Hyundai
86
176,834
UniCarriers Forklift MP1F1A15LV to MP1F2A25LV Parts Manual 997PE-53000
Brand: UniCarriers
Type of Machine: Forklift
Model: UniCarriers
MP1F1A15LV
MP1F1A18LV
MP1F1A20LV
MP1F2A20LV
MP1F2A25LV
Part Number: 997PE-53000
Number of Pages: 533 Pages
01-ENGINE MECHANICAL
100-01 Engine Assembly​
100-02 Engine Assembly-CABA Option​
102 Engine Gasket Kit​
110 Cylinder Block & Oil Pan​
111 Cylinder Head & Rocker Cover​
112 Engine & Mounting​
118 Crank Case Ventilation​
120 Piston, Crankshaft & Flywheel​
130 Camshaft & Valve Mechanism​
135 Front Cover & Fitting​
140 Manifold​
150 Lubricating System​
296 Controller VCM​
02-FUEL & ENGINE CONTROL
163 Throttle Body​
164 Fuel Strainer & Fuel Hose​
165-01 Air Cleaner-1 Ton​
165-02 Air Cleaner-2 Ton​
180 Accelerator Linkage​
195 Vaporizer​
196 LPG Filter & Piping​
199-01 LPG Bombe​
199-02 LPG Bombe-LPGQ Option​
03-EXHAUST & COOLING
200 Exhaust Tube & Muffler​
210 Water Pump, Cooling Fan & Thermostat​
214-01 Radiator, Shroud & Fitting-1 Ton​
214-02 Radiator, Shroud & Fitting-2 Ton​
216-01 Torque Converter Oil Cooler & Piping-1 Ton​
216-02 Torque Converter Oil Cooler & Piping-2 Ton​
04-ENGINE ELECTRICAL
220 Ignition System​
221 Distributor-Ignition Coil Harness​
223 Vacuum Piping​
226 Engine Control Module​
230 Alternator Fitting​
231 Alternator​
233 Starter Motor​
05-BODY ELECTRICAL
240 Wiring Engine Room & Instrument​
241-01 Wiring Body Part 1-1 Ton​
241-02 Wiring Body Part 1-2 Ton​
241-03 Wiring Body Part 2-1 Ton​
241-04 Wiring Body Part 2-2 Ton​
244 Battery & Battery Mounting​
248 Instrument Meter & Gauge​
251 Switch​
253 Electrical Unit​
260-01 Head Lamp​
260-02 Head Lamp-LMSF Option​
260-03 Head Lamp-LMSF/LVRP, LMSF/LVRR Options​
261 Front Combination Lamp​
265-01 Rear Combination Lamp​
265-02 Rear Combination Lamp-LMRA Option​
267-01 Lamps (Others)​
267-02 Lamps (Others)-CABA Option​
267-03 Lamps (Others)-MBZBR Option​
267-04 Lamps (Others)-LMRA Option​
06-POWER TRAIN
310 Transmission Assembly & Fitting-ATM​
311 Torque Converter Case & Housing-ATM​
313 Oil Pump Parts-ATM​
314 Governor & Gear Parts-ATM​
315 Clutch & Brake Band-ATM​
317 Control Valve-ATM​
370 Propeller Shaft-ATM​
380-01 Final Drive Assembly-ATM 1.0 & 2.0 (1F1) Ton​
380-02 Final Drive Assembly-ATM 2.0 & 2.5 (1F2) Ton​
07-AXLE & SUSPENSION
402-01 Drive Axle-1 Ton​
402-02 Drive Axle-2 Ton​
403 Steering Axle​
433-01 Road Wheel & Tire-Drive Axle 1 Ton​
433-02 Road Wheel & Tire-Drive Axle 2 Ton​
434 Road Wheel & Tire-Steering Axle​
08-BRAKE
440-01 Front Brake-1 Ton​
440-02 Front Brake-2 Ton​
443 Parking Brake Control​
460 Brake Master Cylinder​
462 Brake Piping & Control​
465 Brake & Clutch Pedal​
09-STEERING
480 Steering Gear​
484 Steering Wheel​
485 Steering Linkage​
488 Steering Column​
497 Power Steering Piping​
10-BODY (FRONT, ROOF & FLOOR)
500-01 Frame-Main​
500-02 Frame-Front Covers​
500-03 Frame-NIZ2, DSTC, DSTW, DSTY, MRPKG Options​
580-01 Lift Cylinder-2F 1 Ton​
580-02 Lift Cylinder-2F 2 Ton​
580-03 Lift Cylinder-2W​
580-04 Lift Cylinder-2W​
580-05 Lift Cylinder-3F 2 Ton​
580-06 Lift Cylinder-3V​
585-01 Chain Wheel Support & Chain-2F​
585-02 Chain Wheel Support & Chain-2W​
585-03 Chain Wheel Support & Chain-3F​
585-04 Chain Wheel Support & Chain-3V​
586-01 Tilt Cylinder-1 Ton​
