Valtra Planter Fertilizer BP1508-BP1709 L M Parts Catalog C100002
Brand: Valtra
Type of Machine: Seeding Planter, Planter Fertilizer
Model: Valtra BP1508, BP1709L, BP1709M Planter Fertilizer Hitech
Number of Pages: 686 Pages
Header
Header Set
Header Hitch Set
Header Jacks Set
Chassis Assy.
Set Frame Pvt - Bp1508
Set Frame Ptg - Bp1508
Set Frame Pvt - Bp1709
Set Frame Ptg - Bp1709
Set Body Guard
Set Body Guard 1745
Pre Set Ladder
Set Support Stand
Set Side Protector Left Right
Set Ladder
Set Side Protector
Set Wheelsdouble Ratchet
Set Wheels Double Ratchet
Set Hub
Left Wheeled Assy.
Set Wheels Right W Transmission
Set Wheels W Transmission
Set Tire With Whell
Set Stretcher Roller
Set Line Diverter
Fertilizer Tank
Set Fertilizer Spreader
Set Six Compartment Fertilizer Box
Set Four Compartment Fertilizer Box
Set Fertilizer Distribution Bushing
Set Bearing With Flange
Set Space Driver
Fertilizer Distributor
Set Meter Transmission Shaft Ht 15000 8l
Set Meter Transmission Shaft Ht 15000 9l
Set Meter Transmission Shaft Ht 15000 10l
Set Meter Transmission Shaft Ht 15000 11l
Set Meter Transmission Shaft Ht 15000 12l
Set Meter Transmission Shaft Ht 15000 13l
Set Meter Transmission Shaft Ht 15000 14l
Set Meter Transmission Shaft Ht 15000 15l
Set Meter Transmission Shaft Ht 17000 9l
Set Meter Transmission Shaft Ht 17000 10l
Set Meter Transmission Shaft Ht 17000 11l
Set Meter Transmission Shaft Ht 17000 12l
Set Meter Transmission Shaft Ht 17000 13l
Set Meter Transmission Shaft Ht 17000 14l
Set Meter Transmission Shaft Ht 17000 15l
Set Meter Transmission Shaft Ht 17000 16l
Set Meter Transmission Shaft Ht 17000 17l
Set Meter Transmission Shaft Ht 17000 18l
Set Right Fertisytem Dosing
Set Left Fertisytem Dosing
Fertilizer Line
Set Smaller Upper Cutting Disc
Set Larger Upper Cutting Disc
Set Cutting Disk - Smaller - Upper
Set Cutting Disk - Larger - Upper
Set Fork Flat Cutting Disc 18
Set Fork Cutting Disk
Set Cutting Disk Hub
Set Left Furrower
Set Right Furrower
Set Furrower
Set Larger Right Furrower
Set Larger Left Furrower
Set Disarm Arm Furrower Large
Rigth Dual Disk 15 Pol
Left Dual Disk 15 Pol
Set Dual Disk
Set Right Dual Disk
Set Left Dual Disk
Set Left Pvt Turbo Disk
Set Right Pvt Turbo Disk
Set Ptg Turbo Disk
Set Turbo Disk Hub
Set Left Limiter Arm
Set Right Limiter Arm
Set Limiter Wheel Hub
Set Wheel
Greaser
Seed Line
Set Pvt Seed Short Line
Set Pvt Seed Long Line
Set Short Seed Line Side Limiting
Set Long Seed Line Side Limiting
Set Seed Line
Set Ptg Line
Short Line Assembly - From Serial Or Engine Number Di000097
Long Line Assembly - From Serial Or Engine Number Di000097
Pre Set Short Seed Line
Set Seed Distribution
Set Larger Seed Box
Set Seed Line - From Serial Or Engine Number Di000097
Bearing
Set Reservoir Fixing Clamp
Set Dual Disk 15 Pol
Pre Set Coupling Base With Crown And Pinion
Clip Set
Pre Conjunto Caixa E Tampa
Set Right Dual Disk Hub
Set Left Dual Disk Hub
Pre Set Seed Line Coupling Base
Set Stretcher Seed Line
Set Left Limiting Wheels
Set Right Limiting Wheels
Set Aligned Dual Disk Support 16 Pol
Set Large Compactor
Set Pneumatic Limiting Hub
Set Aligned Dual Disk Hub
Set Handle Regulatory
Set Compactor Wheel
Set Rail Cleaner Hub
Pre Set Side Long Line
Rear Structure Set
Set Lower Articulator
Set Top Articulator
M Line Structure Set
Structure Transmission Shaft Set - Right Side
Set Line Stretched Pantograph
Set Base Acoplad
Bearing - 2 Bolts
Set Transmission
Bearing With Flanged Bush
Set Limiter Line Side
Set Line Transmission
Set Pivot Transmission 1545
Set Pivot Transmission 1745
Set Pantograph Transmission
Cj Montado Transmissao Pantografica 1745
Set Transmission Pvtl
Set Transmission Ptg Double Wheel
Set 6 Gear
Set Right Ratchet
Set Seed Shaft
Front Shaft Set
Rear Shaft Set
Set Left Ratchet
Set Hex Backstop
Set Pantographic Seed Axle
Set Front Axle Manure Mec Pant
