VAG DPF 3.26.11 Full (for Android device + ELM37)
Test
VAG DPF 3.28.12 Full (for Android device + ELM37)
With this application you can find out if the filter is really in the process of regeneration, if the regeneration is awaiting completion, how many kilometers have you traveled since the last regeneration, etc.
Core functions:
Core functions:
- Display of 12 DPF filter parameters like soot mass accumulation in the filter, regeneration duration, km traveled and time passed since last regeneration, EGR valve closing, exhaust gas temperatures of the inlet, and outlet of DPF (Attention: data shown may vary depending on the engine type due to the presence of the parameters into the engine ECU)
- Manual or automatic parameters update
- Display, for all the parameters, of the previous value and the difference between the actual and the previous value (only for automatic update delays different from 0 seconds)
- Ability to exclude one or more parameter to increase the reading speed
- Display of the filter filling percentage before reaching the filling limit that starts the execution of a field regeneration (standard regeneration controlled by the engine ECU)
- Graphical display, using a progress bar, of the filling percentage value before starting a field regeneration or a service regeneration
- Graphical display of the filter status: red filter for the regeneration phase (passive, field, or service) of the grey filter with different back internal areas depending on the filling percentage value
- Display of extra data: adapter communication error counter, filter filling rating in µg/min, update time of all the 12 parameters, automatic update delay actually selected in the options menu
- Notification bar icon to show an active connection and the auto-update process running.
- Delphi/AuTocom 2013.2 with update 1 [Activation, CDP, CDP+,ADP186,SDP]
- Mitchell OnDemand 2015 + Mitchell Manager Torrent
- Autocom/delphi 2013.1 Full
- AutoCom/Delphi 2013.3 Activator!!!! Also Including My Delphi 2013.3 Super Easy Installer by SuperS
- Delphi/Autocom 2013.R3 How to install
- Autocom & Delphi 2013 R1 Activator patch Works Fine
- Autocom 2013 R2 Full
- TachoSoft Mileag Calculator 25.9 - 2016 full
- Autocom CDP 2013.R1 FULL
- KG Vivid Workshop DATA ATI v.10.2 + Instruction
- Autocom CDP+ Delphi 2014.Release 1 Update Full
- DELPHI DIAMAND [02.2016]
- Delphi><Autocom Keygen 2013.3 Xml file activator
- Autocom - Delphi 2012.3 Full
- NYO4 calculator Torrent
