Hyundai
86
176,834
Tug Tow Tractor GT-50 GT-60 Operation Maintenance And Parts Manual
Brand: Tug
Type of Machine: Tow Tractor
Type of Manual: Operation Maintenance Manual, Parts Manual, Wiring Diagram
Model: Tug GT-50 GT-60 Tow Tractor
Publication Date: 1989
Number of Pages: 525 Pages
Chapter 1: General Information And Operating Instructions
Table Of Contents​
Section 1​
Section 2 Operation​
Section 3 Specifications​
Chapter 2: Maintenance
Table Of Contents​
Section 1 Preventive Maintenance​
Section 2 Troubleshooting​
Section 3 Adjustment​
Chapter 3: Overhaul
Table Of Contents​
Section 1 Introduction​
Section 2 Overhaul Data​
Section 3 Removal And Installation​
Chapter 4: Parts
Table Of Contents​
Section 1 Parts List​
Section 2 Manufacturer's Codes​
Section 3 Alpha-Numeric Index​
Section 4 Group Index​
Chapter 5: Drawings
Table Of Contents​
Chapter 6: Options And Manufacturer's Data
Table Of Contents​
Section 1 Four Wheel Steering​
Section 2 Ether Injection System​
Section 3 Fuel Filter-Water Separator​
Section 4 Special Transmission Shifters​
Section 5 Cab Options​
Section 6 Heater Systems​
Detroit Diesel 8.2 Liter Parts Catalog
General Information​
Group Nomenclature​
Alphabetical Index​
Model Indexes​
Cylinder Block Valley Cover​
Cylinder Head​
Engine Lifter Bracket, Crankshaft​
Engine Front Cover, Crankshaft Pulley​
Flywheel​
Flywheel Housing​
Connecting Rod And Piston, Camshaft And Gear​
Gear Train​
Valve Operating Mechanism​
Rocker Cover​
Fuel Injector​
Fuel Pump Assembly, Fuel Pump​
Fuel System​
Electric Governor​
Governor Assembly​
Governor Weight Shaft And Carrier​
Injector Controls​
Air Cleaner Adaptor, Air Inlet Housing​
Turbocharger Assembly, Air Outlet Elbow​
Oil Pump - Oil Pressure Regulator Valve​
Oil Distribution​
Oil Filter Adaptor - Filters​
Oil Cooler​
Oil Cooler Water Lines​
Dipstick, Oil Filler Cap​
Oil Pan Assembly​
Ventilating System​
Fresh Water Pump Assembly, Pulley And Thermostats​
Fresh Water Pump, Water Connections​
Exhaust Manifold​
Battery Charging Generator​
Starting Motor, Air Shut-Off Solenoid​
Engine Front Support​
Hydraulic Pump​
Shift-O-Matic Model 2000
Parts Ordering Instructions​
Table Of Contents​
Parts List​
Steerable Axle Parts Manual
Untitled