Pre Conjunto Rolamento Com Flange 3 Furos
Pre Set Stretcher
Set Roller
Pre Set 3 Gear Set
Set Mecanical Transmission Pantograph
Set Internal Stretcher
Set Transmission Inverter Bushing
Set Transmission 15000
Set Transmission Ptg 15000
Set Transmission Ptg 17000
Pre Set Seed Bushing
Set Hydraulic System
Set Smaller Cylinder Wedge
Thick Cylinder Wedge Set
Set Thin Cylinder Wedge
Set Large Cylinder Wedge
Set Transport Cylinder Wedge
Set Hydraulics
Line Marker
Set Hydraulic Marker Lines
Set Front Line Marker
Set Front Line Marker Independent
Hydraulic Marker Dependent Set
Set Marker Disk
Ht Hydraulic Marker Independent Set
Front Hydraulic Marker Set
Hydraulic Marker Hub Set
Pre Set Arm Support
Limiters - Compact
Compactador Limiter Fixed Angle V
Limiter Angle Fixed
Limiter Angle Pvt Plan Compactador
Limiter Pvt Plan Compactador V
Limitador Eixo Plano Compactador Em V
V Fixed Limiter Set
Set Compactor
Set Flat Adjustable Compactor
Set Angle Pivoted Limiter
Set Flat Pivoted Limiter
Set Flat Fixed Limiter
Set Flat Compacting Wheel
Set Limiting Wheels
Set Limiting Hub
Optional
Set Chassi Ptg Top Box - Bp1508
Set Chassi Ptg Top Box - Bp1709
Set Smaller Seed Reservoir
Set Left Larger Seed Reservoir
Set Right Larger Seed Reservoir
Set Seed Reservoir 12
Set Seed Reservoir 8
Set Ptg Short Line Top Box
Set Seed Line Rear Structure
Pre Set Seed Line Rear Structure
Set Lower Seed Reservoir
Set Pneumatic Meter Transmission Shaft
V Pvt Rail Cleaner Set
Ptg Rail Cleaner Set
V Ptg Rail Cleaner Set
Pre Set V Compactor Wheels
Set Rose Gear Rail Cleaner
Pre Set Compactor Wheels
Set Limiter Line Side - From Serial Or Engine Number Di000097
Arm - From Serial Or Engine Number Di000097
Regulator Kit - From Serial Or Engine Number Di000097
Set Wheels - From Serial Or Engine Number Di000097
Set Compactor - From Serial Or Engine Number Di000097
Cover Grove - From Serial Or Engine Number Di000097
Set Rose Gear Rail Cleaner - From Serial Or Engine Number Di000097
Seed
Cj Seed Chassis 1545 M
Cj Seed Chassis 1745 M
Set Seed Platform 1545m
Set Seed Platform 1745m
Set Larger Seed Reservoir
Set Smaller Platform Seed
Set Mt Left Ladder
Set Complement Ladder Seed
Set Handrail Seed
Set Guard Body Side
Set Platform Seed
Set Furrower Mechanical Line 18 Pol Smaller
Set Furrower Mechanical Line Flat Disk 18 Pol
Disarm Line Flat Disk 18 Pol Smaller
Turbo Disk Line 18 Smaller
Turbo Disk Line 18
Mec Furrower Line Flat Disk 20 Pol Smaller
Disarm Line Flat Disk 20 Pol Smaller
Turbo Disk Line 20 Smaller
Turbo Disk Line 20 Pol
Set Furrower Line Turbo Disk 18 Pol
Disarm Line Turbo Disk 18 Pol
Set Cutting Disk 18
Set Cutting Disk 20
Set Turbo Disk 18
Pre Cutting Disk Fork 18 Pol
Pre Cutting Disk Fork 20 Pol
Pre Turbo Cutting Disk Fork 18 Pol
Set Furrower Mechanical Ht
Set Turbo Disk Ht
Pre Set Cutting Disk Smaller Upper
Pre Set Cutting Disk Larger Upper
Set Right Short Seed Line
Set Left Short Seed Line
Set Right Long Seed Line
Set Left Long Seed Line
Set Short Seed Line Right Side Limiter
Set Short Seed Line Left Side Limiter
Set Long Seed Line Right Side Limiter
Set Long Seed Line Left Side Limiter
Kit Right Short Seed Tube
Kit Left Short Seed Tube
Kit Right Long Seed Tube
Kit Left Long Seed Tube
Cj Anel Reservatorio De Semente
Set Reservoir Inf Seed Right
Set Short Seed Tube
Set Mt Seed Outlet Spout
Set Upper Guide Hub
Set Seed Gate
Set Split Curve
Set Reservoir Inf Seed Left
Set Long Seed Line
Set Transmission 15 Lines
Set Transmission 17 Lines
Set Transmission Mt Pantograph Wheeled Double
Set Twist Cast Stretcher
Set Rear Shaft
Variable Rate
Chassis Assy. - Bp1508
Chassis Assy. - Bp1709
Set Wheels - Bp1508
Set Wheels - Bp1709
Bracket And Sensor
Set Fertilizer Spreader - Bp1508
Set Fertilizer Spreader - Bp1709
Bearing Set
Hydraulic Container
Tank
Set Valves
Block
Side Console
Guard Kit
End
Support
Harness Cab
Wire Harness
