Martin Welker
104
230,310
TYM Sub-Compact Tractor 2500R_EU_FL Transmission Parts Catalog EN KO
Download this document, you need 250 Gallons
Language: English, Korean
Brand: TYM
Type of Machine: Sub-Compact Tractor
Type of Manual: Transmission Parts Manual
Model: TYM 2500_EU_FL(AC02156) Tractor
Publication Date: 16-12-2022
Number Of Pages: 58 Pages
CLUTCH HOUSING
TRANSMISSION CASE
REAR AXLE CASE
DIFFERENTIAL GEAR CASE
CLUTCH SHAFT
CENTER FRAME
PROPELLER SHAFT
FRONT SHAFT
HYDRAULIC OIL LINE, CLUTCH
MAIN SHIFT DRIVE SHAFT
(RANGE SHIFT DRIVE SHAFT)
REAR DIFFERENTIAL
REAR AXLE ASSY
PTO DRIVE SHAFT
PTO SHAFT
MID PTO
MAIN GEAR SHIFT FORK
RANGE GEAR SHIFT FORK
4WD FORK
DIFFERENTIAL LOCK SHIFT FORK
PTO GEAR SHIFT FORK
LIFT ARM
POSITION CONTROL LEVER
HYD VALVE
FEED BACK LEVER- POSITION
REAR SCV(2PORT)
DIFFERENTIAL LOCK PEDAL
FRONT WHEEL DRIVE LEVER