586-02 Tilt Cylinder-2 Ton​
591-01 Mast-2F​
591-02 Mast-2W​
591-03 Mast-3F​
591-04 Mast-3V​
594 Back Rest & Fork​
595-01 Carriage-2F​
595-02 Carriage-2W​
595-03 Carriage-3F​
595-04 Carriage-3V​
597-01 Side Shifter-S/S01, S/S02 Options​
597-02 Side Shifter-S/S03, S/S04 Options​
655-01 Top Panel, Hinge & Fitting-1 Ton​
655-02 Top Panel, Hinge & Fitting-2 Ton​
680 Instrument Panel, Pad & Cluster Lid​
691-01 Hydraulic Oil Pump & Fitting-Tank Fitting Part​
691-02 Hydraulic Oil Pump & Fitting-Pump Fitting Part​
692 Hydraulic Oil Pump Assembly​
693-01 Hydraulic Control Valve​
693-02 Hydraulic Control Valve-LVRP, LVRR Options​
694-01 Hydraulic Control Valve Fitting-VAL3​
694-02 Hydraulic Control Valve Fitting-VAL4 Option​
694-03 Hydraulic Control Valve Fitting-Kit Parts​
694-04 Hydraulic Control Valve Fitting-VAL3/LVRP, VAL3/LVRR Options​
694-05 Hydraulic Control Valve Fitting-VAL4/LVRP, VAL4/LVRR Options​
695-01 Hydraulic Control Lever-Fitting Parts​
695-02 Hydraulic Control Lever-LVRW/VAL3 Option​
695-03 Hydraulic Control Lever-LVRW/VAL4 Option​
695-04 Hydraulic Control Lever-LVRL/VAL3 1 Ton​
695-05 Hydraulic Control Lever-LVRL/VAL3 2 Ton​
695-06 Hydraulic Control Lever-LVRL/VAL4 Option 1 Ton​
695-07 Hydraulic Control Lever-LVRL/VAL4 Option 2 Ton​
695-08 Hydraulic Control Lever-Fitting Parts LVRP, LVRR Options​
695-09 Hydraulic Control Lever-LVRP, LVRR Options​
695-10 Hydraulic Control Lever-Wiring LVRP, LVRR Options​
697-01 Hydraulic Oil Piping-From Tank to Pump​
697-02 Hydraulic Oil Piping-From Tank to Valve​
697-03 Hydraulic Oil Piping-From Valve to Cylinder 1 Ton​
697-04 Hydraulic Oil Piping-From Valve to Cylinder 2 Ton​
697-05 Hydraulic Oil Piping-From Tank to Strg​
697-06 Hydraulic Oil Piping-ACMX Option​
698-01 Hydraulic Oil Piping Mast-2F 1 Ton​
698-02 Hydraulic Oil Piping Mast-2F 2 Ton​
698-03 Hydraulic Oil Piping Mast-2W​
698-04 Hydraulic Oil Piping Mast-3F​
698-05 Hydraulic Oil Piping Mast-3V​
699-01 Hydraulic Oil Piping-Attachment 2F​
699-02 Hydraulic Oil Piping-Attachment 2F, VAL3 1 Ton​
699-03 Hydraulic Oil Piping-Attachment 2F, VAL3 2 Ton​
699-04 Hydraulic Oil Piping-Attachment 2F, VAL4 1 Ton​
699-05 Hydraulic Oil Piping-Attachment 2F, VAL4 2 Ton​
699-06 Hydraulic Oil Piping-Attachment 2W​
699-07 Hydraulic Oil Piping-Attachment 2W, VAL3​
699-08 Hydraulic Oil Piping-Attachment 2W, VAL4​
699-09 Hydraulic Oil Piping-Attachment 3F​
699-10 Hydraulic Oil Piping-Attachment 3F, VAL3​
699-11 Hydraulic Oil Piping-Attachment 3F, VAL4​
699-12 Hydraulic Oil Piping-Attachment 3V​
699-13 Hydraulic Oil Piping-Attachment 3V, VAL3​
699-14 Hydraulic Oil Piping-Attachment 3V, VAL4​
735 Cab​
737-01 Over Head Guard​
737-02 Over Head Guard-Pillar Options​
740 Floor Panel​
11-BODY (SIDE, REAR & SEAT)
871-01 Seat 10/2015~05/2018-1 Ton​
871-02 Seat 10/2015~05/2018-2 Ton​
871-03 Seat-OHGR, OHGRX Options 10/2015~05/2018​
871-04 Seat-LVRP, LVRR Options 10/2015~05/2018​
871-05 Seat 05/2018~​
871-06 Seat-OHGR, OHGRX Options 05/2018~​
871-07 Seat-LVRP, LVRR Options 05/2018~​
871-08 Seat-Wiring 05/2018~​
13-MISCELLANEOUS
991-01 Caution Plate & Label Car-1 Ton​
991-02 Caution Plate & Label Car-2 Ton​
992 Caution Plate & Label Electrical​
993 Caution Plate & Label Mast​
999 Touch Up Paint​
Alpha Index
Numeric Index
Back Cover
