheel
Engine Bed And Front Part
Center Frame, Fuel Tank
Front Wheel
Cab And Shields
Doors
Cab Windows
Cab Upholstery
Floor
Cab Equipment
Flexible Mount
Steering Wheel Console
Heating Unit
Shields
Seat Belt (Optional Equipment)
Front Shield Net (Optional Equipment)
Working Hydraulics
Hydraulic Pump And Pipes
Power Lift 25
Power Lift Eh
Lift Cylinder 25
Lift Cylinder Eh
Hydr. Control Links
Hydr. Control Levers
Lower Links
Lower Links Eh
Lift Link And Top Link
Lift Link Gear
Telescopic Lower Links
Trailer Hitch
Agricultural Drawbar
Directional Control Valve
Rear Hitch Europe (Optional Equipment)
Lower Links, Ball-Hitch (Optional Equipment)
Hydraulic Lewelling (Optional Equipment)
Tools
Tools And Warning Triangle
